imx7D hdmi audio will failed work after video mode changed.
It is cause by imx7D sii902x hdmi audio should setting to SAI
mode but sii902x default set audio to spdif mode in sii902x_setup
function. The function is called by every video mode change.
Move sii902x default audio mode code into probe function to
resolve the issue.
Signed-off-by: Sandor Yu <R01008@freescale.com>
-Remove variable waiting_for_fb, add manually trigger interrupter
to support plugin interrupt is missed on some platform such as imx7D SDB.
-Remove stop probe code if device_reset failed to support
imx7D SDB.
-Remove interrupt bit check in ISR.
Forward imx_3.10_y mxc video drivers to 3.14 kernel.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
