path: root/drivers/watchdog/geodewdt.c
2012-03-27watchdog: nowayout is boolWim Van Sebroeck
nowayout is actually a boolean value. So make it bool for all watchdog device drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-12-18watchdog: update geodewdt for new MFGPT APIAndres Salomon
Update to the new cs5535_mfgpt* API. The geode-specific wording should eventually be dropped from this driver... Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-09-23[WATCHDOG] unlocked_ioctl changesWim Van Sebroeck
Fix some drivers so that they use the unlocked_ioctl call. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] more coding style clean-up'sWim Van Sebroeck
More coding style clean-up's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 1Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1: The preferred way to ease multiple indentation levels in a switch statement is to align the "switch" and its subordinate "case" labels in the same column instead of "double-indenting" the "case" labels. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Clean-up includesWim Van Sebroeck
Use #include <linux/io.h> instead of <asm/io.h> Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Clean-up includes. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-30drivers/watchdog/geodewdt.c: build fixIngo Molnar
* Wim Van Sebroeck <wim@iguana.be> wrote: > Author: Jordan Crouse <jordan.crouse@amd.com> > Date: Mon Jan 21 10:07:00 2008 -0700 > > [WATCHDOG] Add a watchdog driver based on the CS5535/CS5536 MFGPT timers -tip testing found the following build failure on latest -git: drivers/watchdog/geodewdt.c: In function 'geodewdt_probe': drivers/watchdog/geodewdt.c:225: error: too many arguments to function 'geode_mfgpt_alloc_timer' make[1]: *** [drivers/watchdog/geodewdt.o] Error 1 make: *** [drivers/watchdog/geodewdt.o] Error 2 with this config: http://redhat.com/~mingo/misc/config-Fri_May_30_15_19_52_CEST_2008.bad find the fix below. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-25[WATCHDOG] Add a watchdog driver based on the CS5535/CS5536 MFGPT timersJordan Crouse
Add a watchdog timer based on the MFGPT timers in the CS5535/CS5536 companion chips to the AMD Geode GX and LX processors. Only caveat is that the BIOS must provide at least a one free timer, and most do not. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
