path: root/drivers/video/sysfillrect.c
2008-04-28fb: add support for foreign endiannessAnton Vorontsov
Add support for the framebuffers with non-native endianness. This is done via FBINFO_FOREIGN_ENDIAN flag that will be used by the drivers. Depending on the host endianness this flag will be overwritten by FBINFO_BE_MATH internal flag, or cleared. Tested to work on MPC8360E-RDK (BE) + Fujitsu MINT framebuffer (LE). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: <Valdis.Kletnieks@vt.edu> Cc: Clemens Koller <clemens.koller@anagramm.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: consolidate common drawing functions into a header fileAntonino A. Daplas
Consolidate common drawing functions into a single header file. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fbdev: add drawing functions for framebuffers in system RAMAntonino A. Daplas
The generic drawing functions (cfbimgblt, cfbcopyarea, cfbfillrect) assume that the framebuffer is in IO memory. However, we have 3 drivers (hecubafb, arcfb, and vfb) where the framebuffer is allocated from system RAM (via vmalloc). Using _raw_read/write and family for these drivers (as used in the cfb* functions) is illegal, especially in other platforms. Create 3 new drawing functions, based almost entirely from the original except that the framebuffer memory is assumed to be in system RAM. These are named as sysimgblt, syscopyarea, and sysfillrect. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
