path: root/drivers/watchdog/pcwd_usb.c
2010-05-20USB: rename usb_buffer_alloc() and usb_buffer_free() usersDaniel Mack
For more clearance what the functions actually do, usb_buffer_alloc() is renamed to usb_alloc_coherent() usb_buffer_free() is renamed to usb_free_coherent() They should only be used in code which really needs DMA coherency. All call sites have been changed accordingly, except for staging drivers. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Pedro Ribeiro <pedrib@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-25[PATCH 13/13] drivers/watchdog: use USB API functions rather than constantsJulia Lawall
This set of patches introduces calls to the following set of functions: usb_endpoint_dir_in(epd) usb_endpoint_dir_out(epd) usb_endpoint_is_bulk_in(epd) usb_endpoint_is_bulk_out(epd) usb_endpoint_is_int_in(epd) usb_endpoint_is_int_out(epd) usb_endpoint_num(epd) usb_endpoint_type(epd) usb_endpoint_xfer_bulk(epd) usb_endpoint_xfer_control(epd) usb_endpoint_xfer_int(epd) usb_endpoint_xfer_isoc(epd) In some cases, introducing one of these functions is not possible, and it just replaces an explicit integer value by one of the following constants: USB_ENDPOINT_XFER_BULK USB_ENDPOINT_XFER_CONTROL USB_ENDPOINT_XFER_INT USB_ENDPOINT_XFER_ISOC An extract of the semantic patch that makes these changes is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r1@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) == - \(USB_ENDPOINT_XFER_CONTROL\|0\)) + usb_endpoint_xfer_control(epd) @r5@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) == - \(USB_DIR_IN\|0x80\)) + usb_endpoint_dir_in(epd) @inc@ @@ #include <linux/usb.h> @depends on !inc && (r1||r5)@ @@ + #include <linux/usb.h> #include <linux/usb/...> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] more coding style clean-up'sWim Van Sebroeck
More coding style clean-up's. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] Coding style - Indentation - part 1Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1: The preferred way to ease multiple indentation levels in a switch statement is to align the "switch" and its subordinate "case" labels in the same column instead of "double-indenting" the "case" labels. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-06[WATCHDOG] pcwd: a couple of watchdogs escaped conversionAlan Cox
Fix them up. Once we know the long term plan the watchdogs can all get shrunk massively anyway Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-08-06[WATCHDOG] Clean-up includesWim Van Sebroeck
Use #include <linux/io.h> instead of <asm/io.h> Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Clean-up includes. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-03-06[WATCHDOG] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
