path: root/drivers/watchdog/bfin_wdt.c
2012-11-28watchdog: remove use of __devexitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-28watchdog: remove use of __devexit_pBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-15watchdog: cleanup spaces before tabsWim Van Sebroeck
cleanup spaces before tabs in drivers/watchdog/ Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-05-25watchdog: bfin: use new common Blackfin watchdog headerMike Frysinger
use new common Blackfin watchdog header Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] change reboot_notifier to platform-shutdown method.Wim Van Sebroeck
Platform device drivers can use the .shutdown method to handle soft shutdown's instead of reboot_notifier's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-02-21[WATCHDOG] bfin: fix max timeout calculationMike Frysinger
Relying on overflow/wrap around isn't exact because if you wrap far enough, you get back to "valid" values. Reported-by: Thorsten Pohlmann <pohlmann@tetronik.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: stable <stable@kernel.org>
2009-06-18[WATCHDOG] Some more general cleanupWim Van Sebroeck
Clean-up the watchdog drivers so that checkpatch.pl get's happy... Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Clean-up includesWim Van Sebroeck
Use #include <linux/io.h> instead of <asm/io.h> Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Clean-up includes. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-06-07[WATCHDOG 19/57] bfin: watchdog cleanup and unlocked_ioctlAlan Cox
Scan, tidy and check for unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Blackfin Watchdog Driver: split platform device/driverMike Frysinger
- split platform device/driver registering from actual watchdog device/driver registering so that we can cleanly load/unload - fixup __initdata with __initconst and __devinitdata with __devinitconst Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-02-18[WATCHDOG] blackfin Watchdog driver: relocate all strings used in __init ↵Mike Frysinger
functions to __initdata Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-01-25[WATCHDOG] constify function pointer tablesJan Engelhardt
"static struct file_operations" should be "static const struct file_operations". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-11-19[WATCHDOG] bfin_wdt, remove SPIN_LOCK_UNLOCKEDJiri Slaby
bfin_wdt, remove SPIN_LOCK_UNLOCKED SPIN_LOCK_UNLOCKED is deprecated, use DEFINE_SPINLOCK instead Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
