path: root/drivers/video
2012-07-11Merge tag 'fbdev-fixes-for-3.5-2' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev fixes from Florian Tobias Schandinat: "Two fixes for OMAPDSS by Tomi Valkeinen: - one to avoid warnings when runtime PM is not enabled - one workaround to dependancy issues during suspend/resume" * tag 'fbdev-fixes-for-3.5-2' of git://github.com/schandinat/linux-2.6: OMAPDSS: fix warnings if CONFIG_PM_RUNTIME=n OMAPDSS: Use PM notifiers for system suspend
2012-07-08OMAPDSS: fix warnings if CONFIG_PM_RUNTIME=nTomi Valkeinen
If runtime PM is not enabled in the kernel config, pm_runtime_get_sync() will always return 1 and pm_runtime_put_sync() will always return -ENOSYS. pm_runtime_get_sync() returning 1 presents no problem to the driver, but -ENOSYS from pm_runtime_put_sync() causes the driver to print a warning. One option would be to ignore errors returned by pm_runtime_put_sync() totally, as they only say that the call was unable to put the hardware into suspend mode. However, I chose to ignore the returned -ENOSYS explicitly, and print a warning for other errors, as I think we should get notified if the HW failed to go to suspend properly. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Jassi Brar <jaswinder.singh@linaro.org> Cc: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Archit Taneja <archit@ti.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-07-08OMAPDSS: Use PM notifiers for system suspendTomi Valkeinen
The current way how omapdss handles system suspend and resume is that omapdss device (a platform device, which is not part of the device hierarchy of the DSS HW devices, like DISPC and DSI, or panels.) uses the suspend and resume callbacks from platform_driver to handle system suspend. It does this by disabling all enabled panels on suspend, and resuming the previously disabled panels on resume. This presents a few problems. One is that as omapdss device is not related to the panel devices or the DSS HW devices, there's no ordering in the suspend process. This means that suspend could be first ran for DSS HW devices and panels, and only then for omapdss device. Currently this is not a problem, as DSS HW devices and panels do not handle suspend. Another, more pressing problem, is that when suspending or resuming, the runtime PM functions return -EACCES as runtime PM is disabled during system suspend. This causes the driver to print warnings, and operations to fail as they think that they failed to bring up the HW. This patch changes the omapdss suspend handling to use PM notifiers, which are called before suspend and after resume. This way we have a normally functioning system when we are suspending and resuming the panels. This patch, I believe, creates a problem that somebody could enable or disable a panel between PM_SUSPEND_PREPARE and the system suspend, and similarly the other way around in resume. I choose to ignore the problem for now, as it sounds rather unlikely, and if it happens, it's not fatal. In the long run the system suspend handling of omapdss and panels should be thought out properly. The current approach feels rather hacky. Perhaps the panel drivers should handle system suspend, or the users of omapdss (omapfb, omapdrm) should handle system suspend. Note that after this patch we could probably revert 0eaf9f52e94f756147dbfe1faf1f77a02378dbf9 (OMAPDSS: use sync versions of pm_runtime_put). But as I said, this patch may be temporary, so let's leave the sync version still in place. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Reported-by: Jassi Brar <jaswinder.singh@linaro.org> Tested-by: Jassi Brar <jaswinder.singh@linaro.org> Tested-by: Joe Woodward <jw@terrafix.co.uk> Signed-off-by: Archit Taneja <archit@ti.com> [fts: fixed 2 brace coding style issues] Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-16Merge tag 'fbdev-fixes-for-3.5-1' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev fixes from Florian Tobias Schandinat: - two fixes for s3c-fb by Jingoo Han (including a fix for a potential division by zero) - a couple of randconfig fixes by Arnd Bergmann - a cleanup for bfin_adv7393fb by Emil Goode * tag 'fbdev-fixes-for-3.5-1' of git://github.com/schandinat/linux-2.6: video: s3c-fb: fix possible division by zero in s3c_fb_calc_pixclk video: s3c-fb: clear SHADOWCON register when clearing hardware window registers drivers/tosa: driver needs I2C and SPI to compile drivers/savagefb: use mdelay instead of udelay video/console: automatically select a font video/ili9320: do not mark exported functions __devexit drivers/video: use correct __devexit_p annotation video: bfin_adv7393fb: Convert to kstrtouint_from_user
2012-06-13video: s3c-fb: fix possible division by zero in s3c_fb_calc_pixclkJingoo Han
Divider value can be zero and it makes division by zero from debug message in s3c_fb_calc_pixclk; therefore, it should be fixed. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-13video: s3c-fb: clear SHADOWCON register when clearing hardware window registersJingoo Han
All bits of SHADOWCON register should be cleared when clearing hardware window registers; however, some bits of SHADOWCON register are not cleared previously. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-13Merge tag 'omapdss-for-3.5-rc2' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
Pull omapdss build problem fix from Tomi Valkeinen: "Small fixes for omapdss driver. Most importantly, fixes a build problem when debugfs or omapdss debug support is turned off, and fixes a suspend related crash." This has apparently been annoying rmk for a while.. * tag 'omapdss-for-3.5-rc2' of git://gitorious.org/linux-omap-dss2/linux: OMAPDSS: fix registration of DPI and SDI devices OMAPDSS: DSI: Fix bug when calculating LP command interleaving parameters OMAPDSS: fix bogus WARN_ON in dss_runtime_put() OMAPDSS: Taal: fix compilation warning OMAPDSS: fix build when DEBUG_FS or DSS_DEBUG_SUPPORT disabled
2012-06-09drivers/tosa: driver needs I2C and SPI to compileArnd Bergmann
This driver requires both SPI and I2C to build. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-09drivers/savagefb: use mdelay instead of udelayArnd Bergmann
Long delays need to use mdelay on architectures such as ARM that cannot compute long timeouts in udelay. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-09video/console: automatically select a fontArnd Bergmann
The frame buffer console needs at least one font to be built into the kernel, so add the necessary Kconfig magic to guarantee that one of the available font is always on. If a user accidentally disables all fonts manually, the 8x16 font will be selected anyway. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-09video/ili9320: do not mark exported functions __devexitArnd Bergmann
No symbol can be exported when the section is discarded - the only solution I could think of is not to mark symbols as __devexit when they are exported. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-09drivers/video: use correct __devexit_p annotationArnd Bergmann
__devexit functions are discarded when CONFIG_HOTPLUG is not set, so the symbol needs to be referenced carefully. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-05video: bfin_adv7393fb: Convert to kstrtouint_from_userEmil Goode
This patch removes a call to the deprecated simple_strtoul function and simplifies the code by replacing two function calls with one call to kstrtouint_from_user. -Simplify the adv7393_write_proc function by replacing the simple_strtoul and copy_from_user calls with one call to kstrtouint_from_user. -Change the count parameter from unsigned long to size_t as this is the type that the kstrtouint_from_user function expects. (size_t is what will be passed to the adv7393_write_proc function by the proc write handler function proc_file_write anyway) Signed-off-by: Emil Goode <emilgoode@gmail.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-06-05Merge tag 'omapdss-for-3.5-rc2' of git://gitorious.org/linux-omap-dss2/linux ↵Florian Tobias Schandinat
into fbdev-for-linus Small fixes for omapdss driver. Most importantly, fixes a build problem when debugfs or omapdss debug support is turned off, and fixes a suspend related crash.
2012-06-04OMAPDSS: DSI: Fix bug when calculating LP command interleaving parametersArchit Taneja
In function dsi_compute_interleave_lp(), the escape clock/LP clock time period is calculated incorrectly. The escape clock/LP clock is calculated as: LP Clock(Hz) = DSI_FCLK(Hz) / lp_clk_div Since we are calculating the time period of LP clock, the LP clock divider should be multiplied with the time period of DSI_FCLK. Calculating incorrect value of txclkesc results in incorrect calculation of LP interleaving parameters, it also creates a possibility of a divide by zero error. Reported-by: Sureshkumar Manimuthu <mail2msuresh@ti.com> Signed-off-by: Archit Taneja <archit@ti.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-06-04OMAPDSS: fix bogus WARN_ON in dss_runtime_put()Tomi Valkeinen
pm_runtime_put_sync() in dss_runtime_put() returns -EBUSY when any child of dss is still enabled. This happens, for example, when a display output is enabled and one dumps the clocks via debugfs. This causes dss_runtime_get & put to be called. While I couldn't find anything about this in the documentation and it wasn't immediately clear from runtime_pm code, it looks to me that pm_runtime_put_sync() returns -EBUSY to inform that things went fine, but the device could not be turned off as there are still child devices that are enabled. This is not a problem. This patch skips the WARN_ON if pm_runtime_put_sync() returns -EBUSY. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-06-04OMAPDSS: Taal: fix compilation warningTomi Valkeinen
This patch fixes a warning: drivers/video/omap2/displays/panel-taal.c: In function ‘taal_num_errors_show’: drivers/video/omap2/displays/panel-taal.c:529: warning: ‘errors’ may be used uninitialized in this function Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-06-04OMAPDSS: fix build when DEBUG_FS or DSS_DEBUG_SUPPORT disabledTomi Valkeinen
If CONFIG_DEBUG_FS or CONFIG_OMAP2_DSS_DEBUG_SUPPORT is disabled, the build fails: drivers/video/omap2/dss/core.c:197:50: error: static declaration of 'dss_debugfs_create_file' follows non-static declaration drivers/video/omap2/dss/dss.h:166:5: note: previous declaration of 'dss_debugfs_create_file' was here This patch fixes the dummy dss_debugfs_create_file() so that the driver builds. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2012-06-01Merge tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: - driver for AUO-K1900 and AUO-K1901 epaper controller - large updates for OMAP (e.g. decouple HDMI audio and video) - some updates for Exynos and SH Mobile - various other small fixes and cleanups * tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits) video: bfin_adv7393fb: Fix cleanup code video: exynos_dp: reduce delay time when configuring video setting video: exynos_dp: move sw reset prioir to enabling sw defined function video: exynos_dp: use devm_ functions fb: handle NULL pointers in framebuffer release OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request OMAPDSS: Apply VENC timings even if panel is disabled OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC OMAPDSS: DISPC: Support rotation through TILER OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n OMAPFB: remove compiler warnings when CONFIG_BUG=n OMAPDSS: remove compiler warnings when CONFIG_BUG=n OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods OMAPDSS: DISPC: Update Accumulator configuration for chroma plane drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers video: exynos mipi dsi: support reverse panel type video: exynos mipi dsi: Properly interpret the interrupt source flags video: exynos mipi dsi: Avoid races in probe() ...
2012-05-30i2c: Split I2C_M_NOSTART support out of I2C_FUNC_PROTOCOL_MANGLINGMark Brown
Since there are uses for I2C_M_NOSTART which are much more sensible and standard than most of the protocol mangling functionality (the main one being gather writes to devices where something like a register address needs to be inserted before a block of data) create a new I2C_FUNC_NOSTART for this feature and update all the users to use it. Also strengthen the disrecommendation of the protocol mangling while we're at it. In the case of regmap-i2c we remove the requirement for mangling as I2C_M_NOSTART is the only mangling feature which is being used. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-05-29backlight: tosa_lcd: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: tosa_bl: use devm_ functionsJingoo Han
2012-05-29backlight: tdo24m: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: s6e63m0: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: InKi Dae <inki.dae@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: ltv350qv: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: lms283gf05: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: ld9040: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Donghwa Lee <dh09.lee@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: l4f00242t03: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Alberto Panizzo <alberto@amarulasolutions.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: ili9320: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: corgi_lcd: use devm_ functionsJingoo Han
2012-05-29backlight: ams369fg06: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: adp8870: use devm_ functionsJingoo Han
The devm_ functions allocate memory that is released when a driver detaches. This patch uses devm_kzalloc of these functions. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Michael Hennerich <michael.hennerich@analog.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: adp8860: use devm_ functionsJingoo Han
2012-05-29backlight: initialize struct backlight_properties properlyCorentin Chary
In all these files, the .power field was never correctly initialized. Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Cc: Jingoo Han <jg1.han@samsung.com> Cc: Dave Airlie <airlied@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29drivers/video/backlight/l4f00242t03.c: use pr_fmtJingoo Han
This driver uses pr_debug(), so provide it with the appropriate prefixing. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Alberto Panizzo <alberto@amarulasolutions.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: progear: use pr_err() instead of printk()Jingoo Han
Use pr_err() instead of printk() to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warnings as below: WARNING: printk() should include KERN_ facility level [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Marcin Juszkiewicz <openembedded@haerwu.biz> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: omap1: use pr_info() instead of printk()Jingoo Han
Use pr_info() instead of printk() to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warning as below: WARNING: Prefer pr_info(... to printk(KERN_INFO, ... [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Andrzej Zaborowski <balrogg@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: jornada720: use pr_err()/pr_info() instead of printk()Jingoo Han
Use pr_err()/pr_info() instead of printk() to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warnings as below: WARNING: Prefer pr_err(... to printk(KERN_ERR, ... WARNING: Prefer pr_info(... to printk(KERN_INFO, ... [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: generic_bl: use pr_info() instead of printk()Jingoo Han
Use pr_info() instead of printk() to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warnings as below: WARNING: printk() should include KERN_ facility level [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: cr_bllcd: use pr_err()/pr_info() instead of printk()Jingoo Han
Use pr_err()/pr_info() instead of printk() to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warnings as below: WARNING: printk() should include KERN_ facility level WARNING: Prefer pr_err(... to printk(KERN_ERR, ... [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: apple_bl: use pr_debug()/pr_err() instead of printk()Jingoo Han
Use pr_debug()/pr_err() instead of printk() to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warnings as below: WARNING: Prefer pr_debug(... to printk(KERN_DEBUG, ... WARNING: Prefer pr_err(... to printk(KERN_ERR, ... [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29backlight: use pr_warn() and pr_debug() instead of printk()Jingoo Han
Use pr_warn() and pr_debug() instead of printk to allow dynamic debugging. The pr_fmt prefix for pr_ macros is used. Also fix checkpatch warnings as below: WARNING: Prefer pr_warn(... to printk(KERN_WARNING, ... [akpm@linux-foundation.org: use KBUILD_MODNAME, per Joe] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29drivers/video/backlight/adp5520_bl.c: use kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred. Thus, kstrtoul should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Michael Hennerich <michael.hennerich@analog.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29drivers/video/backlight/adp8870_bl.c: use kstrtoul()Jingoo Han
2012-05-29drivers/video/backlight/adp8860_bl.c: use kstrtoul()Jingoo Han
2012-05-29backlight: add LM3533 backlight driverJohan Hovold
Add sub-driver for the backlights on National Semiconductor / TI LM3533 lighting power chips. The chip provides 256 brightness levels and ambient-light-sensor and pwm input control. [akpm@linux-foundation.org: fix warning] [akpm@linux-foundation.org: fix the type of `mode'] Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Rob Landley <rob@landley.net> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29drivers/video/backlight/apple_bl.c: include header for exported symbol ↵H Hartley Sweeten
prototypes Include the header to pickup the exported symbol prototype. Quiets the sparse warning: warning: symbol 'apple_bl_register' was not declared. Should it be static? warning: symbol 'apple_bl_unregister' was not declared. Should it be static? [akpm@linux-foundation.org: fix resulting build error] Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29lcd: add callbacks for early fb event blank supportInki Dae
This patchset adds early fb blank feature that a callback of lcd panel driver is called prior to specific fb driver's one. In the case of MIPI-DSI based video mode LCD Panel, for lcd power off, the power off commands should be transferred to lcd panel with display and mipi-dsi controller enabled because the commands is set to lcd panel at vsync porch period. and in opposite case, the callback of fb driver should be called prior to lcd panel driver's one because of same issue. Also if fb_blank mode is changed to FB_BLANK_POWERDOWN then display controller would be off(clock disable) but lcd panel would be still on. at this time, you could see some issue like sparkling on lcd panel because video clock to be delivered to ldi module of lcd panel was disabled. this issue could occurs for all lcd panels. The callback order is as the following: at fb_blank function of fbmem.c -> fb_notifier_call_chain(FB_EARLY_EVENT_BLANK) -> lcd panel driver's early_set_power() -> info->fbops->fb_blank() -> spcefic fb driver's fb_blank() -> fb_notifier_call_chain(FB_EVENT_BLANK) -> lcd panel driver's set_power() -> fb_notifier_call_chain(FB_R_EARLY_EVENT_BLANK) if info->fops->fb_blank() was failed. fb_notifier_call_chain(FB_R_EARLY_EVENT_BLANK) would be called to revert the effects of previous FB_EARLY_EVENT_BLANK call. and note that if early_set_power() of lcd_ops is NULL then early fb blank callback would be ignored. This patch: Add early_set_power and r_early_set_power callbacks. early_set_power callback is called prior to fb_blank() of fbmem.c and r_early_set_power callback is called if fb_blank() was failed to revert the effects of the early_set_power call of lcd panel driver. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29fbdev: add events for early fb event supportInki Dae
Add FB_EARLY_EVENT_BLANK and FB_R_EARLY_EVENT_BLANK event mode supports. first, fb_notifier_call_chain() is called with FB_EARLY_EVENT_BLANK and fb_blank() of specific fb driver is called and then fb_notifier_call_chain() is called with FB_EVENT_BLANK again at fb_blank(). and if fb_blank() was failed then fb_nitifier_call_chain() would be called with FB_R_EARLY_EVENT_BLANK to revert the previous effects. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29blacklight: remove redundant spi driver bus initializationLars-Peter Clausen
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_driver_register() so we can drop the manual assignment. The patch was generated using the following coccinelle semantic patch: // <smpl> @@ identifier _driver; @@ struct spi_driver _driver = { .driver = { - .bus = &spi_bus_type, }, }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
