path: root/drivers/video/geode/video_gx.c
2009-12-15cs5535: define lxfb/gxfb MSRs in linux/cs5535.hAndres Salomon
..and include them in the lxfb/gxfb drivers rather than asm/geode.h (where possible). Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Chris Ball <cjb@laptop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28lxfb/gxfb: when blanking with FB_BLANK_POWERDOWN, also turn off the CRTAndres Salomon
The Display Control's CRT_EN can be shut off when we enter FB_BLANK_POWERDOWN in an attempt to save additional power. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: stop sharing code with gx1fbAndres Salomon
We want to stop sharing stuff with gx1fb; it makes little sense. There were fields in geodefb_par that weren't being used, there was little point to the DC/VP ops callbacks, etc. This implements the following: - Create gxfb_par (based on geodefb_par), place it in gxfb.h - Drop display_gx.h and video_gx.h. The last few patches moved most stuff into gxfb.h anyways, so there was very little left. - Drop the geode_{dc,vid}_ops stuff. Un-static functions, add declarations to gxfb.h. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: move MSR bit fields into gxfb.hAndres Salomon
This continues the gxfb header cleanups. MSRs are defined in geode.h; the specific bits we care about are defined in gxfb.h. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: clean up register definitionsAndres Salomon
This does the following in preparation for register saving: - moves the register definitions from video_gx.h and display_gx.h into gxfb.h. - renames GX_* registers to match their section (ie, VP_). - renames register bitfields to match the data sheet (ie, DC_DCFG_TGEN -> DC_DISPLAY_CFG_TGEN). - for DC registers, rather than defining to specific addresses, use an enum to number them sequentially and just multiply by 4(bytes) to access them (in read_dc/write_dc). - for VP and FP registers, use an enum and multiple by 8 (bytes). They're 64bit registers. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: create DC/VP/FP-specific handlers rather than using readl/writelAndres Salomon
This creates read_dc/write_dc, read_vp/write_vp, and read_fp/write_fp for reading and updating those registers. It creates gxfb.h to house these. We also drop a no-op readl() from gx_set_mode. Other than that, there should be no functionality change. Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: don't enable the CRT DACs when we are in flatpanel modeJordan Crouse
When the FP strap is enabled, don't turn on the CRT DACs - that will save about 35 mA of power. Updated/cleaned up by Andres Salomon. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gxfb: set the right registers to tweak the sync polarityJordan Crouse
While running in flatpanel mode it is important to change the FP sync bits (VG register 0x408) rather then the CRT sync bits (VG register 0x008). This patch keeps the CRT sync bits at default when a flatpanel exists. Note that this also fixes inverted logic; we want CRT_VSYNC_POL to be set (ie, vsync is normally high) when FB_SYNC_VERT_HIGH_ACT is unset. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28x86: geode: MSR cleanupAndres Salomon
This cleans up a few MSR-using drivers in the following manner: - Ensures MSRs are all defined in asm/geode.h, rather than in misc places - Makes the naming consistent; cs553[56] ones begin with MSR_, GX-specific ones start with MSR_GX_, and LX-specific ones start with MSR_LX_. Also, make the names match the data sheet. - Use MSR names rather than numbers in source code - Document the fact that the LX's MSR_PADSEL has the wrong value in the data sheet. That's, uh, good to note. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19x86: convert cpuinfo_x86 array to a per_cpu arrayMike Travis
cpu_data is currently an array defined using NR_CPUS. This means that we overallocate since we will rarely really use maximum configured cpus. When NR_CPU count is raised to 4096 the size of cpu_data becomes 3,145,728 bytes. These changes were adopted from the sparc64 (and ia64) code. An additional field was added to cpuinfo_x86 to be a non-ambiguous cpu index. This corresponds to the index into a cpumask_t as well as the per_cpu index. It's used in various places like show_cpuinfo(). cpu_data is defined to be the boot_cpu_data structure for the NON-SMP case. Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-12-08[PATCH] gxfb: Turn on the flatpanel power and dataJordan Crouse
For Geode devices without a flatpanel aware BIOS, this enables the flatpanel power and data. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] gxfb: Support flat panel timingsJordan Crouse
Support TFT panels by correctly setting up the flat panel registers [akpm@osdl.org: cleanups] Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] gxfb: Fixups for the AMD Geode GX framebuffer driverJordan Crouse
We cannot assume that the BIOS will be correctly setting up the hardware, so set some bits in various display registers to enable video output. Allow an advanced user to specify a frambuffer size, rather then probing the BIOS. All of these fixes were prompted by the OLPC effort. [akpm@osdl.org: cleanups] Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] fbdev: framebuffer driver for Geode GXDavid Vrabel
A framebuffer driver for the display controller in AMD Geode GX processors (Geode GX533, Geode GX500 etc.). Tested at 640x480, 800x600, 1024x768 and 1280x1024 at 8, 16, and 24 bpp with both CRT and TFT. No accelerated features currently implemented and compression remains disabled. This driver requires that the BIOS (or the SoftVG/Firmbase code in the BIOS) has created an appropriate virtual PCI header. Signed-off-by: David Vrabel <dvrabel@arcom.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
