Add a companion function to nvhost_client_device_get_resources()
called nvhost_client_device_put_resources() that does the opposite
thing. This is useful for any nvhost clients that need to be loaded
as modules, since the driver removal path will be exercised in that
case.
Change-Id: Ib5cec6fce7b05c780b135b03fcd88e068f772244
Signed-off-by: Andrew Chew <achew@nvidia.com>
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/169833
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
nvhost_module_remove_client assumes that a client structure
to be freed exists in the linked list. However, if an allocation fails
in nvhost_module_add_client, no client structure is allocated, and
during cleanup, nvhost_module_remove_client would then attempt
to free an invalid pointer.
Bug 1034729
Change-Id: Ie1a641071b86f8246951e9be824a6003f14b04b6
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/124096
GVS: Gerrit_Virtual_Submit
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Add parameters in host1x nvhost_device on
* number of sync points
* number of wait bases
* number of channels
* number of mlocks
* client managed bitmask
* naming of sync points
Add automatically generated headers and use symbols from them to
access hardware.
Move host1x device definition from generic host1x to SoC specific
source files t20.c and t30.c.
Bug 982965
Change-Id: Ibec84be22d75b363900d10bcbd59d4d8321d54a1
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/104974
Add configuration variable for default timeout for clients. Set it to
30s for silicon and infinity for simulation.
Change-Id: I08c1fd234f738c4919adfe482dfc50948dc2f862
Reviewed-on: http://git-master/r/105331
Abstract nvmap support to one file, and use it via function pointers
from other parts of nvhost.
Bug 965206
Change-Id: I4e5e7de4271e0797d117ac8210af4732b6018973
Reviewed-on: http://git-master/r/105665
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Remove BUG_ON()s in error cases:
* If IOCTL size is too large, return error instead
* If sync point id is out of range, return error. Prevents panics in
sanity checks nvhost_cdma.
Bug 993642
Change-Id: I3cfa7a23dc557c811e20b726885f82666437de7f
Reviewed-on: http://git-master/r/105866
Register access (read/write) to modules MPE, ISP and VI lack sanity
check for the register number. Add checks to ensure only aperture is
accessed. Also make sure that the check accounts for wrapping of
values of offset and count.
Also fixes the register offset for reads which are done in multiple
blocks.
Bug 992938
Change-Id: I35f30cbd1dda31956286e48c5995b24fd262d1ae
Reviewed-on: http://git-master/r/105585
Convert the jiffies to msecs when assigning a channel the default
timeout.
Change-Id: If9b6fb7c695e9621a0c50d99d4d1362b6dd214b6
Reviewed-on: http://git-master/r/105022
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
When a submit fails, the related nvhost_job is not freed. Add an
explicit free. Also, 3D is mapping the save buffer, but it is not
unmapped.
Bug 991972
Change-Id: Ie335adb5e64f54557e76d12dfb6a9a1557781e8d
Reviewed-on: http://git-master/r/105152
Implement per channel counter for jobs in each priority level. If
there are jobs active with higher priority than the one being
submitted, throttle.
Bug 926690
Change-Id: I5fed341e3f248325873b31d1c53bf57bf0a78074
Reviewed-on: http://git-master/r/104939
Replace usage of nvmap_pinarray_elem with own nvhost_reloc and
nvhost_reloc_shift structs.
Bug 965206
Change-Id: I90618d8a34d79156d8880d9925dadbf416353811
Reviewed-on: http://git-master/r/104450
Job pinning and relocation already maps the gather buffers to
kernel memory. Move waitchk to be done at the same time so that we
do not need to re-map the memory to patch expired waits.
Bug 965206
Change-Id: I23634b501a45de080200e57d3debf267b39fea38
Reviewed-on: http://git-master/r/104415
- remove usage of custom interface of nvmap to patch the relocs and
and pin the gathers/relocs
- convert code that references nvmap_handle to nvmap_handle_ref
- add logic to pin and map only unique gathers and relocs
- rename nvhost_channel_gather to nvhost_job_gather, because it's
used in nvhost_job code only
Bug 965206
Change-Id: Iaa7fbac9e4a7b08c0a7c1e184b8dd3566e1edfe2
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/95299
Use nvmap.h include file from kernel/include instead of mach-tegra/include.
Bug 854182
Change-Id: I9a44471dc77d1ed7aa3b6e61a5eca4833fe6dc25
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/102721
nvhost panics if hardware does not respond within 30 seconds. Remove
this behavior, as it causes problems in emulation and simulation.
Panic should be used only to prevent corruption.
Submits are now given a default timeout of 30 seconds. The clients
can still override with their own timeout value.
MPE doesn't provide the number of slots for context save/restore.
This information is needed to be able to use the submit timeout for
MPE.
Bug 982946
Change-Id: I0f54d639df0fb726cc3163b317bf9c90bf56798b
Reviewed-on: http://git-master/r/100246
- nvhost_master holds a reference to all the channels for
a chip architecture
- however, nvhost_master is a private data of host1x hardware
device. so it should contain only members needed by host1x
hardware device
- add chip specific apis to allocate and free channels
- this will also help to remove the static binding between
nvhost_device and a channel per SoC in future
Bug 871237
Change-Id: I2148db57b995b4cb60954ebb6e670f588552eca4
Reviewed-on: http://git-master/r/91687
- currently, nvhost_master holds the reference to struct
chip_support
- the struct chip_support hides the chip specific implementation
for channel submit, cdma, push buffer operations etc. so
it exposed all the internal structures through nvhost_master
- move chip_support to be a part of nvhost_bus since it only has
function pointers to chip specific api implementations
- nvhost_master is host1x device specific private data so
ideally it should not hold reference to chip specifics
Bug 871237
Change-Id: I4f3f48ee5fc47a90288d110ea8eef905150275a0
Reviewed-on: http://git-master/r/94421
Add context switch to the ftrace dump.
Change-Id: I5df032273982b919fb94263cff38d8b8b6b6be45
Reviewed-on: http://git-master/r/101523
Do not use nb_channels to find out the number of client devices.
Instead, allocate devno regions when they are needed and find a
device by module id by iterating over nvhost bus.
Bug 871237
Change-Id: I53fd0d8e5874422ef9877430c0a170db2660118a
Reviewed-on: http://git-master/r/99067
Clean up #includes. Replace #includes with forward declarations where
possible, and remove extraneous #includes.
Bug 871237
Change-Id: I6942e0c632b42ad7009589ebdd78def88ae4baa4
Reviewed-on: http://git-master/r/99046
- as of now the resources needed by all the host1x
modules are part of resource list of host1x device
- now that each module is a nvhost_device of its own,
so it should hold the resources it needs instead of
host1x device holding it for them
- each device that needs its resources gets it in its
_probe() using a helper API in bus_client.c
Bug 871237
Change-Id: Ia7c63fcf40cbc5db76d4d8339294a0e9ce75e352
Reviewed-on: http://git-master/r/94166
Reviewed-by: Simone Willett <swillett@nvidia.com>
- remove redundant 2nd argument to nvhost_module_suspend()
- also remove the debug_not_idle() as it redundant after
refactor of host1x code
- debug_not_idle() iterates through host1x's private instance
of channels to find out which client module is active (along
with host1x itself). we are going to remove these instances of
channels from host1x's device private data
- reduce the prints during suspend
Bug 871237
Change-Id: I66c7c4d8f35c157b1626784a6a27166442a50557
Reviewed-on: http://git-master/r/92550
- if user space does not open 3d channel, 3d scaling
algorithm is not initialized. so return safely when
3d scaling is disabled
- also do not call nvhost_module_suspend() explicitly
for host1x client modules. nvhost_channel_suspend()
takes care to suspend the module if ref count = 0
- call nvhost_module_suspend() only for host1x device
as it does not use actual hardware channel
Bug 953451
Change-Id: Iba2b771b71d9b41c8ed978112566181872c56259
Reviewed-on: http://git-master/r/92506
Tested-by: Peer Chen <pchen@nvidia.com>
Reviewed-by: Emily Jiang <ejiang@nvidia.com>
Split host1x_channel_submit() into subfunctions.
Bug 926690
Change-Id: I8be55cbc9d25ee76c758a918de4a9bb27e2ea846
Reviewed-on: http://git-master/r/90626
- split the nvhost clients into their own directories
- each client is a nvhost_device and nvhost_driver
- all the code related to host1x control node is centralized
at single place in dev.c
- all the code related to host1x modules nodes is centralized
at single place in bus_client.c
- update the copyright notice & year for new files
Bug 871237
Change-Id: Ief85064699e35ad02b48a7e54496928d7f085af4
Reviewed-on: http://git-master/r/83491
Replace license information in nvhost with GPLv2. Also adds
copyright year 2012 in files which have been changed in 2012.
Change-Id: I86e8ed27095df13d99e0250e57e244d531fdacec
Reviewed-on: http://git-master/r/89735
CPU register read did not have access to nvhost power management.
Due to this only modules that were powered on previously are actually
accessible via the API. This patch refactors CPU access to:
* Move mutexes to sync point, as they're sync point operations
* Move register address spaces to nvhost_device
* Call register read with access to the respective nvhost_device
* Initialize module completely at boot-up so that register reads
can be done without an initialized channel.
Reviewed-on: http://git-master/r/75275
Change-Id: I0db38cef7b2cd92dc64e7f55d227bdd2fdb8f752
Reviewed-on: http://git-master/r/77764
