Reviewed-on: http://git-master/r/51026
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
(cherry picked from commit 060055eea2082adb6da4cf27462ff699fdf2b4e9)
Change-Id: I9244dff21e9cd62b14f97bfb5a5349eb46f73847
Reviewed-on: http://git-master/r/56107
Rebase-Id: Rd3f4f8799a3acad27234422b39a4def0a439e3f3
Bug 871094
(cherry picked from commit 7eb5215660d7e54d2ff84dae17cb00071695aed1)
Change-Id: I4fa16032ce90cd728b2eb32696034a7cfc506717
Reviewed-on: http://git-master/r/54845
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R61d721bbef3293f802a4358560f18bced53c1761
Don't allow root user allocating more than iovm limit to avoid pin
time issues.
Bug 864535
(cherry picked from commit 52e6b556bfc08cb085b283b5ee8d11efb1b07617)
Change-Id: If61577eb09cb96475d5fae5b58813beaee1f7b6f
Reviewed-on: http://git-master/r/54837
Rebase-Id: R59951f6ecba2ed2b075b170630c0ce7c6a84aad5
Change-Id: Ic7fab1575312afd27430b46a50aa6f7a7de0ac4e
Reviewed-on: http://git-master/r/53843
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R44abb981f52475b4431975c5d38611e7ca93b59a
Make kernel boot up with CONFIG_TEGRA_IOVMM=n
(cherry picked from commit f10b613bbd27b8a5f25cbbaebecfe50fd9c0be3f)
Change-Id: I980d762bd9feac3881e00015e6db753ae36e79f9
Reviewed-on: http://git-master/r/54509
Tested-by: Hiro Sugawara <hsugawara@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R0c90a78e3a9e8d5316faa1fee012f6269ee82035
- Use 0x0ff00000 (last 1MB of IOVM).
- For Tegra3 A01, use 0xeff00000.
Original-Change-Id: Ieb21d2bf38158171b97434e04ede7417823b3603
Reviewed-on: http://git-master/r/37742
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Tested-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Rebase-Id: Ra84e71077c8c74fdbd977fc838e74f132f173018
Original-Change-Id: Ic50111924d7adf7838926cb534bbf841b7e8003a
Reviewed-on: http://git-master/r/45358
Rebase-Id: R6399e487b817aa16c39e685d3f7860d1eefa8b09
This is needed to pick up definitions for pgprot*
bug 818525
Original-Change-Id: Idc2de3564eeba9d1bbb7c7211c9c707bc760d14f
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/40510
Rebase-Id: Rb4c7f3cee9d813549bedb53b5fd7ed760f9a32d5
Original-Change-Id: I75e88d6cef2daf625c6ede38a937207b95e2b84c
Reviewed-on: http://git-master/r/44364
Reviewed-by: Ken Adams <kadams@nvidia.com>
Tested-by: Ken Adams <kadams@nvidia.com>
Rebase-Id: Rd79c4aac3d3e03e601be5b35934fe36a35cd358f
Map uncahced memory as uncached, inner cached as inner cached and
cached as cached.
Bug 841109
Original-Change-Id: Id92532828ab2e69bac80b20f2be2fc243e4db888
Reviewed-on: http://git-master/r/43078
Rebase-Id: R75168ffeab3c91d3080b53d4d66c4e550d6f9e12
Bug 39790
Original-Change-Id: I5ce0e35501442ed1a6818aebfeae1670ebb9d08d
Reviewed-on: http://git-master/r/39867
Rebase-Id: R5679d529af4779bde735d3055b04d368b765c620
Fix GART lockups caused by fragmentation by evicting
mapped areas from iovm space after unsuccessful array
pinning attempt.
Fix double unpin error happening during interrupted
submit.
Fix possible sleep in atomic context in iovmm code
(semaphore inside spinlock) by replacing spinlock
with mutex.
Fix race between handle_unpin and pin_handle.
bug 838579
bug 838073
bug 818058
Original-Change-Id: I420447ffb4e02fb78a7987e22a537eefc16ff524
Reviewed-on: http://git-master/r/36129
Rebase-Id: R893c97003f2ec2f69e224f35d99d3488f673d620
In nvmap_munmap(), remove_vm_area just remove the allocated memory
page information. It doesn't de-allocate vm_struct. kfree()
should be used to avoid memory leak in nvmap.
Bug: 833796
Original-Change-Id: Ibd0309c1ff323fb8110870ace27819f5a1e006ba
Reviewed-on: http://git-master/r/35638
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: R417df608c4a24667af81f328bfb65cf3389e19ae
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R40af26da1b703abcca7c96c8fe9ca3f8a42b367d
Rebase-Id: Re05bf8da51b75cfd7c8a10677fce557c76593a43
Bug 835748
Original-Change-Id: I67766cc94496162816cbef4689fa806553d6edfa
Reviewed-on: http://git-master/r/35792
Rebase-Id: Ree8a45408d5763ec8db2cc4072add4c347326f99
The kernel now receives wait tracking data (similar to gathers and
relocs) and compares the current syncpt with the threshold value.
If it's old, it gets a kernel mapping and rewrites the method data
to use a kernel reserved syncpt that is always 0 (so trivially pops
when seen by the HW).
Bug 519650
Bug 785525
Bug 803452
The waitchk implementation is also backward compatible with older
user space code that didn't supply waitchk data as part of the
submit.
(cherry picked from commit 4069d8e67665624ad3dceb628e572980dd57acd0)
(cherry picked from commit 6e4336408588e348804a62e53386acc9abc06823)
(cherry picked from commit 87a9efe751716ca741caac72b9061fdfdcec540a)
(cherry picked from commit 6d8d2c454e835f7cfe34371e07dac173f3153452)
Original-Change-Id: I1bf4c940fefb6e251aa8c396e92631fa3cbe32df
Reviewed-on: http://git-master/r/23159
Reviewed-on: http://git-master/r/30281
Reviewed-on: http://git-master/r/32669
Rebase-Id: Rbad4942a103de7d64d8a6a11d4a973740c56fa8e
Original-Change-Id: I95cdf71e74947d4394e0cfd272a29c47562d4059
Reviewed-on: http://git-master/r/31648
Rebase-Id: Rb8c6f92bdfd0bf124a878800a793828fa61c0043
When user doesn't use default heap policy and selects
GART or carveout allocation, automatic single-page-to-sysmem
rule doesn't work. Because of broken rule many single page
allocations take extra space in carveout and create
unnecessary page mappings in GART and SMMU.
The fix adds sysmem bit to heap mask when allocation is
single page and GART or carveout is present in heap mask.
bug 730124
bug 731923
The change also does sanity check of available system memory
before adding sysmem bit for carveout allocations.
bug 777839
Original-Change-Id: I13a62653825f6c80581adcd2682fb2608d3a284e
Reviewed-on: http://git-master/r/31383
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Tested-by: Kirill Artamonov <kartamonov@nvidia.com>
Rebase-Id: R278606210f20aacc885fa9eb06b3a2a3d8677b55
bug 827505
Original-Change-Id: If6d4fd137b72c3a08bf8fb1094d8dd31ab361f1c
Reviewed-on: http://git-master/r/31633
Reviewed-by: Frank Thomas Bourgeois <fbourgeois@nvidia.com>
Rebase-Id: R563eaa39b299d89133f7a9fb4b1c7129e8ddb71e
Adding a build time CONFIG option to enable forcing of conversion
of non-IRAM CarveOut memory allocation requests to IOVM requests.
Default is "y" to force the conversion.
Each forced conversion is reported to console.
Allocation alignments larger than page size for IOVM are enabled.
Single page CarveOut allocations are converted to system memory.
CarveOut memory reservation has been removed for aruba, cardhu,
and enterprise.
Original-Change-Id: I3a598431d15b92ce853b3bec97be4b583d021264
Reviewed-on: http://git-master/r/29849
Rebase-Id: R602260e283f721b7e0f0d802092516ff68c068fe
Original-Change-Id: I158d2be97c795313e7e74ce9fb4ec0bdc7d95496
Reviewed-on: http://git-master/r/27559
Tested-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Reviewed-by: Jin Qian <jqian@nvidia.com>
Original-Change-Id: I0ff198daa548ed2837f7fb1794013bf0adf7e5a1
Rebase-Id: R83df5f3b5104183bfe774d8eed8ce94427c9b7fc
This commit:
tegra:video:nvmap: optimize cache_maint operation.
added some dead code
Original-Change-Id: I9193a7865f5e3126b06950efaf9b5a4b6c7fd919
Rebase-Id: R30ba7719d8aa6ad48d708714396299b154cf0131
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: R5a6d087b717731c957b016f903fb82b4ea22b92d
Bug 764354
Original-Change-Id: I807433ff825bed1fe91ce0cf50a2b3691c64ef0a
Reviewed-on: http://git-master/r/12227
Original-Change-Id: I3da91a438f98f2f51618446ce024f3fefd726a19
Rebase-Id: Rb1717b1f80aaf0242f4da555ce16c06946b7d072
nvmap's debugfs had a bad format so it was
very difficult to read the outputs. this commit
fixes it and added total allocation size along
with it
Bug 813891
Original-Change-Id: I6e3165b3ff917d9510d39f1e35b8e6b59c086592
Reviewed-on: http://git-master/r/27349
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
Rebase-Id: R0959d3648c3fe8e1d0a4bbbca5e79f0b5a744c6f
video:tegra:nvmap: Clean whole L1 instead of cleaning by MVA
For large allocations, cleaning each page of the allocation can
take a significant amount of time. If an allocation that nvmap needs
to clean or invalidate out of the cache is significantly larger than
the cache, just flush the entire cache by set/ways.
bug 788967
Reviewed-on: http://git-master/r/19354
(cherry picked from commit c01c12e63b1476501204152356867aeb5091fb80)
optimize cache_maint operation for carveout and heap memories.
flush carveout memory allocations on memory free.
Bug 761637
Reviewed-on: http://git-master/r/21205
drivers/video/tegra/nvmap/nvmap_dev.c
drivers/video/tegra/nvmap/nvmap_heap.c
drivers/video/tegra/nvmap/nvmap_ioctl.c
(cherry picked from commit 731df4df5e895e1d4999359d6d5939fc2095f883)
tegra:video:nvmap: optimize cache flush for system heap pages.
optimize cache flush for pages allocated from system heap.
Bug 788187
Reviewed-on: http://git-master/r/21687
(cherry picked from commit 3f318911ad91410aed53c90494210e2b8f74308b)
Original-Change-Id: Ia7b90ba0b50acfef1b88dd8095219c51733e027f
Reviewed-on: http://git-master/r/23465
Rebase-Id: R04f618f88ed1d2c7a680d51a8c5113f42de3f667
Bug 786016
Original-Change-Id: Ic72c57b710a305851dfea3dda3eb217156683b39
Reviewed-on: http://git-master/r/17795
Rebase-Id: R9839c206d5606463e124c59f733282561ff8a48d
Enabled mutex debugging reavealed potential deadlocks
introduced with compaction.
Handle spin lock replaced with mutex. Heap functions cannot be
protected with spinlock because they call kernel slab allocation
functions which cannot be called from atomic context.
nvmap_client ref_lock is also replaced with mutex. Otherwise we
cannot access heap parameters protected by mutex nvmap_handle lock.
Extra locking for handle->owner removed.
bug 793364
Original-Change-Id: I635ce9ebf259dd7bf8802457567f93b7be5795ea
Reviewed-on: http://git-master/r/19850
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Reaa132703e278d75371d5e2b25426794aa8e0e4e
There are places where nvmap_free_handle_id is called
when interrupts are disabled and mutex cannot be used as
nvmap handle lock.
Original-Change-Id: Icc220fe627c08f21c677d936a54f70c818dc8e8c
Reviewed-on: http://git-master/r/19489
Rebase-Id: Rb5a58e8226ad14340d1acae007d6b632960fae16
bug 762482
Original-Change-Id: Ifadebc1b0c4eb0df89e179091acca0ff6e527e56
Reviewed-on: http://git-master/r/15743
Rebase-Id: R639e7f09f44c8919bd57a16a577b87db91160555
This reverts commit be7b9ce20d645c2c9293441830ee33a0a5fc489f.
Rebase-Id: R34033f7a7ed72aeb1e2a83ad5a09c219d3254048
Need cache maintenance on rw_handle to remove
display garbage issue which happens randomly.
Change-Id: I73606ae6551c0e75058e055f4a19e5f074a47004
Signed-off-by: Greg Roth <groth@nvidia.com>
Change-Id: I51fe70b92f256951e68c6bbd21e6b4d6081f4731
This reverts commit b3cc1d84d0b962fe80fc297d2e2417c3157508b6.
This reverts commit 2d49bf33f3885aab293f12d54447f66e911e3226.
Patch has dependency to the user-space patches
Submitted on behalf of: Chris Johnson <cjohnson@nvidia.com>
original work by: Chris Johnson <cjohnson@nvidia.com>
Change-Id: I4d4e5d3b49cab860485c4172f87247f5b4f5ea6e
An attempt had been made to reduce the number of pte operations
while patching relocs. The optimization was incorrectly coded
and was not providing the expected speedup.
Credit for the find goes to Peter Pipkorn.
Change-Id: Ic83b20ee470e54d5053f747dbcbdf7b038b7c7c4
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
-Add a module param to enable/disable carveout killer
-Fix race condition in code to wait for something to free memory
after firing carveout killer
-Fix the check for current so we always compare task->group_leaders
Change-Id: Ie030978827dce6b0fbbfa1db0d80e4abe59eaa51
-Modify the carveout killer to only kill tasks with lower priorities
than the one that's trying to allocate
-After delivering a sigkill to a task, wait for something to exit and
cleanup before retrying the allocation
Change-Id: If62b6ed008a73fc3c347ff26735a83eee284909e
No need to maintain a reference to the task struct if the client
is a kernel thread. In this case just set the task to NULL.
Change-Id: Ica4785388932f6b298eeb0da04b78b0e1cdc3a44
This change attempts to reclaim carveout memory by killing
other carveout users when an allocation fails. Processes
are killed in order of priority from lowest to highest, and then
from largest to smallest users.
Change-Id: Iee8a6f36269bc8165d691000a153dbf9f4337775
Change-Id: I1ec34fd4a6bb21a6d84912a7228c209f459261be
A struct nvmap_handle may be shared by multiple clients. If the
original client (the handle "owner") is destroyed, but the handle is
still referenced by other clients, h->owner points to freed memory. To
prevent this, clear h->owner when the owner frees its reference to that
struct nvmap_handle.
Change-Id: I54722091568ce2058f5988e5f6e00e68605a8100
Fix the way the total number of carveout allocations is
managed per client.
Change-Id: I3e12e2a98a74cafc1f4c51a48e3c3c549e930160
This reverts commit e3ad53ad739afae7e8a4252c807a195e2311cfa7.
This modifies the api to allow the user to specify a name
for their clients. This will allow the system to track
allocations from the kernel by name.
Change-Id: I44aad209bc54e72126be3bebfe416b30291d206c
Moves the file tracking clients to debugfs
Add a debugfs file to track the list of allocations per client
Change-Id: I2bb683e3ac0599fa05d962c79ef0b7cbd0007d75
Prints a log message if the nvmap allocate ioctl fails.
Change-Id: Ia0777bc2fcd665dafff0f8948b01faad3f552d72
In the current implementation handles hold references to a
client and clients hold references to their handles. As a
result when a process terminates it's handles can't be cleaned
up and we leak memory. Instead only hold references to handles
from clients.
Change-Id: Iba699e740a043deaf0a78b13b4ea01544675078f
