path: root/drivers/video/fbdev/smscufx.c
2016-09-27video: smscufx: remove unused variableSudip Mukherjee
The variable was only assigned with the pointer but was never used. We can safely remove it. Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-12-04video: smscufx: Deletion of unnecessary checks before the function call "vfree"Markus Elfring
The vfree() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-04-17video: move fbdev to drivers/video/fbdevTomi Valkeinen
The drivers/video directory is a mess. It contains generic video related files, directories for backlight, console, linux logo, lots of fbdev device drivers, fbdev framework files. Make some order into the chaos by creating drivers/video/fbdev directory, and move all fbdev related files there. No functionality is changed, although I guess it is possible that some subtle Makefile build order related issue could be created by this patch. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Rob Clark <robdclark@gmail.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
