When user doesn't use default heap policy and selects
GART or carveout allocation, automatic single-page-to-sysmem
rule doesn't work. Because of broken rule many single page
allocations take extra space in carveout and create
unnecessary page mappings in GART and SMMU.
The fix adds sysmem bit to heap mask when allocation is
single page and GART or carveout is present in heap mask.
bug 730124
bug 731923
The change also does sanity check of available system memory
before adding sysmem bit for carveout allocations.
bug 777839
Reviewed-on: http://git-master/r/31383
(cherry picked from commit 502c2becc54b49d26371f9b167f0c6f82a1bc37f)
Bug 844307
drivers/video/tegra/nvmap/nvmap_handle.c
Reviewed-on: http://git-master/r/38429
(cherry picked from commit ddfc93d27830a28a1c9786fd5bce6dc35727e9ff)
Change-Id: I9b8f84a5a7daf192d1d412926f91e5de71938818
Reviewed-on: http://git-master/r/47829
Reviewed-by: Andre Sihera <asihera@nvidia.com>
Tested-by: Andre Sihera <asihera@nvidia.com>
Reviewed-by: Kirill Artamonov <kartamonov@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Overlays can now be horizontally or vertically flipped.
Bug 834182
Bug 794998
Change-Id: I2a3bf43ba15b9917bf3cfa0cef3c9bb0769948d3
Reviewed-on: http://git-master/r/46012
Reviewed-by: Bo Kim <bok@nvidia.com>
Tested-by: Bo Kim <bok@nvidia.com>
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Bug 851086
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/40788
(cherry picked from commit 835196496da8c426d1a7d6342faf525c900ea81f)
Change-Id: Ic7d1a4fba87ae03fab344039b1de5a6f7c15f3e6
Reviewed-on: http://git-master/r/42382
Reviewed-by: Youngjin Kim <nkim@nvidia.com>
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
If there are more than one hdmi modes that have same xres,
yres, and vmode, tegra_dc_hdmi_mode_equal can return true even
though pixclocks are way different from each other.
Now, tegra_dc_hdmi_mode_equal will retun false if pixclock has
more than 1Hz of difference. Also, tegra_fb_set_par will use
fb_find_nearest_mode instead of fb_find_best_mode to take
refresh rate into the consideration.
Bug: 815409
Reviewed-on: http://git-master/r/36464
(cherry picked from commit 8cf6e47dd3d4efaa3a1f0a15f1bd36ad34d3a951)
Change-Id: I14fbfba832bd130c7f04369b360d48fbbfad3d7b
Reviewed-on: http://git-master/r/43655
Reviewed-by: Manish Tuteja <mtuteja@nvidia.com>
Tested-by: Manish Tuteja <mtuteja@nvidia.com>
hdmi modeset triggers to re-start hdcp and trying to negotiate
too early can cause HDCP failure. using delayed_work can avoid
this situation by starting HDCP a little bit late
Bug 855002
Change-Id: I607d31c80b57c4e76dc34d2b19d1d8e9cebe4b8f
Reviewed-on: http://git-master/r/43692
Tested-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
wait_event_interruptible_timeout checks the condition before
it enters a sleep. Adding a real condition to the function
avoids an un-wanted aditional sleep.
Bug 833476
Reviewed-on: http://git-master/r/43225
Reviewed-on: http://git-master/r/43426
(cherry picked from commit 40a95f668b311b66212cf81638bb65f241835e98)
Change-Id: I46ebab6229d24d0977e1ce640bdec9611df621e7
Reviewed-on: http://git-master/r/43610
Refresh rate nearness is not calculated or reset when nearest resolution
changes.
This patch resets the refresh rate differential measurement whenever a
new nearest resolution is discovered. This fixes two error cases;
first, wherein the first mode's refresh rate differential is never
calculated and second, when the closest refresh rate from a previous
nearest resolution is erroneously preserved.
back-ported from kernel.org
(cherry picked from commit 8917a5603a3e6534d6c75ed0d91077062805b111)
Reviewed-on: http://git-master/r/37417
(cherry picked from commit a169b1a92dc1ed4c824569e9dc70267cb1e2eb52)
Change-Id: I9757e98053a0676491dfe943f06a0c4946ef96be
Reviewed-on: http://git-master/r/42390
Tested-by: Gerrit_Virtual_Submit
3D power gate should be always disabled to keep the power. Set T20
enabled by default.
Bug 843271
Change-Id: Icf464cd107e65636440f8103ac6b104e2939e8b9
Reviewed-on: http://git-master/r/40342
Reviewed-on: http://git-master/r/43175
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
tegra_edid_dump() causes audio noise when plugin HDMI cable during
video playback and should not be enabled by default.
Bug 837728
Reviewed-on: http://git-master/r/42006
(cherry picked from commit 02bedac446b3951e9d5a34f1be97ca3918d80821)
Change-Id: I3298f5a98245fc9c3561b3a62a496dcf452280f5
Reviewed-on: http://git-master/r/42311
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-by: ChihJen Hsu <chhsu@nvidia.com>
When monitor is auto-detected on HDMI port, a special structure
is initialised to hold the video mode properties for the plugged-
in monitor. From this the display string is generated for displa
via the "mode" character device under /sys.
When the monitor is disconnected, the structures associated with
the monitor tself are cleared, but the pointer to the video mode
properties structure was left initialised and so pointed into thin
air, which resulted in garbage appearing on the "mode" device.
Added explicit deinitialisation code to reset pointer to video
mode properties so "cat mode" within /sys yields an empty string
when the HDMI monitor is unplugged.
Bug 849877
Change-Id: Idbd3f308ee0ee466f7aba0af9aac7e60af72b7fd
Reviewed-on: http://git-master/r/41205
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
The cursor in Android application flashes about 1 hz and
the duty cycle for this kind of 3D activity should be far
smaller than 1 second. To save power set acm timeout to 25 ms.
40 ms (4 in jiffies) is selected to prevent jitter of 30 fps
video capture.
BUG 824299
(cherry picked from http://git-master/r/31905)
Change-Id: Ibab9949d18c464119886ecefa016fbb963eeb2b7
Reviewed-on: http://git-master/r/37279
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Tested-by: Sun Kyu Choi <sunkyuc@nvidia.com>
Reviewed-by: Joshua Cha <joshuac@nvidia.com>
As HDMI is not a wakeup source. To detect HDMI peripheral which is
connected after suspend, we scan for it during HDMI resume.
Bug 846365
Reviewed-on: http://git-master/r/39776
(cherry picked from commit fd1134f413845f8e0b3944153eb7406f713a9709)
Change-Id: Ifcdeb340d953b288bdfee224f3b0f0f3caab98c1
Reviewed-on: http://git-master/r/40808
Reviewed-by: Gaurav Sarode <gsarode@nvidia.com>
This reverts commit 2b96783fd25eb2153cab2fb6ff92b2bacc809bed.
Recovery process is hanging because of this change.
Bug 848403
Bug 800107
Change-Id: I1b7d3f6c08d6db40eda077e5f128c4bf3be681ac
Reviewed-on: http://git-master/r/41818
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Kaushik Sen <ksen@nvidia.com>
Reviewed-by: Joseph Lehrer <jlehrer@nvidia.com>
Tested-by: Joseph Lehrer <jlehrer@nvidia.com>
Carveout memory leak occured in video playback on abnormal termination as the
tegra overlay driver didn't had the implementation to reduce the usage count of
nvmap client on device closure.
Hence on abnormal termination of mediaserver, the carveout memory remained
allocated causing memory leak.
The usage count of nvmap client for overlay driver is incremented on
ioctl TEGRA_OVERLAY_IOCTL_SET_NVMAP_FD.It should be decremented on
device closure.
Added the code to decrement the uage count of nvmap client on release, so that
the client and the carveout memory is free'd whenever the count reaches zero
on successful as well as abnormal termination of mediaserver process.
Similar implementation is done by NvHost channel driver,
The NvHost drivers takes care of nvmap client usage count.i.e. decrement the
uasge count of nvmap client which is incremented by
NVHOST_IOCTL_CHANNEL_SET_NVMAP_FD ioctl.
Bug 845676
Change-Id: I17b8d3c34adba5352af61355d8648b2611b62ef2
Reviewed-on: http://git-master/r/40157
Tested-by: Vandana Salve <vsalve@nvidia.com>
fb_mmap maps current window so that content of screen is
accessible through mmap sys call to user space components.
BUG 832288
Change-Id: I10ccb0b70c951f6d43dbd8a7a1e59e86c0ee75e9
Reviewed-on: http://git-master/r/39204
BUG_ON() function has wrong comparision.
the comparision should be '>='. (not '>')
Change-Id: I39453cc02615236b52aa04be076184da35df8e94
Reviewed-on: http://git-master/r/39503
Reviewed-by: BK Kim <bkk@nvidia.com>
Tested-by: BK Kim <bkk@nvidia.com>
Avoid Display Controller (DC) syncpoint increments if that instance of DC is
not enabled.
Bug 793874
(cherry picked from commit 5be1dd4dd04db4a4c4e8004e364d504bf9f56857)
Change-Id: I91f05694044bbefb15c3b92047be3be47b2ceacc
Reviewed-on: http://git-master/r/38464
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
dc lock is head while flush occurred, but functions called by workers need
take the dc lock to proceed.
Bug 807015
(cherry picked from commit 2e12d89ac51fe1358f0b01b9ff5cb4978fdcbe9d)
Change-Id: Ib358685c478c05a8f95c926e708de12b6a3556fb
Reviewed-on: http://git-master/r/38463
Reviewed-by: Linqiang Pu <dpu@nvidia.com>
Tested-by: Linqiang Pu <dpu@nvidia.com>
HDMI connect/disconnect will not affect the suspended device.
bug 835157
Change-Id: Ie094a2dcebdca2e405f3e02b4de3d12d0cb665f0
Reviewed-on: http://git-master/r/37174
(cherry picked from commit 31f69bbe2e832a7dfa7678bb965b3461f421e0f5)
Reviewed-on: http://git-master/r/38089
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Change-Id: I32755368de7059a8aa08b114af84d952adf16a1d
Reviewed-on: http://git-master/r/37981
To support the 25.2MHz pixel clock frequency required for CEA-861-B format 1: 640x480p at 59.94Hz
bug 837571
Change-Id: I33d5c82bbc9c79fd43d86abf72d5b94b1c723dd5
Reviewed-on: http://git-master/r/37916
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Fix incorrect invocation of mutex_destroy that results in a compile
error if mutex debugging features are enabled.
Change-Id: I4f5ce4406e11b94d108f0e0b09b2d4a77d902ac6
Reviewed-on: http://git-master/r/37435
This incorrect condition adds sleep to i2c read & write
functions even though they are executed successfully.
Bug 831891
Change-Id: If029b16c724516e96bf75458c60ca6b411ab5a96
Reviewed-on: http://git-master/r/37463
Reviewed-on: http://git-master/r/37472
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Tested-by: Pritesh Raithatha <praithatha@nvidia.com>
HDMI clock is not auto dvfs, so we need set the clock rate to 0 if HDMI
is disabled. Otherwise the Vdd core voltage will be always 1.2v even
after HDMI cable unplugged.
BUG 828306
Reviewed-on: http://git-master/r/34379
(cherry picked from commit 58ddd144a6c2dd9bbc9d2f3c8b1e025364d88c22)
Change-Id: I5b455a7a945d4834fb162b2986639df5a26b112c
Reviewed-on: http://git-master/r/37176
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
hdcp worker could be in sleep during modeset.
The front part of the video could be lost because of it.
This change makes hdcp respond quickly to shorten the delay.
bug 826468
Reviewed-on: http://git-master/r/#change,35449
Change-Id: I4e0105b1bc5815b223810d23ca8595747e541ee6
Reviewed-on: http://git-master/r/36417
Tested-by: Seongho Joo <sjoo@nvidia.com>
1. fix dc hang during dc reset
2. do dc reset after dc clk enabling
in reset worker function
3. remove a few build warnings
Bug 801463
Change-Id: Icc85b09ae5cf5ab97839ae8625224ea2b163adb4
Reviewed-on: http://git-master/r/33112
Reviewed-on: http://git-master/r/36235
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Tested-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-by: Hyong Bin Kim <hyongbink@nvidia.com>
Change-Id: I035a6cd254342fe11f074cb85439f378a7675943
Signed-off-by: Michael I. Gold <gold@nvidia.com>
Reviewed-on: http://git-master/r/33038
Reviewed-by: Brian Anderson <branderson@nvidia.com>
Change-Id: I6ec62abdaf3a8ec2e59e2a533b36b280d69538e1
Signed-off-by: Ari Hirvonen <ahirvonen@nvidia.com>
Reviewed-on: http://git-master/r/33037
Reviewed-by: Michael I Gold <gold@nvidia.com>
Tested-by: Michael I Gold <gold@nvidia.com>
unlock mutex if reset worker finds the display disabled.
Bug 801463
Reviewed-on: http://git-master/r/29898
(cherry picked from commit 672459efb81140b496e3749f1b1b14dcf84af74d)
Change-Id: I94254fca387cddcd58166757e46422167ed9262d
Reviewed-on: http://git-master/r/32758
Removes changes to DC reset flow introduced in commit e9f069bc2c9e0a9e3d7dfd30b66367667ab82dee.
Fixes the issue of HDMI output after playing 1080p stream.
bug 820455
bug 826061
Change-Id: I9c0802c4c39d4f899e948e8020a721699634d84c
Reviewed-on: http://git-master/r/31959
use smaller h_ref_to_sync values.
removed old debug printks
Bug 806009
(cherry picked from commit 8292b4988e6aa75c71f14cbf96dad8b5e931e681)
Change-Id: Iae3e84ddd8c02be1a83f9ac255fc1152dc867f0b
Reviewed-on: http://git-master/r/30585
Change-Id: I8ee718e0d56ff8dc2f2c2e1b5215d195f317f0e2
Reviewed-on: http://git-master/r/31084
tegra_dc_hdmi_equal doesn't check pixclock. some devices doesn't
support 14.85Mhz pixclock so 1080p@60 cannot be used. However,
1080p@30 is supported. Therefore, adding a max pixclock prevents
1080p@60 mode is falsely used for those devices
Bug: 815409
Change-Id: Ia2d8dcf360afa51e160d0e997986fe1714254a6b
Reviewed-on: http://git-master/r/31663
The kernel now receives wait tracking data (similar to gathers and
relocs) and compares the current syncpt with the threshold value.
If it's old, it gets a kernel mapping and rewrites the method data
to use a kernel reserved syncpt that is always 0 (so trivially pops
when seen by the HW).
Bug 519650
Bug 785525
Bug 803452
Note: reset the author in this commit to fix a email addr problem
and since from the latest/last cherry pick there was a reworking
of the code to be compatible with different user space versions
it also seemed reasonable.
(cherry picked from commit 4069d8e67665624ad3dceb628e572980dd57acd0)
(cherry picked from commit 6e4336408588e348804a62e53386acc9abc06823)
(cherry picked from commit 87a9efe751716ca741caac72b9061fdfdcec540a)
Change-Id: I9c6076da2384f373d5f402bee4406b09b4ebc4ff
Reviewed-on: http://git-master/r/23159
Reviewed-on: http://git-master/r/30281
Tested-by: Chris Johnson <cwj@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
clip invalid windows to fix screen size, failure to do so causes display
errors that result in corrupted display and invalid video modes.
prints a warning only once, if this warning is present in the logs then
there is a misbehaving application.
Bug 821094
(cherry picked from commit e08f18eba00bd5d86cb7770f709417a1bd0ca14f)
Change-Id: Ie5cec5c805bfe2bd4c5f1e5b7e22d5f255ca2680
Reviewed-on: http://git-master/r/30587
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Do not handle requests further for displays that are not enabled
Bug 813310
Bug 813728
Reviewed-on: http://git-master/r/29515
(cherry picked from commit 22578f1d7065ea84855fdbcaf09a792e9f9d3856)
Change-Id: I1fa907e33f2d250fff64752c8f0e26de51f3655b
Reviewed-on: http://git-master/r/30672
arch/arm/mm/proc-v7.S
drivers/video/tegra/dc/dc.c
Change-Id: I40be0d615f14f1c01305388a706d257f624ba968
Resolve potential race between resume and reset
Fix wmb after return
Change-Id: I98ad1e713b9781d780bf93561496011bf62b86d1
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
Change-Id: I903db54b76781cdb9231bb25d79635cb8f264087
bug 811316
Change-Id: I4513f81719a60c8f214ee07082e58defb1cca0aa
Reviewed-on: http://git-master/r/26985
there was a cropping code which saves from out of FB.However,
the cropping code was wrong and cropping should be done from
usermode driver instead of kernel. a warning is added here
for easy debugging
Bug 792524
Change-Id: Id57243e36f903b14a093dad23a6111032890c01a
Reviewed-on: http://git-master/r/28055
Change-Id: I023482f230dc4f413647f47b3c7c36fd4c98b97d
Prevents HDMI detect worker from re-disabling DC during
suspend (after tegra_dc_suspend has disabled DC itself)/
Change-Id: I90016fb709934ab8fb5135443980898069f8071f
Signed-off-by: Erik Gilling <konkers@android.com>
When HDCP repeater has no device attached, DEVICE_COUNT reports back as 0.
HDCP driver should handle this case as a good case and continue downstream
authentication, other than fail it.
Change-Id: Ied2e46428c0247f14fbd96016cd4fdbf358f6587
Change-Id: Ibf21f94d93ef237de6ab379dc1aa2498df08cdbd
Register assignments were wrong for incoming overlay blend
parameters. DisplayManagerLite policy sets src combine mode
to premult to signal dst premult aplha blending. But the DC
expects premult set for the dst window for this mode.
Bug 796009
Change-Id: I5929bc4cd362ac60c7a9f14bb4ae83da04b857ab
Reviewed-on: http://git-master/r/26835
Change-Id: I30dfa03324eb5c4c344c62578eb808a150c80deb
use pixel clock to configure HDMI interface signaling properties.
These options are different depending on which SoC.
Bug 786961 Bug 795251
(cherry picked from commit a59e2483a9f85a72186f51c124709401af554eb3)
Change-Id: Ie5ef35fe03065d3e77831a0e1a2bbf8319d04125
Reviewed-on: http://git-master/r/27722
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Jessica Liao <jeliao@nvidia.com>
