path: root/drivers/w1/w1_int.c
2005-09-08[PATCH] w1: Detouching bug fixed.Evgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] w1: hotplug support.Evgeniy Polyakov
Here is W1 hotplug in addition to netlink notifications. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] W1: w1_netlink: New init/fini netlink callbacks.Evgeniy Polyakov
They are guarded with NETLINK_DISABLE compile time options, so if CONFIG_NET is disabled, no linking errors occur. Bug noticed by Adrian Bunk <bunk@stusta.de>. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: w1_int.c: fix default netlink groupEvgeniy Polyakov
w1 does not need to multicast its state to several groups at once, and upcoming netlink changes will not allow bitmask for groups anyway. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-24[W1]: Do not use NFLOG netlink number.David S. Miller
Use the reserved by never used NETLINK_SKIP value instead. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[PATCH] w1: reconnect feature.Evgeniy Polyakov
I've created reconnect feature - if on start there are no registered families all new devices will have defailt family, later when driver for appropriate family is loaded, slaves, which were faound earlier, will still have defult family instead of right one. Reconnect feature will force control thread to run through all master devices and all slaves found and search for slaves with default family id and try to reconnect them. It does not store newly registered family and does not check only those slaves which have reg_num.family the same as being registered one - all slaves with default family are reconnected. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Adds a sysfs entry (w1_master_search) that allows you to ↵Evgeniy Polyakov
disable/enable periodic searches. Adds a sysfs entry (w1_master_search) that allows you to disable/enable periodic searches. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: Cleans up usage of touch_bit/w1_read_bit/w1_write_bit.Evgeniy Polyakov
Cleans up usage of touch_bit/w1_read_bit/w1_write_bit. Signed-off-by: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] w1: cleanups.Evgeniy Polyakov
- white space changes. - list_for_each_entry/list_for_each_entry_safe and reverse changes. - small coding style changes. - removed redundant NULL checks. - use attribute group and macros instead of direct device attributes. Patch is havily based on work from Adrian Bunk and Dmitry Torokhov, thanks guys. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
