path: root/drivers/video/sis
2010-05-25sis: strcpy() => strlcpy()Dan Carpenter
These are different size buffers (40 chars vs 16), we may as well be cautious. Signed-off-by: Dan Carpenter <error27@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12fbdev: remove obsolete CONFIG_FB_SOFT_CURSORChristoph Egger
The config Option FB_SOFT_BUFFER was removed in c465e05a03209651078b95686158648fd7ed84c5 ("fbcon/fbdev: Move softcursor out of fbdev to fbcon"). While moving to fbcon this single driver has it left as a select in KConfig / #ifdef in source. This last occurence is removed here so the option is really gone Signed-off-by: Christoph Egger <siccegge@stud.informatik.uni-erlangen.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fbdev: TV_PALN bit set twice in sisfb_detect_VB_connect()Roel Kluin
The TV_PALN bit was tested twice, replace one by TV_PALM. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23sisfb: change SiS_DDC_Port type to SISIOADDRESSAaro Koskinen
The patch enables the driver to be used on platforms such as ARM where an I/O address is a 32-bit memory address. The patch avoids the following kernel oops: debian:~# modprobe sisfb [ 73.070000] sisfb: Video ROM found [ 73.080000] sisfb: Video RAM at 0x80000000, mapped to 0xe0a00000, size 1024k [ 73.090000] sisfb: MMIO at 0x84080000, mapped to 0xe0b80000, size 256k [ 73.090000] sisfb: Memory heap starting at 800K, size 32K [ 73.360000] Unable to handle kernel paging request at virtual address 6e000844 [ 73.380000] pgd = df230000 [ 73.380000] [6e000844] *pgd=00000000 [ 73.380000] Internal error: Oops: 8f5 [#1] [ 73.380000] Modules linked in: sisfb(+) fb cfbcopyarea cfbimgblt cfbfillrect [ 73.380000] CPU: 0 Not tainted (2.6.31-iop32x #1) [ 73.380000] PC is at SiS_SetRegANDOR+0x10/0x38 [sisfb] [ 73.380000] LR is at SiS_SetSCLKHigh+0x38/0x94 [sisfb] [ 73.380000] pc : [<bf01dc00>] lr : [<bf0238f8>] psr: 60000013 [ 73.380000] sp : df38fd00 ip : 6e000000 fp : 00000002 [ 73.380000] r10: 00000108 r9 : 00000000 r8 : 00000108 [ 73.380000] r7 : df064258 r6 : 00000110 r5 : 6e000844 r4 : 0000010a [ 73.380000] r3 : 00000001 r2 : 0000000e r1 : 00000011 r0 : 00000844 [ 73.380000] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 73.380000] Control: 0000397f Table: bf230000 DAC: 00000015 [ 73.380000] Process modprobe (pid: 1849, stack limit = 0xdf38e270) [ 73.380000] Stack: (0xdf38fd00 to 0xdf390000) [ 73.380000] fd00: 0000010a 00000108 df064258 df064258 df064258 00000000 00000000 bf02c4e0 [ 73.380000] fd20: 00000114 bf02c50c 00000013 00000114 0000010a df064258 00000000 bf02c980 [ 73.380000] fd40: 00009c66 00000004 00000001 df064250 a0010000 a6a2a0a0 df064250 00000003 [ 73.380000] fd60: df064250 00000000 df064258 0000fffd 00000000 00000000 00000000 bf033948 [ 73.380000] fd80: 00000000 00000000 00000000 bf019e2c 00000000 df064a70 bf03b470 00010000 [ 73.380000] fda0: 00000000 df064250 00000000 df831c00 00000012 bf039f70 00000000 c00abed8 [ 73.380000] fdc0: 000008a6 000008a4 df0649b0 df064878 df064258 df064000 00000000 00000000 [ 73.380000] fde0: 00000001 00008000 00000001 00030000 df81c930 bf049f88 df831c00 00000000 [ 73.380000] fe00: bf049f58 df3952a0 c0447708 bf049f88 bf049fe0 c0191980 df831c00 c0191b10 [ 73.380000] fe20: df831c58 bf049f58 df831c00 bf04aca8 df3952a0 df831c58 df831c58 bf049f88 [ 73.380000] fe40: c01ba1b4 c01ba0a0 df831c58 df831c8c bf049f88 c01ba1b4 df3952a0 00000000 [ 73.380000] fe60: c03e265c c01ba240 00000000 df38fe78 bf049f88 c01b990c df812938 df81b8d0 [ 73.380000] fe80: df3952a0 df807780 00000000 00000060 bf049f88 c01b9224 bf0429c8 00000000 [ 73.380000] fea0: bf049f58 00000000 bf049f88 00000000 00000000 bf04aea8 00000000 c01ba4e4 [ 73.380000] fec0: e09861a0 bf049f58 00000000 bf049f88 00000000 c0191f20 00000000 00000000 [ 73.380000] fee0: c03f7bac bf04d418 0000fff2 0000fff1 bf04ad08 0002f260 0002f260 e0986038 [ 73.380000] ff00: e0986150 e098568b df143340 e0990280 00000036 c03d8b00 fffffffd 00000000 [ 73.380000] ff20: bf04acfc 00000000 fffffffc 0003cf4b 00018098 c03f7bac 00000000 bf04d000 [ 73.380000] ff40: df38e000 00000000 bedc0984 c00272a4 ffffffff c005bc88 00000000 00000000 [ 73.380000] ff60: 0003cf4b 0003cf4b 00018098 bf04acfc 00000000 c0027fe8 df38e000 00000000 [ 73.380000] ff80: bedc0984 c006882c 00001000 00000003 00000000 00009064 00000000 00008edc [ 73.380000] ffa0: 00000080 c0027e20 00009064 00000000 4014e000 0003cf4b 00018098 0003cf4b [ 73.380000] ffc0: 00009064 00000000 00008edc 00000080 00000000 00000000 40025000 bedc0984 [ 73.380000] ffe0: 00000000 bedc08fc 0000b6b0 400e8f34 60000010 4014e000 00000000 00000000 [ 73.380000] [<bf01dc00>] (SiS_SetRegANDOR+0x10/0x38 [sisfb]) from [<df064258>] (0xdf064258) [ 73.380000] Code: e92d0030 e20110ff e280546e e3a0c46e (e5c51000) [ 73.680000] ---[ end trace 62a93e01df37a5f2 ]--- Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23sisfb: read buffer overflowRoel Kluin
If called with mode_idx = 1, rate = 68, a read occurs from sisfb_vrate[-1].refresh. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-06sisfb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove redundant call to the sisfb_get_fix() before sis frambuffer is registered. This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30fbdev: add mutex for fb_mmap lockingKrzysztof Helt
Add a mutex to avoid a circular locking problem between the mm layer semaphore and fbdev ioctl mutex through the fb_mmap() call. Also, add mutex to all places where smem_start and smem_len fields change so the mutex inside the fb_mmap() is actually used. Changing of these fields before calling the framebuffer_register() are not mutexed. This is 2.6.31 material. It removes one lockdep (fb_mmap() and register_framebuffer()) but there is still another one (fb_release() and register_framebuffer()). It also cleans up handling of the smem_start and smem_len fields used by mutexed section of the fb_mmap(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: use framebuffer_release() for freeing fb_info structuresKrzysztof Helt
Use the framebuffer_release() for freeing fb_info structures allocated with framebuffer_alloc(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13sisfb: fix color component length for pseudocolor modesMichal Januszewski
sisfb incorrectly sets the length of the color fields to 6 bits for PSEUDOCOLOR modes, even though 8 bits are always used per pixel. Fix this by setting the length to 8. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Thomas Winischhofer <thomas@winischhofer.net> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24video/sis/: remove compat codeAdrian Bunk
This patch removes compat code for older kernel versions. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-23fbdev: fix integer as NULL pointer warningHarvey Harrison
drivers/video/aty/atyfb_base.c:3359:26: warning: Using plain integer as NULL pointer drivers/video/aty/radeon_base.c:2280:32: warning: Using plain integer as NULL pointer drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer drivers/video/matrox/matroxfb_base.h:203:25: warning: Using plain integer as NULL pointer drivers/video/sis/sis_main.c:5790:44: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06drivers/video: remove unnecessary pci_dev_putJulia Lawall
pci_get_class implicitly does a pci_dev_put on its second argument, so pci_dev_put is only needed if there is a break out of the loop. The semantic match detecting this problem is as follows: // <smpl> @@ expression dev; expression E; @@ * pci_dev_put(dev) ... when != dev = E ( * pci_get_device(...,dev) | * pci_get_device_reverse(...,dev) | * pci_get_subsys(...,dev) | * pci_get_class(...,dev) ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fix ! versus & precedence in various placesAlexey Dobriyan
Fix various instances of if (!expr & mask) which should probably have been if (!(expr & mask)) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01USB: sisusb: *_ioctl32_conversion functions do not exist in recent kernelsFernando Luis Vázquez Cao
Remove dead code while at it. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-14video/sis/: fix negative array indexAdrian Bunk
This patch fixes the possible usage of a negative value as an array index spotted by the Coverity checker. sisfb_validate_mode() could return a negative error code and we must check for that prior to using its return value as an array index. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17sisfb: fix pseudo_palette array size and overrunAntonino A. Daplas
- the pseudo_palette is only 16 elements long. - do not write to the pseudo_palette if regno (array index) is more than 15. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: Change all drivers to use pci_device->revisionAuke Kok
Instead of all drivers reading pci config space to get the revision ID, they can now use the pci_device->revision member. This exposes some issues where drivers where reading a word or a dword for the revision number, and adding useless error-handling around the read. Some drivers even just read it for no purpose of all. In devices where the revision ID is being copied over and used in what appears to be the equivalent of hotpath, I have left the copy code and the cached copy as not to influence the driver's performance. Compile tested with make all{yes,mod}config on x86_64 and i386. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Acked-by: Dave Jones <davej@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-08drivers/video/sis/: remove more kernel 2.4 codeAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] drivers/video/sis: Convert to generic booleanRichard Knutsson
Convert: FALSE -> false TRUE -> true BOOLEAN -> bool Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Cc: Thomas Hellstrom <thomas@tungstengraphics.com> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] video SiS: remove unnecessary variables in SiS_DDC2DelayDavid Rientjes
Remove unnecesary iteration and accumulator variables from SiS_DDC2Delay. Originally spotted by Jesper Juhl <jesper.juhl@gmail.com>. Cc: Jesper Juhl <jesper.juhl@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: David Rientjes <rientjes@cs.washington.edu> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] drivers/video/sis/sis_main.h Removal of old codeMichal Piotrowski
Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] drivers/video/sis/vgatypes.h: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/sis_main.c: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/sis_accel.h: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/sis_accel.c: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/osdef.h: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/init.h: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/initextlfb.c: removal of old codeMichal Piotrowski
2006-10-03[PATCH] drivers/video/sis/init301.h: removal of old codeMichal Piotrowski
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30typo fixes: bandwith -> bandwidthAdrian Bunk
2006-06-26[PATCH] fbdev: cleanup the CONFIG_VIDEO_SELECT messAdrian Bunk
We had three (sic) VIDEO_SELECT options: - two in drivers/video/Kconfig - one in drivers/video/console/Kconfig This patch removes the two options in drivers/video/Kconfig and also removes the unneeded usage in drivers/video/sis/sis_main.c . Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] video/sis/init301.c:SiS_ChrontelDoSomething2(): remove dead codeAdrian Bunk
The Coverity checker spotted these two unused variables. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Thomas Winischhofer <thomas@winischhofer.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] sisfb updateThomas Winischhofer
This lifts sisfb from version 1.7.17 to version 1.8.9. Changes include: - Added support for XGI V3XT, V5, V8, Z7 chipsets, including POSTing of all of these chipsets. - Added support for latest SiS chipsets (761). - Added support for SiS76x memory "hybrid" mode. - Added support for new LCD resolutions (eg 1280x854, 856x480). - Fixed support for 320x240 STN panels (for embedded devices). - Fixed many HDTV modes (525p, 750p, 1080i). - Fixed PCI config register reading/writing to use proper kernel functions for this purpose. - Fixed PCI ROM handling to use the kernel's proper functions. - Removed lots of "typedef"s. - Removed lots of code which was for X.org/XFree86 only. - Fixed coding style in many places. - Removed lots of 2.4 cruft. - Reduced stack size by unifying two previously separate structs into one. - Added new hooks for memory allocation (for DRM). Now the driver can truly handle multiple cards, including memory management. - Fixed numerous minor bugs. Signed-off-by: Thomas Winischhofer <thomas@winischhofer.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] make some things staticAdrian Bunk
This patch makes some needlessly global identifiers static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Arjan van de Ven <arjanv@infradead.org> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
