path: root/drivers/watchdog/intel_scu_watchdog.c
2011-03-15watchdog: Intel SCU Watchdog Timer Driver for Moorestown and Medfield platforms.Donald Johnson
This submission includes: - Fix to intel_scu_write() to start watchdog timer the on the first write, and refresh on subsequent writes. This enables Open, write, write, ... usage model. - Moves boot parameter checks from intel_scu_open() to intel_scu_watchdog_init(), so driver init will fail if these parameters are out of bounds. - Adds check for whether process waiting in wait_event_interruptible() received a signal while it was waiting. - Other small error handling changes. Removed the read() method for now as that wass a non-standard behaviour. Signed-off-by: Donald Johnson <donald.k.johnson@intel.com> Signed-off-by: Shuduo Sang <shuduo.sang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
