path: root/drivers/video
2013-06-01atmel_lcdfb: blank the backlight on removeRichard Genoud
When removing atmel_lcdfb module, the backlight is unregistered but not blanked. (only for CONFIG_BACKLIGHT_ATMEL_LCDC case). This can result in the screen going full white depending on how the PWM is wired. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2013-06-01trivial: atmel_lcdfb: add missing error messageRichard Genoud
When a too small framebuffer is given, the atmel_lcdfb_check_var silently fails. Adding an error message will save some head scratching. Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2013-05-29Merge branch 'fbdev-3.10-fixes' of git://gitorious.org/linux-omap-dss2/linux ↵Jean-Christophe PLAGNIOL-VILLARD
into linux-fbdev/for-3.10-fixes Pull Tomi fixes for ps3fb and omap2 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2013-05-24fbdev: FB_GOLDFISH should depend on HAS_DMAGeert Uytterhoeven
If NO_DMA=y: drivers/built-in.o: In function `goldfish_fb_remove': drivers/video/goldfishfb.c:301: undefined reference to `dma_free_coherent' drivers/built-in.o: In function `goldfish_fb_probe': drivers/video/goldfishfb.c:247: undefined reference to `dma_alloc_coherent' drivers/video/goldfishfb.c:280: undefined reference to `dma_free_coherent' Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24drivers/video: implement a simple framebuffer driverStephen Warren
A simple frame-buffer describes a raw memory region that may be rendered to, with the assumption that the display hardware has already been set up to scan out from that buffer. This is useful in cases where a bootloader exists and has set up the display hardware, but a Linux driver doesn't yet exist for the display hardware. Examples use-cases include: * The built-in LCD panels on the Samsung ARM chromebook, and Tegra devices, and likely many other ARM or embedded systems. These cannot yet be supported using a full graphics driver, since the panel control should be provided by the CDF (Common Display Framework), which has been stuck in design/review for quite some time. One could support these panels using custom SoC-specific code, but there is a desire to use common infra-structure rather than having each SoC vendor invent their own code, hence the desire to wait for CDF. * Hardware for which a full graphics driver is not yet available, and the path to obtain one upstream isn't yet clear. For example, the Raspberry Pi. * Any hardware in early stages of upstreaming, before a full graphics driver has been tackled. This driver can provide a graphical boot console (even full X support) much earlier in the upstreaming process, thus making new SoC or board support more generally useful earlier. [akpm@linux-foundation.org: make simplefb_formats[] static] Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Olof Johansson <olof@lixom.net> Cc: Rob Clark <robclark@gmail.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-23Merge tag 'staging-3.10-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver fixes from Greg Kroah-Hartman: "Here are some staging tree driver fixes for 3.10-rc2 The drivers/iio/ changes are here as they are still tied into drivers/staging/iio/. Nothing major, just a number of small bugfixes, and a larger documentation update for the ramster code." * tag 'staging-3.10-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (28 commits) staging: dwc2: remove compile warning for USB_DWC2_TRACK_MISSED_SOFS iio: exynos_adc: fix wrong structure extration in suspend and resume iio:common:st: added disable function after read info raw data iio: dac: Fix build error when CONFIG_SPI_MASTER=y && CONFIG_I2C=m staging:iio:light:tsl2x7x: fix the error handling in tsl2x7x_probe() staging/iio/mxs-lradc: fix preenable for multiple buffers staging: imx-drm: imx-tve: Check the return value of 'regulator_enable()' staging: video: imx: Select VIDEOMODE_HELPERS for parallel display staging: ramster: add how-to document staging: dwc2: Fix dma-enabled platform devices using a default dma_mask staging: vt6656: [bug] Fix missing spin lock in iwctl_siwpower. staging: Swap zram and zsmalloc in Kconfig staging: android: logger: use kuid_t instead of uid_t staging: zcache: Fix incorrect module_param_array types staging/solo6x10: depend on CONFIG_FONTS staging/drm: imx: add missing dependencies staging: ste_rmi4: Suppress 'ignoring return value of ‘regulator_enable()' warning staging: sep: fix driver build and kconfig staging: nvec: cleanup childs on remove staging: nvec: implement unregistering of notifiers ...
2013-05-23OMAPDSS: Fix crash with DT bootTomi Valkeinen
When booting with DT, there's a crash when omapfb is probed. This is caused by the fact that omapdss+DT is not yet supported, and thus omapdss is not probed at all. On the other hand, omapfb is always probed. When omapfb tries to use omapdss, there's a NULL pointer dereference crash. The same error should most likely happen with omapdrm and omap_vout also. To fix this, add an "initialized" state to omapdss. When omapdss has been probed, it's marked as initialized. omapfb, omapdrm and omap_vout check this state when they are probed to see that omapdss is actually there. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Tested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
2013-05-18drivers/video/omap2/dss: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-05-18drivers/video/omap2: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-16staging/solo6x10: depend on CONFIG_FONTSArnd Bergmann
The new SOLO6X10 driver needs the built-in console fonts, specifically the VGA8x16 font and building it without console support results in a link error error. drivers/built-in.o: In function `solo_osd_print': :(.text+0x7d3424): undefined reference to `find_font' This adds a dependency on the CONFIG_FONTS symbol and changes the console code to always build the base driver even if there are no specific fonts built-in. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Hans Verkuil <hans.verkuil@cisco.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-10Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - More work on DT support for various platforms - Various fixes that were to late to make it straight into 3.9 - Improved platform support, in particular the Netlogic XLR and BCM63xx, and the SEAD3 and Malta eval boards. - Support for several Ralink SOC families. - Complete support for the microMIPS ASE which basically reencodes the existing MIPS32/MIPS64 ISA to use non-constant size instructions. - Some fallout from LTO work which remove old cruft and will generally make the MIPS kernel easier to maintain and resistant to compiler optimization, even in absence of LTO. - KVM support. While MIPS has announced hardware virtualization extensions this KVM extension uses trap and emulate mode for virtualization of MIPS32. More KVM work to add support for VZ hardware virtualizaiton extensions and MIPS64 will probably already be merged for 3.11. Most of this has been sitting in -next for a long time. All defconfigs have been build or run time tested except three for which fixes are being sent by other maintainers. Semantic conflict with kvm updates done as per Ralf * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits) MIPS: Add new GIC clockevent driver. MIPS: Formatting clean-ups for clocksources. MIPS: Refactor GIC clocksource code. MIPS: Move 'gic_frequency' to common location. MIPS: Move 'gic_present' to common location. MIPS: MIPS16e: Add unaligned access support. MIPS: MIPS16e: Support handling of delay slots. MIPS: MIPS16e: Add instruction formats. MIPS: microMIPS: Optimise 'strnlen' core library function. MIPS: microMIPS: Optimise 'strlen' core library function. MIPS: microMIPS: Optimise 'strncpy' core library function. MIPS: microMIPS: Optimise 'memset' core library function. MIPS: microMIPS: Add configuration option for microMIPS kernel. MIPS: microMIPS: Disable LL/SC and fix linker bug. MIPS: microMIPS: Add vdso support. MIPS: microMIPS: Add unaligned access support. MIPS: microMIPS: Support handling of delay slots. MIPS: microMIPS: Add support for exception handling. MIPS: microMIPS: Floating point support. MIPS: microMIPS: Fix macro naming in micro-assembler. ...
2013-05-09video: mxsfb: Adapt to new videomode APIFabio Estevam
commit 6cd2c7db4 (videomode: videomode_from_timing work) changed the name of the function from videomode_from_timing() to videomode_from_timings(). commit 32ed6ef1 (videomode: create enum for videomode's display flags) changed the 'data_flags' field in videomode structure to 'flags' Adapt to these changes in order to fix the following errors: drivers/video/mxsfb.c:761:3: error: too many arguments to function 'videomode_from_timing' drivers/video/mxsfb.c:761:7: error: void value not ignored as it ought to be drivers/video/mxsfb.c:768:9: error: 'struct videomode' has no member named 'data_flags' drivers/video/mxsfb.c:770:9: error: 'struct videomode' has no member named 'data_flags' Also, select VIDEOMODE_HELPER instead of OF_VIDEOMODE, as this one is deprecated. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-05-09Merge tag 'gpio-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull removal of GENERIC_GPIO from Grant Likely: "GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it is possible to do so which has been causing confusion and breakage. This branch does the work to completely eliminate GENERIC_GPIO." * tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux: gpio: update gpio Chinese documentation Remove GENERIC_GPIO config option Convert selectors of GENERIC_GPIO to GPIOLIB blackfin: force use of gpiolib m68k: coldfire: use gpiolib mips: pnx833x: remove requirement for GENERIC_GPIO openrisc: default GENERIC_GPIO to false avr32: default GENERIC_GPIO to false xtensa: remove explicit selection of GENERIC_GPIO sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB powerpc: remove redundant GENERIC_GPIO selection unicore32: default GENERIC_GPIO to false unicore32: remove unneeded select GENERIC_GPIO arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB arm: remove redundant GENERIC_GPIO selection mips: alchemy: require gpiolib mips: txx9: change GENERIC_GPIO to GPIOLIB mips: loongson: use GPIO driver on CONFIG_GPIOLIB mips: remove redundant GENERIC_GPIO select
2013-05-08MIPS: remove obsolete Kconfig macrosPaul Bolle
The support for PB1100, PB1500, and PB1550 got merged into the code for DB1000 and DB1550 code in v3.7. When that was done the three related Kconfig symbols were dropped. But not all related Kconfig macros were removed. Do so now. Note that the PB1100 code in the Au1100 LCD driver is removed entirely and not converted to use its current Kconfig macro. That is done because the macros it uses (PB1100_G_CONTROL, PB1100_G_CONTROL_BL, and PB1100_G_CONTROL_VDD) are never defined. Actually only one of these was ever defined (PB1100_G_CONTROL) but that define was removed in v2.6.34. So, as far as I can tell, this code could have never compiled. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Patchwork: http://patchwork.linux-mips.org/patch/5040/ Acked-by: John Crispin <blogic@openwrt.org>
2013-05-07Merge tag 'dt-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC device tree updates (part 2) from Arnd Bergmann: "These are mostly new device tree bindings for existing drivers, as well as changes to the device tree source files to add support for those devices, and a couple of new boards, most notably Samsung's Exynos5 based Chromebook. The changes depend on earlier platform specific updates and touch the usual platforms: omap, exynos, tegra, mxs, mvebu and davinci." * tag 'dt-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (169 commits) ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: add mshc controller node for Exynos4x12 SoCs ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree ARM: davinci: da850-evm: add SPI flash support ARM: davinci: da850: override SPI DT node device name ARM: davinci: da850: add SPI1 DT node spi/davinci: add DT binding documentation spi/davinci: no wildcards in DT compatible property ARM: dts: mvebu: Convert mvebu device tree files to 64 bits ARM: dts: mvebu: introduce internal-regs node ARM: dts: mvebu: Convert all the mvebu files to use the range property ARM: dts: mvebu: move all peripherals inside soc ARM: dts: mvebu: fix cpus section indentation ARM: davinci: da850: add EHRPWM & ECAP DT node ARM/dts: OMAP3: fix pinctrl-single configuration ARM: dts: Add OMAP3430 SDP NOR flash memory binding ARM: dts: Add NOR flash bindings for OMAP2420 H4 ...
2013-05-06Merge tag 'for-3.10-rc1' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull pwm changes from Thierry Reding: "Nothing very exciting this time around. A couple of bug fixes and a lot of cleanup across the board. The DaVinci 8xx family of SoCs now use the same driver as the AM33xx family. Many thanks to Axel Lin and Jingoo Han who have done a great job fixing various bugs and inconsistencies." * tag 'for-3.10-rc1' of git://gitorious.org/linux-pwm/linux-pwm: (27 commits) pwm: lpc32xx: Don't change PWM_ENABLE bit in lpc32xx_pwm_config pwm: lpc32xx: Properly set PWM_ENABLE bit in lpc32xx_pwm_[enable|disable] pwm: Constify OF match tables pwm: pwm-tiehrpwm: Update device-tree binding document pwm: pwm-tiecap: Update device-tree binding document pwm: puv3: Remove unused enabled filed from struct puv3_pwm_chip pwm: pxa: Remove PWM_ID_BASE macro pwm: spear: Remove unused *dev from struct spear_pwm_chip pwm: mxs: Remove unused *dev from struct mxs_pwm_chip pwm: twl: Return proper error if twl6030_pwm_enable() fails pwm: pxa: Remove clk_enabled field from struct pxa_pwm_chip pwm: imx: Remove enabled field from struct imx_chip pwm: twl: Add .owner to struct pwm_ops pwm: twl-led: Add .owner to struct pwm_ops pwm: atmel-tcb: Add .owner to struct pwm_ops pwm: ab8500: Add .owner to struct pwm_ops pwm: spear: Fix checking return value of clk_enable() and clk_prepare() pwm: tiehrpwm: Staticize non-exported symbols pwm: tiecap: Staticize non-exported symbols pwm: ab8500: Fix trivial typo in dev_err message ...
2013-05-06Merge branch 'late/dt' into next/dt2Arnd Bergmann
This is support for the ARM Chromebook, originally scheduled as a "late" pull request. Since it's already late now, we can combine this into the existing next/dt2 branch. * late/dt: ARM: exynos: dts: cros5250: add EC device ARM: dts: Add sbs-battery for exynos5250-snow ARM: dts: Add i2c-arbitrator bus for exynos5250-snow ARM: dts: Add chip-id controller node on Exynos4/5 SoC ARM: EXYNOS: Create virtual I/O mapping for Chip-ID controller using device tree
2013-05-04Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "This is a rather large set of patches for device drivers that for one reason or another the subsystem maintainer preferred to get merged through the arm-soc tree. There are both new drivers as well as existing drivers that are getting converted from platform-specific code into standalone drivers using the appropriate subsystem specific interfaces. In particular, we can now have pinctrl, clk, clksource and irqchip drivers in one file per driver, without the need to call into platform specific interface, or to get called from platform specific code, as long as all information about the hardware is provided through a device tree. Most of the drivers we touch this time are for clocksource. Since now most of them are part of drivers/clocksource, I expect that we won't have to touch these again from arm-soc and can let the clocksource maintainers take care of these in the future. Another larger part of this series is specific to the exynos platform, which is seeing some significant effort in upstreaming and modernization of its device drivers this time around, which unfortunately is also the cause for the churn and a lot of the merge conflicts. There is one new subsystem that gets merged as part of this series: the reset controller interface, which is a very simple interface for taking devices on the SoC out of reset or back into reset. Patches to use this interface on i.MX follow later in this merge window, and we are going to have other platforms (at least tegra and sirf) get converted in 3.11. This will let us get rid of platform specific callbacks in a number of platform independent device drivers." * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (256 commits) irqchip: s3c24xx: add missing __init annotations ARM: dts: Disable the RTC by default on exynos5 clk: exynos5250: Fix parent clock for sclk_mmc{0,1,2,3} ARM: exynos: restore mach/regs-clock.h for exynos5 clocksource: exynos_mct: fix build error on non-DT pinctrl: vt8500: wmt: Fix checking return value of pinctrl_register() irqchip: vt8500: Convert arch-vt8500 to new irqchip infrastructure reset: NULL deref on allocation failure reset: Add reset controller API dt: describe base reset signal binding ARM: EXYNOS: Add arm-pmu DT binding for exynos421x ARM: EXYNOS: Add arm-pmu DT binding for exynos5250 ARM: EXYNOS: Enable PMUs for exynos4 irqchip: exynos-combiner: Correct combined IRQs for exynos4 irqchip: exynos-combiner: Add set_irq_affinity function for combiner_irq ARM: EXYNOS: fix compilation error introduced due to common clock migration clk: exynos5250: Fix divider values for sclk_mmc{0,1,2,3} clk: exynos4: export clocks required for fimc-is clk: samsung: Fix compilation error clk: tegra: fix enum tegra114_clk to match binding ...
2013-05-02Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull request for 3.10. Wierd bits: - OMAP drm changes required OMAP dss changes, in drivers/video, so I took them in here. - one more fbcon fix for font handover - VT switch avoidance in pm code - scatterlist helpers for gpu drivers - have acks from akpm Highlights: - qxl kms driver - driver for the spice qxl virtual GPU Nouveau: - fermi/kepler VRAM compression - GK110/nvf0 modesetting support. Tegra: - host1x core merged with 2D engine support i915: - vt switchless resume - more valleyview support - vblank fixes - modesetting pipe config rework radeon: - UVD engine support - SI chip tiling support - GPU registers initialisation from golden values. exynos: - device tree changes - fimc block support Otherwise: - bunches of fixes all over the place." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (513 commits) qxl: update to new idr interfaces. drm/nouveau: fix build with nv50->nvc0 drm/radeon: fix handling of v6 power tables drm/radeon: clarify family checks in pm table parsing drm/radeon: consolidate UVD clock programming drm/radeon: fix UPLL_REF_DIV_MASK definition radeon: add bo tracking debugfs drm/radeon: add new richland pci ids drm/radeon: add some new SI PCI ids drm/radeon: fix scratch reg handling for UVD fence drm/radeon: allocate SA bo in the requested domain drm/radeon: fix possible segfault when parsing pm tables drm/radeon: fix endian bugs in atom_allocate_fb_scratch() OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found OMAPDSS: VENC: Add error handling for venc_probe_pdata OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata OMAPDSS: DSI: Add error handling for dsi_probe_pdata OMAPDSS: SDI: Add error handling for sdi_probe_pdata OMAPDSS: DPI: Add error handling for dpi_probe_pdata ...
2013-05-03Merge tag 'omapdss-for-3.10-fixes' of ↵Dave Airlie
git://gitorious.org/linux-omap-dss2/linux into drm-next OMAPDSS fixes for 3.10: * Compilation fix when DSI is disabled in Kconfig * Basic deferred probe support to fix DT boot * tag 'omapdss-for-3.10-fixes' of git://gitorious.org/linux-omap-dss2/linux: OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found OMAPDSS: VENC: Add error handling for venc_probe_pdata OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata OMAPDSS: DSI: Add error handling for dsi_probe_pdata OMAPDSS: SDI: Add error handling for sdi_probe_pdata OMAPDSS: DPI: Add error handling for dpi_probe_pdata OMAPDSS: VENC: use platform_driver_register() OMAPDSS: HDMI: use platform_driver_register() OMAPDSS: RFBI: use platform_driver_register() OMAPDSS: DSI: use platform_driver_register() OMAPDSS: SDI: use platform_driver_register() OMAPDSS: DPI: use platform_driver_register() OMAPFB: defer probe if no displays OMAPFB: use module_platform_driver() OMAPDSS: Makefile: move omapfb after panels OMAPDSS: DPI: fix compilation if DSI not compiled in
2013-05-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlights this time around are: - A pile of addition POWER8 bits and nits, such as updated performance counter support (Michael Ellerman), new branch history buffer support (Anshuman Khandual), base support for the new PCI host bridge when not using the hypervisor (Gavin Shan) and other random related bits and fixes from various contributors. - Some rework of our page table format by Aneesh Kumar which fixes a thing or two and paves the way for THP support. THP itself will not make it this time around however. - More Freescale updates, including Altivec support on the new e6500 cores, new PCI controller support, and a pile of new boards support and updates. - The usual batch of trivial cleanups & fixes" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) powerpc: Fix build error for book3e powerpc: Context switch the new EBB SPRs powerpc: Turn on the EBB H/FSCR bits powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S powerpc: Setup BHRB instructions facility in HFSCR for POWER8 powerpc: Fix interrupt range check on debug exception powerpc: Update tlbie/tlbiel as per ISA doc powerpc: Print page size info during boot powerpc: print both base and actual page size on hash failure powerpc: Fix hpte_decode to use the correct decoding for page sizes powerpc: Decode the pte-lp-encoding bits correctly. powerpc: Use encode avpn where we need only avpn values powerpc: Reduce PTE table memory wastage powerpc: Move the pte free routines from common header powerpc: Reduce the PTE_INDEX_SIZE powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format powerpc: New hugepage directory format powerpc: Don't truncate pgd_index wrongly powerpc: Don't hard code the size of pte page powerpc: Save DAR and DSISR in pt_regs on MCE ...
2013-05-02fbdev/ps3fb: fix compile warningTomi Valkeinen
Commit 11bd5933abe0 ("fbdev/ps3fb: use vm_iomap_memory()") introduced the following warning: drivers/video/ps3fb.c: In function 'ps3fb_mmap': drivers/video/ps3fb.c:712:2: warning: suggest parentheses around '+' inside '<<' [-Wparentheses] Fix this by adding the parentheses. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not foundTomi Valkeinen
If the I2C adapter needed by the TFP410 device is not available yet, return EPROBE_DEFER so that the device will get probed again. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: VENC: Add error handling for venc_probe_pdataTomi Valkeinen
Add proper error handling for venc_probe_pdata(). This will cause EPROBE_DEFER to be properly passed upwards, causing the VENC driver to be probed again later if a resource was missing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: HDMI: Add error handling for hdmi_probe_pdataTomi Valkeinen
Add proper error handling for hdmi_probe_pdata(). This will cause EPROBE_DEFER to be properly passed upwards, causing the HDMI driver to be probed again later if a resource was missing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: RFBI: Add error handling for rfbi_probe_pdataTomi Valkeinen
Add proper error handling for rfbi_probe_pdata(). This will cause EPROBE_DEFER to be properly passed upwards, causing the RFBI driver to be probed again later if a resource was missing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: DSI: Add error handling for dsi_probe_pdataTomi Valkeinen
Add proper error handling for dsi_probe_pdata(). This will cause EPROBE_DEFER to be properly passed upwards, causing the DSI driver to be probed again later if a resource was missing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: SDI: Add error handling for sdi_probe_pdataTomi Valkeinen
Add proper error handling for sdi_probe_pdata(). This will cause EPROBE_DEFER to be properly passed upwards, causing the SDI driver to be probed again later if a resource was missing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: DPI: Add error handling for dpi_probe_pdataTomi Valkeinen
Add proper error handling for dpi_probe_pdata(). This will cause EPROBE_DEFER to be properly passed upwards, causing the DPI driver to be probed again later if a resource was missing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: VENC: use platform_driver_register()Tomi Valkeinen
Use platform_driver_register() instead of platform_driver_probe() so that we can support EPROBE_DEFER. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: HDMI: use platform_driver_register()Tomi Valkeinen
2013-05-02OMAPDSS: RFBI: use platform_driver_register()Tomi Valkeinen
2013-05-02OMAPDSS: DSI: use platform_driver_register()Tomi Valkeinen
2013-05-02OMAPDSS: SDI: use platform_driver_register()Tomi Valkeinen
2013-05-02OMAPDSS: DPI: use platform_driver_register()Tomi Valkeinen
2013-05-02OMAPFB: defer probe if no displaysTomi Valkeinen
omapfb requires the panel drivers to have been probed when omapfb is initialized. omapfb does not support insertion of new panels after its probe. This causes a problem in case omapdss or the panel probes have been deferred due to EPROBE_DEFER error, as omapfb won't find any displays. As a quick fix, this patch changes the omapfb probe so that if omapfb does not find any displays, it'll return EPROBE_DEFER. This is not perfect, as with a board with no displays, omapfb will get deferred forever. Also, if the board has multiple displays, but only some of them have been probed, omapfb will start and leave the unprobed displays out. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPFB: use module_platform_driver()Tomi Valkeinen
Instead of using platform_driver_probe(), use module_platform_driver() so that we can support deferred probing. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: Makefile: move omapfb after panelsTomi Valkeinen
omapfb requires the panels to have been probed before omapfb's probe. We currently manage that by having omapfb in late initcall level. However, a much simpler way is to just change the makefile so that omapfb is after the panel drivers. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-02OMAPDSS: DPI: fix compilation if DSI not compiled inTomi Valkeinen
Commit 100c826235793345efe06b3558cc9d36166b1e26 (OMAPDSS: DPI: use new clock calculation code) breaks dpi.c compilation if DSI is not enabled in the kernel configuration. Fix compilation by adding dummy inline functions for the ones that dpi.c references. The functions will never be called, as dpi.c knows that there is no DSI device available. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-29video/uvesafb: rename random32() to prandom_u32()Akinobu Mita
Use preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Michal Januszewski <spock@gentoo.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/video/backlight/tps65217_bl.c add default brightness value optionMatus Ujhelyi
Signed-off-by: Matus Ujhelyi <matus.ujhelyi@streamunlimited.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: add a device tree structureKim, Milo
Enable supporting the DT structure of LP855x family devices. If the platform data is NULL, the driver tries to parse a DT structure. Then, the platform data is copied from the DT. Documentation is added as well. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: remove duplicate platform dataKim, Milo
The 'load_new_rom_data' was used for checking whether new ROM data should be updated or not. However, we can decide it with 'size_program' data. If the size is greater than 0, it means updating ROM area is required. Otherwise, the default ROM data will be used. Therefore, this duplicate platform data can be removed. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: move backlight mode platform dataKim, Milo
The brightness of LP855x devices is controlled by I2C register or PWM input . This mode was selected through the platform data, but it can be chosen by the driver internally without platform data configuration. How to decide the control mode: If the PWM period has specific value, the mode is PWM input. On the other hand, the mode is register-based. This mode selection is done on the _probe(). Move 'mode' from a header file to the driver private data structure, 'lp855 x'. And correlated code was replaced. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: lp855x: convert a type of device nameKim, Milo
Configurable data, backlight device name is set to constant character type. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: vgg2432a4: convert vgg2432a4_driver to dev_pm_opsJingoo Han
Instead of using legacy suspend/resume methods, using newer dev_pm_ops structure allows better control over power management. Also, use of pm_message_t is deprecated. Thus, it is removed. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: tosa: convert tosa to dev_pm_opsJingoo Han
Instead of using legacy suspend/resume methods, using newer dev_pm_ops structure allows better control over power management. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29backlight: omap1: convert omapbl to dev_pm_opsJingoo Han
