path: root/drivers/video/pnx4008
2008-05-13drivers/video/pnx4008: eliminate double freeJulia Lawall
The function framebuffer_release just calls kfree, so calling kfree subsequently on the same argument represents a double free. The comments with the definition of framebuffer_release in drivers/video/fbsysfs.c suggest that a more elaborate definition of this function is planned, such that the splitting up of framebuffer_release and kfree as done in the second instance might someday make sense, but it does not make sense now. This was found using the following semantic match. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; @@ * kfree(E); ... * framebuffer_release(E); @@ expression E; @@ * framebuffer_release(E); ... * kfree(E); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Grigory Tolstolytkin <gtolstolytkin@ru.mvista.com> Cc: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19define global BIT macroJiri Slaby
define global BIT macro move all local BIT defines to the new globally define macro. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-16[PATCH] pnx4008:fix NULL dereference in rgbfbVitaly Wool
Fix possible NULL dereference in pnxrgbfb. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-16[PATCH] pnx4008: rename driverVitaly Wool
Make the drivers' names less generic to avoid possible confusion in future, as was requested by Russell King. Signed-off-by: Vitaly Wool <vwool@ru.mvista.com> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] fbdev: Add framebuffer and display update module support for pnx4008Vitaly Wool
Add support for Display Update Module and RGB framebuffer device on Philips PNX4008 ARM board. Signed-off-by: Grigory Tolstolytkin <gtolstolytkin@ru.mvista.com> Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
