path: root/drivers/video/fb_draw.h
2007-10-16fbdev: copyarea function taught to fully support swapped pixel order in bytePavel Pisa
This correct case, when source and destination X coordinates difference is n multiple of pixels in byte. This is probably rare case, but this case should supported for completeness. Reorganization of FB_READL and FB_WRITEL calls results in code size decrease for normal build without swapping support and size with support enabled is reasonable too. [adaplas] Add missing fb_rev_pixels_in_long() prototype. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: Support for byte-reversed framebuffer formatsPavel Pisa
Allow generic frame-buffer code to correctly write texts and blit images for 1, 2 and 4 bit per pixel frame-buffer organizations when pixels in bytes are organized to in opposite order than bytes in long type. Overhead should be reasonable. If option is not selected, than compiler should eliminate completely all overhead. The feature is disabled at compile time if CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set. [adaplas] Convert helper functions to macros if feature is not enabled. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: consolidate common drawing functions into a header fileAntonino A. Daplas
Consolidate common drawing functions into a single header file. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
