path: root/drivers/watchdog/booke_wdt.c
2013-03-01watchdog: Convert BookE watchdog driver to watchdog infrastructureGuenter Roeck
Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-11-19Fix misspellings of "whether" in comments.Adam Buchbinder
"Whether" is misspelled in various comments across the tree; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-08-17booke/wdt: some ioctls do not return values properlyTiejun Chen
Fix some booke wdt ioctls return value error. Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-07-10powerpc/watchdog: replace CONFIG_FSL_BOOKE with CONFIG_PPC_FSL_BOOK3EShaohui Xie
CONFIG_FSL_BOOKE is only defined in 32-bit, CONFIG_PPC_FSL_BOOK3E is defined in both 32-bit and 64-bit, so use CONFIG_PPC_FSL_BOOK3E to make driver work in 32-bit & 64-bit. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-02-29watchdog: fix GETTIMEOUT ioctl in booke_wdtDmitry Artamonow
Commit dcfb748422 ([WATCHDOG] fix book E watchdog to take WDIOC_SETTIMEOUT arg in seconds) fixed SETTIMEOUT ioctl to use seconds as a parameter instead of some hardware-specific "period", but missed to apply similar changes to GETTIMEOUT, so it still returns "period" value. Let's fix it! Also, while at it, make SETTIMEOUT ioctl return real timeout value as it should do according to the documentation. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-03-15watchdog: booke_wdt: clean up status messagesTimur Tabi
Improve the status messages that are displayed during some operations of the PowerPC watchdog timer driver. When the watchdog is enabled, the timeout is displayed as a number of seconds, instead of an obscure "period". The "period" is the position of a bit in a 64-bit timer register. The higher the value, the quicker the watchdog timeout occurs. Some people chose a high "period" value for the timer and get confused as to why the board resets within a few seconds. Messages displayed during open and close are now debug messages, so that they don't clutter the console by default. Finally, printk() is replaced with the pr_xxx() equivalent. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-01-12watchdog: Propagate Book E WDT period changes to all coresRandy Vinson
When the watchdog period is changed, it needs to be propagated to all cores in addition to the core that performed the change. Signed-off-by: Randy Vinson <rvinson@mvista.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2011-01-12watchdog: add CONFIG_WATCHDOG_NOWAYOUT support to PowerPC Book-E watchdog driverTimur Tabi
Normally, the watchdog is disabled when dev/watchdog is closed, but if CONFIG_WATCHDOG_NOWAYOUT is defined, then it means that the watchdog should remain enabled. So we should disable it only if CONFIG_WATCHDOG_NOWAYOUT is not defined. Also ensure that /dev/watchdog is only opened by one process at a time. That way, a second process can't accidentally disable the watchdog while the first process has it open. There shouldn't be any need for more than one process to open /dev/watchdog anyway. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-10-14powerpc/watchdog: Make default timeout for Book-E watchdog a Kconfig optionTimur Tabi
The PowerPC Book-E watchdog driver (booke_wdt.c) defines a default timeout value in the code based on whether it's a Freescale Book-E part of not. Instead of having hard-coded values in the driver, make it a Kconfig option. As newer chips gets faster, the current default values become less appropriate, since the timeout sometimes occurs before the kernel finishes booting. Making the value a Kconfig option allows BSPs to configure a new value without requiring the wdt_period command-line parameter to be set. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-14powerpc/watchdog: Allow the Book-E driver to be compiled as a moduleTimur Tabi
Register the __init and __exit functions in the PowerPC Book-E Watchdog driver as module entry/exit functions, and modify the Kconfig entry. Add a .release method for the PowerPC Book-E Watchdog driver, so that the watchdog is disabled when the driver is closed. Loosely based on original code from Jiang Yutang <b14898@freescale.com>. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-05-25watchdog: booke_wdt: fix ioctl status flagsWim Van Sebroeck
The WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS ioctl calls return the WDIOF_* flags and nothing else. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-04-27watchdog: booke_wdt: fix build - unconstify watchdog_infoAnton Vorontsov
commit 42747d712de56cf2087b702d2ad90af114c53138 ("[WATCHDOG] watchdog_info constify") introduced the following build failure: CC booke_wdt.o booke_wdt.c: In function 'booke_wdt_init': booke_wdt.c:220: error: assignment of read-only variable 'ident' Fix this by removing 'const' qualifier from watchdog_info struct. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2010-04-16[WATCHDOG] fixed book E watchdog period register mask.Luuk Paulussen
A previous fix changed the WDTP function to use the period directly, rather than subtracting from 63. However the mask generation was not changed, so the mask was coming out as 0. This patch fixes it. Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-09-18[WATCHDOG] fix book E watchdog to take WDIOC_SETTIMEOUT arg in secondsChris Friesen
The WDIOC_SETTIMEOUT argument is supposed to be a "seconds" value. However, the book E wdt currently treats it as a "period" which is interpreted in a board-specific way. This patch allows the user to pass in a "seconds" value and the driver will set the smallest timeout that is at least as large as specified by the user. It's been tested on e500 hardware and works as expected. The patch only modifies the CONFIG_FSL_BOOKE case, the CONFIG_4xx case is left unmodified as I don't have any hardware to test it on. Signed-off-by: Chris Friesen <cfriesen@nortel.com> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-11-08powerpc: Fix Book-E watchdog timer interval settingMatthias Fuchs
This patch fixes the setting of the Book-E watchdog timer interval setup on initialization and by ioctl(). On initialization the period bits have to be masked before setting a new period. In WDIOC_SETTIMEOUT ioctl we have to use the correct mask. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Acked-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Merge code clean-up's from Alan Cox.Wim Van Sebroeck
Merge branch 'alan' of ../linux-2.6-watchdog-mm Fixed Conflicts in the following files: drivers/watchdog/booke_wdt.c drivers/watchdog/mpc5200_wdt.c drivers/watchdog/sc1200wdt.c Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-07-15generic-ipi: more merge falloutIngo Molnar
fix more API change fallout in recently merged upstream changes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-13[WATCHDOG 20/57] booke watchdog: clean up and unlocked_ioctlAlan Cox
Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Fix booke_wdt.c on MPC85xx SMP system'sChen Gong
On Book-E SMP systems each core has its own private watchdog. If only one watchdog is enabled, when the core that doesn't enable the watchdog is hung, system can't reset because no watchdog is running on it. That's bad. It means we must enable watchdogs on both cores. We can use smp_call_function() to send appropriate messages to all the other cores to enable and update the watchdog. Signed-off-by: Chen Gong <g.chen@freescale.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
