CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
SiS_DRAMType is const and only used by sisfb_post_300_rwtest which is
marked __devinit we can annotate SiS_DRAMType with __devinitconst and
move it into the file scope in order to not have it created on the
stack.
This patch decreases the compiled module size by about 100bytes.
And since hardcoded values are bad we use ARRAY_SIZE for determining
the size of SiS_DRAMType ;)
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
We must not use any information in the passed var besides xoffset,
yoffset and vmode as otherwise applications might abuse it.
Fix checkpatch.pl warnings in the surrounding code.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add support for ZGI Z9 DDR2 POST. The init sequence is from XGI's
xgifb driver.
Tested with ARM board using a PCI card with XGI Z9s and 32 MB DDR2
memory. After a cold reset the POST succeeds.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Thomas Winischhofer <thomas@winischhofer.net>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Move DDR2 register setting code into separate subroutines. No changes
in functionality.
Detect the XGI Z9 RAM type as "documented" by the XGI's xgifb driver.
Z7 and Z9 have the same PCI ID, so additional checking is needed to
detect Z9. The method was "documented" in XGI's xgifb driver.
Move XGI POST RAM type detection into a separate subroutine to make
further code changes easier. No changes in functionality
Currently there is no indication if R/W test fails during POST. This can
happen e.g. when user plugs in a card with unsupported type of memory.
Since the driver will be unusable, it's better to fail the whole POST
if the memory cannot be configured properly.
Convert some bit masks to 8-bit values to avoid the following compiler
warnings:
drivers/video/sis/sis_main.c:3858: warning: large integer implicitly truncated to unsigned type
drivers/video/sis/init301.c:5855: warning: large integer implicitly truncated to unsigned type
drivers/video/sis/init301.c:5869: warning: large integer implicitly truncated to unsigned type
Replace setSISIDXREG() with SiS_SetRegANDOR().
Replace andSISIDXREG() with SiS_SetRegAND().
Replace orSISIDXREG() with SiS_SetRegOR().
Replace outSISIDXREG() with SiS_SetReg().
Replace inSISIDXREG() with SiS_GetReg().
Replace outSISREG() with SiS_SetRegByte().
Replace inSISREG() with SiS_GetRegByte().
Eliminate the following compiler warning on non-x86 platforms by limiting
the variable scope:
drivers/video/sis/sis_main.c:4108: warning: unused variable 'temp'
sis_main.c is always compiled, so we can check Kconfig options there.
If pci_map_rom() fails, there is some fallback code that basically
duplicates pci_map_rom() on non-x86 platforms. No point in that.
Delete a workaround for a PCI ROM bug that has been fixed ages ago by
the commit 761a3ac08c63718dacde12aaf0ec6d6760e8c2b7.
If the POST memory test fails, the driver may access illegal
memory areas. Instead of hard coding the maximum size, set it
according to the PCI resource length (an additional check is needed in
sisfb_post_map_vram() to ensure it's big enough). DRAM sizing will later
adjust video_size to the correct value.
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16 bytes
of uninitialized stack memory, because the "reserved" member of the
fb_vblank struct declared on the stack is not altered or zeroed before
being copied back to the user. This patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Cc: <stable@kernel.org>
These are different size buffers (40 chars vs 16), we may as well be
cautious.
The config Option FB_SOFT_BUFFER was removed in
c465e05a03209651078b95686158648fd7ed84c5 ("fbcon/fbdev: Move softcursor
out of fbdev to fbcon").
While moving to fbcon this single driver has it left as a select in
KConfig / #ifdef in source. This last occurence is removed here so the
option is really gone
Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
The TV_PALN bit was tested twice, replace one by TV_PALM.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
If called with mode_idx = 1, rate = 68, a read occurs from
sisfb_vrate[-1].refresh.
Remove redundant call to the sisfb_get_fix() before sis frambuffer is
registered.
This fixes a problem with uninitialized the fb_info->mm_lock mutex
introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap
locking"
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Tested-by: Wu Zhangjin <wuzhangjin@gmail.com>
Add a mutex to avoid a circular locking problem between the mm layer
semaphore and fbdev ioctl mutex through the fb_mmap() call.
Also, add mutex to all places where smem_start and smem_len fields change
so the mutex inside the fb_mmap() is actually used. Changing of these
fields before calling the framebuffer_register() are not mutexed.
This is 2.6.31 material. It removes one lockdep (fb_mmap() and
register_framebuffer()) but there is still another one (fb_release() and
register_framebuffer()). It also cleans up handling of the smem_start and
smem_len fields used by mutexed section of the fb_mmap().
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Use the framebuffer_release() for freeing fb_info structures allocated
with framebuffer_alloc().
sisfb incorrectly sets the length of the color fields to 6 bits
for PSEUDOCOLOR modes, even though 8 bits are always used per pixel.
Fix this by setting the length to 8.
Signed-off-by: Michal Januszewski <spock@gentoo.org>
Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
This patch removes compat code for older kernel versions.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: <thomas@winischhofer.net>
drivers/video/aty/atyfb_base.c:3359:26: warning: Using plain integer as NULL pointer
drivers/video/aty/radeon_base.c:2280:32: warning: Using plain integer as NULL pointer
drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer
drivers/video/sis/sis_main.c:5790:44: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
pci_get_class implicitly does a pci_dev_put on its second argument, so
pci_dev_put is only needed if there is a break out of the loop.
The semantic match detecting this problem is as follows:
// <smpl>
expression dev;
expression E;
* pci_dev_put(dev)
... when != dev = E
* pci_get_device(...,dev)
* pci_get_device_reverse(...,dev)
* pci_get_subsys(...,dev)
* pci_get_class(...,dev)
// </smpl>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Fix various instances of
if (!expr & mask)
which should probably have been
if (!(expr & mask))
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Jeff Garzik <jeff@garzik.org>
Remove dead code while at it.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
This patch fixes the possible usage of a negative value as an array
index spotted by the Coverity checker.
sisfb_validate_mode() could return a negative error code and we must check for
that prior to using its return value as an array index.
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the
checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver
does not use it.
Signed-off-by: Antonino Daplas <adaplas@gmail.com>
- the pseudo_palette is only 16 elements long.
- do not write to the pseudo_palette if regno (array index) is more than 15.
Instead of all drivers reading pci config space to get the revision
ID, they can now use the pci_device->revision member.
This exposes some issues where drivers where reading a word or a dword
for the revision number, and adding useless error-handling around the
read. Some drivers even just read it for no purpose of all.
In devices where the revision ID is being copied over and used in what
appears to be the equivalent of hotpath, I have left the copy code
and the cached copy as not to influence the driver's performance.
Compile tested with make all{yes,mod}config on x86_64 and i386.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Acked-by: Dave Jones <davej@redhat.com>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
Convert:
FALSE -> false
TRUE -> true
BOOLEAN -> bool
Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se>
Cc: Thomas Hellstrom <thomas@tungstengraphics.com>
Cc: James Simmons <jsimmons@infradead.org>
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com>
screen_info.h doesn't have anything to do with the tty layer and shouldn't be
included by tty.h. This patches removes the include and modifies all users to
directly include screen_info.h. struct screen_info is mainly used to
communicate with the console drivers in drivers/video/console. Note that this
patch touches every arch and I have no way of testing it. If there is a
mistake the worst thing that will happen is a compile error.
[akpm@osdl.org: fix arm build]
[akpm@osdl.org: fix alpha build]
Signed-off-by: Jon Smirl <jonsmir@gmail.com>
Signed-off-by: Antonino Daplas <adaplas@pol.net>
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a
function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h
allows all of the framebuffer and VT console drivers to remove their
dependency on tty.h.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
We had three (sic) VIDEO_SELECT options:
- two in drivers/video/Kconfig
- one in drivers/video/console/Kconfig
This patch removes the two options in drivers/video/Kconfig and also removes
the unneeded usage in drivers/video/sis/sis_main.c .
The ioctl and file arguments to ->fb_mmap are totally unused and there's not
reason a driver should need them.
Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap.
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for
drivers that do not support hardware cursors is redundant. The soft_cursor
function is usable by all drivers because it is just a wrapper around
fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is
moved to the console directory.
Thus, drivers that do not support hardware cursors can leave the fb_cursor
field blank. For drivers that do, they can fill up this field with their own
version.
The end result is a smaller code size. And if the framebuffer console is not
loaded, module/kernel size is also reduced because the soft_cursor module will
also not be loaded.
