path: root/drivers/video/sh_mobile_lcdcfb.c
2011-06-02fbdev: sh_mobile_lcdcfb: Fix up fallout from MERAM changes.Paul Mundt
The LCDC driver does no longer compile: CC drivers/video/sh_mobile_meram.o CC drivers/video/sh_mobile_lcdcfb.o drivers/video/sh_mobile_lcdcfb.c: In function 'sh_mobile_lcdc_start': drivers/video/sh_mobile_lcdcfb.c:640:4: error: 'ret' undeclared (first use in this function) drivers/video/sh_mobile_lcdcfb.c:640:4: note: each undeclared identifier is reported only once for each function it appears in make[2]: *** [drivers/video/sh_mobile_lcdcfb.o] Error 1 make[1]: *** [drivers/video] Error 2 make: *** [drivers] Error 2 Reported-by: Magnus Damm <magnus.damm@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-25Merge branch 'common/fbdev-meram' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
2011-05-25sh_mobile_meram: Safely disable MERAM operation when not initializedDamian
If the MERAM platform data is defined, but the MERAM has not been properly initaliazed we need to safely fall back to non-MERAM operation. Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-24Merge branches 'common/fbdev' and 'common/fbdev-meram' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6
2011-05-24fbdev: sh_mobile_lcdc: remove runtime PM calls from the notifierGuennadi Liakhovetski
The notifier function calls sh_mobile_lcdc_stop() and sh_mobile_lcdc_start(), which already take care about the runtime PM state. Remove redundant calls. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-24fbdev: sh_mobile_lcdc: reduce scope of a variableGuennadi Liakhovetski
The "ret" variable in sh_mobile_lcdc_start() is only used at one location, move its definition to the inner-most scope. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23sh_mobile_meram: Add support for NV24 framebuffersDamian
Since the NV24 framebuffer has a CbCr plane that is twice as wide as the Y plane, it needs to be handled as a special case. Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-05-23sh_mobile_meram: MERAM framework for LCDCDamian
Based on the patch by Takanari Hayama <taki@igel.co.jp> Adds support framework necessary to use Media RAM (MERAM) caching functionality with the LCDC. The MERAM is accessed through up to 4 Interconnect Buffers (ICBs). ICB numbers and MERAM address ranges to use are specified in by filling in the .meram_cfg member of the LCDC platform data Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-29Merge branch 'common/fbdev' of ↵Paul Mundt
2011-03-29fbdev: sh_mobile_lcdcfb: fix module lock acquisitionAlexandre Courbot
Whenever the LCDC is to be started or stopped, a board callback is checked for existence and invoked. Prior to the invokation, the callback's module lock is also acquired, to be released once the callback returns. However, the order of testing makes it possible for the lock to be acquired and not released in case the callback does not exist. This patch reorders the tests to prevent this particular case. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-29fbdev: sh_mobile_lcdcfb: add blanking supportAlexandre Courbot
Add a blanking callback to the LCDC driver in order to support both FBIOBLANK and TIOCLINUX blanking ioctls. LCDC clocks are also released if the requested blanking level is superior to FB_BLANK_NORMAL, to allow runtime PM to disable the clocks if possible. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22fbdev: sh_mobile_lcdc: checking NULL instead of IS_ERR()Dan Carpenter
backlight_device_register() returns an ERR_PTR. It doesn't return NULL. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-16fbdev: sh_mobile_lcdc: Add YUV framebuffer supportDamian Hobson-Garcia
Supports YCbCr420sp, YCbCr422sp, and YCbCr44sp, formats (bpp = 12, 16, and 24) respectively. When double-buffering both Y planes appear before the C planes (Y-Y-C-C), as opposed to Y-C-Y-C. Set .nonstd in struct sh_mobile_lcdc_chan_cfg to enable YUV mode, and use .bpp to distiguish between the 3 modes. The value of .nonstd is copied to bits 16-31 of LDDFR in the LCDC and should be set accordingly. .nonstd must be set to 0 for RGB mode. Due to the encoding of YUV data, the framebuffer will clear to green instead of black. In YUV 420 mode, panning is only possible in 2 line increments. Additionally in YUV 420 mode the vertical resolution of the framebuffer must be an even number. Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-10fbdev: sh_mobile_lcdcfb: add backlight supportAlexandre Courbot
Support for backlight devices controlled through board-specific routines. Backlights can be defined per-channel and follow fbdev directives to switch off as the LCD blanks or is turned on/off. Signed-off-by: Alexandre Courbot <gnurou@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-26console: rename acquire/release_console_sem() to console_lock/unlock()Torben Hohn
The -rt patches change the console_semaphore to console_mutex. As a result, a quite large chunk of the patches changes all acquire/release_console_sem() to acquire/release_console_mutex() This commit makes things use more neutral function names which dont make implications about the underlying lock. The only real change is the return value of console_trylock which is inverted from try_acquire_console_sem() This patch also paves the way to switching console_sem from a semaphore to a mutex. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make console_trylock return 1 on success, per Geert] Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Thomas Gleixner <tglx@tglx.de> Cc: Greg KH <gregkh@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-06Merge branch 'master' of ↵Paul Mundt
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/video/sh_mobile_lcdcfb.c Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-01-06fbdev: sh_mobile_lcdcfb: Enable 32 bpp and 24 bpp supportMagnus Damm
This patch extends the LCDC driver with 24 bpp and 32 bpp support. These modes have been kept disabled earlier due to dependencies between the potential two LCDC channels that are exported as two separate framebuffer devices. The dependency boils down to a byte swap register that is shared between multiple channels. With this patch applied all single channel LCDC hardware can chose freely from 16, 24 and 32 bpp. Dual channel LCDC must stick to the same setup for both channels. Without this patch only 16 bpp is fully supported. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-27fbdev: sh_mobile_lcdc: increase maximum framebuffer size to support 1080pGuennadi Liakhovetski
LCDC hardware can support 1920x1080 formats, adjust the driver to cover them. Besides, instead of guessing some "reasonable" validity checks, only verify values in .fb_check_var(), that we are sure, we cannot support. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22fbdev: sh-mobile: restore display size configurationGuennadi Liakhovetski
An earlier patch replaced open-coded video-mode configuration from platform data by a call to fb_videomode_to_var(), thereby setting ofdisplay sizes have been accidentally lost. Restore them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-22Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-11-16fbdev: sh_mobile_lcdcfb: fix bug in reconfig()Arnd Hannemann
The function sh_mobile_fb_reconfig() contained a bug, which caused the line_length to be set wrongly, if a mode with a different X-resolution than the default one was chosen. This caused 1080p24 mode to not work on AP4EVB. Additionally the notifier chain was also called with the wrong mode. This patch fixes this, by using the X-resolution of the new mode instead of the old one to calculate line length and hands over the correct mode to the notifier chain. Signed-off-by: Arnd Hannemann <arnd@arndnet.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-10fbdev: sh_mobile_lcdcfb: fix up compiler warnings.Paul Mundt
CC drivers/video/sh_mobile_lcdcfb.o drivers/video/sh_mobile_lcdcfb.c: In function 'sh_mobile_check_var': drivers/video/sh_mobile_lcdcfb.c:922: warning: format '%u' expects type 'unsigned int', but argument 11 has type 'long unsigned int' Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-10fbdev: sh_mobile_lcdc: increase maximum framebuffer size to support 1080pGuennadi Liakhovetski
2010-11-10fbdev: sh_mobile_lcdc: use correct number of modes, when using the defaultGuennadi Liakhovetski
Fix zero mode number, when using the default 720p mode. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-10fbdev: sh_mobile_lcdc: use the standard CEA-861 720p timingGuennadi Liakhovetski
sh_mobile_lcdcfb.c has a hard-coded 720p video mode, used as default, if none is explicitly specified by the platform. Adjust its timing to match the CEA standard. Also add an explicit refresh rate value, which is needed, when used with HDMI, to be able to recognise the default 720p mode as a pre-programmed VIC #4. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/genesis-2.6 into ↵Russell King
devel-stable Conflicts: drivers/video/sh_mobile_hdmi.c
2010-10-15fbdev: sh_mobile_lcdc: relax .check_var() HSYNC testGuennadi Liakhovetski
Some valid and supported video modes have .hsync_len > 120. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-15fbdev: sh_mobile_lcdc: make platform videomode table optionalGuennadi Liakhovetski
Add a default 720p mode to the sh_mobile_lcdc driver to be used, when no videomode is specified in the platform data. This can be used, e.g., with HDMI. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-13sh: free-without-alloc fix for sh_mobile_lcdcfbMagnus Damm
Without this fix the LCDC driver will try to free framebuffer memory even though the allocation failed. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-16fbdev: sh_mobile_lcdc: reconfigure the framebuffer, when freeGuennadi Liakhovetski
Currently the sh_mobile_lcdc driver only reconfigures the hardware interface, when a new monitor is plugged in. This patch adds support for dynamic framebuffer reconfiguration, when no user is holding the framebuffer device node open. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_hdmi: support hot-plugging of different HDMI / DVI displaysGuennadi Liakhovetski
With this patch hot-plugging of an HDMI or a DVI monitor can select a different video mode and reconfigure the LCDC and HDMI controllers accordingly. Due to a lack of a standard API to inform framebuffer users of a changed video mode, the framebuffer configuration is preserved regardless of a specific mode, selected for the monitor. As described in a previous patch, this leads to smaller framebuffers being displayed on larger monitors or a part of a larger framebuffer being displayed on a smaller resolution monitor. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: separate display variable data from framebuffer dataGuennadi Liakhovetski
This is a preparation for a patch, that shall allow displaying of a smaller framebuffer on a bigger display and of a part of a bigger framebuffer on a smaller display. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_hdmi: implement lockingGuennadi Liakhovetski
The SH-Mobile HDMI driver runs in several contexts: ISR, delayed work-queue, task context, when called from the sh_mobile_lcdc framebuffer driver. This creates ample race possibilities. Even though most these races are purely theoretical, it is better to close them. To trace fb_info validity we install a notification callback in the HDMI driver, and the only way for it to get to driver internal data is by using struct sh_mobile_lcdc_chan, therefore it had to be extracted into a separate common header. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: allocate memory, sufficient for the biggest modeGuennadi Liakhovetski
Now, that we add support for multiple modes to the sh_mobile_lcdcfb driver, it has to allocate memory, sufficient for the biggest of them. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: fix notifier callback return codesGuennadi Liakhovetski
Notifier callbacks have to return either one of NOTIFY_* codes or a negative errno, converted to a suitable value by the notifier_from_errno() inline, if the notifier chain shall not be continued. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: Support multiple video modes in platform dataGuennadi Liakhovetski
This is a preparation for HDMI hotplug support. This patch just moves all platform defined video modes for the sh_mobile_lcdcfb driver to separate arrays and switches all users to use element 0 of that array, so, this patch doesn't introduce any functional changes and as such should not cause any regressions. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: minor simplifications and clean upGuennadi Liakhovetski
Remove an unused variable and simplify several pointer dereferences. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: fix more error pathsGuennadi Liakhovetski
This patch fixes the following two erroneous error paths: hw_usecnt is allocated with a value of 0, therefore in an early error case, calling sh_mobile_lcdc_clk_off() will wrongly conclude, that hw_usecnt has already been incremented. Then sh_mobile_lcdc_runtime_suspend() will be called, which will access uninitialised data fields and crash the kernel. sh_mobile_lcdc_stop() can be called before framebuffer has been allocated, then ch->info is NULL and dereferencing it will Oops too. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-09-14fbdev: sh_mobile_lcdcfb: use fb_videomode_to_var() instead of open-codingGuennadi Liakhovetski
Use the standard fb_videomode_to_var() instead of filling fb_var_screeninfo fields manually in, also remove a redundant memset(0). Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-08-04fbdev: sh-mobile: HDMI support for SH-Mobile SoCsGuennadi Liakhovetski
Some SH-Mobile SoCs have an HDMI controller and a PHY, attached to one of their LCDC interfaces. This patch adds a preliminary static support for such controllers, this means, that only the 720p mode is handled ATM. Support for more modes and a dynamic switching between them will be added by a follow up patch. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-08-04sh: add a parameter to LCDC driver's .display_on() callbackGuennadi Liakhovetski
HDMI support for the sh_mobile_lcdc framebuffer driver will require a 'struct fb_info *' pointer for its .display_on() callback. While at it fix kfr2r09 framebuffer modular build. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-08-04fbdev: sh-mobile-lcdc: fix potential Oops in SH-Mobile LCDC framebuffer driverGuennadi Liakhovetski
sh_mobile_lcdc_setup_clocks() can perform IO, therefore it has to be called after ioremap(). Also check return code of ioremap() and use resource_size() instead of open-coding it. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-25fbdev: fix erroneous index in drivers/video/sh_mobile_lcdcfb.cGuennadi Liakhovetski
2010-05-06sh: fix a number of Oopses and leaks in SH framebuffer driverGuennadi Liakhovetski
Fix a number of Oopses, memory leaks and unbalanced calls on error paths in sh_mobile_lcdcfb.c. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07platform-drivers: move probe to .devinit.text in drivers/videoUwe Kleine-König
A pointer to a probe callback is passed to the core via platform_driver_register and so the function must not disappear when the .init sections are discarded. Otherwise (if also having HOTPLUG=y) unbinding and binding a device to the driver via sysfs will result in an oops as does a device being registered late. An alternative to this patch is using platform_driver_probe instead of platform_driver_register plus removing the pointer to the probe function from the struct platform_driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Adrian Bunk <bunk@stusta.de> Cc: Alberto Mardegan <mardy@users.sourceforge.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andriy Skulysh <askulysh@gmail.com> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Frans Pop <elendil@planet.nl> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Helge Deller <deller@gmx.de> Cc: Huang Ying <ying.huang@intel.com> Cc: Ian Molton <spyro@f2s.com> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Kaj-Michael Lang <milang@tal.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Magnus Damm <damm@igel.co.jp> Cc: Martin Michlmayr <tbm@cyrius.com> Cc: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Pavel Machek <pavel@suse.cz> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Roland Stigge <stigge@antcom.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Vincent Sanders <vince@simtec.co.uk> Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: James Simmons <jsimmons@infradead.org> Acked-by: Peter Jones <pjones@redhat.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-16video: sh_mobile_lcdcfb: Fix panning.Phil Edworthy
Fixed SH-Mobile panning. Previously the address of the frame to be displayed was updated in the VSync end interrupt. This meant there was a minimum of 1 frame bewteen calling FBIOPAN_DISPLAY ioctl and the pan occuring. This meant that apps were not able to use the FBIO_WAITFORVSYNC ioctl to wait for the pan to complete. This patch moves the write to LDSA1R mirror reg into the pan ioctl. Tested on MS7724 board against 2.6.33-rc7 Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-02-16video: sh_mobile_lcdcfb: Add wait for vsync.Phil Edworthy
Added FBIO_WAITFORVSYNC ioctl for SH-Mobile devices. Tested on MS7724 and MigoR boards against 2.6.33-rc7. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (33 commits) sh: Fix test of unsigned in se7722_irq_demux() sh: mach-ecovec24: Add FSI sound support sh: mach-ecovec24: Add mt9t112 camera support sh: mach-ecovec24: Add tw9910 support sh: MSIOF/mmc_spi platform data for the Ecovec24 board sh: ms7724se: Add ak4642 support sh: Fix up FPU build for SH5 sh: Remove old early serial console code V2 sh: sh5 scif pdata (sh5-101/sh5-103) sh: sh4a scif pdata (sh7757/sh7763/sh7770/sh7780/sh7785/sh7786/x3) sh: sh4a scif pdata (sh7343/sh7366/sh7722/sh7723/sh7724) sh: sh4 scif pdata (sh7750/sh7760/sh4-202) sh: sh3 scif pdata (sh7705/sh770x/sh7710/sh7720) sh: sh2a scif pdata (sh7201/sh7203/sh7206/mxg) sh: sh2 scif pdata (sh7616) sh-sci: Extend sh-sci driver with early console V2 sh: Stub in P3 ioremap support for nommu parts. sh: wire up vmallocinfo support in ioremap() implementations. sh: Make the unaligned trap handler always obey notification levels. sh: Couple kernel and user write page perm bits for CONFIG_X2TLB ...
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
