A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Commit b4aa0163056b ("efifb: Implement vga_default_device() (v2)") added
efifb vga_default_device() so EFI systems that do not load shadow VBIOS or
setup VGA get proper value for boot_vga PCI sysfs attribute on the
corresponding PCI device.
Xorg doesn't detect devices when boot_vga=0, e.g., on some EFI systems such
as MacBookAir2,1. Xorg detects the GPU and finds the DRI device but then
bails out with "no devices detected".
Note: When vga_default_device() is set boot_vga PCI sysfs attribute
reflects its state. When unset this attribute is 1 whenever
IORESOURCE_ROM_SHADOW flag is set.
With introduction of sysfb/simplefb/simpledrm efifb is getting obsolete
while having native drivers for the GPU also makes selecting sysfb/efifb
optional.
Remove the efifb implementation of vga_default_device() and initialize
vgaarb's vga_default_device() with the PCI GPU that matches boot
screen_info in pci_fixup_video().
[bhelgaas: remove unused "dev" in efifb_setup()]
Fixes: b4aa0163056b ("efifb: Implement vga_default_device() (v2)")
Tested-by: Anibal Francisco Martinez Cortina <linuxkid.zeuz@gmail.com>
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Matthew Garrett <matthew.garrett@nebula.com>
CC: stable@vger.kernel.org # v3.5+
The drivers/video directory is a mess. It contains generic video related
files, directories for backlight, console, linux logo, lots of fbdev
device drivers, fbdev framework files.
Make some order into the chaos by creating drivers/video/fbdev
directory, and move all fbdev related files there.
No functionality is changed, although I guess it is possible that some
subtle Makefile build order related issue could be created by this
patch.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Rob Clark <robdclark@gmail.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
