commit 6fbc198cf623944ab60a1db6d306a4d55cdd820d upstream.
On restore, virtio pci does the following:
+ set features
+ init vqs etc - device can be used at this point!
+ set ACKNOWLEDGE,DRIVER and DRIVER_OK status bits
This is in violation of the virtio spec, which
requires the following order:
- ACKNOWLEDGE
- DRIVER
- init vqs
- DRIVER_OK
This behaviour will break with hypervisors that assume spec compliant
behaviour. It seems like a good idea to have this patch applied to
stable branches to reduce the support butden for the hypervisors.
Cc: Amit Shah <amit.shah@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to meet
kernel coding style guidelines. This issue was reported by checkpatch.
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
As result of deprecation of MSI-X/MSI enablement functions
pci_enable_msix() and pci_enable_msi_block() all drivers
using these two interfaces need to be updated to use the
new pci_enable_msi_range() or pci_enable_msi_exact()
and pci_enable_msix_range() or pci_enable_msix_exact()
interfaces.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Currently a host kick error is silently ignored and not reflected in
the virtqueue of a particular virtio device.
Changing the notify API for guest->host notification seems to be one
prerequisite in order to be able to handle such errors in the context
where the kick is triggered.
This patch changes the notify API. The notify function must return a
bool return value. It returns false if the host notification failed.
Signed-off-by: Heinz Graalfs <graalfs@linux.vnet.ibm.com>
The virtio_pci_freeze/restore are defined under CONFIG_PM but is used
by SET_SYSTEM_SLEEP_PM_OPS macro, which is defined under
CONFIG_PM_SLEEP. So if CONFIG_PM_SLEEP is not cofigured but
CONFIG_PM_RUNTIME is, the following warning message appeared:
drivers/virtio/virtio_pci.c:770:12: warning: ‘virtio_pci_freeze’ defined but not used [-Wunused-function]
static int virtio_pci_freeze(struct device *dev)
drivers/virtio/virtio_pci.c:790:12: warning: ‘virtio_pci_restore’ defined but not used [-Wunused-function]
static int virtio_pci_restore(struct device *dev)
Fix it by changing CONFIG_PM to CONFIG_PM_SLEEP.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Reviewed-by: Amit Shah <amit.shah@redhat.com>
vp_dev->msix_vectors should be initialized before allocating
msix_affinity_masks, otherwise vp_free_vectors will not free these
objects.
unreferenced object 0xffff88010f969d88 (size 512):
comm "systemd-udevd", pid 158, jiffies 4294673645 (age 80.545s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff816e455e>] kmemleak_alloc+0x5e/0xc0
[<ffffffff811aa7f1>] kmem_cache_alloc_node_trace+0x141/0x2c0
[<ffffffff8133ba23>] alloc_cpumask_var_node+0x23/0x80
[<ffffffff8133ba8e>] alloc_cpumask_var+0xe/0x10
[<ffffffff813fdb3d>] vp_try_to_find_vqs+0x25d/0x810
[<ffffffff813fe171>] vp_find_vqs+0x81/0xb0
[<ffffffffa00d2a05>] init_vqs+0x85/0x120 [virtio_balloon]
[<ffffffffa00d2c29>] virtballoon_probe+0xf9/0x1a0 [virtio_balloon]
[<ffffffff813fb61e>] virtio_dev_probe+0xde/0x140
[<ffffffff814452b8>] driver_probe_device+0x98/0x3a0
[<ffffffff8144566b>] __driver_attach+0xab/0xb0
[<ffffffff814432f4>] bus_for_each_dev+0x94/0xb0
[<ffffffff81444f4e>] driver_attach+0x1e/0x20
[<ffffffff81444910>] bus_add_driver+0x200/0x280
[<ffffffff81445c14>] driver_register+0x74/0x160
[<ffffffff813fb7d0>] register_virtio_driver+0x20/0x40
v2: change msix_vectors uncoditionaly in vp_free_vectors
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Jason Wang <jasowang@redhat.com>
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Acked-by: Jason Wang <jasowang@redhat.com>
Use DEVICE_TABLE macro which also makes table const.
It is just a table of function pointers, make it const for cleanliness and security
reasons.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, and __devexit
from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
They're generic concepts, so hoist them. This also avoids accessor
functions (though kept around for merge with DaveM's net tree).
This goes even further than Jason Wang's 17bb6d4088 patch
("virtio-ring: move queue_index to vring_virtqueue") which moved the
queue_index from the specific transport.
Use the module_pci_driver() macro to make the code simpler
by eliminating module_init and module_exit calls.
dpatch engine is used to auto generate this patch.
(https://github.com/weiyj/dpatch)
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
virtio network device multiqueue support reserves
vq 3 for future use (useful both for future extensions and to make it
pretty - this way receive vqs have even and transmit - odd numbers).
Make it possible to skip initialization for
specific vq numbers by specifying NULL for name.
Document this usage as well as (existing) NULL callback.
Drivers using this not coded up yet, so I simply tested
with virtio-pci and verified that this patch does
not break existing drivers.
Sometimes, virtio device need to configure irq affinity hint to maximize the
performance. Instead of just exposing the irq of a virtqueue, this patch
introduce an API to set the affinity for a virtqueue.
The api is best-effort, the affinity hint may not be set as expected due to
platform support, irq sharing or irq type. Currently, only pci method were
implemented and we set the affinity according to:
- if device uses INTX, we just ignore the request
- if device has per vq vector, we force the affinity hint
- if the virtqueues share MSI, make the affinity OR over all affinities
requested
Signed-off-by: Jason Wang <jasowang@redhat.com>
Instead of storing the queue index in transport-specific virtio structs,
this patch moves them to vring_virtqueue and introduces an helper to get
the value. This lets drivers simplify their management and tracing of
virtqueues.
Use the SET_SYSTEM_SLEEP_PM_OPS macro to initialise the suspend/resume
functions in the new PM API.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
There's no difference in supporting S3 and S4 for virtio devices: the
vqs have to be re-created as the device has to be assumed to be reset at
restore-time. Since S4 already handles this situation, we can directly
use the same code and callbacks for S3 support.
restore_common() was shared between restore and thaw callbacks. With
thaw gone, we don't need restore_common() anymore.
The thaw operation was used by the balloon driver, but after the last
commit there's no reason to have separate thaw and restore callbacks.
Handle thaw, restore and freeze notifications from the PM core. Expose
these to individual virtio drivers that can quiesce and resume vq
operations. For drivers not implementing the thaw() method, use the
restore method instead.
These functions also save device-specific data so that the device can be
put in pre-suspend state after resume, and disable and enable the PCI
device in the freeze and resume functions, respectively.
The older PM API doesn't have a way to get notifications on hibernate
events. Switch to the newer one that gives us those notifications.
We were cheating with our barriers; using the smp ones rather than the
real device ones. That was fine, until rpmsg came along, which is
used to talk to a real device (a non-SMP CPU).
Unfortunately, just putting back the real barriers (reverting
d57ed95d) causes a performance regression on virtio-pci. In
particular, Amos reports netbench's TCP_RR over virtio_net CPU
utilization increased up to 35% while throughput went down by up to
14%.
By comparison, this branch is in the noise.
Reference: https://lkml.org/lkml/2011/12/11/22
virtio pci device reset actually just does an I/O
write, which in PCI is really posted, that is it
can complete on CPU before the device has received it.
Further, interrupts might have been pending on
another CPU, so device callback might get invoked after reset.
This conflicts with how drivers use reset, which is typically:
reset
unregister
a callback running after reset completed can race with
unregister, potentially leading to use after free bugs.
Fix by flushing out the write, and flushing pending interrupts.
This assumes that device is never reset from
its vq/config callbacks, or in parallel with being
added/removed, document this assumption.
The forcedeth changes had a conflict with the conversion over
to atomic u64 statistics in net-next.
The libertas cfg.c code had a conflict with the bss reference
counting fix by John Linville in net-next.
drivers/net/ethernet/nvidia/forcedeth.c
drivers/net/wireless/libertas/cfg.c
Add a new .bus_name to virtio_config_ops then modify virtio_net to
call through to it in an ethtool .get_drvinfo routine to report
bus_info in ethtool -i output which is consistent with other
emulated NICs and the output of lspci.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
Commit 31a3ddda166cda86d2b5111e09ba4bda5239fae6 introduced
a use after free in virtio-pci. The main issue is
that the release method signals removal of the virtio device,
while remove signals removal of the pci device.
For example, on driver removal or hot-unplug,
virtio_pci_release_dev is called before virtio_pci_remove.
We then might get a crash as virtio_pci_remove tries to use the
device freed by virtio_pci_release_dev.
We allocate/free all resources together with the
pci device, so we can leave the release method empty.
Acked-by: Amit Shah <amit.shah@redhat.com>
Cc: stable@kernel.org
For the MSI but non-per_vq_vector case, the config/change vq
also gets added to the list of vqs that need to process the
MSI interrupt. This is not needed as config has it's own
handler (vp_config_changed). In any case, vring_interrupt()
finds nothing needs to be done on this vq.
I tested this patch by testing the "Fallback:" and "Finally
fall back" cases in vp_find_vqs(). Please review.
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
In the case where a virtio-console port is in use (opened by a program)
and a virtio-console device is removed, the port is kept around but all
the virtio-related state is assumed to be gone.
When the port is finally released (close() called), we call
device_destroy() on the port's device. This results in the parent
device's structures to be freed as well. This includes the PCI regions
for the virtio-console PCI device.
Once this is done, however, virtio_pci_release_dev() kicks in, as the
last ref to the virtio device is now gone, and attempts to do
pci_iounmap(pci_dev, vp_dev->ioaddr);
pci_release_regions(pci_dev);
pci_disable_device(pci_dev);
which results in a double-free warning.
Move the code that releases regions, etc., to the virtio_pci_remove()
function, and all that's now left in release_dev is the final freeing of
the vp_dev.
We sometimes need to map between the virtio device and
the given pci device. One such use is OS installer that
gets the boot pci device from BIOS and needs to
find the relevant block device. Since it can't,
installation fails.
Instead of creating a top-level devices/virtio-pci
directory, create each device under the corresponding
pci device node. Symlinks to all virtio-pci
devices can be found under the pci driver link in
bus/pci/drivers/virtio-pci/devices, and all virtio
devices under drivers/bus/virtio/devices.
Signed-off-by: Milton Miller <miltonm@bga.com>
Tested-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Gleb Natapov <gleb@redhat.com>
Tested-by: "Daniel P. Berrange" <berrange@redhat.com>
virtio-pci resets the device at startup by writing to the status
register, but this does not clear the pci config space,
specifically msi enable status which affects register
layout.
This breaks things like kdump when they try to use e.g. virtio-blk.
Fix by forcing msi off at startup. Since pci.c already has
a routine to do this, we export and use it instead of duplicating code.
Tested-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: linux-pci@vger.kernel.org
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
[Ss]ytem => [Ss]ystem
udpate => update
paramters => parameters
orginal => original
Signed-off-by: Thomas Weber <swirl@gmx.li>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
As all virtio devices perform DMA, we
must enable bus mastering for them to be
spec compliant.
This patch fixes hotplug of virtio devices
with Linux guests and qemu 0.11-0.12.
Tested-by: Alexander Graf <agraf@suse.de>
I have observed the following error on virtio-net module unload:
WARNING: at kernel/irq/manage.c:858 __free_irq+0xa0/0x14c()
Hardware name: Bochs
Trying to free already-free IRQ 0
Modules linked in: virtio_net(-) virtio_blk virtio_pci virtio_ring
virtio af_packet e1000 shpchp aacraid uhci_hcd ohci_hcd ehci_hcd [last
unloaded: scsi_wait_scan]
Pid: 1957, comm: rmmod Not tainted 2.6.33-rc8-vhost #24
Call Trace:
[<ffffffff8103e195>] warn_slowpath_common+0x7c/0x94
[<ffffffff8103e204>] warn_slowpath_fmt+0x41/0x43
[<ffffffff810a7a36>] ? __free_pages+0x5a/0x70
[<ffffffff8107cc00>] __free_irq+0xa0/0x14c
[<ffffffff8107cceb>] free_irq+0x3f/0x65
[<ffffffffa0081424>] vp_del_vqs+0x81/0xb1 [virtio_pci]
[<ffffffffa0091d29>] virtnet_remove+0xda/0x10b [virtio_net]
[<ffffffffa0075200>] virtio_dev_remove+0x22/0x4a [virtio]
[<ffffffff812709ee>] __device_release_driver+0x66/0xac
[<ffffffff81270ab7>] driver_detach+0x83/0xa9
[<ffffffff8126fc66>] bus_remove_driver+0x91/0xb4
[<ffffffff81270fcf>] driver_unregister+0x6c/0x74
[<ffffffffa0075418>] unregister_virtio_driver+0xe/0x10 [virtio]
[<ffffffffa0091c4d>] fini+0x15/0x17 [virtio_net]
[<ffffffff8106997b>] sys_delete_module+0x1c3/0x230
[<ffffffff81007465>] ? old_ich_force_enable_hpet+0x117/0x164
[<ffffffff813bb720>] ? do_page_fault+0x29c/0x2cc
[<ffffffff81028e58>] sysenter_dispatch+0x7/0x27
---[ end trace 15e88e4c576cc62b ]---
The bug is in virtio-pci: we use msix_vector as array index to get irq
entry, but some vqs do not have a dedicated vector so this causes an out
of bounds access. By chance, we seem to often get 0 value, which
results in this error.
Fix by verifying that vector is legal before using it as index.
Acked-by: Anthony Liguori <aliguori@us.ibm.com>
Acked-by: Shirley Ma <xma@us.ibm.com>
This is needed to compile with CONFIG_VIRTIO_PCI=y,
because virtio_pci_remove is marked __devexit.
Signed-off-by: Jamie Lokier <jamie@shareable.org>
Commit f68d24082e22ccee3077d11aeb6dc5354f0ca7f1
in 2.6.32-rc1 broke requesting IRQs for per-VQ MSI-X vectors:
- vector number was used instead of the vector itself
- we try to request an IRQ for VQ which does not
have a callback handler
This is a regression that causes warnings in kernel log,
potentially lower performance as we need to scan vq list,
and might cause system failure if the interrupt
requested is in fact needed by another system.
This was not noticed earlier because in most cases
we were falling back on shared interrupt for all vqs.
The warnings often look like this:
virtio-pci 0000:00:03.0: irq 26 for MSI/MSI-X
virtio-pci 0000:00:03.0: irq 27 for MSI/MSI-X
virtio-pci 0000:00:03.0: irq 28 for MSI/MSI-X
IRQ handler type mismatch for IRQ 1
current handler: i8042
Pid: 2400, comm: modprobe Tainted: G W
2.6.32-rc3-11952-gf3ed8d8-dirty #1
Call Trace:
[<ffffffff81072aed>] ? __setup_irq+0x299/0x304
[<ffffffff81072ff3>] ? request_threaded_irq+0x144/0x1c1
[<ffffffff813455af>] ? vring_interrupt+0x0/0x30
[<ffffffff81346598>] ? vp_try_to_find_vqs+0x583/0x5c7
[<ffffffffa0015188>] ? skb_recv_done+0x0/0x34 [virtio_net]
[<ffffffff81346609>] ? vp_find_vqs+0x2d/0x83
[<ffffffff81345d00>] ? vp_get+0x3c/0x4e
[<ffffffffa0016373>] ? virtnet_probe+0x2f1/0x428 [virtio_net]
[<ffffffffa00150d8>] ? skb_xmit_done+0x0/0x39 [virtio_net]
[<ffffffff8110ab92>] ? sysfs_do_create_link+0xcb/0x116
[<ffffffff81345cc2>] ? vp_get_status+0x14/0x16
[<ffffffff81345464>] ? virtio_dev_probe+0xa9/0xc8
[<ffffffff8122b11c>] ? driver_probe_device+0x8d/0x128
[<ffffffff8122b206>] ? __driver_attach+0x4f/0x6f
[<ffffffff8122b1b7>] ? __driver_attach+0x0/0x6f
[<ffffffff8122a9f9>] ? bus_for_each_dev+0x43/0x74
[<ffffffff8122a374>] ? bus_add_driver+0xea/0x22d
[<ffffffff8122b4a3>] ? driver_register+0xa7/0x111
[<ffffffffa001a000>] ? init+0x0/0xc [virtio_net]
[<ffffffff81009051>] ? do_one_initcall+0x50/0x148
[<ffffffff8106e117>] ? sys_init_module+0xc5/0x21a
[<ffffffff8100af02>] ? system_call_fastpath+0x16/0x1b
Reported-by: Marcelo Tosatti <mtosatti@redhat.com>
Reported-by: Shirley Ma <xma@us.ibm.com>
1) Rename vp_request_vectors to vp_request_msix_vectors, and take
non-MSI-X case out to caller.
2) Comment weird pci_enable_msix API
3) Rename vp_find_vq to setup_vq.
4) Fix spaces to tabs
5) Make nvectors calc internal to vp_try_to_find_vqs()
6) Rename vector to msix_vector for more clarity.
This refactors find_vqs, making it more readable and robust, and fixing
two regressions from 2.6.30:
- double free_irq causing BUG_ON on device removal
- probe failure when vq can't be assigned to msi-x vector
(reported on old host kernels)
Tested-by: Amit Shah <amit.shah@redhat.com>
This makes delete vq the reverse of find vq.
This is required to make it possible to retry find_vqs
after a failure, otherwise the list gets corrupted.
Make vp_free_vectors do the reverse of vq_request_vectors.
If pci_register_driver() fails we're incorrectly unregistering the root
device with device_unregister() rather than root_device_unregister().
Reported-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
This implements optional MSI-X support in virtio_pci.
MSI-X is used whenever the host supports at least 2 MSI-X
vectors: 1 for configuration changes and 1 for virtqueues.
Per-virtqueue vectors are allocated if enough vectors
available.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ whitespace, style)
This reorganizes virtio-pci code in vp_interrupt slightly, so that
it's easier to add per-vq MSI support on top.
This replaces find_vq/del_vq with find_vqs/del_vqs virtio operations,
and updates all drivers. This is needed for MSI support, because MSI
needs to know the total number of vectors upfront.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (+ lguest/9p compile fixes)
Add a linked list of all virtqueues for a virtio device: this helps for
debugging and is also needed for upcoming interface change.
Also, add a "name" field for clearer debug messages.
The host really shouldn't be notifying us of config changes
before the device status is VIRTIO_CONFIG_S_DRIVER or
VIRTIO_CONFIG_S_DRIVER_OK.
However, if we do happen to be interrupted while we're not
attached to a driver, we really shouldn't oops. Prevent
this simply by checking that device->driver is non-NULL
before trying to notify the driver of config changes.
Problem observed by doing a "set_link virtio.0 down" with
QEMU before the net driver had been loaded.
We shouldn't be statically allocating the root device object,
so dynamically allocate it using root_device_register()
instead.
Also avoids this warning from 'rmmod virtio_pci':
Device 'virtio-pci' does not have a release() function, it is broken and must be fixed
Cc: Anthony Liguori <aliguori@us.ibm.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
