path: root/drivers/virtio/virtio_balloon.c
2010-05-19virtio_balloon: use virtqueue_xxx wrappersMichael S. Tsirkin
Switch virtio_balloon to new virtqueue_xxx wrappers. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-22virtio: Fix GFP flags passed from the virtio balloon driverBalbir Singh
The virtio balloon driver can dig into the reservation pools of the OS to satisfy a balloon request. This is not advisable and other balloon drivers (drivers/xen/balloon.c) avoid this as well. The patch also adds changes to avoid printing a warning if allocation fails, since we retry after sometime anyway. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: kvm <kvm@vger.kernel.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-24virtio: fix balloon without VIRTIO_BALLOON_F_STATS_VQRusty Russell
When running under qemu-kvm-0.11.0: BUG: unable to handle kernel paging request at 56e58955 ... Process vballoon (pid: 1297, ti=c7976000 task=c70a6ca0 task.ti=c7 ... Call Trace: [<c88253a3>] ? balloon+0x1b3/0x440 [virtio_balloon] [<c041c2d7>] ? schedule+0x327/0x9d0 [<c88251f0>] ? balloon+0x0/0x440 [virtio_balloon] [<c014a2d4>] ? kthread+0x74/0x80 [<c014a260>] ? kthread+0x0/0x80 [<c0103b36>] ? kernel_thread_helper+0x6/0x30 need_stats_update should be zero-initialized. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Adam Litke <agl@us.ibm.com>
2010-02-24virtio: Fix scheduling while atomic in virtio_balloon statsAdam Litke
This is a fix for my earlier patch: "virtio: Add memory statistics reporting to the balloon driver (V4)". I discovered that all_vm_events() can sleep and therefore stats collection cannot be done in interrupt context. One solution is to handle the interrupt by noting that stats need to be collected and waking the existing vballoon kthread which will complete the work via stats_handle_request(). Rusty, is this a saner way of doing business? There is one issue that I would like a broader opinion on. In stats_request, I update vb->need_stats_update and then wake up the kthread. The kthread uses vb->need_stats_update as a condition variable. Do I need a memory barrier between the update and wake_up to ensure that my kthread sees the correct value? My testing suggests that it is not needed but I would like some confirmation from the experts. Signed-off-by: Adam Litke <agl@us.ibm.com> To: Rusty Russell <rusty@rustcorp.com.au> Cc: Anthony Liguori <aliguori@linux.vnet.ibm.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-02-24virtio: Add memory statistics reporting to the balloon driver (V4)Adam Litke
Changes since V3: - Do not do endian conversions as they will be done in the host - Report stats that reference a quantity of memory in bytes - Minor coding style updates Changes since V2: - Increase stat field size to 64 bits - Report all sizes in kb (not pages) - Drop anon_pages stat and fix endianness conversion Changes since V1: - Use a virtqueue instead of the device config space When using ballooning to manage overcommitted memory on a host, a system for guests to communicate their memory usage to the host can provide information that will minimize the impact of ballooning on the guests. The current method employs a daemon running in each guest that communicates memory statistics to a host daemon at a specified time interval. The host daemon aggregates this information and inflates and/or deflates balloons according to the level of host memory pressure. This approach is effective but overly complex since a daemon must be installed inside each guest and coordinated to communicate with the host. A simpler approach is to collect memory statistics in the virtio balloon driver and communicate them directly to the hypervisor. This patch enables the guest-side support by adding stats collection and reporting to the virtio balloon driver. Signed-off-by: Adam Litke <agl@us.ibm.com> Cc: Anthony Liguori <anthony@codemonkey.ws> Cc: virtualization@lists.linux-foundation.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (minor fixes)
2010-01-16virtio: fix section mismatch warningsJeff Mahoney
Fix fixes the following warnings by renaming the driver structures to be suffixed with _driver. WARNING: drivers/virtio/virtio_balloon.o(.data+0x88): Section mismatch in reference from the variable virtio_balloon to the function .devexit.text:virtballoon_remove() WARNING: drivers/char/hw_random/virtio-rng.o(.data+0x88): Section mismatch in reference from the variable virtio_rng to the function .devexit.text:virtrng_remove() Signed-off-by: Jeff Mahoney <jeffm@suse.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-22move virtballoon_remove to .devexit.textUwe Kleine-König
The function virtballoon_remove is used only wrapped by __devexit_p so define it using __devexit. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: make add_buf return capacity remainingRusty Russell
This API change means that virtio_net can tell how much capacity remains for buffers. It's necessarily fuzzy, since VIRTIO_RING_F_INDIRECT_DESC means we can fit any number of descriptors in one, *if* we can kmalloc. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dinesh Subhraveti <dineshs@us.ibm.com>
2009-06-12virtio: find_vqs/del_vqs virtio operationsMichael S. Tsirkin
This replaces find_vq/del_vq with find_vqs/del_vqs virtio operations, and updates all drivers. This is needed for MSI support, because MSI needs to know the total number of vectors upfront. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ lguest/9p compile fixes)
2009-06-12virtio: add names to virtqueue struct, mapping from devices to queues.Rusty Russell
Add a linked list of all virtqueues for a virtio device: this helps for debugging and is also needed for upcoming interface change. Also, add a "name" field for clearer debug messages. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-04-19virtio: fix suspend when using virtio_balloonMarcelo Tosatti
Break out of wait_event_interruptible() if freezing has been requested, in the vballoon thread. Without this change vballoon refuses to stop and the system can't suspend. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2008-12-30virtio: avoid implicit use of Linux page size in balloon interfaceHollis Blanchard
Make the balloon interface always use 4K pages, and convert Linux pfns if necessary. This patch assumes that Linux's PAGE_SHIFT will never be less than 12. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (modified)
2008-08-26virtio_balloon: fix towards_target when deflating balloonAnthony Liguori
Both v and vb->num_pages are u32 and unsigned int respectively. If v is less than vb->num_pages (and it is, when deflating the balloon), the result is a very large 32-bit number. Since we're returning a s64, instead of getting the same negative number we desire, we get a very large positive number. This handles the case where v < vb->num_pages and ensures we get a small, negative, s64 as the result. Rusty: please push this for 2.6.27-rc4. It's probably appropriate for the stable tree too as it will cause an unexpected OOM when ballooning. Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (simplified)
2008-05-02virtio: explicit advertisement of driver featuresRusty Russell
A recent proposed feature addition to the virtio block driver revealed some flaws in the API: in particular, we assume that feature negotiation is complete once a driver's probe function returns. There is nothing in the API to require this, however, and even I didn't notice when it was violated. So instead, we require the driver to specify what features it supports in a table, we can then move the feature negotiation into the virtio core. The intersection of device and driver features are presented in a new 'features' bitmap in the struct virtio_device. Note that this highlights the difference between Linux unsigned-long bitmaps where each unsigned long is in native endian, and a straight-forward little-endian array of bytes. Drivers can still remove feature bits in their probe routine if they really have to. API changes: - dev->config->feature() no longer gets and acks a feature. - drivers should advertise their features in the 'feature_table' field - use virtio_has_feature() for extra sanity when checking feature bits Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02virtio: change config to guest endian.Rusty Russell
A recent proposed feature addition to the virtio block driver revealed some flaws in the API, in particular how easy it is to break big endian machines. The virtio config space was originally chosen to be little-endian, because we thought the config might be part of the PCI config space for virtio_pci. It's actually a separate mmio region, so that argument holds little water; as only x86 is currently using the virtio mechanism, we can change this (but must do so now, before the impending s390 merge). API changes: - __virtio_config_val() just becomes a striaght vdev->config_get() call. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-03-17virtio: handle > 2 billion page balloon targetsRusty Russell
If the host asks for a huge target towards_target() can overflow, and we up oops as we try to release more pages than we have. The simple fix is to use a 64-bit value. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-06virtio: add missing #include <linux/delay.h>Johann Felix Soden
Include linux/delay.h to fix compiler error: drivers/virtio/virtio_balloon.c: In function 'fill_balloon': drivers/virtio/virtio_balloon.c:98: error: implicit declaration of function 'msleep' Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04virtio: balloon driverRusty Russell
After discussions with Anthony Liguori, it seems that the virtio balloon can be made even simpler. Here's my attempt. The device configuration tells the driver how much memory it should take from the guest (ie. balloon size). The guest feeds the page numbers it has taken via one virtqueue. A second virtqueue feeds the page numbers the driver wants back: if the device has the VIRTIO_BALLOON_F_MUST_TELL_HOST bit, then this queue is compulsory, otherwise it's advisory (and the guest can simply fault the pages back in). This driver can be enhanced later to deflate the balloon via a shrinker, oom callback or we could even go for a complete set of in-guest regulators. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
