Added driver to support the 14F021P00 BMC Watchdog.
The BMC is a Board Management Controller including watchdog functionality.
Signed-off-by: Andreas Werner <andreas.werner@men.de>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 patches from Martin Schwidefsky:
"A couple of bug fixes, a debug change for qdio, an update for the
default config, and one small extension.
The watchdog module based on diagnose 0x288 is converted to the
watchdog API and it now works under LPAR as well"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/ccwgroup: use ccwgroup_ungroup wrapper
s390/ccwgroup: fix an uninitialized return code
s390/ccwgroup: obtain extra reference for asynchronous processing
qdio: Keep device-specific dbf entries
s390/compat: correct ucontext layout for high gprs
s390/cio: set device name as early as possible
s390: update default configuration
s390: avoid format strings leaking into names
s390/airq: silence lockdep warning
s390/watchdog: add support for LPAR operation (diag288)
s390/watchdog: use watchdog API
s390/sclp_vt220: Enable ASCII console per default
s390/qdio: replace shift loop by ilog2
s390/cio: silence lockdep warning
s390/uaccess: always load the kernel ASCE after task switch
s390/ap_bus: Make modules parameters visible in sysfs
Add initial Intel MID watchdog driver support.
This driver is an initial implementation of generic Intel MID watchdog
driver. Currently it supports Intel Merrifield platform.
Signed-off-by: Eric Ernst <eric.ernst@intel.com>
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Since both chips are now supported by the w83627hf watchdog driver,
the chip specific drivers are no longer needed and can be removed.
Converted the vmwatchdog driver to use the kernel's watchdog API.
Signed-off-by: Philipp Hachtmann <phacht@de.ibm.com>
Add a driver for the hardware watchdogs in NVIDIA Tegra SoCs (Tegra30 and
later). This driver will configure one watchdog timer that will reset the
system in the case of a watchdog timeout.
This driver binds to the nvidia,tegra30-timer device node and gets its
register base from there.
Signed-off-by: Andrew Chew <achew@nvidia.com>
This patch adds a watchdog driver for devices controlled through GPIO,
(Analog Devices ADM706, Maxim MAX823, National NE555 etc).
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
This commit adds support for the watchdog timer used on the BCM281xx
family of SoCs.
Signed-off-by: Markus Mayer <markus.mayer@linaro.org>
Reviewed-by: Matt Porter <matt.porter@linaro.org>
On CSR SiRFprimaII and SiRFatlasVI, the 6th timer can act as a watchdog
timer when the Watchdog mode is enabled.
watchdog occur when TIMER watchdog counter matches the value software
pre-set, when this event occurs, the effect is the same as the system
software reset.
Signed-off-by: Xianglong Du <Xianglong.Du@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Cc: Romain Izard <romain.izard.pro@gmail.com>
Add a driver for the watchdog timer found on Ralink SoC
Signed-off-by: John Crispin <blogic@openwrt.org>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: linux-watchdog@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: devicetree-discuss@lists.ozlabs.org
This patch adds a watchdog driver for the main hardware watchdog timer
found on MOXA ART SoCs.
The MOXA ART SoC provides one writable timer register, restarting
the hardware once it reaches zero. The register is auto decremented
every APB clock cycle.
Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com>
Architecture is gone.
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
This patch adds the driver for the watchdog found in the Allwinner A10 and
A13 SoCs. It has DT-support and uses the new watchdog framework.
Signed-off-by: Carlo Caione <carlo.caione@gmail.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This patch adds the driver for the watchdog devices found on MEN Mikro
Elektronik A21 VMEbus CPU Carrier Boards. It has DT-support and uses the
watchdog framework.
Signed-off-by: Johannes Thumshirn <johannes.thumshirn@men.de>
This adds a driver for watchdog timer hardware present on Broadcom BCM2835 SoC,
used in Raspberry Pi and Roku 2 devices.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: linux-rpi-kernel@lists.infradead.org
Interrupt request doesn't use the right API: The TWD watchdog uses a per-cpu
interrupt (usually interrupt #30), and the GIC configuration should flag it as
such. With this setup, request_irq() should fail, and the right API is
request_percpu_irq(), together with enable_percpu_irq()/disable_percpu_irq().
Nothing ensures the userspace ioctl() will end-up kicking the watchdog on the
right CPU.
There are no users of this driver since a long time and it makes more sense to
get rid of it as nobody is looking to fix it.
In case somebody wakes up after this has been removed and needs it, please
revert this driver and pick these updates (These were never pushed to mainline):
http://comments.gmane.org/gmane.linux.ports.arm.kernel/245998
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Add watchdog timer support for the on-board PLD found on some Kontron
embedded modules.
Originally-From: Michael Brunner <michael.brunner@kontron.com>
Signed-off-by: Kevin Strasser <kevin.strasser@linux.intel.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
Now that the new driver is in place, we can remove the old one.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Replace the existing STMP3xxx driver because it has enough drawbacks
that a rewrite is apropriate. The new driver is designed to use the
watchdog framework which makes it a lot smaller and avoids open coding
the watchdog API again. It also uses now an explicitly exported function
from the RTC driver to set up its registers (the old driver silently
reused the hopefully(!) already remapped RTC registers). Also, this
driver is mach independent, while the old one depends on a mach replaced
by another one a year ago. Since the user interface is still the
standard watchdog API, users don't need to adapt.
Introduce Retu watchdog driver.
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
This patch adds support for the ux500_wdt watchdog that is found in
ST-Ericsson Ux500 platform. The driver is based on PRCMU APIs.
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
This is the Watchdog patch for the DA9055 PMIC. This patch has got dependency on
the DA9055 MFD core.
This patch is functionally tested on SMDK6410
Signed-off-by: David Dajun Chen <dchen@diasemi.com>
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
This driver adds support for the watchdog functionality provided by
the Dialog Semiconductor DA9052 PMIC chip.
Tested on samsung smdkv6410 and i.mx53 QS boards.
Signed-off-by: Anthony Olech <Anthony.Olech@diasemi.com>
Add driver for the watchdog timer built into the
Intel Atom E6XX (TunnelCreek) processor.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
The platform is removed, so there are no users of this driver.
New driver for the hardware watchdog timer on VIA chipsets.
This driver uses the new watchdog framework.
PnP must be enabled in BIOS to get full control of watchdog registers.
The timer code has been added by Wim Van Sebroeck.
Tested on a Artigo A1100, VX855 chipset.
Signed-off-by: Marc Vertes <marc.vertes@sigfox.com>
Remove the driver (that was added in v2.6.32) since the architecture
has never been merged into mainline.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Acked-by: Thierry Reding <thierry.reding@avionic-design.de>
The WatchDog Timer Driver Core is a framework
that contains the common code for all watchdog-driver's.
It also introduces a watchdog device structure and the
operations that go with it.
This is the introduction of this framework. This part
supports the minimal watchdog userspace API (or with
other words: the functionality to use /dev/watchdog's
open, release and write functionality as defined in
the simplest watchdog API). Extra functionality will
follow in the next set of patches.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Watchdog timer device driver for Xilinx xps_timebase_wdt compatible ip cores.
It takes watchdog timer configuration from device tree and it needs that its
parent has defined the property "clock-frecuency".
It is compatible with watchdog timer kernel API, so user apps like watchdogd
may talk with it.
Signed-off-by: Alejandro Cabrera <aldaya@gmail.com>
The Synopsys DesignWare watchdog is found in several ARM based systems
and provides a choice of 16 timeout periods depending on the clock
input. The watchdog cannot be disabled once started.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
This patch adds the driver for the watchdog found inside the Lantiq SoC family.
Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com>
Cc: Wim Van Sebroeck <wim@iguana.be>
Patchwork: https://patchwork.linux-mips.org/patch/2327/
While the hypervisor change adding SCHEDOP_watchdog support included a
daemon to make use of the new functionality, having a kernel driver
for /dev/watchdog so that user space code doesn't need to distinguish
non-Xen and Xen seems to be preferable.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
This submission includes:
- Fix to intel_scu_write() to start watchdog timer the on the
first write, and refresh on subsequent writes.
This enables Open, write, write, ... usage model.
- Moves boot parameter checks from intel_scu_open() to
intel_scu_watchdog_init(), so driver init will fail if these
parameters are out of bounds.
- Adds check for whether process waiting in wait_event_interruptible()
received a signal while it was waiting.
- Other small error handling changes.
Removed the read() method for now as that wass a non-standard behaviour.
Signed-off-by: Donald Johnson <donald.k.johnson@intel.com>
Signed-off-by: Shuduo Sang <shuduo.sang@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Adds support for the hardware watchdog found in Ingenic's jz4740
System-on-Chip.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
All m548x files were renamed to m54xx, except m548x_wdt.c. Fix that.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
Add watchdog driver for MCF548x.
This patch adds a driver for the built-in hardware watchdog device
of the Atheros AR71XX/AR724X/AR913X SoCs.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
This driver adds support for /dev/watchdog for boards using either the MCP51 or
MCP55 chipsets. These are also known as the nForce 430 and nForce 550. This
driver is likely to work on other chipsets as well, though those are the only
two that have been tested.
Signed-off-by: Mike Waychison <mikew@google.com>
This driver adds /dev/watchdog support for the AMD sp5100 aka SB7x0 chipsets.
It follows the same conventions found in other /dev/watchdog drivers.
Signed-off-by: Priyanka Gupta <priyankag@google.com>
This patch adds support for the Broadcom BCM63xx SoC built-in watchdog, it
uses one of the BCM63xx hardware timer id.
Signed-off-by: Miguel Gaio <miguel.gaio@efixo.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Technical Reference Manual can be found at:
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0270b/DDI0270.pdf
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Add a new watchdog driver for the Fintek F71808E and F71882FG Super I/O
controllers.
Signed-off-by: Giel van Schijndel <me@mortis.eu>
The OCTEON is a MIPS64 based SOC family with an on chip watchdog unit.
The driver is split into two source files one for the C code and one
for assembly. Assembly is needed to handle the NMI and then print the
machine state before the reboot is triggered.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Marc Zyngier <maz@misterjones.org>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
To: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org,
Patchwork: https://patchwork.linux-mips.org/patch/1503/
create mode 100644 drivers/watchdog/octeon-wdt-main.c
create mode 100644 drivers/watchdog/octeon-wdt-nmi.S
processors.
This is the driver for the hardware watchdog on the Freescale IMX2 and later processors.
Cc: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Tested-by: Juergen Beisert <jbe@pengutronix.de>
This driver adds support for the max63{69,70,71,72,73,74} family of
watchdog timer chips.
It has been tested on an Arcom Zeus (max6369).
Signed-off-by: Marc Zyngier <maz@misterjones.org>
Technologic Systems TS-72xx SBCs have external glue logic
CPLD which includes watchdog timer. This driver implements
kernel support for that.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
The platform has never been fully merged
Cc: Thomas Koeller <thomas.koeller@baslerweb.com>
Cc: linux-mtd@lists.infradead.org
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Remove the old WDT implementation.
Signed-off-by: Albrecht Dreß <albrecht.dress@arcor.de>
This patch adds support for the watchdog timer on Avionic Design Xanthos
boards.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
