Add GET_INVERT used for calling
tegra_dc_parse_feature and retrieving the invert
status (will be used by MODS driver)
Bug 1479112
Signed-off-by: Lael Jones <lajones@nvidia.com>
Change-Id: I70382ec9fc159e7025da602b66cbbe4d315c3a17
Reviewed-on: http://git-master/r/380418
GVS: Gerrit_Virtual_Submit
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Check if a window supports SCAN_COLUMN before permitting flip requests.
Change-Id: Ib3107e22a90e50c7d9e02b6f32267221c571fab2
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/380569
Add compat ioctls and clean up data structures where it would be
simplier to break the old 64-bit APIs for a new one that works.
Some user space binaries will have to be rebuilt after this patch, but
those binaries were almost certainly already broken as the driver wasn't
doing the right thing.
adds 32-bit compat version of:
TEGRA_DC_EXT_CONTROL_GET_OUTPUT_EDID
TEGRA_DC_EXT_FLIP2
TEGRA_DC_EXT_SET_PROPOSED_BW
TEGRA_DC_EXT_SET_LUT
TEGRA_DC_EXT_GET_FEATURES
updates struct tegra_dc_ext_flip_windowattr to be the same size in both
environments. This allows these ioctls to work:
TEGRA_DC_EXT_FLIP
TEGRA_DC_EXT_FLIP3
Bug 1466416
Change-Id: I17b8ba1b1fc5ace659b7db99dd252c03e96273e8
Reviewed-on: http://git-master/r/378129
This reverts commit 0ca988fecb9b58567f2019d9dc0530200e3f764f.
Bug 1466416
Change-Id: I8393151c04a032834d7658d2f4181c0fedccb13a
Reviewed-on: http://git-master/r/378128
Support for compat ioctls of DC where userspace is 32bit
and kernel is 64bit.
Bug 1349118
Change-Id: Ie48d426eaddda4126b9088794585a4f5765facbc
Signed-off-by: Peng Du <pdu@nvidia.com>
Reviewed-on: http://git-master/r/274472
Reviewed-by: Bo Yan <byan@nvidia.com>
Filtering capabilities of windows on t124 were incorrectly
setup.
Bug 1413155
Bug 1418047
Change-Id: Ide2cf08a0ad33e953a0d417607e819ce3e2b24a6
Signed-off-by: Michael Frydrych <mfrydrych@nvidia.com>
Reviewed-on: http://git-master/r/337115
Reviewed-by: Tuomas Kulve <tkulve@nvidia.com>
Reviewed-by: Chao Xu <cxu@nvidia.com>
Change-Id: I4f138daa014d8d688a74205658b94d4c904f4823
Reviewed-on: http://git-master/r/280874
Reviewed-by: Xue Dong <xdong@nvidia.com>
Reviewed-by: Wen Yi <wyi@nvidia.com>
Tested-by: Wen Yi <wyi@nvidia.com>
(cherry picked from commit 1aebf628c0ea2cb3d62c07a0d20587f16db132fa)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
bug 1322596
Change-Id: I6baee32a769a67863707a4603cc723b0330427ec
Signed-off-by: Xue Dong <xdong@nvidia.com>
Reviewed-on: http://git-master/r/266191
This is just a workaround. Ideally any access of the tegra_dc_feature_xxx
function needs to check if the window exists.
Change-Id: Ib15e618412e03038b08579b57aef1ff32592b6d8
Signed-off-by: Chao Xu <cxu@nvidia.com>
Reviewed-on: http://git-master/r/242516
Change-Id: I11b293f288270e26d399b1e364b02851f2c1dffd
Reviewed-on: http://git-master/r/223937
Bug 1172562
arch/arm/mach-tegra/include/mach/dc.h
drivers/video/tegra/dc/mode.c
Change-Id: I9e33ae73c60e0d98c5009a2a72c243d598bf084f
Reviewed-on: http://git-master/r/200502
Change-Id: Icd8feba013b1d6d00b9c3b685b22f5feb7778ba4
Reviewed-on: http://git-master/r/113407
Tested-by: Xue Dong <xdong@nvidia.com>
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
Signed-off-by: Mark Stadler <mastadler@nvidia.com>
Add display feature table so that user and kernel could set and
update window attributes properly.
Bug 962353
Change-Id: Ic5fb0b712a6ccb912e49b4cfd14282f552c1408a
Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com>
Reviewed-on: http://git-master/r/105529
Tested-by: Mark Stadler <mastadler@nvidia.com>
Windows support 1x1 to 4096x4096 size.
Change-Id: I7d1a7e182ba5c740af1061e2ceb22cac092bedf0
Reviewed-on: http://git-master/r/208880
Use 1x1 as the minimum window size.
Bug 1193195
Change-Id: I42e13fec82bbc2dc37bde6416088f3ae49b304b7
Reviewed-on: http://git-master/r/173302
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Bug 962353
Change-Id: I08a7f2d5cee6e817b5597206bf007a96f1eded2c
Signed-off-by: Prashant Malani <pmalani@nvidia.com>
Reviewed-on: http://git-master/r/106809
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Tested-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
(cherry picked from commit 8b705c12b8ac45e24b7c5ed4fc7300616be368ec)
(cherry picked from commit bf86139fff37b1841f6844f97e40d7c6a35fcf2b)
(cherry picked from commit 3df84956ae6898a0e223eec75b11eacbea2f3904)
Reviewed-on: http://git-master/r/116269
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Tested-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Change-Id: I9fcef4544e934fb59c55968484059e938e82da43
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/126943
Rebase-Id: R73c7799e4790227488101edb2aece976b812ae30
Moved mode setting code into mode.c
Move window code info window.c
Moved clock related code into clock.c
Moved LUT and gamma related code into lut.c
Moved csc(color space conversion) into csc.c
Removed unnecessary static function prototypes from header.
Moved many short inline functions to dc_priv.h
Cleaned up copyright headings.
Cleaned up formatting and indent in all files.
Fixed build warnings.
Bug 870907
Change-Id: I6ccc37150191765394f0b5629423eafd4e5e5792
Reviewed-on: http://git-master/r/111371
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: Rc7ed74e733798a26a2af94b2384c5c9f1c9a19d7
Change-Id: I748fc9d982f87f2cc763b793aa40f657214bcad4
Reviewed-on: http://git-master/r/103734
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Rebase-Id: Rfd6b20cabaa323fe550ef6b9116293bfd77dab84
Change-Id: I13f0f7502aea7f43b2ddff12e9664c22a1d9bd21
Reviewed-on: http://git-master/r/103210
(cherry picked from commit 1f4ccee135b9729ec09eceaddd1b573ea7366d15)
Reviewed-on: http://git-master/r/103733
Rebase-Id: Ra13be73c61fe0688c731b8ef5efb49850243cc17
change t114 feature table to use one defined for
t30. Prevents build break.
Change-Id: I6c1ed54b5cae8016a7e2ef37113418293ec13b56
Reviewed-on: http://git-master/r/102641
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R5782f75b7776359dc2b1f77db48ba4891209ee9c
Add support to different blenders.
Bug 962353
Change-Id: Ie9530969a11dd0c329012aa54b90e3e62765c44c
Reviewed-on: http://git-master/r/102406
Rebase-Id: R98b3510aab3c9e3fc2645903a1269a8d179bd300
Rebase-Id: Rfdc3dd51a8aae515ffd36355ce551363d4d8dd1d
Move WinB's format limitations to a list of preferred formats.
Bug 985197
Change-Id: Ife37c79441b2737592ace51e94ab0c80af4af917
Reviewed-on: http://git-master/r/102629
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Rebase-Id: R4ee3a7eb63050b39ffa7a365ea643174660b066f
Bug 962353
Change-Id: I08490a225892660126f3eefe4d5b7a4bb61d9bf7
Reviewed-on: http://git-master/r/101078
Reviewed-by: Simone Willett <swillett@nvidia.com>
Rebase-Id: Rcb2df6e6e059ab289531451c25da384bd9169f4e
