path: root/drivers/video/fbdev
2018-02-25fbdev: sm712fb: avoid unused function warningsArnd Bergmann
commit 24ed78dc2e8b2428eccc70c3162e70d33ab448c4 upstream. The sm712fb framebuffer driver encloses the power-management functions in #ifdef CONFIG_PM, but the smtcfb_pci_suspend/resume functions are only really used when CONFIG_PM_SLEEP is also set, as a frequent gcc warning shows: fbdev/sm712fb.c:1549:12: warning: 'smtcfb_pci_suspend' defined but not used fbdev/sm712fb.c:1572:12: warning: 'smtcfb_pci_resume' defined but not used The driver also avoids using the SIMPLE_DEV_PM_OPS macro when CONFIG_PM is unset, which is redundant. This changes the driver to remove the #ifdef and instead mark the functions as __maybe_unused, which is a nicer anyway, as it provides build testing for all the code in all configurations and is harder to get wrong. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25fbdev: s6e8ax0: avoid unused function warningsArnd Bergmann
commit b54729b6cea7d1f46b1ed70cb7065c6bdefaa780 upstream. The s6e8ax0 suspend/resume functions are hidden inside of an #ifdef when CONFIG_PM is set to avoid unused function warnings, but they call some other functions that nothing else calls, and we get warnings about those: drivers/video/fbdev/exynos/s6e8ax0.c:449:13: error: 's6e8ax0_sleep_in' defined but not used [-Werror=unused-function] drivers/video/fbdev/exynos/s6e8ax0.c:485:13: error: 's6e8ax0_display_off' defined but not used [-Werror=unused-function] This marks the PM functions as __maybe_unused so the compiler can silently drop them when they are not referenced. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25fbdev: auo_k190x: avoid unused function warningsArnd Bergmann
commit a8a31afad5ffa1c7de0cef1c4bc383b50f426bf8 upstream. The auo_k190x framebuffer driver encloses the power-management functions in #ifdef CONFIG_PM, but the auok190x_suspend/resume functions are only really used when CONFIG_PM_SLEEP is also set, as a frequent gcc warning shows: drivers/video/fbdev/auo_k190x.c:859:12: warning: 'auok190x_suspend' defined but not used drivers/video/fbdev/auo_k190x.c:899:12: warning: 'auok190x_resume' defined but not used This changes the driver to remove the #ifdef and instead mark the functions as __maybe_unused, which is a nicer anyway, as it provides build testing for all the code in all configurations and is harder to get wrong. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25video: Use bool instead int pointer for get_opt_bool() argumentDaniel Wagner
commit 206fc20598157ce15597822cf01b94377e30075b upstream. As the function name already indicates that get_opt_bool() parses for a bool. It is not a surprise that compiler is complaining about it when -Werror=incompatible-pointer-types is used: drivers/video/fbdev/intelfb/intelfbdrv.c: In function ‘intelfb_setup’: drivers/video/fbdev/intelfb/intelfbdrv.c:353:39: error: passing argument 3 of ‘get_opt_bool’ from incompatible pointer type [-Werror=incompatible-pointer-types] if (get_opt_bool(this_opt, "accel", &accel)) Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25fbdev: sis: enforce selection of at least one backendArnd Bergmann
commit 5b833fea4377577eafecb888141a05470922ef25 upstream. The sis framebuffer driver complains with a compile-time warning if neither the FB_SIS_300 nor FB_SIS_315 symbols are selected: drivers/video/fbdev/sis/sis_main.c:61:2: warning: #warning Neither CONFIG_FB_SIS_300 nor CONFIG_FB_SIS_315 is se This is reasonable because it doesn't work in that case, but it's also annoying for randconfig builds and is one of the most common warnings I'm seeing on ARM now. This changes the Kconfig logic to prevent the silly configuration, by always selecting the FB_SIS_300 variant if the other one is not set. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25video: fbdev: sis: remove unused variableSudip Mukherjee
commit 32ad61951574d011d363694d6037592e99da9421 upstream. The variables modeflag and resinfo were only assigned some value but were never used. Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25video: fbdev: via: remove possibly unused variablesArnd Bergmann
commit 484c7bbf2649831714da3a0fa30213977458e9b5 upstream. When CONFIG_PROC_FS is disabled, we get warnings about unused variables as remove_proc_entry() evaluates to an empty macro. drivers/video/fbdev/via/viafbdev.c: In function 'viafb_remove_proc': drivers/video/fbdev/via/viafbdev.c:1635:4: error: unused variable 'iga2_entry' [-Werror=unused-variable] drivers/video/fbdev/via/viafbdev.c:1634:4: error: unused variable 'iga1_entry' [-Werror=unused-variable] These are easy to avoid by using the pointer from the structure. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25video: fbdev/mmp: add MODULE_LICENSEArnd Bergmann
commit c1530ac5a3ce93a1f02adabc4508b5fbf862dfe2 upstream. Kbuild complains about the lack of a license tag in this driver: WARNING: modpost: missing MODULE_LICENSE() in drivers/video/fbdev/mmp/mmp_disp.o This adds the license, author and description tags. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22video: fbdev: atmel_lcdfb: fix display-timings lookupJohan Hovold
commit 9cb18db0701f6b74f0c45c23ad767b3ebebe37f6 upstream. Fix child-node lookup during probe, which ended up searching the whole device tree depth-first starting at the parent rather than just matching on its children. To make things worse, the parent display node was also prematurely freed. Note that the display and timings node references are never put after a successful dt-initialisation so the nodes would leak on later probe deferrals and on driver unbind. Fixes: b985172b328a ("video: atmel_lcdfb: add device tree suport") Cc: stable <stable@vger.kernel.org> # 3.13 Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@microchip.com> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20video: fbdev: au1200fb: Return an error code if a memory allocation failsChristophe JAILLET
[ Upstream commit 8cae353e6b01ac3f18097f631cdbceb5ff28c7f3 ] 'ret' is known to be 0 at this point. In case of memory allocation error in 'framebuffer_alloc()', return -ENOMEM instead. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20video: fbdev: au1200fb: Release some resources if a memory allocation failsChristophe JAILLET
[ Upstream commit 451f130602619a17c8883dd0b71b11624faffd51 ] We should go through the error handling code instead of returning -ENOMEM directly. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20video: udlfb: Fix read EDID timeoutLadislav Michl
[ Upstream commit c98769475575c8a585f5b3952f4b5f90266f699b ] While usb_control_msg function expects timeout in miliseconds, a value of HZ is used. Replace it with USB_CTRL_GET_TIMEOUT and also fix error message which looks like: udlfb: Read EDID byte 78 failed err ffffff92 as error is either negative errno or number of bytes transferred use %d format specifier. Returned EDID is in second byte, so return error when less than two bytes are received. Fixes: 18dffdf8913a ("staging: udlfb: enhance EDID and mode handling support") Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Cc: Bernie Thompson <bernie@plugable.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20fbdev: controlfb: Add missing modes to fix out of bounds accessGeert Uytterhoeven
[ Upstream commit ac831a379d34109451b3c41a44a20ee10ecb615f ] Dan's static analysis says: drivers/video/fbdev/controlfb.c:560 control_setup() error: buffer overflow 'control_mac_modes' 20 <= 21 Indeed, control_mac_modes[] has only 20 elements, while VMODE_MAX is 22, which may lead to an out of bounds read when parsing vmode commandline options. The bug was introduced in v2.4.5.6, when 2 new modes were added to macmodes.h, but control_mac_modes[] wasn't updated: https://kernel.opensuse.org/cgit/kernel/diff/include/video/macmodes.h?h=v2.5.2&id=29f279c764808560eaceb88fef36cbc35c529aad Augment control_mac_modes[] with the two new video modes to fix this. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15video: fbdev: pmag-ba-fb: Remove bad `__init' annotationMaciej W. Rozycki
[ Upstream commit 879e5a0df626f39cbb3c61bb90373e56d67012c4 ] Fix: WARNING: drivers/video/fbdev/pmag-ba-fb.o(.text+0x308): Section mismatch in reference from the function pmagbafb_probe() to the function .init.text:pmagbafb_erase_cursor() The function pmagbafb_probe() references the function __init pmagbafb_erase_cursor(). This is often because pmagbafb_probe lacks a __init annotation or the annotation of pmagbafb_erase_cursor is wrong. -- a fallout from a missed update from commit 9625b51350cc ("VIDEO: PMAG-BA: Fix section mismatch") and then commit 48c68c4f1b54 ("Drivers: video: remove __dev* attributes.") Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05video: fbdev: aty: do not leak uninitialized padding in clk to userspaceVladis Dronov
commit 8e75f7a7a00461ef6d91797a60b606367f6e344d upstream. 'clk' is copied to a userland with padding byte(s) after 'vclk_post_div' field unitialized, leaking data from the stack. Fix this ensuring all of 'clk' is initialized to zero. References: https://github.com/torvalds/linux/pull/441 Reported-by: sohu0106 <sohu0106@126.com> Signed-off-by: Vladis Dronov <vdronov@redhat.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06video: fbdev: cobalt_lcdfb: Handle return NULL error from devm_ioremapArvind Yadav
[ Upstream commit 4dcd19bfabaee8f9f4bcf203afba09b98ccbaf76 ] Here, If devm_ioremap will fail. It will return NULL. Kernel can run into a NULL-pointer dereference. This error check will avoid NULL pointer dereference. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Acked-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21xen, fbfront: fix connecting to backendJuergen Gross
commit 9121b15b5628b38b4695282dc18c553440e0f79b upstream. Connecting to the backend isn't working reliably in xen-fbfront: in case XenbusStateInitWait of the backend has been missed the backend transition to XenbusStateConnected will trigger the connected state only without doing the actions required when the backend has connected. Signed-off-by: Juergen Gross <jgross@suse.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-01fbdev: color map copying bounds checkingKees Cook
commit 2dc705a9930b4806250fbf5a76e55266e59389f2 upstream. Copying color maps to userspace doesn't check the value of to->start, which will cause kernel heap buffer OOB read due to signedness wraps. CVE-2016-8405 Link: http://lkml.kernel.org/r/20170105224249.GA50925@beast Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Peter Pi (@heisecode) of Trend Micro Cc: Min Chong <mchong@google.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28fbdev/efifb: Fix 16 color palette entry calculationMax Staudt
commit d50b3f43db739f03fcf8c0a00664b3d2fed0496e upstream. When using efifb with a 16-bit (5:6:5) visual, fbcon's text is rendered in the wrong colors - e.g. text gray (#aaaaaa) is rendered as green (#50bc50) and neighboring pixels have slightly different values (such as #50bc78). The reason is that fbcon loads its 16 color palette through efifb_setcolreg(), which in turn calculates a 32-bit value to write into memory for each palette index. Until now, this code could only handle 8-bit visuals and didn't mask overlapping values when ORing them. With this patch, fbcon displays the correct colors when a qemu VM is booted in 16-bit mode (in GRUB: "set gfxpayload=800x600x16"). Fixes: 7c83172b98e5 ("x86_64 EFI boot support: EFI frame buffer driver") # v2.6.24+ Signed-off-by: Max Staudt <mstaudt@suse.de> Acked-By: Peter Jones <pjones@redhat.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04fbdev: da8xx-fb: fix videomodes of lcd panelsSushaanth Srirangapathi
commit 713fced8d10fa1c759c8fb6bf9aaa681bae68cad upstream. Commit 028cd86b794f4a ("video: da8xx-fb: fix the polarities of the hsync/vsync pulse") fixes polarities of HSYNC/VSYNC pulse but forgot to update known_lcd_panels[] which had sync values according to old logic. This breaks LCD at least on DA850 EVM. This patch fixes this issue and I have tested this for panel "Sharp_LK043T1DG01" using DA850 EVM board. Fixes: 028cd86b794f4a ("video: da8xx-fb: fix the polarities of the hsync/vsync pulse") Signed-off-by: Sushaanth Srirangapathi <sushaanth.s@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04xen kconfig: don't "select INPUT_XEN_KBDDEV_FRONTEND"Arnd Bergmann
commit 13aa38e291bdd4e4018f40dd2f75e464814dcbf3 upstream. The Xen framebuffer driver selects the xen keyboard driver, so the latter will be built-in if XEN_FBDEV_FRONTEND=y. However, when CONFIG_INPUT is a loadable module, this configuration cannot work. On mainline kernels, the symbol will be enabled but not used, while in combination with a patch I have to detect such useless configurations, we get the expected link failure: drivers/input/built-in.o: In function `xenkbd_remove': xen-kbdfront.c:(.text+0x2f0): undefined reference to `input_unregister_device' xen-kbdfront.c:(.text+0x30e): undefined reference to `input_unregister_device' This removes the extra "select", as it just causes more trouble than it helps. In theory, some defconfig file might break if it has XEN_FBDEV_FRONTEND in it but not INPUT_XEN_KBDDEV_FRONTEND. The Kconfig fragment we ship in the kernel (kernel/configs/xen.config) however already enables both, and anyone using an old .config file would keep having both enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Suggested-by: David Vrabel <david.vrabel@citrix.com> Fixes: 36c1132e34bd ("xen kconfig: fix select INPUT_XEN_KBDDEV_FRONTEND") Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-09OMAPDSS: fix timings for VENC to match what omapdrm expectsH. Nikolaus Schaller
Otherwise check_timings fails and we get a "has no modes" message from xrandr. This fix makes the venc assume PAL and NTSC timings that match the timings synthetized by copy_timings_drm_to_omap() from omapdrm mode settings so that check_timings() succeeds. Tested on: BeagleBoard XM, GTA04 and OpenPandora Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-12-09video: fbdev: fsl: Fix kernel crash when diu_ops is not implementedWang Dongsheng
If diu_ops is not implemented on platform, kernel will access a NULL pointer. We need to check this pointer in DIU initialization. Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Acked-by: Timur Tabi <timur@tabi.org> Cc: stable@vger.kernel.org Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-11-10Merge tag 'fbdev-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: - omap: fix hdmi audio configuration issue - ssd1307fb: add ssd1309 support - tridentfb: support DDC - gxt4500: enable support for non-PPC platforms * tag 'fbdev-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: radeonfb: Deinline large functions gxt4500: enable panning gxt4500: Use arch_phys_wc_* for framebuffer gxt4500: fix color order gxt4500: fix 16bpp 565 mode gxt4500: enable on non-PPC architectures tridentfb: Add DDC support fb_ddc: Allow I2C adapters without SCL read capability fbdev: ssd1307fb: add ssd1309 support fbdev: ssd1307fb: alphabetize headers video/omap: remove invalid check OMAPDSS: hdmi: Reconfigure and restart audio when display is enabled
2015-11-06mm, page_alloc: distinguish between being unable to sleep, unwilling to ↵Mel Gorman
sleep and avoiding waking kswapd __GFP_WAIT has been used to identify atomic context in callers that hold spinlocks or are in interrupts. They are expected to be high priority and have access one of two watermarks lower than "min" which can be referred to as the "atomic reserve". __GFP_HIGH users get access to the first lower watermark and can be called the "high priority reserve". Over time, callers had a requirement to not block when fallback options were available. Some have abused __GFP_WAIT leading to a situation where an optimisitic allocation with a fallback option can access atomic reserves. This patch uses __GFP_ATOMIC to identify callers that are truely atomic, cannot sleep and have no alternative. High priority users continue to use __GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify callers that want to wake kswapd for background reclaim. __GFP_WAIT is redefined as a caller that is willing to enter direct reclaim and wake kswapd for background reclaim. This patch then converts a number of sites o __GFP_ATOMIC is used by callers that are high priority and have memory pools for those requests. GFP_ATOMIC uses this flag. o Callers that have a limited mempool to guarantee forward progress clear __GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall into this category where kswapd will still be woken but atomic reserves are not used as there is a one-entry mempool to guarantee progress. o Callers that are checking if they are non-blocking should use the helper gfpflags_allow_blocking() where possible. This is because checking for __GFP_WAIT as was done historically now can trigger false positives. Some exceptions like dm-crypt.c exist where the code intent is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to flag manipulations. o Callers that built their own GFP flags instead of starting with GFP_KERNEL and friends now also need to specify __GFP_KSWAPD_RECLAIM. The first key hazard to watch out for is callers that removed __GFP_WAIT and was depending on access to atomic reserves for inconspicuous reasons. In some cases it may be appropriate for them to use __GFP_HIGH. The second key hazard is callers that assembled their own combination of GFP flags instead of starting with something like GFP_KERNEL. They may now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless if it's missed in most cases as other activity will wake kswapd. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-05Merge tag 'spi-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "Quite a lot of activity in SPI this cycle, almost all of it in drivers with a few minor improvements and tweaks in the core. - Updates to pxa2xx to support Intel Broxton and multiple chip selects. - Support for big endian in the bcm63xx driver. - Multiple slave support for the mt8173 - New driver for the auxiliary SPI controller in bcm2835 SoCs. - Support for Layerscale SoCs in the Freescale DSPI driver" * tag 'spi-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (87 commits) spi: pxa2xx: Rework self-initiated platform data creation for non-ACPI spi: pxa2xx: Add support for Intel Broxton spi: pxa2xx: Detect number of enabled Intel LPSS SPI chip select signals spi: pxa2xx: Add output control for multiple Intel LPSS chip selects spi: pxa2xx: Use LPSS prefix for defines that are Intel LPSS specific spi: Add DSPI support for layerscape family spi: ti-qspi: improve ->remove() callback spi/spi-xilinx: Fix race condition on last word read spi: Drop owner assignment from spi_drivers spi: Add THIS_MODULE to spi_driver in SPI core spi: Setup the master controller driver before setting the chipselect spi: dw: replace magic constant by DW_SPI_DR spi: mediatek: mt8173 spi multiple devices support spi: mediatek: handle controller_data in mtk_spi_setup spi: mediatek: remove mtk_spi_config spi: mediatek: Update document devicetree bindings to support multiple devices spi: fix kernel-doc warnings about missing return desc in spi.c spi: fix kernel-doc warnings about missing return desc in spi.h spi: pxa2xx: Align a few defines spi: pxa2xx: Save other reg_cs_ctrl bits when configuring chip select ...
2015-11-04Merge remote-tracking branches 'spi/topic/omap-100k', ↵Mark Brown
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
2015-10-28spi: Drop owner assignment from spi_driversAndrew F. Davis
An spi_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-14Merge tag 'efi-next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into core/efi Pull v4.4 EFI updates from Matt Fleming: - Make the EFI System Resource Table (ESRT) driver explicitly non-modular by ripping out the module_* code since Kconfig doesn't allow it to be built as a module anyway. (Paul Gortmaker) - Make the x86 efi=debug kernel parameter, which enables EFI debug code and output, generic and usable by arm64. (Leif Lindholm) - Add support to the x86 EFI boot stub for 64-bit Graphics Output Protocol frame buffer addresses. (Matt Fleming) - Detect when the UEFI v2.5 EFI_PROPERTIES_TABLE feature is enabled in the firmware and set an efi.flags bit so the kernel knows when it can apply more strict runtime mapping attributes - Ard Biesheuvel - Auto-load the efi-pstore module on EFI systems, just like we currently do for the efivars module. (Ben Hutchings) - Add "efi_fake_mem" kernel parameter which allows the system's EFI memory map to be updated with additional attributes for specific memory ranges. This is useful for testing the kernel code that handles the EFI_MEMORY_MORE_RELIABLE memmap bit even if your firmware doesn't include support. (Taku Izumi) Note: there is a semantic conflict between the following two commits: 8a53554e12e9 ("x86/efi: Fix multiple GOP device support") ae2ee627dc87 ("efifb: Add support for 64-bit frame buffer addresses") I fixed up the interaction in the merge commit, changing the type of current_fb_base from u32 to u64. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-12efifb: Add support for 64-bit frame buffer addressesMatt Fleming
The EFI Graphics Output Protocol uses 64-bit frame buffer addresses but these get truncated to 32-bit by the EFI boot stub when storing the address in the 'lfb_base' field of 'struct screen_info'. Add a 'ext_lfb_base' field for the upper 32-bits of the frame buffer address and set VIDEO_TYPE_CAPABILITY_64BIT_BASE when the field is useable. It turns out that the reason no one has required this support so far is that there's actually code in tianocore to "downgrade" PCI resources that have option ROMs and 64-bit BARS from 64-bit to 32-bit to cope with legacy option ROMs that can't handle 64-bit addresses. The upshot is that basically all GOP devices in the wild use a 32-bit frame buffer address. Still, it is possible to build firmware that uses a full 64-bit GOP frame buffer address. Chad did, which led to him reporting this issue. Add support in anticipation of GOP devices using 64-bit addresses more widely, and so that efifb works out of the box when that happens. Reported-by: Chad Page <chad.page@znyx.com> Cc: Pete Hawkins <pete.hawkins@znyx.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2015-10-08radeonfb: Deinline large functionsDenys Vlasenko
With this .config: http://busybox.net/~vda/kernel_config, after uninlining these functions have sizes and callsite counts as follows: __OUTPLLP: 61 bytes, 12 callsites __INPLL: 79 bytes, 150 callsites __OUTPLL: 82 bytes, 138 callsites _OUTREGP: 101 bytes, 8 callsites _radeon_msleep: 66 bytes, 18 callsites _radeon_fifo_wait: 83 bytes, 24 callsites _radeon_engine_idle: 92 bytes, 10 callsites radeon_engine_flush: 105 bytes, 2 callsites radeon_pll_errata_after_index_slow: 31 bytes, 11 callsites radeon_pll_errata_after_data_slow: 91 bytes, 9 callsites radeon_pll_errata_after_FOO functions are split into two parts: the inlined part which checks corresponding rinfo->errata bit, and out-of-line part which performs workaround magic per se. Reduction in code size is about 49,500 bytes: text data bss dec hex filename 85789648 22294616 20627456 128711720 7abfc28 vmlinux.before 85740176 22294680 20627456 128662312 7ab3b28 vmlinux Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dave Airlie <airlied@redhat.com> Cc: linux-kernel@vger.kernel.org Cc: linux-fbdev@vger.kernel.org Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-10-08gxt4500: enable panningOndrej Zary
The driver implements pan_display but the corresponding flags are not set. Add FBINFO_HWACCEL_XPAN and FBINFO_HWACCEL_YPAN to flags to allow HW accelerated panning (for fast scrolling). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-10-08gxt4500: Use arch_phys_wc_* for framebufferOndrej Zary
Add arch_phys_wc_* calls to allow write-combining using MTRR. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-10-08gxt4500: fix color orderOndrej Zary
The color order in truecolor modes is wrong. This does not affect console but is visible e.g. in X11 which has wrong colors. Swap blue and red colors to fix the problem. Fixes https://forums.gentoo.org/viewtopic-t-692740-start-0.html Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-10-08gxt4500: fix 16bpp 565 modeOndrej Zary
Fix wrong colors in 16bpp 565 mode. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-10-08gxt4500: enable on non-PPC architecturesOndrej Zary
These chips can be present at least on x86 too - Fire GL2 AGP has GXT6000P but this driver is currently limited to PPC. Enable it for all architectures and add chip configuration for little-endian. Tested on x86 with Fire GL2 AGP. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-30tridentfb: Add DDC supportOndrej Zary
Add DDC support for Trident cards. Tested on TGUI9440, TGUI9680, 3DImage 9750, Blade3D 9880 and Blade XP. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-30fb_ddc: Allow I2C adapters without SCL read capabilityOndrej Zary
i2c-algo-bit allows I2C adapters without SCL read capability to work but fb_ddc_read fails to work on them. Fix fb_ddc_read to work with I2C adapters not capable of reading SCL. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-30fbdev: broadsheetfb: fix memory leakSudip Mukherjee
We have requested the firmware and it was loaded but we missed releasing it both on success and error. Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24OMAPDSS: panel-sony-acx565akm: Export OF module alias informationJavier Martinez Canillas
Drivers needs to export the OF id table and this be built into the module or udev won't have the necessary information to autoload the driver module when the device is registered via OF. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24fbdev: omap2: connector-dvi: use of_get_i2c_adapter_by_node interfaceVladimir Zapolskiy
This change is needed to properly lock I2C bus driver, which serves DDC. Prior to this change i2c_put_adapter() is misused, which may lead to an overflow over zero of I2C bus driver user counter. Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24tridentfb: Fix set_lwidth on TGUI9440 and CYBER9320Ondrej Zary
According to X.Org driver, chips older than TGUI9660 have only 1 width bit in AddColReg. Touching the 2nd one causes I2C/DDC to fail on TGUI9440. Set only 1 bit of width in AddColReg on TGUI9440 and CYBER9320. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24tridentfb: fix hang on Blade3D with CONFIG_CC_OPTIMIZE_FOR_SIZEOndrej Zary
When the kernel is compiled with -Os (CONFIG_CC_OPTIMIZE_FOR_SIZE), tridentfb hangs the machine upon load with Blade3D cards unless acceleration is disabled. This is caused by memcpy() which copies data byte-by-byte (rep movsb) when compiled with -Os. The card does not like that - it requires 32-bit access. Use iowrite_32() instead. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24video: fbdev: mb862xx: Fix module autoload for OF platform driverLuis de Bethencourt
This platform driver has a OF device ID table but the OF module alias information is not created so module autoloading won't work. Signed-off-by: Luis de Bethencourt <luisbg@osg.samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24fbdev: ssd1307fb: add ssd1309 supportOlliver Schinagl
The ssd1307fb driver supports a lot of chips from the ssd130xfb series. This patch adds the ssd1309 chip, a 128x64 OLED driver chip. It is very similar to the other chips and only has some definitions added to support it. Signed-off-by: Olliver Schinagl <o.schinagl@ultimaker.com> Acked-by: Rob Herring <robh@kernel.org> Acked-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24fbdev: ssd1307fb: alphabetize headersOlliver Schinagl
This patch sorts the headers on ssd1307fb driver. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24video/omap: remove invalid checkAndrzej Hajda
regno is unsigned so it cannot be negative. The problem has been detected using proposed semantic patch scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1]. [1]: http://permalink.gmane.org/gmane.linux.kernel/2038576 Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24OMAPDSS: hdmi: Reconfigure and restart audio when display is enabledJyri Sarha
Reconfigure and restart audio when display is enabled, if audio playback was active before. This is needed in a situation when an audio+video stream application opens the audio stream before the video. When video stream is opened the display mode may change and that aborts audio playback, because the display is momentarily turned off. The audio configuration is stored when it is successfully applied and a boolean is set when the audio playback is started and unset when stopped. This data is used to reconfigure the audio when display is re-enabled. The audio playback is aborted if the reconfiguration fails. A new spin lock is introduced in order to protect state variables related to audio playback status. This is needed for the transition from display enabled state (when audio start/stop commands can be written to HW) to display disabled state (when audio start/stop commands update only the hdmi.audio_playing variable) to always serialize correctly with the start/stop audio commands. The already existing mutex can not be used, because the audio start and stop commands are executed in atomic context. For example: when display is turned back on we take the spinlock and we can be sure that the audio start/stop status will not change while we update the HW according to hdmi.audio_playing state and set hdmi.display_enabled to true. After releasing the lock hdmi.display_enabled is true and all audio_start and audio_stop commands write their stuff directly to HW. Signed-off-by: Jyri Sarha <jsarha@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-24video: fbdev: fsl: Fix the sleep function for FSL DIU moduleJason Jin
For deep sleep, the diu module will power off, when wake up from the deep sleep, the registers need to be reinitialized. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Wang Dongsheng <dongsheng.wang@freescale.com> Acked-by: Timur Tabi <timur@tabi.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-09-10Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: - even more of the rest of MM - lib/ updates - checkpatch updates - small changes to a few scruffy filesystems - kmod fixes/cleanups - kexec updates - a dma-mapping cleanup series from hch * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (81 commits) dma-mapping: consolidate dma_set_mask dma-mapping: consolidate dma_supported dma-mapping: cosolidate dma_mapping_error dma-mapping: consolidate dma_{alloc,free}_noncoherent dma-mapping: consolidate dma_{alloc,free}_{attrs,coherent} mm: use vma_is_anonymous() in create_huge_pmd() and wp_huge_pmd() mm: make sure all file VMAs have ->vm_ops set mm, mpx: add "vm_flags_t vm_flags" arg to do_mmap_pgoff() mm: mark most vm_operations_struct const namei: fix warning while make xmldocs caused by namei.c ipc: convert invalid scenarios to use WARN_ON zlib_deflate/deftree: remove bi_reverse() lib/decompress_unlzma: Do a NULL check for pointer lib/decompressors: use real out buf size for gunzip with kernel fs/affs: make root lookup from blkdev logical size sysctl: fix int -> unsigned long assignments in INT_MIN case kexec: export KERNEL_IMAGE_SIZE to vmcoreinfo kexec: align crash_notes allocation to make it be inside one physical page kexec: remove unnecessary test in kimage_alloc_crash_control_pages() kexec: split kexec_load syscall from kexec core code ...
