path: root/drivers/video/sis/init.h
2010-12-22sisfb: remove duplicate function declarationsAaro Koskinen
Remove duplicate register I/O function declarations by moving them into a common header file. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: delete osdef.hAaro Koskinen
The file is not needed. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: use CONFIG_FB_SIS_301/315 instead of SIS301/315HAaro Koskinen
There is no need to alias CONFIG #defines. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: delete redudant #define SIS_LINUX_KERNELAaro Koskinen
It's not needed anymore with SIS_XORG_XF86 gone. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-24sisfb: delete dead SIS_XORG_XF86 codeAaro Koskinen
Delete code for compiling the driver for X.org/XFree86. The development has forked, so there is no point keeping this code in the tree. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-24video/sis/: remove compat codeAdrian Bunk
This patch removes compat code for older kernel versions. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] drivers/video/sis: Convert to generic booleanRichard Knutsson
Convert: FALSE -> false TRUE -> true BOOLEAN -> bool Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Thomas Hellstrom <thomas@tungstengraphics.com> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03[PATCH] drivers/video/sis/init.h: removal of old codeMichal Piotrowski
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] sisfb updateThomas Winischhofer
This lifts sisfb from version 1.7.17 to version 1.8.9. Changes include: - Added support for XGI V3XT, V5, V8, Z7 chipsets, including POSTing of all of these chipsets. - Added support for latest SiS chipsets (761). - Added support for SiS76x memory "hybrid" mode. - Added support for new LCD resolutions (eg 1280x854, 856x480). - Fixed support for 320x240 STN panels (for embedded devices). - Fixed many HDTV modes (525p, 750p, 1080i). - Fixed PCI config register reading/writing to use proper kernel functions for this purpose. - Fixed PCI ROM handling to use the kernel's proper functions. - Removed lots of "typedef"s. - Removed lots of code which was for X.org/XFree86 only. - Fixed coding style in many places. - Removed lots of 2.4 cruft. - Reduced stack size by unifying two previously separate structs into one. - Added new hooks for memory allocation (for DRM). Now the driver can truly handle multiple cards, including memory management. - Fixed numerous minor bugs. Signed-off-by: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
