path: root/drivers/video/omap2/Makefile
2011-05-11OMAP2: avoid descending into disabled framebuffer dirsMike Frysinger
Rather than always add the omap2 dirs to the build list (and thus force everyone to generate a useless built-in.o), bind the dirs to their relevant kconfig symbol. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2009-12-09OMAP: DSS2: Add generic and Sharp panel driversTomi Valkeinen
Add Generic panel (user for DVI output) and Sharp LS037V7DW01 LCD panel. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2009-12-09OMAP: DSS2: omapfb driverTomi Valkeinen
2009-12-09OMAP: DSS2: Display Subsystem Driver coreTomi Valkeinen
The core files of DSS2. DSS2 commits are split a bit artificially to make the individual commits smaller, and DSS2 doesn't compile properly without the rest of the core commits. This shouldn't be a problem, as no configuration uses DSS2 yet. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2009-12-09OMAP: Add support for VRFB rotation engineTomi Valkeinen
VRFB rotation engine is a block in OMAP2/3 that offers 12 independent contexts that can be used for framebuffer rotation. Each context has a backend area of real memory, where it stores the pixels in undisclosed format. This memory is offered to users via 4 virtual memory areas, which see the same memory area in different rotation angles (0, 90, 180 and 270 degrees). Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
2009-12-09OMAP: Add VRAM managerTomi Valkeinen
Add a Video RAM manager for OMAP 2 and 3 platforms. VRAM manager is used to allocate large continuous blocks of SDRAM or SRAM. The features VRAM manager has that are missing from dma_alloc_* functions are: - Support for OMAP2's SRAM - Allocate without ioremapping - Allocate at defined physical addresses - Allows larger VRAM area and larger allocations The upcoming DSS2 uses VRAM manager. VRAM area size can be defined in kernel config, board file or with kernel boot parameters. Board file definition overrides kernel config, and boot parameter overrides kernel config and board file. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@nokia.com>
