These interfaces:
pcibios_resource_to_bus(struct pci_dev *dev, *bus_region, *resource)
pcibios_bus_to_resource(struct pci_dev *dev, *resource, *bus_region)
took a pci_dev, but they really depend only on the pci_bus. And we want to
use them in resource allocation paths where we have the bus but not a
device, so this patch converts them to take the pci_bus instead of the
pci_dev:
pcibios_resource_to_bus(struct pci_bus *bus, *bus_region, *resource)
pcibios_bus_to_resource(struct pci_bus *bus, *resource, *bus_region)
In fact, with standard PCI-PCI bridges, they only depend on the host
bridge, because that's the only place address translation occurs, but
we aren't going that far yet.
[bhelgaas: changelog]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux
Pull fbdev changes from Tomi Valkeinen:
"Nothing particularly stands out in this pull request. The biggest
part of the changes are cleanups.
Maybe one fix to mention is the "fb: reorder the lock sequence to fix
potential dead lock" which hopefully fixes the fb locking issues
reported by multiple persons.
There are also a few commits that have changes to arch/arm/mach-at91
and arch/avr32, which have been acked by the maintainers"
* tag 'fbdev-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (143 commits)
fb: reorder the lock sequence to fix potential dead lock
fbdev: shmobile-lcdcfb: Convert to clk_prepare/unprepare
fbdev: shmobile-hdmi: Convert to clk_prepare/unprepare
omapdss: Add new panel driver for Topolly td028ttec1 LCD.
video: exynos_mipi_dsi: Unlock the mutex before returning
video: da8xx-fb: remove unwanted define
video: Remove unnecessary semicolons
simplefb: use write-combined remapping
simplefb: fix unmapping fb during destruction
OMAPDSS: connector-dvi: fix releasing i2c_adapter
OMAPDSS: DSI: fix perf measuring ifdefs
framebuffer: Use fb_<level>
framebuffer: Add fb_<level> convenience logging macros
efifb: prevent null-deref when iterating dmi_list
fbdev: fix error return code in metronomefb_probe()
video: xilinxfb: Fix for "Use standard variable name convention"
OMAPDSS: Fix de_level in videomode_to_omap_video_timings()
video: xilinxfb: Simplify error path
video: xilinxfb: Use devm_kzalloc instead of kzalloc
video: xilinxfb: Use standard variable name convention
Neaten and shorten the code using the new fb_<level> macros.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Fix to return -EINVAL when virtual vertical size smaller than real
instead of 0, as done elsewhere in this function. Also remove dup code.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Add support for Virge/MX (86C260) chip. Although this is a laptop chip,
there's an AGP card with this chip too.
Tested with AGP card, will probably not work correctly with laptops.
DDC does not work on this card (even in DOS or Windows).
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Add memory size detection for Virge/VX and small delay in mode setting (same
as in X.org driver) to fix blank screen problem.
Also adjust DTPC position to fix garbled screen in some modes (tested that
this adjustment does not break other cards - at least Trio32, Trio64V+,
Trio64V2/DX, Virge, Virge/DX).
Tested on ELSA Winner 2000AVI/3D.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
We must not use any information in the passed var besides xoffset,
yoffset and vmode as otherwise applications might abuse it.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Ondrej Zary <linux@rainbow-software.org>
drivers/video/s3fb.c: In function 's3_pci_remove':
drivers/video/s3fb.c:1388: error: 'par' undeclared (first use in this function)
Add I2C support for the DDC bus and also default mode initialization by
reading monitor EDID to the s3fb driver.
Tested on Trio64V+ (2 cards), Trio64V2/DX, Virge (3 cards),
Virge/DX (3 cards), Virge/GX2, Trio3D/2X (4 cards), Trio3D.
Will probably not work on Trio32 - my 2 cards have DDC support in BIOS that
looks different from the other cards but the DDC pins on the VGA connector
are not connected.
Fix Virge/GX2 support in s3fb:
- fix IDs: 86C357 is GX2, 86C359 is GX2+, 86C356 probably does not exist
- add memory size detection
- drive it the same way as Trio3D/2X
The original IDs most likely came from S3 website which claims that:
- 356 is Virge/GX2 with ID=8A10, driver included in Windows 2K, XP
- 357 is Virge/GX2+ with ID=8A11, driver included in Windows ME
- 359 is Virge/GX2+ with ID=8A12, driver included in Windows ME
but:
- google search for 86C356 only reveals references to Trio3D (probably
because of a typo - Trio3D is 86C365)
- my card is clearly marked as 86C357, Virge/GX2 and has ID=8A10
- there is no driver for IDs 8A11 and 8A12 in Windows ME
- there is a driver for ID 8A10 in Windows ME that says it's GX2 (357)
Tested with #9 Reality 334 (86C357 Virge/GX2, ID=0x8A10).
Use "new" start address register 0x69 (bits 16-20) instead of "old" 0x31
(bits 16-17) and 0x51 (bits 18-19). This is needed for panning to work
correctly on Trio3D/2X cards (and does no harm on other ones).
Acked-by: Ondrej Zajicek <santiago@crfreenet.org>
Enable Data Transfer Position Control (DTPC). This is needed at least on
Virge/DX to correctly display at higher pixclocks.
Enable pixel multiplexing in 15/16bpp modes when pixclock is over 115MHz
on Trio3D (86C365) cards to fix artifacts on the left side of screen.
Add support for S3 Trio3D (86C365) cards to s3fb driver. Tested with one 4MB card.
Maximize virtual vertical framebuffer size during init to allow fast scrolling
(accelerated by panning).
This allows the driver to work in multi-domain PCI
configurations.
Instead of just plain NULL.
And use vga_{r,w}().
The -rt patches change the console_semaphore to console_mutex. As a
result, a quite large chunk of the patches changes all
acquire/release_console_sem() to acquire/release_console_mutex()
This commit makes things use more neutral function names which dont make
implications about the underlying lock.
The only real change is the return value of console_trylock which is
inverted from try_acquire_console_sem()
This patch also paves the way to switching console_sem from a semaphore to
a mutex.
[akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: Thomas Gleixner <tglx@tglx.de>
Cc: Greg KH <gregkh@suse.de>
Add support for S3 Trio3D/1X (86C360) and S3 Trio3D/2X (86C362 and 86C368)
cards to s3fb driver. Tested with 86C362 AGP and 86C368 PCI&AGP.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
s3fb incorrectly sets the length of the color fields to 6 bits for
PSEUDOCOLOR modes, even though 8 or 4 bits are used per pixel. Fix this
by setting the length to 8 or 4, respectively.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
commit 20e061fb750d36ec0ffcb2e44ed7dafa9018223b
Author: Ondrej Zajicek <santiago@crfreenet.org>
Date: Mon Apr 28 02:15:18 2008 -0700
fbdev: framebuffer_alloc() fixes
Correct the dev arg of framebuffer_alloc() in arkfb, s3fb and vt8623fb.
causes a null-pointer deref because "info->dev is NULL, info was just
kzallocated".
Signed-off-by: Ondrej Zajicek <santiago@crfreenet.org>
Reported-by: "MadLoisae@gmx.net" <MadLoisae@gmx.net>
Tested-by: "MadLoisae@gmx.net" <MadLoisae@gmx.net>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: <stable@kernel.org> [2.6.26.x]
Add the option "mode_option". It also moves mtrr variable to devinitdata
section.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
This patch adds check if selected pixclock is valid (is in the PLL range).
Previously, if the pixclock could not be set, the new mode resolution was set
but pixclock was not set which led to incorrect timings sent to monitor.
[adaplas]
Fixed a few misplaced curly braces.
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
This patch changes mode selection matching algorithm. It allows to choose
mode with matching depth even when requested color lengths are greater than
color lengths of every mode with requested color depth.
It also fixes bug in s3fb - wrong error value returned when format is not
supported by chip.
Move fb_get_caps() method to svgalib.c as svga_get_caps() so it can be used by
s3fb, arkfb and vt8623fb.
Move s3fb_get_tilemax to svgalib.c as svga_get_tilemax, because it reports
limitation of other code from svgalib (svga_settile, svga_tilecopy, ...)
Limit font width to 8 pixels in 4 bpp mode.
Implement fb_get_caps(). This will allow the driver to tell upper layer that
it can only support 256 8x16 bitmaps when in tileblitting mode
(var->bits_per_pixel == 0);
This fixes broken fbcon on Virge VX in 24 bpp mode, and contains several
other small updates.
Implement fb_get_tilemax(). It just returns 256.
If tileblitting is enabled (text mode), the hardware can only accept 8x16
bitmaps. Advertise this to the upper layer. And to ensure that an appropriate
font is always available, select an 8x16 font in Kconfig.
Add sparse annotations and use fb_read/fb_write and family to access the
framebuffer.
drivers/video/s3fb.c:1078: warning: ignoring return value of 'pci_enable_device', declared with attribute warn_unused_result
