path: root/drivers/video/logo/logo.c
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-16fbdev: move logo externs to header fileGeert Uytterhoeven
Now we have __initconst, we can finally move the external declarations for the various Linux logo structures to <linux/linux_logo.h>. James' ack dates back to the previous submission (way to long ago), when the logos were still __initdata, which caused failures on some platforms with some toolchain versions. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14video/logo: add support for Blackfin/Linux logo for framebuffer consoleRobin Getz
This art design is beautiful, isn't it? And you can watch our demo on YouTube: http://youtube.com/watch?v=fKyQOntPEFs Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18logo.c: get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95 so I recently deleted this from everywhere except the last instance in logo.c. This patch removes the last two instances in logo.c. They conditions were not useful anyway as when compiled in they would always evaluate as true. Last not least this is necessary to get the SGI IP22 and DECstation kernels to compile again. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbcon: logo: disable logo at bootRandy Dunlap
Add logo.nologo kernel boot option to disable the logo in order to provide more screen space for kernel messages; especially useful when debugging and screen space is more critical. newport_con driver changes are untested. [akpm@linux-foundation.org: cleanups, coding-style fixes] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16kbuild: remove hardcoded _logo names from modpostSam Ravnborg
Replaced this with a __init_refok marker in front of fb_find_logo(). I think that the __initdata marker for the logo's are wrong but I have not justified this so I did not remove it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-07[PATCH] m32r: framebuffer device supportHirokazu Takata
This patch is for supporting Epson s1d13xxx framebuffer device for m32r. # Sorry, a little bigger. The Epson s1d13806 is already supported by 2.6.12 kernel, and its driver is placed as drivers/video/s1d13xxxfb.c. For the m32r, a header file include/asm-m32r/s1d13806.h was prepared for several m32r target platforms. It was originally generated by an Epson tool S1D13806CFG.EXE, and modified manually for the m32r platforms. Signed-off-by: Hayato Fujiwara <fujiwara@linux-m32r.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
