path: root/drivers/watchdog/sa1100_wdt.c
2009-07-09[WATCHDOG] SA1100 watchdog maximum timeoutRaphael Assenat
This patch replaces the hardcoded 255 seconds limit for a real limit based on oscr_freq. Also, the 'firmware_version' field is changed to '1' to allow the user space application to easily detect that this driver supports a higher maximum timeout. Signed-off-by: Raphael Assenat <raph@8D.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-09[ARM] pxa: separate definitions from pxa-regs.h and remove it finallyEric Miao
The remaining registers are separated into: - <mach/regs-ost.h> - <mach/regs-rtc.h> - <mach/regs-intc.h> and then we can remove pxa-regs.h completely. Instead of #include this file, let's: 1. include the specific <mach/regs-*.h> with care (if that's absolutely necessary) 2. define the registers in the driver, make cleanly defined API to expose the register access to external with sufficient reason Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-29Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
2008-12-29[ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constantEric Miao
See description of commit: [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant for additional information. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-11-29[ARM] Remove linux/sched.h from asm/cacheflush.h and asm/uaccess.hRussell King
... and fix those drivers that were incorrectly relying upon that include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-08Merge Linus' latest into masterRussell King
Conflicts: drivers/watchdog/at91rm9200_wdt.c drivers/watchdog/davinci_wdt.c drivers/watchdog/ep93xx_wdt.c drivers/watchdog/ixp2000_wdt.c drivers/watchdog/ixp4xx_wdt.c drivers/watchdog/ks8695_wdt.c drivers/watchdog/omap_wdt.c drivers/watchdog/pnx4008_wdt.c drivers/watchdog/sa1100_wdt.c drivers/watchdog/wdt285.c
2008-08-07Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 Conflicts: arch/arm/mach-pxa/generic.c arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c arch/arm/mach-pxa/pxa2xx.c arch/arm/mach-pxa/pxa3xx.c arch/arm/mach-pxa/reset.c arch/arm/mach-pxa/spitz.c arch/arm/mach-pxa/tosa.c drivers/watchdog/sa1100_wdt.c
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-05[ARM] sa1100_wdt: use reset_status to remember watchdog reset statusEric Miao
2008-06-21[WATCHDOG 36/57] sa1100_wdt: Switch to unlocked_ioctlAlan Cox
Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
