These structures are only used to copy into other structures, so declare
them as const.
The semantic patch that makes this change in the fb_fix_screeninfo case is
as follows (http://coccinelle.lip6.fr/). The fb_var_screeninfo case is
analogous.
// <smpl>
@r disable optional_qualifier@
identifier i;
position p;
static struct fb_fix_screeninfo i@p = { ... };
@ok@
identifier r.i;
expression e;
position p;
e = i@p
@bad@
position p != {r.p,ok.p};
identifier r.i;
struct fb_fix_screeninfo e;
e@i@p
@depends on !bad disable optional_qualifier@
identifier r.i;
static
+const
struct fb_fix_screeninfo i = { ... };
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The message is missing a \n, add it.
Preparation for uniform definition of ioremap, ioremap_wc, ioremap_wt,
and ioremap_cache, tree-wide.
Acked-by: Christoph Hellwig <hch@lst.de>
The drivers/video directory is a mess. It contains generic video related
files, directories for backlight, console, linux logo, lots of fbdev
device drivers, fbdev framework files.
Make some order into the chaos by creating drivers/video/fbdev
directory, and move all fbdev related files there.
No functionality is changed, although I guess it is possible that some
subtle Makefile build order related issue could be created by this
patch.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Rob Clark <robdclark@gmail.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
