When a DC window is being released, a NULL flip is used to indicate
that the window should be disabled. To disable a window, 0 is
written to WIN_OPTIONS.
The MC_DECERR on window shutdown is a symptom of forgetting step 2)
below when disabling windows, leaving no indication that there is
anything to wait for. This causes DC to erroneously unpin the
scanout buffer while the buffer is still actively being used.
Summary of flip (window update) synchronization in DC:
1) program some window registers
2) set win->dirty=1
3) schedule the activation of the registers
4) request VBLANK or HBLANK interrupts
5) wait for win->dirty==0
In the trigger_windows ISR (every VBLANK or HBLANK):
1) if there is no window update pending in HW, clear dirty flag to
indicate that ACTIVE registers are up-to-date.
bug 991572
bug 995614
bug 989119
bug 983251
bug 960424
bug 866711
Change-Id: I8b710aac874b202838c3989608b7e0bd15425382
Signed-off-by: Adam Cheney <acheney@nvidia.com>
Reviewed-on: http://git-master/r/109370
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Nirav Patel <nipatel@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Make all chip specific functions static. Include the chip specific
functions in SoC files after including the hardware headers. This
makes the chip specific functions to be compiled per SoC, and with
the correct hardware definitions.
Bug 982965
Change-Id: I4774d4dc351951cb886d9d4da66cf021f3f0121e
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/107581
Give names to the structures inside nvhost_chip_support. This way
they can be referred to individually.
Change-Id: I9b727bfc232d11957a8bd3e3570583d47cff778e
Reviewed-on: http://git-master/r/109103
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Remove unused functions in CDMA and debug. They were left unused
when debug dump started using sync queue instead of channel
registers for detecting current position.
Change-Id: Ib1f0bc8f702667d0453079e6d5f5d8ca08f8db09
Reviewed-on: http://git-master/r/109102
Call drain fifo and save context functions via nvhost_chip_support.
Earlier client drivers called into host1x code directly, which
makes each client driver SoC specific.
Change-Id: I4f805abad21012e59e11bf6a98fa46441c71c51a
Reviewed-on: http://git-master/r/109101
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/108827
Reviewed-by: Francis Hart <fhart@nvidia.com>
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Remove version from nvhost_device name, and use a new field,
version, to distinguish between IP versions. This restores the
sysfs API for 3D clock scaling back to its original path.
Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686
Reviewed-on: http://git-master/r/108501
Reviewed-by: Simone Willett <swillett@nvidia.com>
Move #include directives for nvhost headers from dc_priv.h to the
source files that need the #includes. This allows #including
dc_priv.h without access to all nvhost headers.
Also adds nvhost to the #include path of dc to allow making dev.h a
stub in a later commit.
Bug 982965
Change-Id: Icfe7084d295f57926195b178174f81047eb01187
Reviewed-on: http://git-master/r/108225
Add parameters in host1x nvhost_device on
* number of sync points
* number of wait bases
* number of channels
* number of mlocks
* client managed bitmask
* naming of sync points
Add automatically generated headers and use symbols from them to
access hardware.
Move host1x device definition from generic host1x to SoC specific
source files t20.c and t30.c.
Bug 982965
Change-Id: Ibec84be22d75b363900d10bcbd59d4d8321d54a1
Reviewed-on: http://git-master/r/104974
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Reviewed-on: http://git-master/r/104076
The tegra_dc_trigger_windows function was improperly using the
WIN_x_UPDATE bits to determine when a flip has occurred instead of the
WIN_x_ACT_REQ bits. Without this change, it's possible for the postflip
syncpoint for a buffer to get incremented before it actually flips.
Still need to figure out why that's even possible...
Fixes bug 902955
Change-Id: I67ba093a0114646977cc8cb95a040ec4178cebfc
Reviewed-on: http://git-master/r/65389
Reviewed-by: Nate Huang <nhuang@nvidia.com>
Tested-by: Nate Huang <nhuang@nvidia.com>
Reviewed-on: http://git-master/r/98024
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 990586
Change-Id: I63da2bd0aaae86070718e0d769b8c9555db18547
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/107714
Add configuration variable for default timeout for clients. Set it to
30s for silicon and infinity for simulation.
Change-Id: I08c1fd234f738c4919adfe482dfc50948dc2f862
Reviewed-on: http://git-master/r/105331
Bug 936337
Bug 899053
Change-Id: I2b3d8cfc8a00881338c1e17d03f2844d15ba7d3e
Reviewed-on: http://git-master/r/106313
Abstract nvmap support to one file, and use it via function pointers
from other parts of nvhost.
Bug 965206
Change-Id: I4e5e7de4271e0797d117ac8210af4732b6018973
Reviewed-on: http://git-master/r/105665
Initialize host1x generic irq at bootup.
Bug 971602
Change-Id: I03fb426a0538c1549fdb5360166c4e4b516e75d6
Reviewed-on: http://git-master/r/106167
GVS: Gerrit_Virtual_Submit
Clear out all overlays and disable DC on .shutdown
Change-Id: I4bc78fddb0ed8bd621733df191f305ecb279e3f7
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/106549
Move bandwidth calculation logic into its own file.
Change-Id: I57f58a6399805eede8783fea922c6f07dcbd54cb
Reviewed-on: http://git-master/r/106291
removed tegra_dc_hdmi_mode_equal.
It was replaced by tegra_dc_hdmi_cvt_mode_equal
Change-Id: I7988d02a1c0b91eed88fdf573d8c993b6ee7be8d
Reviewed-on: http://git-master/r/106074
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
remove and rename unused variable in tega_dc_get_stride
Change-Id: I0d101de22c08609f9727469ad7e4708de8de59ef
Reviewed-on: http://git-master/r/106072
drivers/media/video/tegra/nvavp/nvavp_dev.c
Change-Id: I7779b0ce58004f80cccf6193148ac49551ce5da5
The function tegra_dc_host_trigger() is no longer used, removing it.
Change-Id: I929450bdf0224779910e8569bc8d1b3edb93f12d
Reviewed-on: http://git-master/r/106075
Added void to function prototypes and initialized some variables.
Change-Id: I69250f5e17560f900fffddec9697e496af6ad4d2
Reviewed-on: http://git-master/r/106073
Bug 992947
Change-Id: I0d1ecc9f8f042956cbe631779260a38573936616
Reviewed-on: http://git-master/r/105776
Change to correct behavior for changing settings while
phase_in_adjustments is set. Manual K values should not be overridden
in the case where DIDIM was on and aggressiveness was changed.
They should maintain state to avoid flickering.
Bug 992995
Change-Id: Ic35c32a0fd5c6caaeee147dff114649ea25770c5
Signed-off-by: Matt Wagner <mwagner@nvidia.com>
Reviewed-on: http://git-master/r/105523
Change-Id: I762929a0d72a0b26aa1451a946993f4a57806fd4
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/104292
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Reviewed-by: Hiro Sugawara <hsugawara@nvidia.com>
Remove BUG_ON()s in error cases:
* If IOCTL size is too large, return error instead
* If sync point id is out of range, return error. Prevents panics in
sanity checks nvhost_cdma.
Bug 993642
Change-Id: I3cfa7a23dc557c811e20b726885f82666437de7f
Reviewed-on: http://git-master/r/105866
Register access (read/write) to modules MPE, ISP and VI lack sanity
check for the register number. Add checks to ensure only aperture is
accessed. Also make sure that the check accounts for wrapping of
values of offset and count.
Also fixes the register offset for reads which are done in multiple
blocks.
Bug 992938
Change-Id: I35f30cbd1dda31956286e48c5995b24fd262d1ae
Reviewed-on: http://git-master/r/105585
Add config option to enable/disable cache maintenance by set/ways.
Change-Id: Ie795e19650b2c05cd4789dbc1e8f04f9edc70bf1
Reviewed-on: http://git-master/r/104290
Remove nvhost dsi driver. Real dsi driver is in tegradc.
Bug 982965
Change-Id: I86044ba586d796ae8d049471a154dcf37bd0e6ed
Reviewed-on: http://git-master/r/104975
Tested-by: Terje Bergstrom <tbergstrom@nvidia.com>
Convert the jiffies to msecs when assigning a channel the default
timeout.
Change-Id: If9b6fb7c695e9621a0c50d99d4d1362b6dd214b6
Reviewed-on: http://git-master/r/105022
When a submit fails, the related nvhost_job is not freed. Add an
explicit free. Also, 3D is mapping the save buffer, but it is not
unmapped.
Bug 991972
Change-Id: Ie335adb5e64f54557e76d12dfb6a9a1557781e8d
Reviewed-on: http://git-master/r/105152
Dump contents of sync queue when debug dump is requested, either
because of a stuck sync point, or when the debugfs entry is accessed.
Exclude FIFO from normal debugfs dump. Dumping FIFO is invasive and
actually changes how the channel behaves. It's safe to dump only when
system is in fault condition.
Change-Id: I12c68e8186acd7bd17e4ab52b2589f765396ed17
Reviewed-on: http://git-master/r/104970
Implement per channel counter for jobs in each priority level. If
there are jobs active with higher priority than the one being
submitted, throttle.
Bug 926690
Change-Id: I5fed341e3f248325873b31d1c53bf57bf0a78074
Reviewed-on: http://git-master/r/104939
Remove nvmap_pin_array() and nvmap_patch_word() and their utility
functions.
Bug 965206
Change-Id: I217a427934b0b99b5252b33ab3ac4eaaa8c7e076
Reviewed-on: http://git-master/r/104451
Replace usage of nvmap_pinarray_elem with own nvhost_reloc and
nvhost_reloc_shift structs.
Bug 965206
Change-Id: I90618d8a34d79156d8880d9925dadbf416353811
Reviewed-on: http://git-master/r/104450
Job pinning and relocation already maps the gather buffers to
kernel memory. Move waitchk to be done at the same time so that we
do not need to re-map the memory to patch expired waits.
Bug 965206
Change-Id: I23634b501a45de080200e57d3debf267b39fea38
Reviewed-on: http://git-master/r/104415
This reverts commit 5bdd03b21f625d0a07c66e4894b79e557287a3a1.
The reverted commit kept vcore at 1.2 volts whenever 2D engine is on
and increased power consumption for use cases that utilize 2D but
doesn't require its full speed.
Bug 979545
Change-Id: I4297ab1fb83558501ff620952284c8590dc5f1dd
Signed-off-by: Wen Yi <wyi@nvidia.com>
Reviewed-on: http://git-master/r/104293
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
Debug allocations data for iovmm has carvout allocations
also and vice versa. Fixed it to show only iovmm for iovmm
and carveout for carveout.
Add missing "FLAGS" print for iovmm allocations.
Change-Id: I0fd271be24d0d2d3924ca473fd32476776fdcf84
Reviewed-on: http://git-master/r/104246
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Clean up carveout to iovmm conversion code.
Fixed bug in converting iovmm requests to carveout.
Change-Id: I35a5238c955d0478f0e1a295e501bae9ee52b0a8
Reviewed-on: http://git-master/r/103991
Change function declaration order to avoid multiple
CONFIG_TEGRA_NVMAP #ifdef's.
Change-Id: Icb10380f8da4b8037b90e787f961a28e8528814f
Reviewed-on: http://git-master/r/103990
nvhost_syncpt_wait_timeout() relies on sync point interrupt to
signal reaching the sync point value. With low timeout values, the
resolution is not good enough and an error is returned even when
the value is reached.
Update syncpoint value from hardware when doing a sync point wait and
do an explicit check for reaching the value even if wait returns a
timeout.
bug 984166
bug 986788
bug 987597
Change-Id: I640e32cdcdfa66b8977eac273dd32f62bd72abd6
Reviewed-on: http://git-master/r/103827
- remove usage of custom interface of nvmap to patch the relocs and
and pin the gathers/relocs
- convert code that references nvmap_handle to nvmap_handle_ref
- add logic to pin and map only unique gathers and relocs
- rename nvhost_channel_gather to nvhost_job_gather, because it's
used in nvhost_job code only
Bug 965206
Change-Id: Iaa7fbac9e4a7b08c0a7c1e184b8dd3566e1edfe2
Reviewed-on: http://git-master/r/95299
Detect the stride size used by the bootloader.
If DC is not enabled, fallback to a default stride size.
Bug 973111
Change-Id: If04647ddf04a44987cd841062ff30e03fa4d6a02
Reviewed-on: http://git-master/r/104031
Enable dsi panel B by setting the first bit
in APB_MISC_GP_MIPI_PAD_CTRL_0 register.
Bug 935764
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Change-Id: I9e958e0c9d9e934edf77688fd6a987b5e863392b
Reviewed-on: http://git-master/r/96672
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
Reviewed-by: Animesh Kishore <ankishore@nvidia.com>
Used free memory check in allocation policy is not working,
because it doesn't calculate available physical memory size in
same way as android oom killer.
It also breaks kernel build if swapping is enabled.
Remove free memory check from allocation policy.
Change-Id: I214d1829451f313dbace967e87ed4111e688865d
Reviewed-on: http://git-master/r/85227
arch/arm/mach-tegra/pm.c
drivers/power/smb349-charger.c
include/linux/smb349-charger.h
include/trace/events/power.h
Change-Id: Ia8c82e2acfe3463ae6778bdd03aac8da104f7ad3
We support dynamic pixel-clock setting now, so open HDMI mode
filter by not rejecting a mode due to pixel clock mismatch. If the
mode's requested pixclock is within the suppoted range, check few
constraints of hardware and allow it.
Add aspect ratio check to reject modes with awkward aspect ratio.
Bug 967458
Signed-off-by: Shashank Sharma <shashanks@nvidia.com>
Change-Id: Ife474dbfe4137a000a4a43b0e1ff72847f2a8b0a
Reviewed-on: http://git-master/r/96163
