path: root/drivers/watchdog/pnx833x_wdt.c
2010-05-25watchdog: fix several MODULE_PARM_DESC stringsRandy Dunlap
Fix MODULE_PARM_DESC() strings in several watchdog drivers. Some are simple as add a parenthesis. Others are problems from __stringify() being used on a variable name instead of a macro name, so the variable name is produced in the string instead of its build-time value. In these cases, create a macro for the value so that the module param description string is useful. Only pc87413_wdt has been built (due to toolchains). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-07[WATCHDOG] watchdog_info constifyWim Van Sebroeck
make the watchdog_info struct const where possible. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-06-20[WATCHDOG] Add pnx833x_wdtDaniel Laird
Add support for PNX833x watchdog timer. Signed-off-by: Daniel Laird <daniel.j.laird@nxp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
