path: root/drivers/video/intelfb
2008-04-28fbdev: intelfb: add support for the Intel Integrated Graphics Controller ↵Maik Broemme
965G/965GM Add support for the 965G and 965GM graphic chipsets to the intelfb driver. I have a notebook with an Intel Mobile GM965/GL960 Integrated Graphics Controller and with the attached patch the framebuffer comes up. I have tested it a bit with DirectFB to make sure it is working stable. I also have an Intel Mobile GM945 and I compared the results, the programming interface of the 9xx series from Intel is mostly the same, so I think the patch should add all the functionality which the 945GM has. Signed-off-by: Maik Broemme <mbroemme@plusserver.de> Cc: Dave Airlie <airlied@linux.ie> Cc: Antonino Daplas <adaplas@pol.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Krzysztof Halasa <khc@pm.waw.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove pointless casts from void pointersJeff Garzik
Mostly in and around irq handlers. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Karsten Keil <kkeil@suse.de> Acked-by: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: David Brownell <david-b@pacbell.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/video/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16Remove magic macros for screen_info structure membersH. Peter Anvin
Stop using magic macros for screen_info structure members. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2007-10-16Intel FB: more interlaced mode supportKrzysztof Halasa
Intel FB: allow odd- and even-field-first in interlaced modes, and proper sync to vertical retrace Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: force even line count in interlaced modeKrzysztof Halasa
Intel FB: the chip adds two halflines automatically in interlaced mode, force even line count for the right timings. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: obvious changes and correctionsKrzysztof Halasa
Intel FB: obvious changes and corrections Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: whitespace, bracket and other clean-upsKrzysztof Halasa
Intel FB: whitespace, bracket and other clean-ups Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: support for interlaced video modesKrzysztof Halasa
Intel framebuffer now supports interlaced video modes. Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-19intelfb: Fix bug in DPLL disableAntonino A. Daplas
Reported in Kernel Bugzilla 9006 Fix an obvious bug in DPLL disable. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11Subject: [PATCH] Intel FB pixel clock calculation fixKrzysztof Halasa
Intel framebuffer mis-calculated pixel clocks. The pixel clock (and thus both H and V sync) will be slower than requested, so if you set the minimum allowed the display may not sync. In case of really old CRT display it could theoretically damage it. I'm using it with PAL TV (using RGB input - SCART connector) and the bug prevented it from working at all (TV requirements are more strict and made the bug visible). Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17intelfb: the pseudo_palette is only 16 elements longAntonino A. Daplas
The pseudo_palette is only 16 elements long. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08intelfb: fix ring space calculationOrczykowski, Juergen
If there is less than RING_MIN_FREE available in the ring buffer, dinfo->ring_space is set to a big value forcing wait_ring to return. Fix by making ring space = 0 if ring space < RING_MIN_FREE. Signed-off-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-01i2c: Shrink struct i2c_clientDavid Brownell
This shrinks the size of "struct i2c_client" by 40 bytes: - Substantially shrinks the string used to identify the chip type - The "flags" don't need to be so big - Removes some internal padding It also adds kerneldoc for that struct, explaining how "name" is really a chip type identifier; it's otherwise potentially confusing. Because the I2C_NAME_SIZE symbol was abused for both i2c_client.name and for i2c_adapter.name, this needed to affect i2c_adapter too. The adapters which used that symbol now use the more-obviously-correct idiom of taking the size of that field. JD: Shorten i2c_adapter.name from 50 to 48 bytes while we're here, to avoid wasting space in padding. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Video: fb, kzalloc changesJiri Slaby
Use kzalloc instead of kmalloc + memset(0). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10i2c: Discard the i2c algo del_bus wrappersJean Delvare
They are all only calling i2c_del_adapter, so we may as well do it directly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-08[PATCH] drivers/video/*: use kmemdup()Alexey Dobriyan
From: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25Remove unnecessary check in drivers/video/intelfb/intelfbhw.cEric Sesterhenn
All callers and the function itself dereference dinfo, so we can remove the check. (coverity id #1371) Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-10-25intel fb: switch to pci_get APIAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-30Merge branch 'intelfb-patches' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6 * 'intelfb-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/intelfb-2.6: intelfbhw.c: intelfbhw_get_p1p2 defined but not used intelfb: fix mtrr_reg signedness intelfb: update doc and Kconfig (supported devices) intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add preliminary i2c support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support intelfb: add vsync interrupt support
2006-08-22intelfbhw.c: intelfbhw_get_p1p2 defined but not usedParag Warudkar
intelfbhw_get_p1p2 is used only if REGDUMP is defined - compile it in only if REGDUMP is defined - one less compiler warning. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-08-22intelfb: fix mtrr_reg signednessDave Airlie
This is my fix for gcc 4.1 sign issue reported by Eric Sesterhenn <snakebyte@gmx.de>. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03intelfb: add preliminary i2c supportDennis Munsie
Adds code to unregister the I2C buses in the cleanup function. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
[07/07] intelfb: adds an option to enable I2C support in the intelfb driver. Also adds the intel_i2c.c file to the Makefile. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
[06/07] intelfb: adds intelfb_i2c.c which contains the infrastructure needed to enumerate the i2c busses on the intelfb. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
[05/07] intelfb: add output fields to dinfo. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
[04/07] intelfb: add intelfb_output_rec struct and the constants for it's fields. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
[03/07] intelfb: add intelfb_i2c_chan struct. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
[02/07] intelfb: add GPIO registers. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com>
2006-07-03intelfb: add vsync interrupt supportEric Hustvedt
[05/05] intelfb: Honor FB_ACTIVATE_VBL for display panning Extends the intelfb_vsync struct to store panning offset. The interrupt service routine uses the stored panning offset if a pan is requested for the vsync. intelfbhw_disable_irq also pans the display if there is a pending request. Signed-off-by: Eric Hustvedt <ehustvedt@cecropia.com>
[04/05] intelfb: implement FBIO_WAITFORVSYNC ioctl The (unofficial) FBIO_WAITFORVSYNC ioctl is implemented by sleeping on the appropriate waitqueue, as defined in my earlier patch. Currently, only display 0 (aka pipe A) is supported. Signed-off-by: Eric Hustvedt <ehustvedt@cecropia.com>
[03/05] intelfb: Implement basic interrupt handling Functions have been added to enable and disable interrupts using the MMIO registers. Currently only pipe A vsync interrupts are enabled. A generalized vsync accounting struct is defined, with the intent that it can encapsulate per-pipe vsync related info in the future. Currently a single instance is hard-coded. The interrupt service routine currently only looks for vsync interrupts on pipe A, and increments a counter and wakes up anyone waiting on it. This implementation is heavily influenced by similar implementations in the atyfb and matroxfb drivers. Signed-off-by: Eric Hustvedt <ehustvedt@cecropia.com>
[02/05] intelfb: Add interrupt related register definitions Add constants for accessing HWSTAM, IER, IIR, and IMR registers. Add constants for interrupt types supported by the 8xx and 9xx chipsets. The registers are also stored in the hwstate struct and dumped in the debug routine. Signed-off-by: Eric Hustvedt <ehustvedt@cecropia.com>
[01/05] intelfb: Add 16-bit register access macros This patch adds macros to read and write two-byte MMIO registers. The interrupt-related registers are all word-sized, rather than long-sized. Signed-off-by: Eric Hustvedt <ehustvedt@cecropia.com>
2006-06-24intelfb delousingAl Viro
ring_head is offset in card memory, not iomem pointer. Fixed, removed fuckloads of amazingly bogus casts somebody had sprinkled all over the place. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-06-18intelfb: fixup clock calculation debugging.Dave Airlie
The debugging code for pll clocks was wrong and causing div by 0. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-06-07Removed hard coded EDID buffer size.Dennis Munsie
Signed-off-by: Dennis Munsie <dmunsie@cecropia.com> Acked-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-05-29intelfb: use regular modedb table instead of VESADennis Munsie
intelfb driver -- use the regular modedb table instead of the VESA modedb table. Ideally, the 9xx stride patch should be applied first, since there are modes in the VESA table that won't work without that patch. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-05-29intelfb: use firmware EDID for mode databaseAntonino A. Daplas
Use firmware EDID for the driver's private mode database. Signed-off-by: Antonino Daplas <adaplas@pol.net> Cc: Sylvain Meyer <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-05-29Revert "intelfb driver -- use the regular modedb table instead of the VESA"Dave Airlie
This reverts 2c47430a03bbcc3c9a623a07eca5baf92c7d20c8 commit. This conflicts with a patch in -mm from Antonino reapply later. Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-05-29intelfb: int option fixEric Hustvedt
Fix integer option parsing in the intelfb driver. The macro wasn't accounting for the equal sign past the option name. As a result, the vram option always returned 0. Signed-off-by: Eric Hustvedt <ehustvedt@cecropia.com> Signed-off-by: Dennis Munsie <dmunsie@cecropia.com Signed-off-by: Dave Airlie <airlied@linux.ie>
2006-05-27sync modesetting code with X.orgDave Airlie
2006-05-27intelfb: align with changes from my X driver.Dave Airlie
This just realigns the PLL calculation routines with the ones from my X.org driver. Signed-off-by: Dave Airlie <airlied@linux.ie>
