path: root/drivers/video/modedb.c
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: make the best-fit section of fb_find_mode return the closest matching ↵Michal Januszewski
mode Currently, if a perfect match in terms of resolution is not found, fb_find_mode() only looks for a best-fit mode among modes with a higher resolution than the one requested. Thus, if the user requests a resolution higher than the largest supported one, they are dropped to the default mode (usually a low resolution one). Change this behaviour so that all valid video modes are considered when looking for a best-fit mode, while still preferring modes with a higher resolution. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-17fix radeonfb regression with Xpress 200m 5955Alex
Fix http://bugzilla.kernel.org/show_bug.cgi?id=9762 Framebuffer is ok only with default parameters only (it is 1280x800-8@60). If parameters are video=radeonfb:1280x800-32@60 then xres, yres and xres_virtual are ok but yres_virtual is 1024. It can be corrected by fbset utility so I think it can be corrected in the driver code also. Steps to reproduce: video=radeonfb:1280x800-32@60 or video=radeonfb:1280x800-16@60 Add 1280x800 mode into modedb Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fb modedb: Refactor confusing mode_option assignmentGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fb: move and rename extern declaration for global_mode_optionGeert Uytterhoeven
Move the extern declaration for global_mode_option to <linux/fb.h> and rename the variable to fb_mode_option. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: find mode with the highest/safest refresh rate in fb_find_mode()Michal Januszewski
Currently, if the refresh rate is not specified, fb_find_mode() returns the first known video mode with the requested resolution, which provides no guarantees wrt the refresh rate. Change this so that the mode with the highest refresh rate is returned when the driver provides a custom video mode database and the monitor limits, and a mode with the safe 60 Hz refresh rate otherwise. Signed-off-by: Michal Januszewski <spock@gentoo.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: Fix incorrect timings in some modedb entriesAntonino A. Daplas
Reported by: John Lumby <johnlumby@hotmail.com> Some of the entries in the mode database does not match the comments and/or the refresh field. Adjust the timings so they match with both the comments and the refresh rate. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: export fb_destroy_modelistMichal Januszewski
Make fb_destroy_modelist an exported symbol for use in the uvesafb driver. Signed-off-by: Michal Januszewski <spock@gentoo.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08VIDEO: add spaces on either side of the case "..." operatorRobert P. J. Day
Following the programming advice laid down in the gcc manual, make sure the case "..." operator has spaces on either side. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] fb_videomode_to_var: reset virtual screen parametersGeert Uytterhoeven
fb_videomode_to_var(): reset the virtual screen parameters when converting from an fb_videomode to an fb_var_screeninfo. Without this the old virtual screen parameters are kept. Hence you cannot switch to a video mode with a lower resolution on frame buffer devices that don't support virtual screens and panning, as values are not supposed to be rounded down when they don't fit. I also reordered the assignments to match the order of the individual members. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] fbdev modedb: make more pointer parameters constGeert Uytterhoeven
fbdev modedb: make more input and output pointer parameters const Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] fbdev modedb: allow refresh rates for named video modesGeert Uytterhoeven
fbdev modedb: Take into account the specified refresh rates for video modes specified by name, so e.g. all of `720p', `720p@60', and `720p@50' work. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] video: Get the default mode from the right databaseJordan Crouse
If no default mode is specified, it should be grabbed from the supplied database, not the default one. [teanropo@jyu.fi: fix it] [akpm@osdl.org: simplify it] [akpm@osdl.org: remove pointless DEFAULT_MODEDB_INDEX] Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Tero Roponen <teanropo@jyu.fi> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fbdev: Remove unused exportsAdrian Bunk
This patch removes the following unused EXPORT_SYMBOL's: - fbcvt.c: fb_find_mode_cvt - fbmem.c: fb_con_duit - fbmem.c: fb_new_modelist - macmodes.c: mac_var_to_vmode - modedb.c: fb_delete_videomode - modedb.c: fb_destroy_modelist Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fbdev: Coverity Bug 90Antonino A. Daplas
It's a false positive, but let's suppress it anyway. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fbdev: Add 1366x768 (WXGA) mode to mode databaseDennis Munsie
Adds 1366x768 @ 60Hz to drivers/video/modedb.c. Signed-off-by: Dennis Munsie <dmunsie@cecropia.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] drivers/video: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of ARRAY_SIZE. Some coding style and trailing whitespaces are also fixed. Compile-tested where possible (some are other arch or BROKEN) Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] fbdev: add modeline for 1680x1050@60Olaf Hering
Add a modeline for the Philips 200W display. aty128fb does not do DDC, it picks 1920x1440 or similar. It works ok with nvidiafb because it can ask for DDC data. mode "1680x1050-60" # D: 146.028 MHz, H: 65.191 kHz, V: 59.863 Hz geometry 1680 1050 1680 1050 16 timings 6848 280 104 30 3 176 6 hsync high vsync high rgba 5/11,6/5,5/0,0/0 endmode hwinfo --monitor 20: None 00.0: 10000 Monitor [Created at monitor.206] Unique ID: rdCR.pzUFTofo1S4 Parent ID: 002j.bJRsY88eNSC Hardware Class: monitor Model: "PHILIPS Philips 200W" Vendor: PHL "PHILIPS" Device: eisa 0x0832 "Philips 200W" Serial ID: "VN 016596" Resolution: 720x400@70Hz Resolution: 640x480@60Hz Resolution: 640x480@67Hz Resolution: 640x480@72Hz Resolution: 640x480@75Hz Resolution: 800x600@56Hz Resolution: 800x600@60Hz Resolution: 800x600@72Hz Resolution: 800x600@75Hz Resolution: 832x624@75Hz Resolution: 1024x768@60Hz Resolution: 1024x768@70Hz Resolution: 1024x768@75Hz Resolution: 1280x1024@75Hz Resolution: 1152x864@70Hz Resolution: 1152x864@75Hz Resolution: 1280x960@60Hz Resolution: 1280x1024@60Hz Resolution: 1680x1050@60Hz Size: 433x271 mm Driver Info #0: Max. Resolution: 1680x1050 Vert. Sync Range: 56-85 Hz Hor. Sync Range: 30-93 kHz Config Status: cfg=new, avail=yes, need=no, active=unknown Attached to: #5 (VGA compatible controller) Signed-off-by: Olaf Hering <olh@suse.de> Acked-by: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] fbdev: Framebuffer mode required for PowerBook TitaniumMichael Hanselmann
This patch adds the framebuffer mode required for an Apple PowerBook G4 Titanium. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbdev: Add helper to get an appropriate initial modeAntonino A. Daplas
Add new helper, fb_find_best_display(), which will search the modelist for the best mode for the attached display. This requires an EDID block that is converted to struct fb_monspecs and a private modelist. The search will be done in this manner: - if 1st detailed timing is preferred, use that - else if dimensions of the display are known, use that to estimate xres and - else if modelist has detailed timings, use the first detailed timing - else, use the very first entry from the modelist Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbdev: fix the fb_find_nearest_mode() functionMichal Januszewski
Currently the fb_find_nearest_mode() function finds a mode with screen resolution closest to that described by the 'var' argument and with some arbitrary refresh rate (eg. in the following sequence of refresh rates: 70 60 53 85 75, 53 is selected). This patch fixes the function so that it looks for the closest mode as far as both resolution and refresh rate are concerned. The function's first argument is changed to fb_videomode so that the refresh rate can be specified by the caller, as fb_var_screeninfo doesn't have any fields that could directly hold this data. Signed-off-by: Michal Januszewski <spock@gentoo.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fbdev: Add VESA Coordinated Video Timings (CVT) supportAntonino A. Daplas
The Coordinated Video Timings (CVT) is the latest standard approved by VESA concerning video timings generation. It addresses the limitation of GTF which is designed mainly for CRT displays. CRT's have a high blanking requirement (as much as 25% of the horizontal frame length) which artificially increases the pixelclock. Digital displays, on the other hand, needs to conserve the pixelclock as much as possible. The GTF also does not take into account the different aspect ratios in its calculation. The new function added is fb_find_mode_cvt(). It is called by fb_find_mode() if it recognizes a mode option string formatted for CVT. The format is: <xres>x<yres>[M][R][-<bpp>][<at-sign><refresh>][i][m] The 'M' tells the function to calculate using CVT. On it's own, it will compute a timing for CRT displays at 60Hz. If the 'R' is specified, 'reduced blanking' computation will be used, best for flatpanels. The 'i' and the 'm' is for 'interlaced mode' and 'with margins' respectively. To determine if CVT was used, check for dmesg for something like this: CVT Mode - <pix>M<n>[-R], ie: .480M3-R (800x600 reduced blanking) where: pix - product of xres and yres, in MB M - is a CVT mode n - the aspect ratio (3 - 4:3; 4 - 5:4; 9 - 16:9, 15:9; A - 16:10) -R - reduced blanking Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-08[PATCH] nvidiafb: Fix initial display corruption on certain laptopsAntonino Daplas
Reported by:Vincent Fortier (Bugzilla Bug 4768) "At boot time the screen appears moved to the mid right portion of the actual video pannel making the end of the line appears at the left edge... It simply looks like moved half way to the right" His particular hardware has a display with an unusual dimension (1920x1200) but unfortunately has no EDID block. None of the entries in the global mode database is correct for this particular display, and it particularly has difficulty scaling up 640x480 (the default startup mode of nvidiafb) to 1920x1200 which causes the above described problem. 1, Add 1920x1200 to the global mode database. 2. Let nvidiafb base the startup mode from the flatpanel dimensions only if the EDID block is absent, no boot mode parameter is specified by the user, and a flatpanel/LCD display is attached. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
