path: root/drivers/watchdog/sa1100_wdt.c
2012-07-09ARM: sa11x0/pxa: convert OS timer registers to IOMEMRussell King
Make the OS timer registers have IOMEM like properities so they can be passed to readl_relaxed/writel_relaxed() et.al. rather than being straight volatile dereferences. Add linux/io.h includes where required. linux/io.h includes added to arch/arm/mach-sa1100/cpu-sa1100.c, arch/arm/mach-sa1100/jornada720_ssp.c, arch/arm/mach-sa1100/leds-lart.c drivers/input/touchscreen/jornada720_ts.c, drivers/pcmcia/sa1100_shannon.c from Arnd. This fixes these warnings: arch/arm/mach-sa1100/time.c: In function 'sa1100_timer_init': arch/arm/mach-sa1100/time.c:104: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type arch/arm/mach-pxa/time.c: In function 'pxa_timer_init': arch/arm/mach-pxa/time.c:126: warning: passing argument 1 of 'clocksource_mmio_init' discards qualifiers from pointer target type Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-27watchdog: Use pr_<fmt> and pr_<level>Joe Perches
Use the current logging styles. Make sure all output has a prefix. Add missing newlines. Remove now unnecessary PFX, NAME, and miscellaneous other #defines. Coalesce formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2012-03-25ARM: pxa: use common IOMEM definitionRob Herring
pxa was missed in the moving of IOMEM to a common definition, so lots of IOMEM redefined warnings were introduced. So remove pxa IOMEM definition and fix all the fallout. Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: rtc-linux@googlegroups.com Cc: alsa-devel@alsa-project.org
2009-07-09[WATCHDOG] SA1100 watchdog maximum timeoutRaphael Assenat
This patch replaces the hardcoded 255 seconds limit for a real limit based on oscr_freq. Also, the 'firmware_version' field is changed to '1' to allow the user space application to easily detect that this driver supports a higher maximum timeout. Signed-off-by: Raphael Assenat <raph@8D.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-28Merge branch 'origin' into develRussell King
Conflicts: sound/soc/pxa/pxa2xx-i2s.c
2009-03-25[WATCHDOG] More coding-style and trivial clean-upWim Van Sebroeck
Some more cleaning-up of the watchdog drivers. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2009-03-09[ARM] pxa: separate definitions from pxa-regs.h and remove it finallyEric Miao
The remaining registers are separated into: - <mach/regs-ost.h> - <mach/regs-rtc.h> - <mach/regs-intc.h> and then we can remove pxa-regs.h completely. Instead of #include this file, let's: 1. include the specific <mach/regs-*.h> with care (if that's absolutely necessary) 2. define the registers in the driver, make cleanly defined API to expose the register access to external with sufficient reason Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-12-29Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
2008-12-29[ARM] sa1100_wdt: don't assume CLOCK_TICK_RATE to be a constantEric Miao
See description of commit: [ARM] rtc-sa1100: don't assume CLOCK_TICK_RATE to be a constant for additional information. Signed-off-by: Eric Miao <eric.miao@marvell.com>
2008-11-29[ARM] Remove linux/sched.h from asm/cacheflush.h and asm/uaccess.hRussell King
... and fix those drivers that were incorrectly relying upon that include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-28[PATCH] Switch all my contributions stuff to a single common addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-08Merge Linus' latest into masterRussell King
Conflicts: drivers/watchdog/at91rm9200_wdt.c drivers/watchdog/davinci_wdt.c drivers/watchdog/ep93xx_wdt.c drivers/watchdog/ixp2000_wdt.c drivers/watchdog/ixp4xx_wdt.c drivers/watchdog/ks8695_wdt.c drivers/watchdog/omap_wdt.c drivers/watchdog/pnx4008_wdt.c drivers/watchdog/sa1100_wdt.c drivers/watchdog/wdt285.c
2008-08-07Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 Conflicts: arch/arm/mach-pxa/generic.c arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c arch/arm/mach-pxa/pxa2xx.c arch/arm/mach-pxa/pxa3xx.c arch/arm/mach-pxa/reset.c arch/arm/mach-pxa/spitz.c arch/arm/mach-pxa/tosa.c drivers/watchdog/sa1100_wdt.c
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-06[WATCHDOG] Coding style - Indentation - part 2Wim Van Sebroeck
This brings the watchdog drivers into line with coding style. This patch takes cares of the indentation as described in chapter 1. Main changes: * Re-structure the ioctl switch call for all drivers as follows: switch (cmd) { case WDIOC_GETSUPPORT: case WDIOC_GETSTATUS: case WDIOC_GETBOOTSTATUS: case WDIOC_GETTEMP: case WDIOC_SETOPTIONS: case WDIOC_KEEPALIVE: case WDIOC_SETTIMEOUT: case WDIOC_GETTIMEOUT: case WDIOC_GETTIMELEFT: default: } This to make the migration from the drivers to the uniform watchdog device driver easier in the future. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-08-05[ARM] sa1100_wdt: use reset_status to remember watchdog reset statusEric Miao
2008-06-21[WATCHDOG 36/57] sa1100_wdt: Switch to unlocked_ioctlAlan Cox
Review and switch to unlocked_ioctl Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18mv watchdog tree under driversWim Van Sebroeck
move watchdog tree from drivers/char/watchdog to drivers/watchdog. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
