- Add compilation flag to treat warning as error
- Handle error of unused variable
- Handle error of uninitialised variable
bug 949219
Change-Id: I07437be5eaa7bf7abe5494c828690b6be3b98178
Signed-off-by: schowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/118039
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
add a driver for the hardware watchdog timer embedded in NVIDIA
Tegra SoCs
Change-Id: I45bc829f26f350143d5a07e1f4ddc46d24f3a54c
Signed-off-by: Gary King <gking@nvidia.com>
The WatchDog Timer Driver Core is a framework
that contains the common code for all watchdog-driver's.
It also introduces a watchdog device structure and the
operations that go with it.
This is the introduction of this framework. This part
supports the minimal watchdog userspace API (or with
other words: the functionality to use /dev/watchdog's
open, release and write functionality as defined in
the simplest watchdog API). Extra functionality will
follow in the next set of patches.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Watchdog timer device driver for Xilinx xps_timebase_wdt compatible ip cores.
It takes watchdog timer configuration from device tree and it needs that its
parent has defined the property "clock-frecuency".
It is compatible with watchdog timer kernel API, so user apps like watchdogd
may talk with it.
Signed-off-by: Alejandro Cabrera <aldaya@gmail.com>
The Synopsys DesignWare watchdog is found in several ARM based systems
and provides a choice of 16 timeout periods depending on the clock
input. The watchdog cannot be disabled once started.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
This patch adds the driver for the watchdog found inside the Lantiq SoC family.
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: linux-mips@linux-mips.org
Cc: linux-watchdog@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/2327/
While the hypervisor change adding SCHEDOP_watchdog support included a
daemon to make use of the new functionality, having a kernel driver
for /dev/watchdog so that user space code doesn't need to distinguish
non-Xen and Xen seems to be preferable.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
This submission includes:
- Fix to intel_scu_write() to start watchdog timer the on the
first write, and refresh on subsequent writes.
This enables Open, write, write, ... usage model.
- Moves boot parameter checks from intel_scu_open() to
intel_scu_watchdog_init(), so driver init will fail if these
parameters are out of bounds.
- Adds check for whether process waiting in wait_event_interruptible()
received a signal while it was waiting.
- Other small error handling changes.
Removed the read() method for now as that wass a non-standard behaviour.
Signed-off-by: Donald Johnson <donald.k.johnson@intel.com>
Signed-off-by: Shuduo Sang <shuduo.sang@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Adds support for the hardware watchdog found in Ingenic's jz4740
System-on-Chip.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
All m548x files were renamed to m54xx, except m548x_wdt.c. Fix that.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Add watchdog driver for MCF548x.
This patch adds a driver for the built-in hardware watchdog device
of the Atheros AR71XX/AR724X/AR913X SoCs.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
This driver adds support for /dev/watchdog for boards using either the MCP51 or
MCP55 chipsets. These are also known as the nForce 430 and nForce 550. This
driver is likely to work on other chipsets as well, though those are the only
two that have been tested.
Signed-off-by: Mike Waychison <mikew@google.com>
This driver adds /dev/watchdog support for the AMD sp5100 aka SB7x0 chipsets.
It follows the same conventions found in other /dev/watchdog drivers.
Signed-off-by: Priyanka Gupta <priyankag@google.com>
This patch adds support for the Broadcom BCM63xx SoC built-in watchdog, it
uses one of the BCM63xx hardware timer id.
Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Technical Reference Manual can be found at:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0270b/DDI0270.pdf
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Add a new watchdog driver for the Fintek F71808E and F71882FG Super I/O
controllers.
Signed-off-by: Giel van Schijndel <me@mortis.eu>
The OCTEON is a MIPS64 based SOC family with an on chip watchdog unit.
The driver is split into two source files one for the C code and one
for assembly. Assembly is needed to handle the NMI and then print the
machine state before the reboot is triggered.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Marc Zyngier <maz@misterjones.org>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
To: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org,
Patchwork: https://patchwork.linux-mips.org/patch/1503/
create mode 100644 drivers/watchdog/octeon-wdt-main.c
create mode 100644 drivers/watchdog/octeon-wdt-nmi.S
processors.
This is the driver for the hardware watchdog on the Freescale IMX2 and later processors.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Juergen Beisert <jbe@pengutronix.de>
This driver adds support for the max63{69,70,71,72,73,74} family of
watchdog timer chips.
It has been tested on an Arcom Zeus (max6369).
Signed-off-by: Marc Zyngier <maz@misterjones.org>
Technologic Systems TS-72xx SBCs have external glue logic
CPLD which includes watchdog timer. This driver implements
kernel support for that.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
The platform has never been fully merged
Cc: Thomas Koeller <thomas.koeller@baslerweb.com>
Cc: linux-mtd@lists.infradead.org
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Remove the old WDT implementation.
Signed-off-by: Albrecht Dreß <albrecht.dress@arcor.de>
This patch adds support for the watchdog timer on Avionic Design Xanthos
boards.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
The WM831x series of devices provide a watchdog with configurable
behaviour on timer expiry.
Currently this driver support refreshes via a register or GPIO line and
autonomous refreshes from a hardware source (eg, a clock).
Add watchdog device driver for the Nuvoton NUC900 series SoCs.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Add support for watchdog found on SBC-FITPC2 board.
Signed-off-by: Denis Turischev <denis@compulab.co.il>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This add watchdog driver for broadcom 47xx device.
It uses the ssb subsytem to access embeded watchdog device.
Because the watchdog timeout is very short (about 2s), a soft timer is used
to increase the watchdog period.
Note : A patch for exporting the ssb_watchdog_timer_set will
be submitted on next linux-mips merge. Without this patch it can't
be build as a module.
Signed-off-by: Aleksandar Radovanovic <biblbroks@sezampro.rs>
Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr>
Tested-by: Florian Fainelli <florian@openwrt.org>
Add watchdog timer support for Freescale STMP3xxx boards
Signed-off-by: Vitaly Wool <vital@embeddedalley.com>
Signed-off-by: Dmitry Pervushin <dpervushin@embeddedalley.com>
Implementation of twl4030 watchdog driver.
Signed-off-by: Timo Kokkonen <timo.t.kokkonen@nokia.com>
Signed-off-by: Atal Shargorodsky <ext-atal.shargorodsky@nokia.com>
This patch adds support for the U300 COH 901 327 watchdog for the
U300 platform recently added to RMK:s ARM tree.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Add support for PNX833x watchdog timer.
Signed-off-by: Daniel Laird <daniel.j.laird@nxp.com>
The Orion watchdog driver is also used on Kirkwood.
Convention is to use orion5x for stuff specific to 88F5xxx Orion chips
and simply "orion" for shared stuff across SoCs including Kirkwood.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Removes ARM26 sections from Kconfig and Makefile, because
ARM26 is long gone.
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
The FPGA based watchdog timer used by the Pika Warp appliance.
Signed-off-by: Sean MacLennan <smaclennan@pikatech.com>
GE Fanuc SBC610
Support for the FPGA based watchdog timer as found on GE Fanuc's SBC310,
SBC610 and PPC9A Single Board Computers.
This patch adds support for the watchdog timer found in one of the devices
FPGAs. There are two identical watchdog timers at different offsets in the
above mentioned boards, this driver is capable of supporting one of them.
The watchdog timers are also capable of generating interrupts at a
user-configurable threshold, though support for this operation is currently
not supported by the driver.
Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com>
This driver implements support for the watchdog functionality provided
by the Wolfson Microelectronics WM8350, a multi-function audio and
power management subsystem intended for use in embedded systems. It is
based on a driver originally written by Graeme Gregory, though it has
been extensively modified since then.
Use of a GPIO to kick the watchdog is not yet supported.
Add a watchdog driver for the hardware watchdog timer on the
SMSC SCH3112, SCH3114 and SCH3116 Super IO chipset.
Tested-by: Marco Chiappero <marco@absence.it>
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[WATCHDOG] orion5x_wdt.c: add spinlocking
[WATCHDOG] Orion: add hardware watchdog support
[WATCHDOG] omap_wdt.c: cleanup a bit omap_wdt.c
[WATCHDOG] omap_wdt.c: another ioremap() fix
[WATCHDOG] omap_wdt.c: sync linux-omap changes
[WATCHDOG] Add AT91SAM9X watchdog
[WATCHDOG] Add driver for winbond w83697ug/uf watchdog feature
[WATCHDOG] add watchdog driver IT8716 IT8726 IT8712J/K
This patch allows the use of the hardware watchdog in the
Marvell Orion series of ARM SoCs.
Signed-off-by: Sylver Bruneau <sylver.bruneau@googlemail.com>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Add a driver for the watchdog timer embedded into AT91SAM9X chips.
Signed-off-by: Renaud Cerrato <r.cerrato@til-technologies.fr>
Adapted the w83627hf_wdt.c driver to work with the w83697ug/uf chip,
found on MSI Fuzzy CX700 boards.
The method used is taken directly from the winbond datasheet and
surprisingly it differs slightly from all the other winbond watchdogs.
So far it has only been tested on the CX700 board that I have, but it
seems to work nicely.
Signed-off-by: Flemming Frandsen <ff@nrvissing.net>
Add it87xx watchdog driver
IT8716 IT8718 IT8726 IT8712-J IT8712-K
Signed-off-by: Oliver Schuster <olivers137@aol.com>
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6
arch/sparc64/kernel/pci_psycho.c
The config stuff was already in drivers/watchdog/Kconfig
Add driver for the IDT RC32434 SoC built-in watchdog.
Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu>
This patch adds support for the built-in RDC R-321x SoC watchdog.
