path: root/drivers/w1
2017-03-12w1: ds2490: USB transfer buffers need to be DMAableMaciej S. Szmigiero
commit 61cd1b4cd1e8f7f7642ab64529d9bd52e8374641 upstream. ds2490 driver was doing USB transfers from / to buffers on a stack. This is not permitted and made the driver non-working with vmapped stacks. Since all these transfers are done under the same bus_mutex lock we can simply use shared buffers in a device private structure for two most common of them. While we are at it, let's also fix a comparison between int and size_t in ds9490r_search() which made the driver spin in this function if state register get requests were failing. Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12w1: don't leak refcount on slave attach failure in w1_attach_slave_device()Maciej S. Szmigiero
commit d2ce4ea1a0b0162e5d2d7e7942ab6f5cc2063d5a upstream. Near the beginning of w1_attach_slave_device() we increment a w1 master reference count. Later, when we are going to exit this function without actually attaching a slave device (due to failure of __w1_attach_slave_device()) we need to decrement this reference count back. Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name> Fixes: 9fcbbac5ded489 ("w1: process w1 netlink commands in w1_process thread") Cc: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20w1:omap_hdq: fix regressionH. Nikolaus Schaller
commit ecfaf0c42fc4306b5ec4bf6be01b66f8fe9a9733 upstream. Commit e93762bbf681 ("w1: masters: omap_hdq: add support for 1-wire mode") added a statement to clear the hdq_irqstatus flags in hdq_read_byte(). If the hdq reading process is scheduled slowly or interrupts are disabled for a while the hardware read activity might already be finished on entry of hdq_read_byte(). And hdq_isr() already has set the hdq_irqstatus to 0x6 (can be seen in debug mode) denoting that both, the TXCOMPLETE and RXCOMPLETE interrupts occurred in parallel. This means there is no need to wait and the hdq_read_byte() can just read the byte from the hdq controller. By resetting hdq_irqstatus to 0 the read process is forced to be always waiting again (because the if statement always succeeds) but the hardware will not issue another RXCOMPLETE interrupt. This results in a false timeout. After such a situation the hdq bus hangs. Link: http://lkml.kernel.org/r/b724765f87ad276a69625bc19806c8c8844c4590.1469513669.git.hns@goldelico.com Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-05Merge tag 'for-v4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply Pull power supply and reset updates from Sebastian Reichel: - new AXP20X USB Power driver - new Qualcomm SMBB driver - new TPS65217 Charger driver - BQ24257: add BQ24250/BQ24251 support - overhaul bq27x00 battery driver, rename to bq27xxx - misc fixes and cleanups * tag 'for-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (54 commits) power: bq27xxx_battery: Remove unneeded dependency in Kconfig power: bq27xxx_battery: move irq handler to i2c section power: bq27xxx_battery: fix platform probe twl4030_charger: add missing iio dependency power_supply: charger-manager: add missing of_node_put Documentation: power: bq24257: Document exported sysfs entries power: bq24257: Add various device-specific sysfs properties power: bq24257: Allow input current limit sysfs access power: bq24257: Add input DPM voltage threshold setting support power: bq24257: Add over voltage protection setting support power: bq24257: Add SW-based approach for Power Good determination power: bq24257: Allow manual setting of input current limit power: bq24257: Add bit definition for temp sense enable power: bq24257: Add basic support for bq24250/bq24251 dt: power: bq24257-charger: Cover additional devices power: bq24257: Simplify bq24257_power_supply_init() power: bq24257: Use managed power supply register power: bq24257: Streamline input current limit setup power: bq24257: Remove IRQ config through stat-gpios power: bq27xxx_battery: fix signedness bug in bq27xxx_battery_read_health() ...
2015-10-17W1: w1-gpio - switch to using dev_pm_opsDmitry Torokhov
Let's stop using legacy platform driver hooks for power management and switch to using the standard dev_pm_ops-based hooks. Also, instead of guarding PM methods with #ifdef CONFIG_PM annotate them as __maybe_unused as it provides better compile coverage. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-05w1: masters: omap_hdq: add support for 1-wire modeVignesh R
This patches makes following changes to omap_hdq driver - Enable 1-wire mode. - Implement w1_triplet callback to facilitate search rom procedure and auto detection of 1-wire slaves. - Proper enabling and disabling of interrupt. - Cleanups (formatting and return value checks). HDQ mode remains unchanged. Signed-off-by: Vignesh R <vigneshr@ti.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Pawel Moll <pawel.moll@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Ian Campbell <ijc+devicetree@hellion.org.uk> Cc: Kumar Gala <galak@codeaurora.org> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Jonathan Corbet <corbet@lwn.net> CC: Tony Lindgren <tony@atomide.com> Cc: Vignesh R <vigneshr@ti.com> Cc: NeilBrown <neilb@suse.de> Cc: Fabian Frederick <fabf@skynet.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-05drivers/w1/w1_int.c: call put_device if device_register failsLevente Kurusa
Currently, memsetting and kfreeing the device is bad behaviour. The device will have a reference count of 1 and hence can cause trouble because it has kfree'd. Proper way to handle a failed device_register is to call put_device right after it fails. Signed-off-by: Levente Kurusa <levex@linux.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-23power: bq27xxx_battery: Platform initialization must declare a deviceAndrew F. Davis
When initialized as a platform device the initializer must now specify a device. An empty device name is no longer valid. Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-09-23power: bq27x00_battery: Renaming for consistencyAndrew F. Davis
Rename functions that are used by multiple devices. New devices have been added and the function names and driver name are no longer general enough for the functionality they provide. Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: GUAN Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Sebastian Reichel <sre@kernel.org>
2015-09-01Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "The usual stuff from trivial tree for 4.3 (kerneldoc updates, printk() fixes, Documentation and MAINTAINERS updates)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) MAINTAINERS: update my e-mail address mod_devicetable: add space before */ scsi: a100u2w: trivial typo in printk i2c: Fix typo in i2c-bfin-twi.c treewide: fix typos in comment blocks Doc: fix trivial typo in SubmittingPatches proportions: Spelling s/consitent/consistent/ dm: Spelling s/consitent/consistent/ aic7xxx: Fix typo in error message pcmcia: Fix typo in locking documentation scsi/arcmsr: Fix typos in error log drm/nouveau/gr: Fix typo in nv10.c [SCSI] Fix printk typos in drivers/scsi staging: comedi: Grammar s/Enable support a/Enable support for a/ Btrfs: Spelling s/consitent/consistent/ README: GTK+ is a acronym ASoC: omap: Fix typo in config option description mm: tlb.c: Fix error message ntfs: super.c: Fix error log fix typo in Documentation/SubmittingPatches ...
2015-08-07w1: Fix typo in MODULE_DESCRIPTION in matrox_w1.cMasanari Iida
This patch fix spelling typo in matrox_w1.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Jiri Kosina <jkosina@suse.com>
2015-08-05w1: Use module_pci_driverVaishali Thakkar
Use module_pci_driver for drivers whose init and exit functions only register and unregister, respectively. A simplified version of the Coccinelle semantic patch that performs this transformation is as follows: @a@ identifier f, x; @@ -static f(...) { return pci_register_driver(&x); } @b depends on a@ identifier e, a.x; @@ -static e(...) { pci_unregister_driver(&x); } @c depends on a && b@ identifier a.f; declarer name module_init; @@ -module_init(f); @d depends on a && b && c@ identifier b.e, a.x; declarer name module_exit; declarer name module_pci_driver; @@ -module_exit(e); +module_pci_driver(x); Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-05w1: Drop owner assignment from i2c_driverKrzysztof Kozlowski
i2c_driver does not need to set an owner because i2c_register_driver() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-12w1: use correct lock on error in w1_seq_show()Dan Carpenter
I noticed there was a problem here because Smatch complained: drivers/w1/slaves/w1_therm.c:416 w1_seq_show() warn: inconsistent returns 'mutex:&sl->master->mutex'. Locked on: line 416 Unlocked on: line 413 The problem is that we lock ->mutex but we unlock ->bus_mutex on error. David Fries says that ->bus_mutex is correct and ->mutex is incorrect. Fixes: d9411e57dc7f ('w1: Add support for DS28EA00 sequence to w1-therm') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-12w1: fix for loop exit condition in w1_seq_show()Dan Carpenter
The W1_42_FINISHED_BYTE is 0xFF so the cast means the condition is never true. Fixes: d9411e57dc7f ('w1: Add support for DS28EA00 sequence to w1-therm') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-01w1: ds2482: Add i2c module alias nameLudek Hlavacek
Add i2c alias to enable autoloading of the module for device specified in device-tree. Signed-off-by: Ludek Hlavacek <ludek_h@seznam.cz> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24w1: Add support for DS28EA00 sequence to w1-thermMatt Campbell
This patch provides support for the DS28EA00 digital thermometer. The DS28EA00 provides an additional two pins for implementing a sequence detection algorithm. This feature allows you to determine the physical location of the chip in the 1-wire bus without needing pre-existing knowledge of the bus ordering. Support is provided through the sysfs w1_seq file. The file will contain a single line with an integer value representing the device index in the bus starting at 0. Signed-off-by: Matt Campbell <mattrcampbell@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24w1_therm reference count family dataDavid Fries
A temperature conversion can take 750 ms and when possible the w1_therm slave driver drops the bus_mutex to allow other bus operations, but that includes operations such as a periodic slave search, which can remove this slave when it is no longer detected. If that happens the sl->family_data will be freed and set to NULL causing w1_slave_show to crash when it wakes up. Signed-off-by: David Fries <David@Fries.net> Reported-By: Thorsten Bschorr <thorsten@bschorr.de> Tested-by: Thorsten Bschorr <thorsten@bschorr.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24w1: introduce an ability to specify microseconds bus scanning intervalsDmitry Khromov
Some of 1-Wire devices commonly associated with physical access control systems are attached/generate presence for as short as 100 ms - hence the tens-to-hundreds milliseconds scan intervals are required. Signed-off-by: Dmitry Khromov <dk@icelogic.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-25w1: constify of_device_id arrayFabian Frederick
of_device_id is always used as const. (See driver.of_match_table and open firmware functions) Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'char-misc-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver update for 3.19-rc1 Lots of little things all over the place in different drivers, and a new subsystem, "coresight" has been added. Full details are in the shortlog" * tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits) parport: parport_pc, do not remove parent devices early spmi: Remove shutdown/suspend/resume kernel-doc carma-fpga-program: drop videobuf dependency carma-fpga: drop videobuf dependency carma-fpga-program.c: fix compile errors i8k: Fix temperature bug handling in i8k_get_temp() cxl: Name interrupts in /proc/interrupt CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning coresight-replicator: remove .owner field for driver coresight: fixed comments in coresight.h coresight: fix typo in comment in coresight-priv.h coresight: bindings for coresight drivers coresight: Adding ABI documentation w1: support auto-load of w1_bq27000 module. w1: avoid potential u16 overflow cn: verify msg->len before making callback mei: export fw status registers through sysfs mei: read and print all six FW status registers mei: txe: add cherrytrail device id mei: kill cached host and me csr values ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-26w1: support auto-load of w1_bq27000 module.NeilBrown
1/ change request_module call to zero-pad single digit family numbers. This appears to be the intention of the code, but not what it actually does. This means that the alias created for W1_FAMILY_SMEM_01 might actually be useful. 2/ Define a family name for the BQ27000 battery charge monitor. Unfortunately this is the same number as W1_FAMILY_SMEM_01 so if both a compiled on a system, one module might need to be blacklisted. 3/ Add a MODULE_ALIAS for the bq27000. Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-26w1: avoid potential u16 overflowDavid Fries
Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David Fries <David@Fries.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-10w1: omap-hdq: support device probing with device-treeNeilBrown
This driver has no 'compatible' string and so is not found when using device-tree. Add one with value to match hdqw1w: 1w@480b2000 { device in omap3.dtsi. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-07W1: ds2490: Increase timeout when waiting for statusAlexander Stein
Adjust the bulk message timeout to the other ones (1000ms). Otherwise the following dmesg errors can be seen on a Raspberry Pi: [ 31.492386] Failed to read 1-wire data from 0x81: err=-110. [ 31.504168] 0x81: count=-110, status: [ 31.613404] Failed to read 1-wire data from 0x81: err=-110. [ 31.621915] 0x81: count=-110, status: [ 43.260968] Failed to read 1-wire data from 0x81: err=-110. [ 43.270998] 0x81: count=-110, status: [ 43.379959] Failed to read 1-wire data from 0x81: err=-110. [ 43.388854] 0x81: count=-110, status: Signed-off-by: Alexander Stein <alexanders83@web.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-20w1: masters: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-23w1: select crc16 library for ds2406Arnd Bergmann
commit 94859308a21b "w1: new w1_ds2406 driver" added a new driver that uses the crc16 library, but didn't ensure that the core is there. This adds the necessary Kconfig statements, just like we have it for other w1 drivers. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Scott Alfter <scott@alfter.us> Cc: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1/masters: use pr_* instead of printkFjodor Schelichow
This patch replaces all calls to the "printk" function within the "masters" subdirectory by calls to the appropriate "pr_*" function thus addressing the following warning generated by the checkpatch script: WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Fjodor Schelichow <fjodor.schelichow@hotmail.com> Signed-off-by: Roman Sommer <romsom2@yahoo.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: use pr_* instead of printkFjodor Schelichow
This patch replaces all calls to the "printk" function within the main "w1" directory by calls to the appropriate "pr_*" function thus addressing the following warning generated by the checkpatch script: WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Fjodor Schelichow <fjodor.schelichow@hotmail.com> Signed-off-by: Roman Sommer <romsom2@yahoo.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1/slaves: use pr_* instead of printkFjodor Schelichow
This patch replaces all calls to the "printk" function within the "slaves" subdirectory by calls to the appropriate "pr_*" function thus addressing the following warning generated by the checkpatch script: WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Fjodor Schelichow <fjodor.schelichow@hotmail.com> Signed-off-by: Roman Sommer <romsom2@yahoo.de> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: new w1_ds2406 driverScott Alfter
Some preliminary work at making use of this driver led me to implement CRC-16 checks on read and write to deal with the occasional glitchiness of the 1-Wire bus. The revised driver (attached) returns an I/O error if the CRC check fails. When reading the chip's state, either you get a valid indication or you get an I/O error. When changing its state, either the change is successful or an I/O error is returned. Signed-off-by: Scott Alfter <scott@alfter.us> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19drivers/w1/w1_int.c: Fix style errors.Thomas Wood
Replace spaces at beginning of the string with tabs, and replace foo * bar with foo *bar in a pointer declaration. Signed-off-by: Thomas Wood <tommyandrena@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: mxc_w1: Optimize mxc_w1_ds2_touch_bit()Alexander Shiyan
According to the i.MX reference manual, the read/write bit operations takes from 60 us to 120 us. This patch optimizes mxc_w1_ds2_touch_bit() function to use proper value for such delay. Nevertheless, a small margin for the timeout has been added for the case if clock frequency is inaccurate. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: mxc_w1: Perform a software reset at startupAlexander Shiyan
This patch adds a software reset for 1-Wire module at driver startup. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: mxc_w1: Optimize mxc_w1_ds2_reset_bus()Alexander Shiyan
According to the i.MX reference manual, the reset procedure and "presence" pulse takes 511 and 512 us, respectively. Measurement for i.MX27 is about 1100 us. There is no need to wait Reset+Presence more than this time. This patch optimizes mxc_w1_ds2_reset_bus() function to use proper value for delay after w1 bus reset. Nevertheless, a small margin for the timeout has been added for the case if clock frequency is inaccurate. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-19w1: mxc_w1: Fix incorrect "presence" statusAlexander Shiyan
W1 reset_bus() should return zero if slave device is present. This patch fix this issue. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-03Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull core locking updates from Ingo Molnar: "The main changes in this cycle were: - reduced/streamlined smp_mb__*() interface that allows more usecases and makes the existing ones less buggy, especially in rarer architectures - add rwsem implementation comments - bump up lockdep limits" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits) rwsem: Add comments to explain the meaning of the rwsem's count field lockdep: Increase static allocations arch: Mass conversion of smp_mb__*() arch,doc: Convert smp_mb__*() arch,xtensa: Convert smp_mb__*() arch,x86: Convert smp_mb__*() arch,tile: Convert smp_mb__*() arch,sparc: Convert smp_mb__*() arch,sh: Convert smp_mb__*() arch,score: Convert smp_mb__*() arch,s390: Convert smp_mb__*() arch,powerpc: Convert smp_mb__*() arch,parisc: Convert smp_mb__*() arch,openrisc: Convert smp_mb__*() arch,mn10300: Convert smp_mb__*() arch,mips: Convert smp_mb__*() arch,metag: Convert smp_mb__*() arch,m68k: Convert smp_mb__*() arch,m32r: Convert smp_mb__*() arch,ia64: Convert smp_mb__*() ...
2014-05-27w1: do not unlock unheld list_mutex in __w1_remove_master_device()Alexey Khoroshilov
w1_process_callbacks() expects to be called with dev->list_mutex held, but it is the fact only in w1_process(). __w1_remove_master_device() calls w1_process_callbacks() after it releases list_mutex. The patch fixes __w1_remove_master_device() to acquire list_mutex for w1_process_callbacks(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Acked-by: David Fries <david@fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: stable <stable@vger.kernel.org> # 3.15 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-27w1: optional bundling of netlink kernel repliesDavid Fries
Applications can submit a set of commands in one packet to the kernel, and in some cases it is required such as reading the temperature sensor results. This adds an option W1_CN_BUNDLE to the flags of cn_msg to request the kernel to reply in one packet for efficiency. The cn_msg flags now check for unknown flag values and return an error if one is seen. See "Proper handling of unknown flags in system calls" http://lwn.net/Articles/588444/ This corrects the ack values returned as per the protocol standard, namely the original ack for status messages and seq + 1 for all others such as the data returned from a read. Some of the common variable names have been standardized as follows. struct cn_msg *cn struct w1_netlink_msg *msg struct w1_netlink_cmd *cmd struct w1_master *dev When an argument and a function scope variable would collide, add req_ to the argument. Signed-off-by: David Fries <David@Fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-16w1: avoid recursive device_addDavid Fries
__w1_attach_slave_device calls device_add which calls w1_bus_notify which calls the w1_bq27000 slave driver, which calls platform_device_add and device_add and deadlocks on getting &(&priv->bus_notifier)->rwsem as it is still held in the previous device_add. This avoids the problem by processing the family add/remove outside of the slave device_add call. Commit 47eba33a0997fc7362a introduced this deadlock and added a KOBJ_ADD, as the add was already reported in device_register two add events were being sent. This change suppresses the device_register add so that any slave device sysfs entries are setup before the add goes out. Belisko Marek reported this change fixed the deadlock he was seeing on ARM device tree, while testing on my x86-64 system never saw the deadlock. Reported-by: Belisko Marek <marek.belisko@gmail.com> Signed-off-by: David Fries <David@Fries.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16w1: fix netlink refcnt leak on error pathDavid Fries
If the message type is W1_MASTER_CMD or W1_SLAVE_CMD, then a reference is taken when searching for the slave or master device. If there isn't any following data m->len (mlen is a copy) is 0 and packing up the message for later execution is skipped leaving nothing to decrement the reference counts. Way back when, m->len was checked before the search that increments the reference count, but W1_LIST_MASTERS has no additional data, the check was moved in 9be62e0b2fadaf5ff causing this bug. This change reorders to put the check before the reference count is incremented avoiding the problem. Signed-off-by: David Fries <David@Fries.net> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28w1: mxc_w1: Enable driver compilation with COMPILE_TESTAlexander Shiyan
This helps increasing build testing coverage. To do this, __raw_{read,write}b() functions was be replaced with simple {read,write}b() variants. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28w1: mxc_w1: Driver cleanupAlexander Shiyan
- Remove old and currently wrong address of the FSF from license parts of the code. - Remove unused #include and sort remaining headers alphabetically. - Remove unised definitions. - Add definitions for bit-fields. - Add missing module owner field. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28w1: mxc_w1: Fix mxc_w1_ds2_reset_bus() return valueAlexander Shiyan
This patch fix mxc_w1_ds2_reset_bus() return value. According to i.MX reference manual, "presence status" reflected in the bit 6 of control register. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-28w1: Remove excess dependencies on W1 for masters and slavesAlexander Shiyan
Configuration for masters and slaves is included only if W1 symbol enabled, so no reason to check it once more. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-15w1-gpio: handle of_get_gpio() returning -EPROBE_DEFER betterUwe Kleine-König
of_get_gpio() might return -EPROBE_DEFER meaning that the driver providing the gpio isn't ready yet. If that happens for the first gpio the resulting kernel output without this patch is: w1-gpio somename: Failed to parse DT platform somename: Driver w1-gpio requests probe deferral The first message is misleading and so is suppressed with this patch. Further if determining the gpio to switch the external pullup yields -EPROBE_DEFER this error should be passed back to the caller instead of just continuing without pullup. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-15w1: small type cleanup in sysfsDan Carpenter
On 64 bit systems, a large value for "long tmp" is truncated when assigning to "int md->max_slave_count" so we still end up with a value less than one despite the "tmp < 1" check. This is more of a problem for static checkers than a real life issue, but it's simple enough to fix. Acked-by: David Fries <david@fries.net> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-08Revert ds1wm.c from "w1: hold bus_mutex in netlink and search"David Fries
This reverts ds1wm.c from commit d3a8a9dbb903c73a7ec2deae4c9b7d74b6834f4c. Of the three files changed ds1wm.c ds2490.c and w1_netlink.c, it turns out ds1wm.c was locking bus_mutex, but inside the loop and I missed it. Reverting ds1wm.c to the previous version. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David Fries <David@Fries.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
