toradex_4.9-2.3.x-imx-next
sound/soc/codecs/sgtl5000.c
sound/soc/fsl/imx-sgtl5000.c
This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
commit d3d19d6fc5736a798b118971935ce274f7deaa82 upstream.
The "fix" struct has a 2 byte hole after ->ywrapstep and the
"fix = info->fix;" assignment doesn't necessarily clear it. It depends
on the compiler. The solution is just to replace the assignment with an
memcpy().
Fixes: 1f5e31d7e55a ("fbmem: don't call copy_from/to_user() with mutex held")
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Andrea Righi <righi.andrea@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Peter Rosin <peda@axentia.se>
Cc: Jani Nikula <jani.nikula@intel.com>
Cc: Gerd Hoffmann <kraxel@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20200113100132.ixpaymordi24n3av@kili.mountain
commit 864eb1afc60cb43e7df879b97f8ca0d719bbb735 upstream.
Clang warns when multiple pairs of parentheses are used for a single
conditional statement.
drivers/video/fbdev/sis/init301.c:851:42: warning: equality comparison
with extraneous parentheses [-Wparentheses-equality]
} else if((SiS_Pr->SiS_IF_DEF_LVDS == 1) /* ||
drivers/video/fbdev/sis/init301.c:851:42: note: remove extraneous
parentheses around the comparison to silence this warning
drivers/video/fbdev/sis/init301.c:851:42: note: use '=' to turn this
equality comparison into an assignment
1 warning generated.
Remove the parentheses and while we're at it, clean up the commented
code, which has been here since the beginning of git history.
Link: https://github.com/ClangBuiltLinux/linux/issues/118
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Cc: Thomas Winischhofer <thomas@winischhofer.net>
If one used display timings in devicetree the display_flags like
pixelclk-active have not been applied.
This commit fixes that and puts some nice debug messages so one can
see from where those timings are applied.
This fixes commit f397f60efbb24c2906cd95f443607b2642b49b24
"video: fbdev: mxsfb: allow setting display timings via kernel
command line"
This commit should not be in 4.9 and was accidentally introduced from
4.1 to 4.9 merge.
It originally was deleted with commit:
"f397f60efbb video: fbdev: mxsfb: allow setting display timings via
kernel command line"
This reverts commit 0342aaf0e15ffe05eccfcf173cf47b88b008be52.
[ Upstream commit 3c911fe799d1c338d94b78e7182ad452c37af897 ]
In the probe function, some resources are allocated using 'dma_alloc_wc()',
they should be released with 'dma_free_wc()', not 'dma_free_coherent()'.
We already use 'dma_free_wc()' in the remove function, but not in the
error handling path of the probe function.
Also, remove a useless 'PAGE_ALIGN()'. 'info->fix.smem_len' is already
PAGE_ALIGNed.
Fixes: 638772c7553f ("fb: add support of LCD display controller on pxa168/910 (base layer)")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Lubomir Rintel <lkundrak@v3.sk>
CC: YueHaibing <yuehaibing@huawei.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190831100024.3248-1-christophe.jaillet@wanadoo.fr
[ Upstream commit 8e71fa5e4d86bedfd26df85381d65d6b4c860020 ]
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/video/fbdev/chipsfb.c: In function 'chipsfb_pci_init':
drivers/video/fbdev/chipsfb.c:352:22: warning:
variable 'size' set but not used [-Wunused-but-set-variable]
Fixes: 8c8709334cec ("[PATCH] ppc32: Remove CONFIG_PMAC_PBOOK").
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
[b.zolnierkie: minor commit summary and description fixups]
[ Upstream commit e5017716adb8aa5c01c52386c1b7470101ffe9c5 ]
The "index + count" addition can overflow. Both come directly from the
user. This bug leads to an information leak.
Cc: Peter Malone <peter.malone@gmail.com>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Cc: Mathieu Malaterre <malat@debian.org>
[ Upstream commit d8bad911e5e55e228d59c0606ff7e6b8131ca7bf ]
I'm not sure why the code assumes that only the first put_user() needs
an access_ok() check. I have made all the put_user() and get_user()
calls checked.
Cc: Peter Malone <peter.malone@gmail.com>,
commit 3b8720e63f4a1fc6f422a49ecbaa3b59c86d5aaf upstream.
It's dead code ever since
commit 34280340b1dc74c521e636f45cd728f9abf56ee2
Author: Geert Uytterhoeven <geert+renesas@glider.be>
Date: Fri Dec 4 17:01:43 2015 +0100
fbdev: Remove unused SH-Mobile HDMI driver
Also with this gone we can remove the cea_modes db. This entire thing
is massively incomplete anyway, compared to the CEA parsing that
drm_edid.c does.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Tavis Ormandy <taviso@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190721201956.941-1-daniel.vetter@ffwll.ch
[ Upstream commit dd9782834dd9dde3624ff1acea8859f3d3e792d4 ]
The page_offset was only applied to the end of the page range. This caused
the display updates to cause a scrolling effect on the display because the
amount of data written to the display did not match the range display
expected.
Fixes: 301bc0675b67 ("video: ssd1307fb: Make use of horizontal addressing mode")
Signed-off-by: Marko Kohtala <marko.kohtala@okoko.fi>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: David Airlie <airlied@linux.ie>
Cc: Michal Vokáč <michal.vokac@ysoft.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190618074111.9309-4-marko.kohtala@okoko.fi
[ Upstream commit 1d84353d205a953e2381044953b7fa31c8c9702d ]
In case ioremap fails, the fix releases resources and returns
-ENOMEM to avoid NULL pointer dereferences.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
Cc: Aditya Pakki <pakki001@umn.edu>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Rob Herring <robh@kernel.org>
[b.zolnierkie: minor patch summary fixup]
[ Upstream commit ec7f6aad57ad29e4e66cc2e18e1e1599ddb02542 ]
When ioremap fails, hga_vram should not be dereferenced. The fix
check the failure to avoid NULL pointer dereference.
Cc: Ferenc Bakonyi <fero@drama.obuda.kando.hu>
commit 8c40292be9169a9cbe19aadd1a6fc60cbd1af82f upstream.
Syzkaller hit 'WARNING in __alloc_pages_nodemask' bug.
WARNING: CPU: 1 PID: 1473 at mm/page_alloc.c:4377
__alloc_pages_nodemask+0x4da/0x2130
Kernel panic - not syncing: panic_on_warn set ...
Call Trace:
alloc_pages_current+0xb1/0x1e0
kmalloc_order+0x1f/0x60
kmalloc_order_trace+0x1d/0x120
fb_alloc_cmap_gfp+0x85/0x2b0
fb_set_user_cmap+0xff/0x370
do_fb_ioctl+0x949/0xa20
fb_ioctl+0xdd/0x120
do_vfs_ioctl+0x186/0x1070
ksys_ioctl+0x89/0xa0
__x64_sys_ioctl+0x74/0xb0
do_syscall_64+0xc8/0x550
entry_SYSCALL_64_after_hwframe+0x49/0xbe
This is a warning about order >= MAX_ORDER and the order is from
userspace ioctl. Add flag __NOWARN to silence this warning.
Signed-off-by: Jiufei Xue <jiufei.xue@linux.alibaba.com>
commit cf84807f6dd0be5214378e66460cfc9187f532f9 upstream.
To fix following divide-by-zero error found by Syzkaller:
divide error: 0000 [#1] SMP PTI
CPU: 7 PID: 8447 Comm: test Kdump: loaded Not tainted 4.19.24-8.al7.x86_64 #1
Hardware name: Alibaba Cloud Alibaba Cloud ECS, BIOS rel-1.12.0-0-ga698c8995f-prebuilt.qemu.org 04/01/2014
RIP: 0010:fb_var_to_videomode+0xae/0xc0
Code: 04 44 03 46 78 03 4e 7c 44 03 46 68 03 4e 70 89 ce d1 ee 69 c0 e8 03 00 00 f6 c2 01 0f 45 ce 83 e2 02 8d 34 09 0f 45 ce 31 d2 <41> f7 f0 31 d2 f7 f1 89 47 08 f3 c3 66 0f 1f 44 00 00 0f 1f 44 00
RSP: 0018:ffffb7e189347bf0 EFLAGS: 00010246
RAX: 00000000e1692410 RBX: ffffb7e189347d60 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffb7e189347c10
RBP: ffff99972a091c00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000100
R13: 0000000000010000 R14: 00007ffd66baf6d0 R15: 0000000000000000
FS: 00007f2054d11740(0000) GS:ffff99972fbc0000(0000) knlGS:0000000000000000
CR2: 00007f205481fd20 CR3: 00000004288a0001 CR4: 00000000001606a0
Call Trace:
fb_set_var+0x257/0x390
? lookup_fast+0xbb/0x2b0
? fb_open+0xc0/0x140
? chrdev_open+0xa6/0x1a0
do_fb_ioctl+0x445/0x5a0
do_vfs_ioctl+0x92/0x5f0
? __alloc_fd+0x3d/0x160
ksys_ioctl+0x60/0x90
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x5b/0x190
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7f20548258d7
Code: 44 00 00 48 8b 05 b9 15 2d 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff ff c3 66 2e 0f 1f 84 00 00 00 00 00 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 89 15 2d 00 f7 d8 64 89 01 48
It can be triggered easily with following test code:
#include <linux/fb.h>
#include <fcntl.h>
#include <sys/ioctl.h>
int main(void)
struct fb_var_screeninfo var = {.activate = 0x100, .pixclock = 60};
int fd = open("/dev/fb0", O_RDWR);
if (fd < 0)
return 1;
if (ioctl(fd, FBIOPUT_VSCREENINFO, &var))
return 1;
return 0;
Signed-off-by: Shile Zhang <shile.zhang@linux.alibaba.com>
Cc: Fredrik Noring <noring@nocrew.org>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
commit 9dc20113988b9a75ea6b3abd68dc45e2d73ccdab upstream.
A fallthrough in switch/case was introduced in f627caf55b8e ("fbdev:
sm712fb: fix crashes and garbled display during DPMS modesetting"),
due to my copy-paste error, which would cause the memory clock frequency
for SM720 to be programmed to SM712.
Since it only reprograms the clock to a different frequency, it's only
a benign issue without visible side-effect, so it also evaded Sudip
Mukherjee's code review and regression tests. scripts/checkpatch.pl
also failed to discover the issue, possibly due to nested switch
statements.
This issue was found by Stephen Rothwell by building linux-next with
-Wimplicit-fallthrough.
Fixes: f627caf55b8e ("fbdev: sm712fb: fix crashes and garbled display during DPMS modesetting")
Signed-off-by: Yifeng Li <tomli@tomli.me>
Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Cc: "Gustavo A. R. Silva" <gustavo@embeddedor.com>
commit f627caf55b8e735dcec8fa6538e9668632b55276 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), blanking the display
or starting the X server will crash and freeze the system, or garble the
display.
Experiments showed this problem can mostly be solved by adjusting the
order of register writes. Also, sm712fb failed to consider the difference
of clock frequency when unblanking the display, and programs the clock for
SM712 to SM720.
Fix them by adjusting the order of register writes, and adding an
additional check for SM720 for programming the clock frequency.
Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Cc: Teddy Wang <teddy.wang@siliconmotion.com>
Cc: <stable@vger.kernel.org> # v4.4+
commit 4ed7d2ccb7684510ec5f7a8f7ef534bc6a3d55b2 upstream.
Loongson MIPS netbooks use 1024x600 LCD panels, which is the original
target platform of this driver, but nearly all old x86 laptops have
1024x768. Lighting 768 panels using 600's timings would partially
garble the display. Since it's not possible to distinguish them reliably,
we change the default to 768, but keep 600 as-is on MIPS.
Further, earlier laptops, such as IBM Thinkpad 240X, has a 800x600 LCD
panel, this driver would probably garbled those display. As we don't
have one for testing, the original behavior of the driver is kept as-is,
but the problem has been documented is the comments.
commit 6053d3a4793e5bde6299ac5388e76a3bf679ff65 upstream.
In order to support the 1024x600 panel on Yeeloong Loongson MIPS
laptop, the original 1024x768-16 table was modified to 1024x600-16,
without leaving the original. It causes problem on x86 laptop as
the 1024x768-16 support was still claimed but not working.
Fix it by introducing the 1024x768-16 mode.
commit 9e0e59993df0601cddb95c4f6c61aa3d5e753c00 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), running fbtest or X
will crash the machine instantly, because the VRAM/framebuffer is not
mapped correctly.
On SM712, the framebuffer starts at the beginning of address space, but
SM720's framebuffer starts at the 1 MiB offset from the beginning. However,
sm712fb fails to take this into account, as a result, writing to the
framebuffer will destroy all the registers and kill the system immediately.
Another problem is the driver assumes 8 MiB of VRAM for SM720, but some
SM720 system, such as this IBM Thinkpad, only has 4 MiB of VRAM.
Fix this problem by removing the hardcoded VRAM size, adding a function to
query the amount of VRAM from register MCR76 on SM720, and adding proper
framebuffer offset.
Please note that the memory map may have additional problems on Big-Endian
system, which is not available for testing by myself. But I highly suspect
that the original code is also broken on Big-Endian machines for SM720, so
at least we are not making the problem worse. More, the driver also assumed
SM710/SM712 has 4 MiB of VRAM, but it has a 2 MiB version as well, and used
in earlier laptops, such as IBM Thinkpad 240X, the driver would probably
crash on them. I've never seen one of those machines and cannot fix it, but
I have documented these problems in the comments.
commit ec1587d5073f29820e358f3a383850d61601d981 upstream.
When the machine is booted in VGA mode, loading sm712fb would cause
a glitch of random pixels shown on the screen. To prevent it from
happening, we first clear the entire framebuffer, and we also need
to stop calling smtcfb_setmode() during initialization, the fbdev
layer will call it for us later when it's ready.
commit 8069053880e0ee3a75fd6d7e0a30293265fe3de4 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), rebooting with
sm712fb framebuffer driver would cause a white screen of death on
the next POST, presumably the proper timings for the LCD panel was
not reprogrammed properly by the BIOS.
Experiments showed a few CRTC Scratch Registers, including CRT3D,
CRT3E and CRT3F may be used internally by BIOS as some flags. CRT3B is
a hardware testing register, we shouldn't mess with it. CRT3C has
blanking signal and line compare control, which is not needed for this
driver.
Stop writing to CR3B-CR3F (a.k.a CRT3B-CRT3F) registers. Even if these
registers don't have side-effect on other systems, writing to them is
also highly questionable.
commit dcf9070595e100942c539e229dde4770aaeaa4e9 upstream.
On a Thinkpad s30 (Pentium III / i440MX, Lynx3DM), the amount of Video
RAM is not detected correctly by the xf86-video-siliconmotion driver.
This is because sm712fb overwrites the GPR71 Scratch Pad Register, which
is set by BIOS on x86 and used to indicate amount of VRAM.
Other Scratch Pad Registers, including GPR70/74/75, don't have the same
side-effect, but overwriting to them is still questionable, as they are
not related to modesetting.
Stop writing to SR70/71/74/75 (a.k.a GPR70/71/74/75).
commit 5481115e25e42b9215f2619452aa99c95f08492f upstream.
sm712fb framebuffer driver would cause the role of brightness up/down
button to swap.
Experiments showed the FPR30 register caused this behavior. Moreover,
even if this register don't have side-effect on other systems, over-
writing it is also highly questionable, since it was originally
configurated by the motherboard manufacturer by hardwiring pull-down
resistors to indicate the type of LCD panel. We should not mess with
it.
Stop writing to the SR30 (a.k.a FPR30) register.
[ Upstream commit a5399db139cb3ad9b8502d8b1bd02da9ce0b9df0 ]
There is no clipping on the x or y axis for logos larger that the framebuffer
size. Therefore: a logo bigger than screen size leads to invalid memory access:
[ 1.254664] Backtrace:
[ 1.254728] [<c02714e0>] (cfb_imageblit) from [<c026184c>] (fb_show_logo+0x620/0x684)
[ 1.254763] r10:00000003 r9:00027fd8 r8:c6a40000 r7:c6a36e50 r6:00000000 r5:c06b81e4
[ 1.254774] r4:c6a3e800
[ 1.254810] [<c026122c>] (fb_show_logo) from [<c026c1e4>] (fbcon_switch+0x3fc/0x46c)
[ 1.254842] r10:c6a3e824 r9:c6a3e800 r8:00000000 r7:c6a0c000 r6:c070b014 r5:c6a3e800
[ 1.254852] r4:c6808c00
[ 1.254889] [<c026bde8>] (fbcon_switch) from [<c029c8f8>] (redraw_screen+0xf0/0x1e8)
[ 1.254918] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:c070d5a0 r5:00000080
[ 1.254928] r4:c6808c00
[ 1.254961] [<c029c808>] (redraw_screen) from [<c029d264>] (do_bind_con_driver+0x194/0x2e4)
[ 1.254991] r9:00000000 r8:00000000 r7:00000014 r6:c070d5a0 r5:c070d5a0 r4:c070d5a0
So prevent displaying a logo bigger than screen size and avoid invalid
memory access.
Signed-off-by: Manfred Schlaegl <manfred.schlaegl@ginzinger.com>
Signed-off-by: Martin Kepplinger <martin.kepplinger@ginzinger.com>
[ Upstream commit ace6033ec5c356615eaa3582fb1946e9eaff6662 ]
User space Android code identifies pixclock == 0 as a sign for emulation
and will set the frame rate to 60 fps when reading this value, which is
the desired outcome.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Peter Maydell <peter.maydell@linaro.org>
Signed-off-by: Roman Kiryanov <rkir@google.com>
This is the 4.9.166 stable release
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
(cherry picked from commit 8a2973e535e27e6f3404b23535f393ac1dd3a3ab)
Related to #47541
[ Upstream commit f75df8d4b4fabfad7e3cba2debfad12741c6fde7 ]
Blitting an image with "negative" offsets is not working since there
is no clipping. It hopefully just crashes. For the bootup logo, there
is protection so that blitting does not happen as the image is drawn
further and further to the right (ROTATE_UR) or further and further
down (ROTATE_CW). There is however no protection when drawing in the
opposite directions (ROTATE_UD and ROTATE_CCW).
Add back this protection.
The regression is 20-odd years old but the mindless warning-killing
mentality displayed in commit 34bdb666f4b2 ("fbdev: fbmem: remove
positive test on unsigned values") is also to blame, methinks.
Fixes: 448d479747b8 ("fbdev: fb_do_show_logo() updates")
Signed-off-by: Peter Rosin <peda@axentia.se>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Fabian Frederick <ffrederick@users.sourceforge.net>
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
cc: Geoff Levand <geoff@infradead.org>
Cc: James Simmons <jsimmons@users.sf.net>
[ Upstream commit fdac751355cd76e049f628afe6acb8ff4b1399f7 ]
clps711x_fb_probe() increments refcnt of disp device node by
of_parse_phandle() and leaves it undecremented on both
successful and error paths.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Cc: Alexander Shiyan <shc_work@mail.ru>
commit a01421e4484327fe44f8e126793ed5a48a221e24 upstream.
Using [1] for static analysis I found that the OMAPFB_QUERY_PLANE,
OMAPFB_GET_COLOR_KEY, OMAPFB_GET_DISPLAY_INFO, and OMAPFB_GET_VRAM_INFO
cases could all leak uninitialized stack memory--either due to
uninitialized padding or 'reserved' fields.
Fix them by clearing the shared union used to store copied out data.
[1] https://github.com/vlad902/kernel-uninitialized-memory-checker
Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net>
Fixes: b39a982ddecf ("OMAP: DSS2: omapfb driver")
Cc: security@kernel.org
[b.zolnierkie: prefix patch subject with "omap2fb: "]
Honor the native-mode property by adding only that mode to the
mode list. With that we loose the list of modes, but we currently
don't make use of it anyway. Also, the mode list lacks the pixel
clock polarity information since struct fb_videomode does not store
this information.
(cherry picked from commit 3cb3771edb98e2ae79a887368fc042b89456da7e)
Use the timing count from the parsed struct display_timings instead
of looping through the device tree again.
(cherry picked from commit 65be28e2a2b3761d088b20c43994be97d74c342f)
The PIXDATA flags of the display_flags enum are controller centric,
e.g. NEGEDGE means the controller shall drive the data signals on
pixelclocks negative edge. However, the drivers flag is display
centric: Sample the data on negative (falling) edge.
Therefore, change the if statement to check for the POSEDGE flag
(which is typically not set):
Drive on positive edge => sample on negative edge
(cherry picked from commit 5652dc1ad78303fb246f050ba23c563319d823cf)
Add support to allow configuring the display timings via
kernel command line.
e.g.:
video=mxsfb:800x480M-16@60,pixclockpol=1,outputen=1
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
(cherry picked from commit 22db6beb45cba5a67cab9e9a55cd60d7471591d9)
drivers/video/fbdev/mxsfb.c
Using the mode_str passed via device tree
as default fall back, fb_find_mode fails
while finding the mode, so avoid using the
non standard mode_str passed via device tree
and use the mode_str from command line as is.
(cherry picked from commit 50e26af30f04d24f4783dae15206c5dba889fd2b)
Use force suspend/resume to trigger runtime PM when entering system
suspend.
(cherry picked from commit ebf45652f2e9ec2ab19831d852363deadeb6407e)
Add support for LVDS frame buffer configuration via kernel boot arguments.
Fix use of the device tree native-mode property.
(cherry picked from commit 122acb64708ac40faa8c5755624a0bcfbebcb9e8)
(cherry picked from commit 735d4f8addae71ef4a70eb16a9639bd6204fd2b9)
Without this the kernel hangs during boot when HDMI is attached.
It looks like we get an overflow IRQ storm. overflow is related
to HDMI audio.
(cherry picked from commit ab9e816efb07dcaec23d3c55d3db1773b745ae47)
(cherry picked from commit d2e0de0ea4c48d0cbbadc28ac4785bd0ed202ea4)
copy/paste error in pixelclock frequency
(cherry picked from commit 291333761167e85e53fb21cbb4a6b97d618a41c8)
(cherry picked from commit 1fe0cf435e9a938d61a3750140026292183c097c)
The keepalive module variable allows to not go into a disconnected
state. Fix the case when keepalive is set to go to disconnect.
Add a precompiler directive which allows to only evaluate the HPD signal
for HDMI monitor detection. Default is to react on the status bits for
HPD and the TMDS signal line detection to detect an attached monitor.
While at it cleanup parameter documentation and whitespace.
(cherry picked from commit b15fed911e022b383295cb5443872d427e756677)
(cherry picked from commit 6bf9ef90b27fea00ae27f719473a5b7fca30a72e)
(cherry picked from commit 2d67c557073a6e728cfe5888323b9aed79392b90)
Copy of mxc_lcdif.c
Adds a second parallel output which drives a Video DAC
available on the second IPU, first DI on a Apalis iMX6 module
Only RGB565 is supported.
video=mxcfb0:dev=vdac,800x480M@60,if=RGB565
(cherry picked from commit 5a330af3bf30a72ca8f086c90e9dbfcbde3aa252)
(cherry picked from commit 0bcaad8a16e6ceca9d964946890aff6727d7e10f)
FusionF10A: 1024x600, used with external parallel to LVDS converter
FusionF07A: 800x480
EDT-VGA: 640x480
EDT-480x272: 480x272
(cherry picked from commit b235eb4d8b06a6334f39de15526d1a4266bec859)
(cherry picked from commit 4e6509cc7b11a7187e419e64621c3add01e23b27)
pixeldata is sampled on the positve pixelclk edge.
(cherry picked from commit 4891f02dae2559af072c31903111bf9ec349320e)
(cherry picked from commit 85aff6446f712f72b33c29f3fd1e80843f923673)
Signed-off-by: Daniel Kochmanski <dkochmanski@antmicro.com>
(cherry picked from commit 98b68aee3695ae898ef19aa547267fcdb69cf7eb)
(cherry picked from commit f6620779981e6aebe40e7a400568e454d6a7408f)
(cherry picked from commit 95e8be3a2e2fb156279897241c80a96cd84b1fda)
When this boolean parameter is true, only add
CEA modes to modelist.
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
Acked-by: Eric Nelson <eric.nelson@boundarydevices.com>
(cherry picked from commit a78fe11904ebd4d3f72438f8b14dfa4eaab7d638)
(cherry picked from commit d69533a9575de0aaeeaca19b4f5ed8ef794257a6)
[rebased to 4.9, use bool as data type]
If enabled too early, a flood of interrupts can happen, and as
console_lock is held, you cannot see any messages being printed.
(cherry picked from commit 38c65caf872e5f9534b7812395224670dd56c297)
(cherry picked from commit 04abce77f44b3e61b0fe5db1b33109e68e6600bc)
