commit d3d19d6fc5736a798b118971935ce274f7deaa82 upstream.
The "fix" struct has a 2 byte hole after ->ywrapstep and the
"fix = info->fix;" assignment doesn't necessarily clear it. It depends
on the compiler. The solution is just to replace the assignment with an
memcpy().
Fixes: 1f5e31d7e55a ("fbmem: don't call copy_from/to_user() with mutex held")
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Andrea Righi <righi.andrea@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Peter Rosin <peda@axentia.se>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: Gerd Hoffmann <kraxel@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200113100132.ixpaymordi24n3av@kili.mountain
[ Upstream commit a5399db139cb3ad9b8502d8b1bd02da9ce0b9df0 ]
There is no clipping on the x or y axis for logos larger that the framebuffer
size. Therefore: a logo bigger than screen size leads to invalid memory access:
[ 1.254664] Backtrace:
[ 1.254728] [<c02714e0>] (cfb_imageblit) from [<c026184c>] (fb_show_logo+0x620/0x684)
[ 1.254763] r10:00000003 r9:00027fd8 r8:c6a40000 r7:c6a36e50 r6:00000000 r5:c06b81e4
[ 1.254774] r4:c6a3e800
[ 1.254810] [<c026122c>] (fb_show_logo) from [<c026c1e4>] (fbcon_switch+0x3fc/0x46c)
[ 1.254842] r10:c6a3e824 r9:c6a3e800 r8:00000000 r7:c6a0c000 r6:c070b014 r5:c6a3e800
[ 1.254852] r4:c6808c00
[ 1.254889] [<c026bde8>] (fbcon_switch) from [<c029c8f8>] (redraw_screen+0xf0/0x1e8)
[ 1.254918] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:c070d5a0 r5:00000080
[ 1.254928] r4:c6808c00
[ 1.254961] [<c029c808>] (redraw_screen) from [<c029d264>] (do_bind_con_driver+0x194/0x2e4)
[ 1.254991] r9:00000000 r8:00000000 r7:00000014 r6:c070d5a0 r5:c070d5a0 r4:c070d5a0
So prevent displaying a logo bigger than screen size and avoid invalid
memory access.
Signed-off-by: Manfred Schlaegl <manfred.schlaegl@ginzinger.com>
Signed-off-by: Martin Kepplinger <martin.kepplinger@ginzinger.com>
[ Upstream commit f75df8d4b4fabfad7e3cba2debfad12741c6fde7 ]
Blitting an image with "negative" offsets is not working since there
is no clipping. It hopefully just crashes. For the bootup logo, there
is protection so that blitting does not happen as the image is drawn
further and further to the right (ROTATE_UR) or further and further
down (ROTATE_CW). There is however no protection when drawing in the
opposite directions (ROTATE_UD and ROTATE_CCW).
Add back this protection.
The regression is 20-odd years old but the mindless warning-killing
mentality displayed in commit 34bdb666f4b2 ("fbdev: fbmem: remove
positive test on unsigned values") is also to blame, methinks.
Fixes: 448d479747b8 ("fbdev: fb_do_show_logo() updates")
Signed-off-by: Peter Rosin <peda@axentia.se>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Fabian Frederick <ffrederick@users.sourceforge.net>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
cc: Geoff Levand <geoff@infradead.org>
Cc: James Simmons <jsimmons@users.sf.net>
commit 8c5b044299951acd91e830a688dd920477ea1eda upstream.
I have a USB display adapter using the udlfb driver and I use it on an ARM
board that doesn't have any graphics card. When I plug the adapter in, the
console is properly displayed, however when I unplug and re-plug the
adapter, the console is not displayed and I can't access it until I reboot
the board.
The reason is this:
When the adapter is unplugged, dlfb_usb_disconnect calls
unlink_framebuffer, then it waits until the reference count drops to zero
and then it deallocates the framebuffer. However, the console that is
attached to the framebuffer device keeps the reference count non-zero, so
the framebuffer device is never destroyed. When the USB adapter is plugged
again, it creates a new device /dev/fb1 and the console is not attached to
it.
This patch fixes the bug by unbinding the console from unlink_framebuffer.
The code to unbind the console is moved from do_unregister_framebuffer to
a function unbind_console. When the console is unbound, the reference
count drops to zero and the udlfb driver frees the framebuffer. When the
adapter is plugged back, a new framebuffer is created and the console is
attached to it.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Bernie Thompson <bernie@plugable.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: stable@vger.kernel.org
[b.zolnierkie: preserve old behavior for do_unregister_framebuffer()]
In drm/i915 we want to get at the video= cmdline modes even when we
don't have fbdev support enabled, so that users can always override
the kernel's initial mode selection.
But that gives us a direct depency upon the parsing code in the fbdev
subsystem. Since it's so little code just extract these 2 functions
and always build them in.
Whiel at it fix the checkpatch fail in this code.
v2: Also move fb_mode_option. Spotted by the kbuild.
v3: Review from Geert:
- Keep the old copyright notice from fb_mem.c, although I have no
idea what exactly applies.
- Only compile this when needed.
Cc: Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: linux-fbdev@vger.kernel.org
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
I prefer if we can merge this through drm-next since we'll use it
there in follow-up patches.
-Daniel
fb_image.dx, fb_image.dy and fbconf2bmap.framebuffer are __u32
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Some drivers that may be loadable modules use the fb_prepare_logo
function, so we have to export it. Found during randconfig
builds with mmpfb.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Instead of having fbdev framework core files at the root fbdev
directory, mixed with random fbdev device drivers, move the fbdev core
files to a separate core directory. This makes it much clearer which of
the files are actually part of the fbdev framework, and which are part
of device drivers.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Rob Clark <robdclark@gmail.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
