commit 936a3f770b8de7042d793272f008ef1bb08522e9 upstream.
This patch adds checks for minimum and maximum pitch size to prevent
invalid settings which could otherwise crash the machine. Also the
alignment is done in a slightly more readable way.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit d933990c57b498c092ceef591c7c5d69dbfe9f30 upstream.
As Laurent pointed out we must not use any information in the passed
var besides xoffset, yoffset and vmode as otherwise applications
might abuse it. Also use the aligned fix.line_length and not the
(possible) unaligned xres_virtual.
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 4a47a0e09c504e3ce0ccdb405411aefc5b09deb8 upstream.
Following on Herton's patch "fb: avoid possible deadlock caused by
fb_set_suspend" which moves lock_fb_info() out of fb_set_suspend()
to its callers, correct sh-mobile's locking around call to
fb_set_suspend() and the same sort of deaklocks with console_lock()
due to order of taking the lock.
console_lock() must be taken while fb_info is already locked and fb_info
must be locked while calling fb_set_suspend().
Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
commit 9e769ff3f585db8f978f9113be83d36c7e3965dd upstream.
A lock ordering issue can cause deadlocks: in framebuffer/console code,
all needed struct fb_info locks are taken before acquire_console_sem(),
in places which need to take console semaphore.
But fb_set_suspend is always called with console semaphore held, and
inside it we call lock_fb_info which gets the fb_info lock, inverse
locking order of what the rest of the code does. This causes a real
deadlock issue, when we write to state fb sysfs attribute (which calls
fb_set_suspend) while a framebuffer is being unregistered by
remove_conflicting_framebuffers, as can be shown by following show
blocked state trace on a test program which loads i915 and runs another
forked processes writing to state attribute:
Test process with semaphore held and trying to get fb_info lock:
fb-test2 D 0000000000000000 0 237 228 0x00000000
ffff8800774f3d68 0000000000000082 00000000000135c0 00000000000135c0
ffff880000000000 ffff8800774f3fd8 ffff8800774f3fd8 ffff880076ee4530
00000000000135c0 ffff8800774f3fd8 ffff8800774f2000 00000000000135c0
Call Trace:
[<ffffffff8141287a>] __mutex_lock_slowpath+0x11a/0x1e0
[<ffffffff814142f2>] ? _raw_spin_lock_irq+0x22/0x40
[<ffffffff814123d3>] mutex_lock+0x23/0x50
[<ffffffff8125dfc5>] lock_fb_info+0x25/0x60
[<ffffffff8125e3f0>] fb_set_suspend+0x20/0x80
[<ffffffff81263e2f>] store_fbstate+0x4f/0x70
[<ffffffff812e7f70>] dev_attr_store+0x20/0x30
[<ffffffff811c46b4>] sysfs_write_file+0xd4/0x160
[<ffffffff81155a26>] vfs_write+0xc6/0x190
[<ffffffff81155d51>] sys_write+0x51/0x90
[<ffffffff8100c012>] system_call_fastpath+0x16/0x1b
modprobe process stalled because has the fb_info lock (got inside
unregister_framebuffer) but waiting for the semaphore held by the
test process which is waiting to get the fb_info lock:
modprobe D 0000000000000000 0 230 218 0x00000000
ffff880077a4d618 0000000000000082 0000000000000001 0000000000000001
ffff880000000000 ffff880077a4dfd8 ffff880077a4dfd8 ffff8800775a2e20
00000000000135c0 ffff880077a4dfd8 ffff880077a4c000 00000000000135c0
Call Trace:
[<ffffffff81411fe5>] schedule_timeout+0x215/0x310
[<ffffffff81058051>] ? get_parent_ip+0x11/0x50
[<ffffffff814130dd>] __down+0x6d/0xb0
[<ffffffff81089f71>] down+0x41/0x50
[<ffffffff810629ac>] acquire_console_sem+0x2c/0x50
[<ffffffff812ca53d>] unbind_con_driver+0xad/0x2d0
[<ffffffff8126f5f7>] fbcon_event_notify+0x457/0x890
[<ffffffff814144ff>] ? _raw_spin_unlock_irqrestore+0x1f/0x50
[<ffffffff8141836d>] notifier_call_chain+0x4d/0x70
[<ffffffff8108a3b8>] __blocking_notifier_call_chain+0x58/0x80
[<ffffffff8108a3f6>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff8125dabb>] fb_notifier_call_chain+0x1b/0x20
[<ffffffff8125e6ac>] unregister_framebuffer+0x7c/0x130
[<ffffffff8125e8b3>] remove_conflicting_framebuffers+0x153/0x180
[<ffffffff8125eef3>] register_framebuffer+0x93/0x2c0
[<ffffffffa0331112>] drm_fb_helper_single_fb_probe+0x252/0x2f0 [drm_kms_helper]
[<ffffffffa03314a3>] drm_fb_helper_initial_config+0x2f3/0x6d0 [drm_kms_helper]
[<ffffffffa03318dd>] ? drm_fb_helper_single_add_all_connectors+0x5d/0x1c0 [drm_kms_helper]
[<ffffffffa037b588>] intel_fbdev_init+0xa8/0x160 [i915]
[<ffffffffa0343d74>] i915_driver_load+0x854/0x12b0 [i915]
[<ffffffffa02f0e7e>] drm_get_pci_dev+0x19e/0x360 [drm]
[<ffffffff8141821d>] ? sub_preempt_count+0x9d/0xd0
[<ffffffffa0386f91>] i915_pci_probe+0x15/0x17 [i915]
[<ffffffff8124481f>] local_pci_probe+0x5f/0xd0
[<ffffffff81244f89>] pci_device_probe+0x119/0x120
[<ffffffff812eccaa>] ? driver_sysfs_add+0x7a/0xb0
[<ffffffff812ed003>] driver_probe_device+0xa3/0x290
[<ffffffff812ed1f0>] ? __driver_attach+0x0/0xb0
[<ffffffff812ed29b>] __driver_attach+0xab/0xb0
[<ffffffff812ebd3e>] bus_for_each_dev+0x5e/0x90
[<ffffffff812ecc2e>] driver_attach+0x1e/0x20
[<ffffffff812ec6f2>] bus_add_driver+0xe2/0x320
[<ffffffffa03aa000>] ? i915_init+0x0/0x96 [i915]
[<ffffffff812ed536>] driver_register+0x76/0x140
[<ffffffff81245216>] __pci_register_driver+0x56/0xd0
[<ffffffffa02f1264>] drm_pci_init+0xe4/0xf0 [drm]
[<ffffffffa02e84a8>] drm_init+0x58/0x70 [drm]
[<ffffffffa03aa094>] i915_init+0x94/0x96 [i915]
[<ffffffff81002194>] do_one_initcall+0x44/0x190
[<ffffffff810a066b>] sys_init_module+0xcb/0x210
fb-test2 which reproduces above is available on kernel.org bug #26232.
To solve this issue, avoid calling lock_fb_info inside fb_set_suspend,
and move it out to where needed (callers of fb_set_suspend must call
lock_fb_info before if needed). So far, the only place which needs to
call lock_fb_info is store_fbstate, all other places which calls
fb_set_suspend are suspend/resume hooks that should not need the lock as
they should be run only when processes are already frozen in
suspend/resume.
References: https://bugzilla.kernel.org/show_bug.cgi?id=26232
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
commit c84c14224bbca6ec60d5851fcc87be0e34df2f44 upstream.
The third parameter of module_param is supposed to be an octal value.
The missing leading "0" causes the following:
$ ls -l /sys/module/carminefb/parameters/
total 0
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_displays
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_mode
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_mode_str
After fixing the perm parameter, we get the expected:
total 0
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_displays
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_mode
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_mode_str
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Since backlight_types[] isn't modified, let's declare it const. That
was probably the intention of the author of commit bb7ca747f8d6
("backlight: add backlight type"), via which the "const char const *"
construct was introduced. The duplicate const was detected by sparse.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
This is an i2c driver, not a platform driver, thus use "i2c" prefix for
the module alias.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
We need a callback to do some things after pwm_enable, pwm_disable
and pwm_config.
Signed-off-by: Dilan Lee <dilee@nvidia.com>
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Reviewed-by: Arun Murthy <arun.murthy@stericsson.com>
ep93xx_bl.c uses interfaces from linux/module.h, so it should include
that file. This patch fixes build errors:
CC [M] drivers/video/backlight/ep93xx_bl.o
drivers/video/backlight/ep93xx_bl.c:138: error: 'THIS_MODULE' undeclared here (not in a function)
drivers/video/backlight/ep93xx_bl.c:158: error: expected declaration specifiers or '...' before string constant
drivers/video/backlight/ep93xx_bl.c:158: warning: data definition has no type or storage class
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Cc: Ryan Mallon <rmallon@gmail.com>
Two additional savage4 variants were added, but the S3_SAVAGE4_SERIES
macro was incompletely modified, resulting in a false positive detection
of a savage4 card regardless of which savage card is actually present.
For non-savage4 series cards, such as a Savage/IX-MV card, this results
in garbled video and/or a hard-hang at boot time. Fix this by changing
an '||' to an '&&' in the S3_SAVAGE4_SERIES macro.
Signed-off-by: John P. Stanley <jpsinthemix@verizon.net>
Reviewed-by: Tormod Volden <debian.tormod@gmail.com>
[ The macros have incomplete parenthesis too, but whatever .. -Linus ]
i386 allmodconfig:
drivers/built-in.o: In function `aat2870_bl_remove':
aat2870_bl.c:(.text+0x414f9): undefined reference to `backlight_device_unregister'
drivers/built-in.o: In function `aat2870_bl_probe':
aat2870_bl.c:(.text+0x418fc): undefined reference to `backlight_device_register'
aat2870_bl.c:(.text+0x41a31): undefined reference to `backlight_device_unregiste
Cc: Jin Park <jinyoungp@nvidia.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Axel Lin <axel.lin@gmail.com>
- Current implementation tests wrong value for setting
aat2870_bl->max_current.
- In the current implementation, we cannot differentiate between 2 cases:
a) if pdata->max_current is not set , or
b) pdata->max_current is set to AAT2870_CURRENT_0_45 (which is also 0).
Fix it by setting AAT2870_CURRENT_0_45 to be 1 and adjust the equation in
aat2870_brightness() accordingly.
Tested-by: Jin Park <jinyoungp@nvidia.com>
backlight_device_register() returns ERR_PTR() on error.
* 'for-3.1-rc1' of git://gitorious.org/linux-omap-dss2/linux: (31 commits)
OMAP: DSS2: HDMI: fix hdmi clock name
HACK: OMAP: DSS2: clk hack for OMAP2/3
OMAP: DSS2: DSS: Fix context save/restore
OMAP: DSS2: DISPC: Fix context save/restore
OMAP: DSS2: Remove ctx loss count from dss.c
OMAP: DSS2: Remove unused code from display.c
OMAP: DSS2: DISPC: remove finegrained clk enables/disables
OMAP: DSS2: Remove unused opt_clock_available
OMAP: DSS2: Use PM runtime & HWMOD support
OMAP: DSS2: Remove CONFIG_OMAP2_DSS_SLEEP_BEFORE_RESET
OMAP: DSS2: Remove core_dump_clocks
OMAP: DSS2: DPI: remove unneeded SYSCK enable/disable
OMAP: DSS2: Use omap_pm_get_dev_context_loss_count to get ctx loss count
OMAP: DSS2: rewrite use of context_loss_count
OMAP: DSS2: Remove clk optimization at dss init
OMAP: DSS2: Fix init and unit sequence
OMAP: DSS2: Clean up probe for DSS & DSI
OMAP: DSS2: Handle dpll4_m4_ck in dss_get/put_clocks
OMAP: DSS2: Fix FIFO threshold and burst size for OMAP4
OMAP: DSS2: DSI: sync when disabling a display
The HDMI clock (hdmi_clk) is missing in the current OMAP4 HWMOD
database. Fix this in the DSS driver by using the old clock name
(dss_48mhz_clk).
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The HWMOD data for OMAP2 and 3 are currently not up to date regarding
DSS (OMAP4 HWMOD data is fine). This patch makes the DSS driver to get
the opt clocks needed for OMAP2/3 with the old clock names, thus
allowing DSS driver to use runtime PM.
The HWMOD databases should be fixes ASAP, and this patch can be reverted
after that.
Add backlight driver for AnalogicTech AAT2870.
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
registered
Since commit a19a6ee "backlight: Allow properties to be passed at
registration" and commit bb7ca74 "backlight: add backlight type", we can
set backlight type and max_brightness before backlights are registered.
Some newly added drivers did not set it properly, let's fix it.
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Donghwa Lee <dh09.lee@samsung.com>
Cc: InKi Dae <inki.dae@samsung.com>
Add the ams369fg06 amoled panel driver. The ams369fg06 amoled panel (480
x 800) driver uses 3-wired SPI inteface. The brightness can be controlled
by gamma setting of amoled panel.
[sfr@canb.auug.org.au: fix build error]
[axel.lin@gmail.com: unregister backlight device when unloading the module]
[axel.lin@gmail.com: staticize ams369fg06_shutdown]
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Cc: Inki Dae <inki.dae@samsung.com>
Cc: anish singh <anish198519851985@gmail.com>
max_brightness
We have set props.max_brightness before registering backlight device.
- Fix checking of wrong return value for backlight_device_register()
- Properly free allocated resources in ld9040_probe() error path and
ld9040_remove().
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
The current method of saving and restoring the context could cause a
restore before saving, effectively "restoring" zero values to registers.
Add ctx_valid field to indicate if the saved context is valid and can be
restored.
restored.
Also restructure the code to save the ctx_loss_count in save_context(),
which makes more sense than the previous method of storing new
ctx_loss_count in dispc_need_ctx_restore.
dss.c only saves 1 register (3 in OMAP3) so the extra overhead from
need_ctx_restore & co. is probably bigger than the time spent saving and
restoring those few registers every time.
So remove the code from dss.c and restore context every time dss has
been off.
dispc.c enables and disables clocks in almost every function to make
sure the clocks are enabled when the function is called. This is rather
unoptimal way to handle the problem.
With pm_runtime other components have to call dispc_runtime_get() to
enable dispc clocks before calling any other dispc functions. Thus the
finegrained clk enables/disables can be removed.
Use PM runtime and HWMOD support to handle enabling and disabling of DSS
modules.
Each DSS module will have get and put functions which can be used to
enable and disable that module. The functions use pm_runtime and hwmod
opt-clocks to enable the hardware.
Acked-by: Kevin Hilman <khilman@ti.com>
CONFIG_OMAP2_DSS_SLEEP_BEFORE_RESET is used to avoid an unclear bug at
DSS reset time. The pm runtime will handle reset in the future, and this
code has to be removed. Hopefully we won't see this error anymore.
Currently dss.c does all the low level clock handling in the DSS, and
thus it contains pointers to all the clocks. This allows dss.c to dump
the clock information for all the clocks.
With pm_runtime this is no longer the case, as each submodule will
handle its clocks independently. Thus remove the core_dump_clocks
function as it cannot be used with pm_runtime.
DSI PLL requires sys_clk to function, and DPI enables sys_clk when it
wants to use DSI PLL. However, DSI PLL code already handles enabling
sys_clk, so DPI's sys_clk code is extra.
Remove the unneeded sys_clk handling from dpi.c.
The function to get device's context loss count has changed from
omap_pm_get_last_off_on_transaction_id() to
omap_pm_get_dev_context_loss_count()
Change name of the function pointer in omapdss.h accordingly, and use
the term "context loss count" instead of "context id" in the code.
Restructure the context loss count functions to handle errors properly,
and ensure that context is always considered lost if an error happens.
DSS enables core clocks for the duration of initialization to avoid
unnecessary context saves and restores.
With PM runtime the clocks cannot be handled in this way, outside the
dss module drivers. Thus we need to remove the optimization.
The initialization order of the DSS modules is important when pm_runtime
support is implemented. Currently RFBI is initialized before DISPC,
which will cause problems with pm_runtime as RFBI uses DISPC.
The same goes for uninitialization order, and dss_uninit needs to be
called last, and dispc_uninit just before that.
Both dss.c and dsi.c had a probe function, which was almost a dummy one,
calling dss_init() and dsi_init().
Remove the init functions by moving the initialization code into probe
functions.
Get and put for dpll4_m4_ck was handled in dss_init/dss_exit. Move the
code to dss_get/put_clocks(), which is a better place to handle it.
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
When releasing framebuffer, free colourmap allocations.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
The DMA FIFO threshold registers and burst size registers have changed
for OMAP4. The current code only handles OMAP2/3 case, and so the
values are a bit off for OMAP4. A summary of the differences between
OMAP2/3 and OMAP4:
Burst size:
OMAP2/3: 4 x 32 bits / 8 x 32 bits / 16 x 32 bits
OMAP4: 2 x 128 bits / 4 x 128 bits / 8 x 128 bits
Threshold size:
OMAP2/3: in bytes (8 bit units)
OMAP4: in 128bit units
This patch fixes the issue by creating two new helper functions in
dss_features: dss_feat_get_buffer_size_unit() and
dss_feat_get_burst_size_unit(). These return (in bytes) the unit size
for threshold registers and unit size for burst size register,
respectively, and are used to calculate correct values.
For the threshold size the usage is straightforward. However, the burst
size register has different multipliers for OMAP2/3 and OMAP4. This
patch solves the problem by defining the multipliers for the burst size
as 2x, 4x and 8x, which fit fine for the OMAP4 burst size definition
(i.e. burst size unit for OMAP4 is 128bits), but requires a slight twist
on OMAP2/3 by defining the burst size unit as 64bit.
As the driver in practice always uses the maximum burst size, and no use
case currently exists where we would want to use a smaller burst size,
this patch changes the driver to hardcode the burst size when
initializing DISPC. This makes the threshold configuration code somewhat
simpler.
When the panel driver calls omapdss_dsi_display_disable() it is possible
that there are still some unsent packets in the TX fifo.
Add dsi_sync_vc() calls in the beginning of
omapdss_dsi_display_disable() to make sure the TX fifos are empty.
This allows us to remove the msleep(10) hack from panel-taal.c
Add Color Phase Rotation (CPR) support and sysfs files to enable CPR and
to set the CPR coefficient matrix.
CPR is enabled via manager?/cpr_enable file, and the coefficient matrix
is set via manager?/cpr_coef file. The values in cpr_coef are in the
following order:
RR RG RB GR GG GB BR BG BB
The overlay_cache_data and manager_cache_data structs include
the elements of omap_overlay_info and omap_overlay_manager_info
structs respectively. Include the structs instead of the individual
elements to reduce code.
Signed-off-by: Nishant Kamat <nskamat@ti.com>
OMAP2 doesn't have CPR, PRELOAD nor FIR_COEF_V registers. Add new
feature definitions for those, and check the feature before accessing
those registers.
OMAP3430 requires an 96MHz clock to VENC's DAC, but no other OMAP needs
it.
Add a new feature, FEAT_VENC_REQUIRES_TV_DAC_CLK, which tells if the
clock is needed on this platform, and use that feature in venc.c to
decide if the clock needs enabling.
LANEx_ULPS_SIG2 bits are left on after entering ULPS. This doesn't cause
any problems currently, as DSI HW is reset when it is enabled. However,
if the reset is not done, operation fails if the bits are still set.
So reset the bits after entering ULPS to ensure operation even without
HW reset.
If ULPS exit fails, and the following reset fails also, Taal driver was
left in state where it thinks DSI is enabled while it really isn't,
leading to crash.
This patch checks the return value of taal_panel_reset, and if that
fails, ulps_enabled is left true, causing the driver to retry ulps exit
later.
Also the return value of taal_wake_up is checked at taal_disable, and if
wake up fails, we'll skip the power_off. This could leave the panel into
a not-quite-valid state, but there's nothing we can do about it in that
situation.
Remove the whole update_mode stuff from omapdss driver. If automatic
update for manual update displays is needed, it's better implemented in
higher layers.
