Get rid of users of of_platform_driver in drivers/video. The
of_platform_{,un}register_driver functions are going away, so the
users need to be converted to using the platform_bus_type directly.
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
Fixes build errors in a number of framebuffer drivers caused
by the OF device_node pointer being moved into struct device
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
Since Valentin's email address @siemens.com is no longer valid, it's time
to change it to the one that actually works so that I don't have to
manually forward patches against mb862xx to him every time.
Signed-off-by: Alexander Shishkin <virtuoso@slind.org>
Acked-by: Valentin Sitdikov <v.sitdikov@gmail.com>
mb862xxfb_accel built as a separate module, but it does not have a
MODULE_LICENSE, so it taints the kernel. Add a MODULE_LICENSE to it (same
as mb862xxfb license).
mb862xxfb_accel: module license 'unspecified' taints kernel.
Or should mb862xxfb_accel be built into the mb862xxfb binary file instead?
Acked-by: Alexander Shishkin <virtuoso@slind.org>
Cc: Valentin Sitdikov <v.sitdikov@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
There was some conditionalizing for the LWMON5 boards in kernel source.
However infrastructure for enabling this isn't here so probably the
special case code can go as well.
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
copyarea * fillrect
[akpm@linux-foundation.org: clean up comments, remove do-nothing tests, use min()]
[akpm@linux-foundation.org: fix Alexandr's email address]
[akpm@linux-foundation.org: export mb862xxfb_init_accel]
Signed-off-by: Valentin Sitdikov <valentin.sitdikov@siemens.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
With this change, the driver builds fine on Microblaze, which helps
allyesconfig compile tests.
I did not test sparc, but the change should have the same effect there.
Acked-by: Anatolij Gustschin <agust@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
sparc64:
drivers/video/mb862xx/mb862xxfb.c:929: warning: long long unsigned int format, resource_size_t arg (arg 4)
drivers/video/mb862xx/mb862xxfb.c:931: warning: long long unsigned int format, resource_size_t arg (arg 4)
We don't know what type the architecture uses to implement u64, hence they
cannot be printed.
Cc: Dmitry Baryshkov <dbaryshkov@gmail.com>
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Matteo Fortini <m.fortini@selcomgroup.com>
Add a framebuffer driver for the Fujitsu Carmine/Coral-P(A)/Lime graphics
controllers. Lime GDC support is known to work on PPC440EPx based lwmon5
and MPC8544E based socrates embedded boards, both equipped with Lime GDC.
Carmine/Coral-P PCI GDC support is known to work on PPC440EPx based
Sequoia board and also on x86 platform.
