path: root/drivers/video/savage
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27savagefb: fix DDC for Savage 4Ondrej Zary
I tested savagefb on 3 different Savage 4 cards: Diamond Stealth III S520 Number Nine SR9 Datapath Horizon 2S (two savage chips on a PCI card) it worked except the DDC which did not work on any of them. Looking at the BIOS code, it does not use MMIO register 0xff20 but CRT register 0xa0 or 0xb1 - depending on the chip revision and something in register 0xa6. With this patch, DDC works fine on all 3 cards (even on the second head of Horizon 2S - although it does not display anything as it's misconfigured because of missing BIOS). Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24i2c: Remove unneeded inclusions of <linux/i2c-id.h>Jean Delvare
These drivers don't use anything which is defined in <linux/i2c-id.h>. This header file was never meant to be included directly anyway, and will be deleted soon. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Dooks <ben-linux@fluff.org> Acked-by: Dave Airlie <airlied@linux.ie> Cc: Hans Verkuil <hverkuil@xs4all.nl>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-12savagefb: fix blanking mode on CRT displayKrzysztof Helt
Fix wrong bit mask for blanking register. Due to the error a CRT monitor blanks off due to wrong frequency (out of range) instead of PM signal (vertical and horizontal frequencies cut off). Just compare the mask with bits set in the switch(blank) clause below the changed line. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12fb: remove fb_save_state() and fb_restore_state operationsKrzysztof Helt
Remove fb_save_state() and fb_restore_state operations from frame buffer layer. They are used only in two drivers: 1. savagefb - and cause bug #11248 2. uvesafb Usage of these operations is misunderstood in both drivers so kill these operations, fix the bug #11248 and avoid confusion in the future. Tested on Savage 3D/MV card and the patch fixes the bug #11248. The frame buffer layer uses these funtions during switch between graphics and text mode of the console, but these drivers saves state before switching of the frame buffer (in the fb_open) and after releasing it (in the fb_release). This defeats the purpose of these operations. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reported-by: Jochen Hein <jochen@jochen.org> Tested-by: Jochen Hein <jochen@jochen.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Januszewski <spock@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-26i2c: Delete many unused adapter IDsJean Delvare
2008-04-28savagefb: speed up the I2C busJean Delvare
There is no reason to drive the savagefb I2C bus at such a low speed, so bump it from 12.5 kbps to 50 kbps. The Intel (i810) and Matrox framebuffer drivers already run their I2C bus at this speed, and so are the legacy i2c-savage4 and i2c-prosavage drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08savagefb: VGA state save and restoreAntonino A. Daplas
Allow the saving and restoration of VGA text mode. The state is saved on the first open and restored on the last close. Because of the VGA registers are linearly mapped to the MMIO space, MMIO access is used which is not limited to X86 platforms nor to the primary display device. An echo 0 > /sys/class/vtconsole/vtcon1/bind will convert the display from graphics to text mode. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08savagefb: rework i2c bit accessAntonino A. Daplas
Use already defined VGAwCR/VGArCR functions to access the i2c bus. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] savagefb: Fix compile error if debugging is enabledAntonino A. Daplas
SavagePrintRegs() requires struct savagefb_par. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] savagefb: Fix black screen on load in Savage IXAntonino A. Daplas
This is a hack that seems to kick start the 2D engine of the Savage IX in some Toshiba laptops. Without this, the laptop starts with a black screen and occasionally crashes X. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] fbdev modedb: make more pointer parameters constGeert Uytterhoeven
fbdev modedb: make more input and output pointer parameters const Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10i2c: Discard the i2c algo del_bus wrappersJean Delvare
They are all only calling i2c_del_adapter, so we may as well do it directly. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2006-12-08[PATCH] drivers/video/*: use kmemdup()Alexey Dobriyan
From: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] savagefb: Use generic DDC readingAntonino A. Daplas
Update driver to use generic DDC reading [khali@linux-fr.org: fix oops in i2c handling] Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jurriaan <thunder7@xs4all.nl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26i2c-algo-bit: Discard the mdelay data struct memberJean Delvare
i2c-algo-bit: Discard the mdelay data struct member The i2c_algo_bit_data structure has an mdelay member, which is not used by the algorithm code (the code has always been ifdef'd out.) Let's discard it to save some code and memory. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25PM: video drivers and PM_EVENT_PRETHAWDavid Brownell
Video drivers which explicitly test for messages reporting PM_EVENT_FREEZE will now handle PM_EVENT_PRETHAW the same way. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] savagefb: Whitespace cleanupAntonino A. Daplas
Whitespace cleanup Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] savagefb: Add state save and_restore hooksAntonino A. Daplas
Reported by: Rich (Bugzilla Bug 6417) "if savage driver is used in x.org together with savagefb, it results in seriously garbled and distorted screen - coupled with severe slowdowns." This bug is the result of Xorg unable to handle savagefb altering the hardware which results in X failing to start properly and/or failed console switching. Add savagefb_state_save and savagefb_state_restore. These hooks will only save and restore the extended VGA registers. Standard VGA registers will be left alone. This is enough to make savagefb play nicely with the latest Xorg savage driver, and perhaps with savage DRI. (Transient screen artifacts may appear before X loads and during console switches). (Unfortunately, blanking the screen also leaves Xorg in a blanked state, so I have to unblank the screen before Xorg loads. So I doubt if the transient screen artifacts will be completely invisible but hopefully it will only be for a shorter duration (not much).) [akpm@osdl.org: cleanups] Signed-off-by: Antonino Daplas <adaplas@pol.net> Cc: <rich@hq.vsaa.lv> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] savagefb: Allocate space for current and saved register statesAntonino A. Daplas
Allocate space for 2 register states: 'current' for the current state of the hardware, and 'saved', to be used for restoring the hardware to a sane state. This is in preparation for the addition of state save and restore hooks to make savagefb work together with the latest Xorg savage driver. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] savagefb: fix section mismatch warningsRandy Dunlap
Fix modpost section mismatch warnings in savagefb driver: WARNING: drivers/video/savage/savagefb.o - Section mismatch: reference to .init.text: from .exit.text after 'savagefb_remove' (at offset 0x66) WARNING: drivers/video/savage/savagefb.o - Section mismatch: reference to .init.text: from .exit.text after 'savagefb_remove' (at offset 0x6e) WARNING: drivers/video/savage/savagefb.o - Section mismatch: reference to .init.text: from .text.savagefb_resume after 'savagefb_resume' (at offset 0x70) Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] fb: Fix section mismatch in savagefbJean Delvare
Fix the following section mismatch: WARNING: drivers/video/savage/savagefb.o - Section mismatch: reference to .init.data: from .text.savagefb_probe after 'savagefb_probe' (at offset 0x5e2) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] savagefb: Remove NULL checkAntonino A. Daplas
Remove unnecessary NULL check. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-11[PATCH] savagefb: Fix kfree before useAntonino A. Daplas
par->edid is kfree'd before using in fb_edid_to_monspecs() Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] savagefb: Trim savagefb_pan_displayAntonino A. Daplas
Remove error checking and updating from savagefb_pan_display. This is guaranteed to be done by the core layer. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] fbdev: savagefb: Driver cleanupAntonino A. Daplas
- remove redundant casts - remove symbol_get/symbol_put Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] savagefb: One more I2C-enabled device in savagefbJean Delvare
The I2C bus of the S3 Savage2000 is supposed to work the same way the Savage4 does. At least, the legacy i2c-savage4 driver handled both devices the same way. I do not have the hardware to test this, so testers are welcome. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] savagefb: X-panning fixesAntonino A. Daplas
The driver unconditionally sets xpanstep to 2. However, a value of 4 empirically works better at bpp = 8, and 2 for 16 and 32. This buglet was exposed by the rotation code. Second fix is the unconditional call to update_start() without verifying if the offsets are correct. Remove this call, it's not necessary and secondly, it causes a crash with invalid values. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbdev: Convert a few drivers to use the fb_find_best_display helperAntonino A. Daplas
Convert i810fb, nvidiafb and savagefb to use the fb_find_best_display helper when searching for the initial video mode. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] savagefb: Convert from VGA IO access to MMIO accessAntonino A. Daplas
Use MMIO registers instead of banging the VGA IO registers. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-15[PATCH] savagefb: Fix load failure of the Twister chipsetAntonino A. Daplas
- The Twister chipsets are actually prosavages. Reclassify them as such and remove the S3_SAVAGE_TWISTER id. - Fix i2c code if fb_firmware_edid() returns NULL Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] savagefb: Make mode_option available when compiled as a moduleAntonino A. Daplas
Make "mode_option" available when compiled as a module. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] better error handing in savagefb_probeOlaf Hering
err remains uninitialized of pci_request_regions fails. Found by Thorsten Kukuk, I added a few more checks. Signed-off-by: Olaf Hering <olh@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] savagefb: Driver updatesAntonino A. Daplas
- Fallback to firmware EDID if chipset has no DDC/I2C support or if I2C probing failed - Add fb_blank hook - Fix savagefb_suspend/resume to enable driver to successfully suspend and resume from S3, memory or disk Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] I2C: Kill i2c_algorithm.id (6/7)Jean Delvare
In theory, there should be no more users of I2C_ALGO_* at this point. However, it happens that several drivers were using I2C_ALGO_* for adapter ids, so we need to correct these before we can get rid of all the I2C_ALGO_* definitions. Note that this also fixes a bug in media/video/tvaudio.c: /* don't attach on saa7146 based cards, because dedicated drivers are used */ if ((adap->id & I2C_ALGO_SAA7146)) return 0; This test was plain broken, as it would succeed for many more adapters than just the saa7146: any those id would share at least one bit with the saa7146 id. We are really lucky that the few other adapters we want this driver to work with did not fulfill that condition. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] swsusp: fix remaining u32 vs. pm_message_t confusionPavel Machek
Fix remaining bits of u32 vs. pm_message confusion. Should not break anything. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] pm: more u32 vs. pm_message_t fixesPavel Machek
Few more u32 vs. pm_message_t fixes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] fbdev: fill in the access_align field.James Simmons
Several drivers miss filling in the access_align field. So this patch has them fill it in. Signed-off-by: James Simmons <jsimmons@www.infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-26[PATCH] savagefb iomem annotationsAl Viro
trivial iomem annotations + memset() replaced with memset_io() in a place that deals with ioremapped area. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix u32 vs. pm_message_t in driver/videoPavel Machek
This fixes u32 vs. pm_message_t confusion in drivers/video. Should change no code. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
