path: root/drivers/video/matrox
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] video/matrox/matroxfb_misc.c: remove dead codeAdrian Bunk
The Coverity checker spotted this dead code. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] drivers/video/: possible cleanupsAdrian Bunk
This patch contains the possible cleanups including the following: - every file should #include the headers containing the prototypes for it's global functions - make needlessly global functions static - kyro/STG4000Interface.h: #include video/kyro.h and linux/pci.h instead of a manual "struct pci_dev" - i810_main.{c,h}: prototypes for static functions belong to the C file Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] matroxfb: Remove fbcon.h from the main header fileAntonino A. Daplas
matroxfb has no need for struct display and fbcon.h. Remove. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05[PATCH] i2c: drop empty i2c_driver.command implementationsLaurent Riffard
Given that implementing i2c_driver.command is optional, there is no point in an empty implementation thereof. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Michael Geng <linux@MichaelGeng.de> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 9 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the matroxfb driver. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] matroxfb: Set maxhipri to 0Ville Syrjälä
The current init code sets hiprilvl to 0 and maxhipri to 5. According to the specs those values are illegal on both G200 and G400. It also causes distortions on the TV-out at least when CRTC2 is in YUV mode as is the case with DirectFB. This patch resets both values to 0. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] matroxfb: Kill a useless messageVille Syrjälä
No point in spamming the logs with a message about xres rounding. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] matroxfb: Use CACHEFLUSH on all chipsVille Syrjälä
Use the CACHEFLUSH register on all chip types. The register is listed in all other specs except 2064W. However I have verified that the register does work on a 2064W despite being marked reserved in the specs. There were no noticeable side effects after writing to the register. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] matroxfb: Add support for Mystique AGPVille Syrjälä
Add new entries for Mystique AGP with the PCI ID 0x051e. I don't actually have such boards but according to google they do exist. Curiosly X.Org doesn't recognize that PCI ID. And what's even more interesting is that Matrox's own Windows drivers don't recognize it either. After going through about a dozen different versions I did find one older driver that does list this particular ID. It is also listed in the pci.ids file. I'm not sure if non-220 AGP chips exist. I left the chip revision check intact for AGP chips nonetheless. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] matroxfb: Remove an unused wait queue entryVille Syrjälä
wait_event_event_interruptible() uses a private wait queue entry so there's no need for the caller to initialize one. Signed-off-by: Ville Syrjälä <syrjala@sci.fi> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] matroxfb adjustmentsJan Beulich
Some adjustments to the matroxfb code, for one part preventing the display to be disabled for longer than necessary, and for the other part to make information about the frame buffer position available so that a kernel debugger might obtain that before the initial mode change. Finally, some return code corrections to fit the generic fb code. Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] matroxfb: read MGA PInS data on PowerPCIan Romanick
This updates the matroxfb code so that it can find the PInS data embedded in the BIOS on PowerPC cards. The process for finding the data is different on OpenFirmware cards than on x86 cards, and the code for doing so was missing. After patching, building, installing, and booting a kernel, you should grep for "PInS" in /var/log/messages. You should see two messages in the log: PInS data found at offset XXXXX PInS memtype = X On the GXT135p card I get "31168" and "5". The first value is irrelevant, but it's presence lets me know that the PInS data was actually found. On a GXT130p, the second value should be 3. Since I don't have access to that hardware, if someone can verify that, I will submit a follow-on patch that rips out all the memtype parameter stuff. Signed-off-by: Ian Romanick <idr@us.ibm.com> Signed-off-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (5/7)Jean Delvare
Merge the algorithm id part (16 upper bits) of the i2c adapters ids into the definition of the adapters ids directly. After that, we don't need to OR both ids together for each i2c_adapter structure. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-25[PATCH] drivers/video/matrox/matroxfb_misc.c: remove dead codeAdrian Bunk
This patch removes some obviously dead code found by the Coverity checker. This patch was already ACK'ed by Petr Vandrovec. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] I2C: Kill address ranges in non-sensors i2c chip driversJean Delvare
Some months ago, you killed the address ranges mechanism from all sensors i2c chip drivers (both the module parameters and the in-code address lists). I think it was a very good move, as the ranges can easily be replaced by individual addresses, and this allowed for significant cleanups in the i2c core (let alone the impressive size shrink for all these drivers). Unfortunately you did not do the same for non-sensors i2c chip drivers. These need the address ranges even less, so we could get rid of the ranges here as well for another significant i2c core cleanup. Here comes a patch which does just that. Since the process is exactly the same as what you did for the other drivers set already, I did not split this one in parts. A documentation update is included. The change saves 308 bytes in the i2c core, and an average 1382 bytes for chip drivers which use I2C_CLIENT_INSMOD, 126 bytes for those which do not. This change is required if we want to merge the sensors and non-sensors i2c code (and we want to do this). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/Documentation/i2c/writing-clients ===================================================================
