path: root/drivers/w1/w1_log.h
2014-06-19w1: use pr_* instead of printkFjodor Schelichow
This patch replaces all calls to the "printk" function within the main "w1" directory by calls to the appropriate "pr_*" function thus addressing the following warning generated by the checkpatch script: WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Fjodor Schelichow <fjodor.schelichow@hotmail.com> Signed-off-by: Roman Sommer <romsom2@yahoo.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-08-25MAINTAINERS: Evgeniy has movedEvgeniy Polyakov
Signed-off-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30drivers: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-06-21[PATCH] w1: cleanups.Evgeniy Polyakov
- white space changes. - list_for_each_entry/list_for_each_entry_safe and reverse changes. - small coding style changes. - removed redundant NULL checks. - use attribute group and macros instead of direct device attributes. Patch is havily based on work from Adrian Bunk and Dmitry Torokhov, thanks guys. Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
