path: root/drivers/video/nvidia
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16backlight: Allow properties to be passed at registrationMatthew Garrett
Values such as max_brightness should be set before backlights are registered, but the current API doesn't allow that. Add a parameter to backlight_device_register and update drivers to ensure that they set this correctly. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-06-23nvidiafb: fix boot-time printk stringMikael Pettersson
On bootup nvidiafb prints the following on my Apple G5: nvidiafb: CRTC 1appears to have a CRT attached There should be a space between the '1' and the 'appears'. Add it. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02fb: nvidiafb recognizes geforcego 7300 chip as mobileSergey Senozhatsky
nvidiafb recognizes geforcego 7300 chip as mobile Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01nvidiafb: remove open_lock mutexAlessio Igor Bogani
Remove mutex from the nvidiafb_open/nvidiafb_release functions as these operations are mutexed at fb layer. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2009-01-06nvidia: fix sparse warningsHannes Eder
Fix this sparse warnings: drivers/video/nvidia/nv_accel.c:304:3: warning: returning void-valued expression drivers/video/nvidia/nv_accel.c:323:3: warning: returning void-valued expression Signed-off-by: Hannes Eder <hannes@hanneseder.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: nv: fix sparse noiseAlexey Dobriyan
Mostly signedness fixes. nv10_sim_state existence in both drivers suggests that one of them should be removed, but that's for later. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fbdev: nv: drop useless MODULE ifdefsAlexey Dobriyan
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fb: nvidiafb: Try harder at initial mode setting.Paul Mundt
The current nvidiafb_check_var() simply bails out if the selected mode is out of range of the panel dimensions. A good question would be why the bogus mode is being selected in the first place -- the panel dimensions that are read back are certainly bogus, but alas, I have no idea where to even begin looking at the i2c/EDID/DDC mess: nvidiafb: Device ID: 10de0165 nvidiafb: CRTC0 analog not found nvidiafb: CRTC1 analog not found nvidiafb: EDID found from BUS1 nvidiafb: CRTC 0 is currently programmed for DFP nvidiafb: Using DFP on CRTC 0 nvidiafb: Panel size is 1280 x 1024 nvidiafb: Panel is TMDS nvidiafb: unable to setup MTRR nvidiafb: Flat panel dithering disabled nvidiafb: PCI nVidia NV16 framebuffer (64MB @ 0xC0000000) In my .config I presently have: CONFIG_FIRMWARE_EDID=y CONFIG_FB_DDC=y CONFIG_FB_NVIDIA_I2C=y I've not tried fiddling with these options, as I haven't the vaguest idea what I should be looking at. As a workaround, simply groveling for a new mode based on the probed dimensions seems to work ok. While it would be nice to debug this further and sort out why the panel information is bogus, I think it's still worth retrying the mode based on the panel information at hand as a last-ditch effort, rather than simply bailing out completely. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Cc: Antonino A. Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16nvidiafb: Correctly assign the i2c class with the port reversalAntonino A. Daplas
If the i2c ports are to be reversed, I2C_CLASS_HWMON assignment must also be reversed. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16nvidiafb: Add boot option to reverse i2c port assignmentAntonino A. Daplas
There are a few nvidia hardware where the i2c port assignments are reversed, i.e., the 1st i2c port is assigned to the secondary display and the 2nd i2c port to the primary display. In most cases, if only 1 display is attached, or if only 1 flatpanel and 1 analog display is attached, the port reversal is of no consequence. However if 2 flatpanels are attached, it can cause display problems. There is no sane way of determining if the hardware reversed the i2c port assignment, so the simplest fix is to add a boot/module option, "reverse_i2c to explicitly reverse the i2c port. This also restores i2c ordering back to the pre-2.6.22 state. Signed-off-by: Antonino Daplas <adaplas@gail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: leds: cr_bllcd.c: build fix backlight: Convert from struct class_device to struct device backlight: Fix order of Kconfig entries
2007-07-17nvidiafb: Add proper support for Geforce 7600 chipsetAntonino A. Daplas
Add proper support for the Geforce 7600 (device id 0x039x). This also sync's nvidiafb with the latest Xorg nv driver. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17nvidiafb: adjust flags to take advantage of new scroll methodAntonino A. Daplas
The SCROLL_MOVE method has been optimized such that it is significantly faster than SCROLL_REDRAW. Adjust flags to indicate that blitting is preferred over rendering. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16backlight: Convert from struct class_device to struct deviceRichard Purdie
Convert the backlight and LCD classes from struct class_device to struct device since class_device is scheduled for removal. One nasty API break is the backlight power attribute has had to be renamed to bl_power and the LCD power attribute has had to be renamed to lcd_power since the original names clash with the core. I can't see a way around this. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-11nvidiafb: Enable debugging messages a Kconfig optionJean Delvare
Let the user enable debugging messages in nvidiafb. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11fbdev: geforce 7300 cleanupMichal Piotrowski
ups... coding style. Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09frame buffer: geforce 7300 gtMichal Piotrowski
My geforce isn't supported by nvidia frame buffer. /sbin/lspci 01:00.0 VGA compatible controller: nVidia Corporation Unknown device 02e2 (rev a2) /usr/sbin/fbset -i mode "1024x768-60" # D: 65.003 MHz, H: 48.365 kHz, V: 60.006 Hz geometry 1024 768 1024 32767 8 timings 15384 160 24 29 3 136 6 accel true rgba 8/0,8/0,8/0,0/0 endmode Frame buffer device information: Name : NV2e Address : 0xe0000000 Size : 134217728 Type : PACKED PIXELS Visual : PSEUDOCOLOR XPanStep : 8 YPanStep : 1 YWrapStep : 0 LineLength : 1024 MMIO Address: 0xf6000000 MMIO Size : 16777216 Accelerator : Unknown (46) Here is a patch for this problem. Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: fix return value of nvidiafb_open()Antonino A. Daplas
Fix return value of nvidiafb_open(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: prevent triggering of softlockupDave Jones
If the chip locks up, we get into a long polling loop, where the softlockup detector kicks in. See https://bugzilla.redhat.com/bugzilla/attachment.cgi?id=151878 for an example. [adaplas] Chip lockup can occur at 3 points (flush, sync, and wait). Consolidate and allow the driver to go to safe mode cleanly. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb/rivafb: switch to pci_get refcountingAlan Cox
Switch to pci_get refcounting APIs [adaplas] Fix a long-standing bug where the return value of pci_find_slot()/pci_get_bus_and_slot() is ignored. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: fix sparse warningAntonino A. Daplas
Fix the following sparse warning: drivers/video/nvidia/nv_setup.c:659:20: warning: dereference of noderef expression Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: VGA state save and restoreAntonino A. Daplas
Allow the saving and restoration of VGA text mode. The state is saved on the first open and restored on the last close. Because of the non-linear mapping of the VGA registers to the MMIO space, this will be done only on X86 platforms where the device is the primary display. An echo 0 > /sys/class/vtconsole/vtcon1/bind will convert the display from graphics to text mode. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: access CRT registers safelyAntonino A. Daplas
Use Read/WriteCrtc() to access CRTC registers in nv_i2c.c. These are safer because it uses the correct CRTC base (0x3bx or 0x3dx). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: ensure that CRTC registers are accessibleAntonino A. Daplas
- Ensure that CRTC registers are accessible by unlocking them on set_par(), otherwise i2c reading will fail. - The function nvidia_vga_protect(), does not protect the VGA registers, but turns off the screen. Rename it to nvidia_screen_off(). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rivafb/nvidiafb: Various cleanupsJean Delvare
Various cleanups to rivafb/nvidiafb's I2C code: * Drop useless par->bus. * Refactor I2C bus deletion code. * Drop useless variable initialization. * Remove unneeded include of <linux/i2c-id.h>. * Simplify +1/-1. * Add __devinit tags where possible. [adaplas] The varible initialization are not useless. However, rivafb must check if i2c bus are created properly before reading the EDID block. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rivafb/nvidiafb: Enable hardware monitoringJean Delvare
Let the hardware monitoring drivers probe the second rivafb/nvidiafb I2C bus for devices. Signed-off-by: Jean Delvare <khali@linux-fr> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: Fix reversed DDC portPetr Vandrovec
After I added some debugging printks I've found that code became a bit confused because it believed that primary monitor is 1920x540, but later it found in CRTC0's registers that panel size is 1920x1200 (Windows also agree that 1920x1200 is primary monitor, and 1920x1080i secondary one). When I applied attached patch then my monitor became as happy as it was before I connected HDMI cable to secondary output. Signed-off-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08nvidiafb: bring back generic ddc readingAntonino A. Daplas
Make nvidiafb use fb_ddc_read(). This patch was submitted before but was reverted due to problems in a non-x86 platform. This includes a fix for that where ddc reading is bypassed if there is no DDC bus (duh). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
These are all the remaining instances of get_property. Simple rename of get_property to of_get_property. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-06[PATCH] nvidiafb backlight: Fix implicit declaration in nv_backlightDave Jones
drivers/video/nvidia/nv_backlight.c: In function 'nvidia_bl_init': drivers/video/nvidia/nv_backlight.c:103: error: implicit declaration of function 'pmac_has_backlight_type' Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05backlight: Allow enable/disable of fb backlights, fixing regressionsRichard Purdie
Enabling the backlight by default appears to cause problems for many users. This patch disables backlight controls unless explicitly enabled by users via a module parameter. Since PMAC users are known to work, default to enabled in that case. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-03-05backlight: Fix nvidia backlight initial brightnessRichard Purdie
Fix a mix up when the nvidia driver was converted resulting in the backlight having an incorrect initial brightness. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Separate backlight properties from backlight ops pointersRichard Purdie
Per device data such as brightness belongs to the indivdual device and should therefore be separate from the the backlight operation function pointers. This patch splits the two types of data and allows simplifcation of some code. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Clean up pmac_backlight handlingRichard Purdie
Move the setting/unsetting of pmac_backlight into the backlight core instead of doing it in each driver. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Rework backlight/fb interaction simplifying, lotsRichard Purdie
fb_info->bl_mutex is badly thought out and the backlight class doesn't need it if the framebuffer/backlight register/unregister order is consistent, particularly after the backlight locking fixes. Fix the drivers to use the order: backlight_device_register() register_framebuffer() unregister_framebuffer() backlight_device_unregister() and turn bl_mutex into a lock for the bl_curve data only. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Remove uneeded nvidia set_power callsRichard Purdie
nvidia_bl_set_power isn't needed since the backlight class handles this by receiving fb events itself and calling update_status so remove it. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Fix external uses of backlight internal semaphoreRichard Purdie
backlight_device->sem has a very specific use as documented in the header file. The external users of this are using it for a different reason, to serialise access to the update_status() method. backlight users were supposed to implement their own internal serialisation of update_status() if needed but everyone is doing things differently and incorrectly. Therefore add a global mutex to take care of serialisation for everyone, once and for all. Locking for get_brightness remains optional since most users don't need it. Also update the lcd class in a similar way. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Remove unneeded owner fieldRichard Purdie
Remove uneeded owner field from backlight_properties structure. Nothing uses it and it is unlikely that it will ever be used. The backlight class uses other means to ensure that nothing references unloaded code. Based on a patch from Dmitry Torokhov <dtor@insightbb.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-12[PATCH] fbdev modedb: make more pointer parameters constGeert Uytterhoeven
fbdev modedb: make more input and output pointer parameters const Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] change nvidiafb_remove to __devexitPrarit Bhargava
Change nvidiafb_remove to __devexit to fix MODPOST warnings: WARNING: drivers/video/nvidia/nvidiafb.o - Section mismatch: reference to .exit.text:nvidiafb_remove from .data.rel.local after 'nvidiafb_driver' (at offset 0x28) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Acked-By: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] Video: fb, kzalloc changesJiri Slaby
Use kzalloc instead of kmalloc + memset(0). Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-20Pull platform-drivers into test branchLen Brown
2006-12-20fbdev: update after backlight argument changeJames Simmons
Update the frambuffer drivers to the backlight_device_registers changes. Signed-off-by: James Simmons <jsimmons@infradead.org> Cc: Luming Yu <Luming.yu@intel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-10i2c: Discard the i2c algo del_bus wrappersJean Delvare
They are all only calling i2c_del_adapter, so we may as well do it directly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
