Add following VGA video modes in tegra_dc_hdmi_supported_modes list:
Resolution Refresh rate(Hz)
640x480 75
720x400 59
800x600 60
800x600 75
1024x768 75
1024x768 60
1152x864 75
1280x800 60
1280x960 60
1280x1024 60
1368x768 60
1440x900 60
1600x1200 75
1680x1050 60
Add CVT representation of all above modes to make sure they pass all the
HDMI constraints.
Add a new function tegra_dc_reload_mode to pick up CVT representation of
matching mode.
Bug 883911
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Change-Id: I5227644207d38ca83a0452d3c078ef202e40a508
Reviewed-on: http://git-master/r/89126
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Not disabling emc clock when it's being set to zero results in incorrect
reference count when a call is made to clear bandwidth. This happens when
two worker threads try to handle dc emc rate. A deep-sleep/wake-up cycle
easily shows this scenario.
With this fix, disp.emc's ref count is properly managed even after multiple
deep-sleep/wake-up cycles.
Bug 947228
Change-Id: I045fafbd483af1e3d492b8d0395275e45642d059
Signed-off-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-on: http://git-master/r/90100
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Change waitchk comparison logic to use the new
nvhost_syncpt_is_expired().
Bug 941327
Change-Id: Ib7de04ad7663990bb416e39f8d79a46a9f5955fa
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/89769
- split the nvhost clients into their own directories
- each client is a nvhost_device and nvhost_driver
- all the code related to host1x control node is centralized
at single place in dev.c
- all the code related to host1x modules nodes is centralized
at single place in bus_client.c
- update the copyright notice & year for new files
Bug 871237
Change-Id: Ief85064699e35ad02b48a7e54496928d7f085af4
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/83491
dsi HW does not clear host trigger bit automatically
on dsi interface disable if host fifo is empty.
This leads to hang. Clearing the bit explicitly.
Bug 930453
Change-Id: Id24359dc274f187f8ac634ad838ef4a6a29a6a5e
Signed-off-by: Animesh Kishore <ankishore@nvidia.com>
Reviewed-on: http://git-master/r/90043
Update nvmap_alloc api to take heap_mask as arg.
This is to let clients specify the specific heap needed.
Change-Id: I9950b3e60e6dac0301b6dc66be3e9d0bab8e0fee
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/90471
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Fix sync point comparison to take into account old expired values, and
do proper comparison taking into account wrapping.
Bug 941327
Change-Id: I70724637ba870b2e29bac695abc0ea2b968394d7
Reviewed-on: http://git-master/r/84808
Reviewed-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-by: Acorn Pooley <apooley@nvidia.com>
Bug 925987
Change-Id: Ifab4e515c7dd06b92d798e7eb93094c35e02b878
Reviewed-on: http://git-master/r/89414
Reviewed-by: Simone Willett <swillett@nvidia.com>
fix some build warnings and bad code style.
Change-Id: I907296ce0e5437dfd6acd0b2b3c119b6dbde7b1c
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/89634
this is a workaround for the SLI scissor bug which can happen
intermittently.
Bug 914785
Change-Id: I5b7071df5bbfdd03bfe8b6f6b12ac7279221bd4e
Signed-off-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-on: http://git-master/r/87968
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Add checks to ensure host1x is powered when DSI is used.
Change-Id: I2e61abdd5c0741571fb18262fd2efa16ffee71d9
Reviewed-on: http://git-master/r/86361
Currently nvhost hard codes usage of context handler and sync point
id. Split the context handler and context structures into generic and
host1x specific parts, and move the allocation to happen via a
function pointer in nvhost_device.
Also updates gr3d and mpe to use sync point id and waitbase from
nvhost_device.
Bug 926690
Change-Id: I7f00b450cac99f3816baa27b37ee4e4cf68cfe24
Reviewed-on: http://git-master/r/84901
Fix race condition in handle_page_alloc. Page allocations
should not try allocate from pool, once it fails for a
request. If it tries and allocation passes during subsequent
attempts, the page_index is not valid for CPA and cache won't be
flushed for all the necessary pages.
Change-Id: I5548e11b713f271cc8473a3f2ae193a69e832f99
Reviewed-on: http://git-master/r/89611
There are HDMI modes which have different margin/sync values
although resolution and pixel clock are the same. One example
is 1080p/24Hz and 1080p/30Hz case.
Those modes are not distinguished when we check if given two
modes are equal. So clocks per frame also should be validated
to decide sameness of the modes.
Bug 950935
Signed-off-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-on: http://git-master/r/89026
(cherry picked from commit b9e6316850a47445be7545aaec85c6a247c44cb9)
Change-Id: I06d3c0f41e63d65f1908614d09df4d16028895f0
Reviewed-on: http://git-master/r/90030
We add this variable for two purposes. First, it would remind developer
to make sure actual refresh rate is larger than rated refresh rate.
Second, gralloc would read rated refresh rate for one-shot mode since
actual refresh rates of most devices are expected running at rated
refresh rate.
Bug 946370
Bug 934977
Change-Id: Ib4121337df1a388b40440b22687c39f373f08890
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/89871
Horizontal blank must be greater than phy timing for
HS transmission.
Bug 938043
Change-Id: I5afe68ec04341f7b83c2897c586d4618bd518222
Reviewed-on: http://git-master/r/89789
Adding support to accomodate hw increment to
phy timing reg values.
Bug 938043
Change-Id: I8de14648c0994b03c37a2ee455a656ff11c3cc34
Reviewed-on: http://git-master/r/89741
Replace license information in nvhost with GPLv2. Also adds
copyright year 2012 in files which have been changed in 2012.
Change-Id: I86e8ed27095df13d99e0250e57e244d531fdacec
Reviewed-on: http://git-master/r/89735
Disable interrupts when driver is being removed.
Bug 952600
Change-Id: I1d697c3c87aca935deadfe20b5e8fa8852b0e556
Reviewed-on: http://git-master/r/89405
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Bug 951626
Change-Id: Ia7c7474aa0f066cba8bd1519a98e302c4b3992e0
Reviewed-on: http://git-master/r/89076
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Changing page attributes and cache maintenance reduces
performance in applications doing runtime reallocations.
Keep pool of UC & WC pages to avoid expensive
operations when doing allocations.
bug 865816
(refactored initial changes from Kirill and added shrinker
notification handling)
Change-Id: I43206efb1adc750ded672bfe074e0648f2f9490b
Reviewed-on: http://git-master/r/87532
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Fixed rate setting problem what set rate for only a clock in nvhost
device, even if there are clocks more than one in nvhost device.
Bug 938580
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/85129
(cherry picked from commit 5818d42dc0ad5dfa7659dca5d7f61b572c08613d)
Change-Id: Id3a7be50541b1d93a2ed7353f3eabc71dd398773
Reviewed-on: http://git-master/r/87276
Tested-by: Jinyoung Park <jinyoungp@nvidia.com>
Remove unnecessary 100ms delay for primary panel since
this is needed for HDMI type only.
Bug 940012
Change-Id: Id27966fb28faa73ade3a868a9f89cadbde76e227
Signed-off-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-on: http://git-master/r/87613
The returned capabilities bitfield is initially 0 (no caps).
bug 942631
Change-Id: Ia7496981e525526147ecebe67b09dc877d3e0c17
Reviewed-on: http://git-master/r/87088
Tested-by: Adam Cheney <acheney@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Add lock to prevent race condition between cancellation of old delayed
work and schedule of new delayed work.
Bug 936337
Change-Id: I52df82e92279163841546127c72be9879ef810d0
Reviewed-on: http://git-master/r/86730
nvhost_job uses kzalloc to hold meta data. Convert
it to vzalloc to avoid large physically contiguous
allocations at runtime.
Change-Id: I13d7e7d60e93354fcf69e5478437fa206b880dcc
Reviewed-on: http://git-master/r/87967
Power gating timeout for 3D is too short, and causes oscillation
in non-idle use cases. Increase timeout to 250ms to get more benefits
from power gating.
Bug 914785
Change-Id: I4e37fda260ceecc2fe3e21989789105b7c8fcf36
Reviewed-on: http://git-master/r/87659
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-by: Graziano Misuraca <gmisuraca@nvidia.com>
In panel resume path DSI_PAD_CONTROL value gets calibrated,
however later on values are overwritten with bit settings
for ulpm mode.
refactor value for reg write to only change ulpm related bits.
Change-Id: I9f9713bdf376c06b0e1b9f43b3e6c9f719bbd855
Signed-off-by: Boris Suvorov <bsuvorov@nvidia.com>
Reviewed-on: http://git-master/r/85873
- the suspend order of devices is governed by the order
in which devices are registered
- this commit ensures that nvhost master is registered before
any of the graphics devices
- previously this was done in rootfs_init call which is
later than arch_init calls of board-xxx-panel.c
- this caused tegra-dc device to be registered *before* nvhost
master device. as a result it was suspended *later* than nvhost
master device. this is a clear violation of dependency rule
for nvhost. this caused suspend-resume to fail for L4T
- this worked on android as it has CONFIG early suspend enabled
while it failed for L4T which doesn't have CONFIG early suspend
enabled
Bug 947617
Change-Id: I6cd405f3ba23d004e7659140019f5130e6c25159
Reviewed-on: http://git-master/r/87756
Fixing dsi syncpt hang issue after multiple cycles of
early suspend-late resume.
Bug 943096
Change-Id: Iefc0530a6e514b7733819dd1df35cde8f5c3dd47
Reviewed-on: http://git-master/r/86946
Reviewed-by: Sang-Hun Lee <sanlee@nvidia.com>
Tested-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
- tegra_grhost is a platform device that represents host1x
- nvhost has device host1x which represents the same hardware
- merge these two device structs
- as the new struct is a nvhost_device, platform_driver
is also converted into a nvhost_driver
- register nvhost device before other graphics devices.
this ensures that nvhost_probe() is called as soon as
nvhost_driver is registered with the core.
- this also ensures that nvmap is probed first, followed
by nvhost, followed by tegra-dc and nvavp (if they
are enabled).
Change-Id: Ic420a6516a9cb20d6f481692a4db10fa6053dd90
Reviewed-on: http://git-master/r/82631
There exits an issue that if window number is less than DC_N_WINDOWS,
window option of some windows won't be cleared. So although it should
be disabled, it might not be disabled properly. This will lead to the
failure of scan-out on screen.
Bug 943846
Change-Id: I604399abaa590b27ab4ea41ed9eb2706be16a75a
Reviewed-on: http://git-master/r/86230
If submit failed, for example when we ran out of memory, we should
reject any subsequent writes.
Bug 936097
Change-Id: Ic124fc08b7715532d210a0c0d0b7aebcb54e43d4
Reviewed-on: http://git-master/r/85479
Don't override contiguous flag in nvmap_page_alloc().
This is causing incorrect iovm_commit accounting.
Bug 938864
Change-Id: If30ea43702465980914b12816fa28eac9e14581d
Reviewed-on: http://git-master/r/85319
Reviewed-by: Kamal Balagopalan <kbalagopalan@nvidia.com>
Tested-by: Kamal Balagopalan <kbalagopalan@nvidia.com>
Use correct type.
Change-Id: Iec3ec1624e4f14c36f02fbee6d838f4b2d188569
Signed-off-by: Hiroshi DOYU <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/84947
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Corrected the formulas to calculate phy timing.
Added mipi d-phy constraints.
Bug 938043
Change-Id: Ie1f2dd45e7e39f83735fe28e21a62dc0415c7c00
Reviewed-on: http://git-master/r/85217
Reviewed-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Change sync point debug dump filtering so that client managed sync
points are added to output.
Remove also an infinite loop when sync point value goes beyond maximum.
Debug dump calls t20_syncpt_update_min, which should not call debug
dump again.
Change-Id: I086a3c21d6171d083e5254e7a34b1582e38a3e49
Reviewed-on: http://git-master/r/84940
GENERAL_ACT_REQ causes double-buffered registers to become active.
This register needs to be programed to reduce the latency of pixel clock after
dc enabled by tegra_dc_enable().
bug 926189
Signed-off-by: Ken Chang <kenc@nvidia.com>
Reviewed-on: http://git-master/r/83346
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
(cherry picked from commit f39c5ddd1867c508900c9aa2d4eead7eb3082343)
Change-Id: I741c9be9074709c1ab571aa631cb462599d5fb78
Reviewed-on: http://git-master/r/84561
A V_BLANK interrupt for each frame does not allow long lp2 idle intervals.
If all windows are clean, mask V_BLANK interrupt after processing it
for updating smart dimmer. It's unmasked again when a new window update
is performed. This will schedule a work for updating smart dimmer for
the new frame.
Bug 920110
Reviewed-on: http://git-master/r/85137
(cherry picked from commit 68398090aee22cf02069e5767c3e9a062b0fc2f6)
Change-Id: I588328bfd0d6036febed236dc07f441878aa81d1
Reviewed-on: http://git-master/r/85166
At system resume, host1x sync point values are restored from memory, and
interrupts are enabled. This is done in reverse order, and in cases it might be
that interrupt is triggered while sync point values are still being restored.
Bug 940381
Change-Id: I0191b84b41306e0f0ba0758d41e5632dcf9d06cd
Reviewed-on: http://git-master/r/83995
Reviewed-by: Bo Yan <byan@nvidia.com>
Sync queue is the list of jobs still in flight. As context priorities
requires possibility to insert a job in the middle of the queue, the
structure needs to be changed into a linked list.
Bug 926690
Change-Id: Id257a11f18476c70dd69e36ba44ed2d380c80040
Reviewed-on: http://git-master/r/83127
When user space calls NvRmChannelSyncPointIncr(), the maximum value of sync
point should not be incremented unless sync point is client managed.
Also prevents kernel panic if user space tries to increment beyond maximum.
Instead, give debug spew and ignore.
Bug 936097
Change-Id: I4dc7ed46b1e0394d41066051a47f1d7a1f08493c
Reviewed-on: http://git-master/r/79957
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Add a config option to limit HDMI stereo 3D output to 74.25MHz pixel clock.
When this option is set,
substitute the frame pack stereo modes
for side-by-side (half) left-right stereo modes
to meet this pixel clock restriction.
By default, do not use it (use frame packed HDMI mode as usual).
Bug 938807
Change-Id: I2ce2ca72cbb15ac1939af0f3386dd23650262435
Reviewed-on: http://git-master/r/84252
Reviewed-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Tested-by: Andrija Bosnjakovic <abosnjakovic@nvidia.com>
Add current values of sync points to sync point read and wait
IOCTL's.
Change-Id: I479a66e283b47867ed13685b75c1858b4fb65c2d
Reviewed-on: http://git-master/r/80006
This is a workaround to make sure serialization of flip worker,
for Android specific.
Android doesn't need mutiple workqueues per each window
since it gets composited one from user layer.
If the last windows' argument index is not 0,
provided change will make the last index to 0 with swap operation
so work will be queued into one workqueue all the time.
Bug 929993
Bug 932592
Bug 933831
Bug 935623
Bug 934569
Change-Id: Ic467bb4f593c72ae98ea1fb324cf1a6d343faa62
Reviewed-on: http://git-master/r/82971
Configure voltage regulator.
Bug 914749
Change-Id: I6cf1924a928839249d4e62029dd14fca84b05792
Reviewed-on: http://git-master/r/83361
If dsi host is unexpectedly busy, soft resetting
will restore controller state.
Bug 930453
Change-Id: I1bbce55d0b27a2be80a66218978e73c616e9d894
Reviewed-on: http://git-master/r/83986
This reverts commit 961c60fe7213d92793d6072abc16f58721a33fed
Change-Id: I8ef0fbaee30e94c78b8df609f729953fee6d1583
Reviewed-on: http://git-master/r/84135
When dc gets many underflows, instances of reset worker can race
to perform reset. dc ext was getting disabled outside critical region
affecting display path. disable dc ext after getting the lock.
Bug 936545
Reviewed-on: http://git-master/r/83108
(cherry picked from commit f9dcf7eee8ca8db28cee6fa9550044d1f746e843)
Change-Id: Ie29dc66eb52c9be472c2d0db8c0014bfe1837ad4
Reviewed-on: http://git-master/r/83406
Bug 932840
Change-Id: I12d8d2d2cd42d0dafea38463ad77b44f7e64d7c1
Reviewed-on: http://git-master/r/83645
