path: root/drivers/video/geode/gxfb.h
2009-12-15cs5535: define lxfb/gxfb MSRs in linux/cs5535.hAndres Salomon
..and include them in the lxfb/gxfb drivers rather than asm/geode.h (where possible). Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: add power management functionalityAndres Salomon
This adds the ability to suspend/resume the gxfb driver, which includes: - The addition of a Graphics Processor register table in gxfb.h, and associated GP handling. - Register and palette saving code; registers are stored in gxfb_par. A few MSR values are saved as well. - gx_powerup and gx_powerdown functions which restore/save registers and enable/disable graphic engines. - gxfb_suspend/gxfb_resume Originally based on a patch by Jordan Crouse. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: stop sharing code with gx1fbAndres Salomon
We want to stop sharing stuff with gx1fb; it makes little sense. There were fields in geodefb_par that weren't being used, there was little point to the DC/VP ops callbacks, etc. This implements the following: - Create gxfb_par (based on geodefb_par), place it in gxfb.h - Drop display_gx.h and video_gx.h. The last few patches moved most stuff into gxfb.h anyways, so there was very little left. - Drop the geode_{dc,vid}_ops stuff. Un-static functions, add declarations to gxfb.h. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: move MSR bit fields into gxfb.hAndres Salomon
This continues the gxfb header cleanups. MSRs are defined in geode.h; the specific bits we care about are defined in gxfb.h. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: clean up register definitionsAndres Salomon
This does the following in preparation for register saving: - moves the register definitions from video_gx.h and display_gx.h into gxfb.h. - renames GX_* registers to match their section (ie, VP_). - renames register bitfields to match the data sheet (ie, DC_DCFG_TGEN -> DC_DISPLAY_CFG_TGEN). - for DC registers, rather than defining to specific addresses, use an enum to number them sequentially and just multiply by 4(bytes) to access them (in read_dc/write_dc). - for VP and FP registers, use an enum and multiple by 8 (bytes). They're 64bit registers. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: create DC/VP/FP-specific handlers rather than using readl/writelAndres Salomon
This creates read_dc/write_dc, read_vp/write_vp, and read_fp/write_fp for reading and updating those registers. It creates gxfb.h to house these. We also drop a no-op readl() from gx_set_mode. Other than that, there should be no functionality change. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
