path: root/drivers/video/matrox/matroxfb_base.h
2010-08-20matroxfb: fix incorrect use of memcpy_toio()Ondrej Zary
Screen is completely corrupted since 2.6.34. Bisection revealed that it's caused by commit 6175ddf06b61720 ("x86: Clean up mem*io functions."). H. Peter Anvin explained that memcpy_toio() does not copy data in 32bit chunks anymore on x86. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Jean Delvare <khali@linux-fr.org> Cc: <stable@kernel.org> [2.6.34.x, 2.6.35.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of CONFIG_FB_MATROX_32MBJean Delvare
CONFIG_FB_MATROX_32MB is always enabled, so there is no point in having ifdefs all around. And it is bad practice to use CONFIG_* as a name for something which is not a Kconfig option. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macro MINFO_FROMJean Delvare
With multihead support always enabled, macros MINFO_FROM and MINFO_FROM_INFO are no longer needed and make the code harder to read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macros WPMINFO and friendsJean Delvare
With multihead support always enabled, these macros are no longer needed and make the code harder to read. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23matroxfb: get rid of unneeded macros ACCESS_FBINFO and MINFOJean Delvare
2009-09-23matroxfb: make CONFIG_FB_MATROX_MULTIHEAD=y mandatoryJean Delvare
I would like to get rid of option CONFIG_FB_MATROX_MULTIHEAD and just always enable it. There are many reasons for doing this: * CONFIG_FB_MATROX_MULTIHEAD=y is what all x86 distributions do, so it definitely works or we would know by now. * Building the matroxfb driver with CONFIG_FB_MATROX_MULTIHEAD not set results in the following build warning: drivers/video/matrox/matroxfb_crtc2.c: In function 'matroxfb_dh_open': drivers/video/matrox/matroxfb_crtc2.c:265: warning: the address of 'matroxfb_global_mxinfo' will always evaluate as 'true' drivers/video/matrox/matroxfb_crtc2.c: In function 'matroxfb_dh_release': drivers/video/matrox/matroxfb_crtc2.c:285: warning: the address of 'matroxfb_global_mxinfo' will always evaluate as 'true' This is nothing to be worried about, the driver will work fine, but build warnings are still annoying. * The trick to get multihead support without CONFIG_FB_MATROX_MULTIHEAD, which is described in the config help text, no longer works: you can't load the same kernel module more than once. * I fail to see how CONFIG_FB_MATROX_MULTIHEAD=y would make the code significantly slower, contrary to what the help text says. A few extra parameters on the stack here and there can't really slow things down in comaprison to the rest of the code, and register access. * The driver built without CONFIG_FB_MATROX_MULTIHEAD is larger than the driver build with CONFIG_FB_MATROX_MULTIHEAD=y by 8%. * One less configuration option makes things simpler. We add options all the time, being able to remove one for once is nice. It improves testing coverage. And I don't think the Matrox adapters are still popular enough to warrant overdetailed configuration settings. * We should be able to unobfuscate the driver code quite a bit after this change (patches follow.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23fbdev: fix integer as NULL pointer warningHarvey Harrison
drivers/video/aty/atyfb_base.c:3359:26: warning: Using plain integer as NULL pointer drivers/video/aty/radeon_base.c:2280:32: warning: Using plain integer as NULL pointer drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer drivers/video/sis/sis_main.c:5790:44: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-11matroxfb: rectify jitter (G450/G550)Paul A. Clarke
This builds upon my previous attempts to resolve some jitter problems seen with the Matrox G450 and G550 -based cards, including odd disparities observed between x86 and Power -based machines in a somewhat less hackish way (removing the hacked ifdefs). Apparently, preference should be given to use the DVI PLL when frequencies permit, the Standard PLL otherwise. The max pixel clock for the panellink interface is extracted from the PInS information on the card and used as a limit to determine which PLL to use. Signed-off-by: Paul A. Clarke <pc@us.ibm.com> Acked-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17matroxfb: color setting fixesAntonino A. Daplas
- the pseudo_palette is only 16 elements long. - do not write to the pseudo_palette if regno (array index) is more than 15 - remove code that writes to the 17th entry of the pseudo_palette Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] matroxfb: fix DVI setup to be more compatiblePaul A. Clarke
There has been a longstanding problem with the Matrox G450 and perhaps other similar cards, with modes "above" 1280x1024-60 on ppc/ppc64 boxes running Linux. Higher resolutions and/or higher refresh rates resulted in a very noticably "jittery" display, and sometimes no display, depending on the physical monitor. This patch fixes that problem on the systems I have easy access to... I've tested with SLES9SP3 (2.6.5+ kernel) and 2.6.16-rc6 custom kernels on an IBM eServer p5 520 w/G450 (a.k.a GXT135P on IBM's ppc64 systems), and a colleague of mine (Ian Romanick) tested it successfully on an Apple ppc32 box (w/GXT135P). I also tested it on IA32 box I have with a GXT135P to verify that it didn't obviously break anything. In my testing, I covered single-card, single and dual-head setups using both HD15 and DVI-D signals, on both the IA32 and ppc64 boxes. While everything appeared fine on both boxes, I did encounter one problem: I can't get any signal on the DVI-D output on the ppc64 box. However, this is also the case without my patch. I just noticed that screen-blanking only occurs on the primary display as well. Signed-off-by: Paul A. Clarke <pc@us.ibm.com> Signed-off-by: Ian Romanick <idr@us.ibm.com> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] matroxfb: Remove fbcon.h from the main header fileAntonino A. Daplas
matroxfb has no need for struct display and fbcon.h. Remove. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] matroxfb: Use CACHEFLUSH on all chipsVille Syrjälä
Use the CACHEFLUSH register on all chip types. The register is listed in all other specs except 2064W. However I have verified that the register does work on a 2064W despite being marked reserved in the specs. There were no noticeable side effects after writing to the register. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
